169-002
169-002
    SANYODENKI
    FANSPEEDTHERMISTOR
169-002 数据手册
Thermal Speed Controlled Fan 60 San Ace 60 15mm thick, 20mm thick, 25mm thick mm sq. with an thermistor external thermistor/ External model / with a built-in thermistor Built-in thermistor model ■General Specifications ・Material ………………… Frame: Plastics (Flammability: UL94V-0), Impeller:Plastics (Flammability: UL94V-1) ・Life Expectancy ……… Varies for each model(L10:Survival rate:90% at 60℃ , rated voltage, and continuously run in a free air state) ・Lead Wire ……………… !red @black Control brown (Only for external thermistor type) ・Fail-safe ………………… The motor becomes high speed when the thermistor is unable Note: Optional external thermistors are sold separately. to detect the temperature in case of open or short circuit etc. (Models equipped with a pulse sensor are excluded.) ・Storage Temperature… -30℃ to +70℃(Non-condensing) 60×60×15mm 〔Mass:60g〕 External ■ Specifications with anthermistor external model thermistor Rated Voltage Operating Voltage Range Rated Current Rated Input Model No. [V] 12 109P0612T7H12 Rated Speed Air Flow Static Pressure [V] [A] [W] [min-1] [m³/min] [CFM] 10.2 to 13.8 0.12 0.08 1.44 0.96 4,100 2,050 0.4 0.2 14.1 7.1 SPL Operating Temperature Life Expectancy [Pa] [inchH²O] [dB(A)] 38.2 9.3 0.153 0.037 32 18 [℃] [h] -10 to +70 60,000 Note: The top row gives characteristics shown when the thermistor temperature is 35℃ ,while the bottom row gives characteristics shown when the thermistor temperature is 28℃ .(Thermistor: 169-002). Built-in model with a thermistor built-in thermistor Rated Voltage Operating Voltage Range Rated Current Rated Input Model No. [V] 12 109P0612T7H122 Rated Speed Air Flow Static Pressure [V] [A] [W] [min-1] [m³/min] [CFM] 10.2 to 13.8 0.12 0.08 1.44 0.96 4,300 2,100 0.42 0.2 14.8 7.0 SPL Operating Temperature Life Expectancy [Pa] [inchH²O] [dB(A)] 42.0 9.7 0.169 0.039 32 18 [℃] [h] -10 to +70 60,000 Note: The top row gives characteristics shown when the emperature is 40℃ , while the bottom row gives characteristics shown when the temperature is 30℃ . ■ Dimensions(Unit : mm) ■ Reference dimensions dimension ofof mounting holes and vent opening(Unit : mm) External thermistor model with an external thermistor 50±0.3 4-φ4.3±0.3 Mounting Hole 取付用穴 (4) (4) +50 300 0 Air 風吹出方向 Flow Direction Built-in thermistor model +1 15 0 +1 60 0 (4) 50±0.3 (4) 50±0.3 +1 60 0 Lead Wire リード線 AWG24 UL1007 +50 300 0 (10) 4-φ4.3±0.3 Mounting Hole 取付用穴 215 Rotating Direction 回転方向 4-φ4.5 50±0.3 63 φ (10) with a built-in thermistor 58 50±0.3 50±0.3 +1 60 0 Lead Wire リード線 AWG24 UL1007 Rotating Direction 回転方向 Inlet side, Outlet side +1 15 0 Air Flow Direction 風吹出方向 58 +1 60 0 ■ Options(Unit : mm) Finger guards Color Surface treatment :Nickel-chrome plating(silver) :Cation electropainting(black) Model:109-139E Resin finger guards Model:109-1003G Inlet side, Outlet side 4 +1  0 4.3±0.3 4-2±0.5 4-φ4.3±0.3 Model:109-1003F13(13PPI) ,109-1003F20(20PPI) :109-1003F30(30PPI) ,109-1003F40(40PPI) ③ 9.5±0.5 64±1 20±5 4-φ4.3±0.3 50±0.3 5±1 500±10 Item 2-1 2-2 2-3 2-4 2-5 2-6 2-7 64±1 Number Name Standards,materials, etc. Chip ① Thermistor Epoxy resin ② Insulated cord UL2555 CSA TR-64 AWG#28(blue) ③ Lead 50±0.3 7 +30 Thermal Speed Controlled Fan 60mm Resin filter kits Model:169-002 ② 50±0.3 60.5±1 62 +1.5 ー0.5 75 φ70.7 Thermistor 3.5Max 6.5±0.5 50±0.3 φ1.6 φ1.6 φ53 ① 60.5±1 Spec Resistance R25 6.8KΩ±3% B constant B25/50 3950K±2% Maximum rated power 188mW(25℃ under still air) Insulation resistance 100MΩor more(DC500V megger) Dielectric strength No problem(AC1500V 1 minute) Operating temperature range -30℃ to +80℃ Storage temperature range -40℃ to +100℃ 4-φ10±0.5 4-2±0.5 Manufactured Manufactured by by OHIZUMI OHIZUMI MFG MGF CO.,LTD. CO.,LTD. Mfr. Part No. 159-682-86 □□□ ■ Air Flow and Static Pressure Characteristics External thermistor model with an external thermistor Built-in model with athermistor built-in thermistor 0.20 0.18 0.16 0.14 0.12 0.10 0.08 0.06 0.04 0.02 0 (inch H2O)(Pa) 50 40 12V temