SDP1-24-100T
SDP1-24-100T
    SOLAHD
    SDP1-24-100T
SDP1-24-100T 数据手册
Power Supplies SDP™ Low Power DIN Rail Series The compact, lightweight DIN Rail power supplies come in output voltages from 5 to 48 Vdc and power ratings of up to 100 Watts. These extra small, efficient units are designed specifically for the industrial environment. Each unit is rated from -10ºC to 70ºC, with no derating necessary until above 60ºC. Many extra “industrial” features are standard for the SDP PowerBoostTM overload circuitry can start up industrial loads (i.e. motors, relays, solenoids and DC-DC converters), that can cause ordinary power supplies to foldback or shutdown. Each unit contains a DC indicator and front panel adjustment potentiometer. With the SolaHD SDP series, you can count on a high grade design. E61379 Certifications and Compliances • Applications • Industrial Control • • Building Automation UL 60950 E137632 CUL/CSA-C22.2 No. 234-M90 UL 60950 E137632 CUL/CSA-C22.2 - ISA 12.12.01, CSA C22.2 No. 213 No. 234-M90 - Class I, Division 2, Groups A, B, C, D • • Instrumentation Features - IEC/EN60950-1, 2nd Edition • RoHS Compliant • Adjustable output • PowerBoost Listed, Industrial Control Equipment, E61379 - UL 508, CSA C22.2 No. 107.1 Recognized Component, ITE, E137632 - UL 60950-1/CSA C22.2 No. 60950-1, 2nd Edition • Recognized Component, Haz. Loc., E234790 • Machine Control TM E137632 E234790 industrial overload design • NEC Class 2 power supply except Model SDP 4-24100RT • Overvoltage, short circuit protection • Continuous short circuit protection • Low output noise Related Products • Screw terminal connections • SDN™ Series • Three year limited warranty • SCP Series Selection Table Catalog Number DC Output Voltage Output Current SDP 5-5-100T 5-6V 5A SDP 2-12-100T 10 - 12 V 3 - 2.5 A SDP 3-15-100T 12 - 15 V 4.2 - 3.4 A SDP 1-48-100T 48 - 56 V 1A SDP 06-24-100T 0.6 A SDP 1-24-100T 1.3 A SDP 2-24-100T 24-28 Vdc 2.1 A SDP 4-24-100LT 3.8 A SDP 4-24-100RT * 4.2 A Ripple / Noise Size (H x W x D) - in. (mm) 2.95 in x 1.77 in x 3.58 in (75.0 mm x 45.0 mm x 91.0 mm) 25 ms Hold-Up Time Efficiency 1.8 A / 1.0 A Not required. Unit provides internal fuse (T3A, not accessible) External Fusing > 80% typ. > 83% typ. < 3.75 W typ. < 6.1 W typ. > 86% typ. > 88% typ. < 8.1 W typ. < 12 W typ. Output 24 V (22.5 - 28.5 Vdc Adj.) Output Voltage 24 V (24 - 25.7 Vdc Adj.) < 50 mVpp Ripple/Noise 2 > 26 Vdc, but < 27.2 Vdc, auto recovery > 30 Vdc, but < 33 Vdc, auto recovery Overvoltage Protection (OVP) Output Noise Suppression Rated Continuous Loading 24 V (22.5 - 28.5 Vdc Adj.) Static 0.5% Vout, dynamic + 2% Vout overall\ Voltage Regulation > 30 Vdc, but < 33 Vdc, auto recovery Radiated EMI values below EN61000-6-2 0.63 A @ 24 Vdc / 0.54 A @ 28 Vdc 1.3 A @ 24 Vdc / 1.1 A @ 28 Vdc 2.1 A @ 24 Vdc / 1.8 A @ 28 Vdc 3.8 A @ 24.5 Vdc 4.2 A @ 24.5 Vdc / 3.6 A @ 28 Vdc Continuous operation at overload/short-circuit: up to 1.5 x Nominal Current Continuous Overload Behavior Unit is continuously protected against short-circuit, overload and open-circuit. Protection 35 V Power Back Immunity Installation Status Indicators Green LED on, when Vout “OK”. Case & Mounting Molded plastic housing using UL 94 approved flameproof material rating 94V-2. Simple snap-on to DIN TS35/7.5 or TS35/15 rail system. Dimensions H x W x D - inches (mm) Weight - lbs (kg) Mounting Orientation 2.95 x 0.90 x 3.80 (75.0 x 22.8 x 96.7) 2.95 x 1.77 x 3.58 (75.0 x 45.0 x 91.0) 2.95 x 2.85 x 3.80 (75.0 x 72.5 x 96.7) 0.4 lbs (0.18 kg) 0.5 lbs (0.23 kg)  0.7 lbs (0.32 kg) Standard: Vertical; Optional: Horizontal or on top (Contact Technical Services). Ventilation/Cooling •Free space for cooling Normal convection, no fan required; Above/below: 25 mm recommended. Connection •Connector size range Input: screw terminals, connector size range: 20-12AWG (1.5 - 6 mm2) for solid or stranded conductors. General Electromagnetic Emissions (EMC) EN61000-6-3 (Includes EN61000-6-4) Class B (EN 55022) incl. Annex A Electromagnetic Immunity (EMI) EN61000-6-2 (Includes EN61000-6-1) (EN55024) Criterion A: no derogation of performance Temperature MTBF Humidity   Safe Low Voltage Protection Class/Voltage Warranty Storage: -25°C to +85°C Operation: -10° to +60°C full power with linear derating to half power from 60°C to 70°C. (Convection cooling, no forced air required). > 500,000 hours according to Telcordia/Bellcore Document SR-332, Issue 1 Up to 90% RH, noncondensing; IEC 68-2-2, 68-2-3 SELV (acc. EN60950) IP20 (IEC529), Protection Class 1 (IEC536) 3 year limited warranty Notes: 1. Not UL listed for DC input. 2. Ripple/noise is stated as typical values when measured with a 20 MHz, bandwidth scope and 50 ohm resistor. Visit our website at www.emerson.com or contact Technical Services at (800) 377-4384 with any questions. © January 2017 145 Power Supplies SDP™ Series Specifications (Other Voltages) Description Catalog Number SDP 5-5-100T SDP 2-12-100T SDP 3-15-100T SDP 1-48-100T Input 85-264 Vac, 90-375 Vdc Input Voltage 1 47 - 63 Hz Input Frequency 0.6 A @ 102 Vac; 0.33 A @196 Vac Input Current 1.0 A @ 102 Vac; 0.6 A @ 196 Vac Not required. Unit provides internal fuse (T3A, not accessible) External Fusing > 25 ms Hold-Up Time > 80% typ. Efficiency Losses 90% typ. < 8.1 W typ. Output Output Voltage 5 - 5.5 Vdc (5 - 6 min adj.) 12 Vdc (9.9 - 12.1 min adj. ) > 6.7 Vdc > 18 Vdc lout = 5A @ Vout = 5.1V 3A @ 10 Vdc 2.5A @12 Vdc > 56 Vdc 4.2A @ 12 Vdc 3.4A @ 15 Vdc Up to 1.05A @ 48 V 0.9A @ 56 V Continuous operation at overload/short-circuit: up to 1.5 x Nominal Current Continuous Overload Behavior Unit is continuously protected against short-circuit, overload and open-circuit. Protection Power Back Immunity > 20 Vdc Radiated EMI values below EN61000-6-2 Output Noise Suppression Rated Continuous Loading 48 Vdc (48 - 56 min adj.) < 50 mVpp Ripple/Noise 2 Overvoltage Protection (OVP) 15 Vdc (11.9 - 15.1 min adj.) < 2% Dynamic; < 0.5% Static Voltage Regulation 10 V 22 V 80 V Installation Status Indicators Green LED on, when Vout “OK”. Case & Mounting Molded plastic housing using UL 94 approved flameproof material rating 94V-2. Simple snap-on to DIN TS35/7.5 or TS35/15 rail system. Dimensions (H x W x D) (in/mm) 2.95 x 1.77 x 3.58 (75.0 x 45.0 x 91.0) 0.5 lbs (0.23 kg) Weight - lbs (kg) Mounting Orientation Standard: Vertical; Optional: Horizontal or On Top (Contact Technical Services). Ventilation/Cooling •Free space for cooling Normal convection, no fan required; Above/below: 25 mm recommended. Connection •Connector size range Input: screw terminals, connector size range: 20-12 AWG (1.5 - 6 mm2) for solid or stranded conductors. General Temperature MTBF Humidity   Storage: -25°C to +85°C Operation: -10°C to +60°C full power with linear derating to half power from +60°C to +70°C. (Convection cooling, no forced air required). > 500,000 hours according to Telcordia/Bellcore Document SR-332, Issue 1. Up to 90% RH, noncondensing; IEC 68-2-2, 68-2-3 Electromagnetic Emissions (EMC) EN61000-6-3 (Includes EN61000-6-4) Class B (EN 55022) incl. Annex A Electromagnetic Immunity (EMI) EN61000-6-2 (Includes EN61000-6-1) (EN55024) Criterion A: no degradation of performance Safe Low Voltage Protection Class/Voltage Warranty SELV (acc. EN60950) IP20 (IEC529), Protection Class 1 (IEC536) 3 year limited warranty Notes: 1. Not UL listed for DC input. 2. Ripple/noise is stated as typical values when measured with a 20 MHz, bandwidth scope and 50 Ohm resistor. 146 Visit our website at www.emerson.com or contact Technical Services at (800) 377-4384 with any questions. © January 2017
SDP1-24-100T 价格&库存
很抱歉,暂时无法提供与“SDP1-24-100T”相匹配的价格&库存,您可以联系我们找货
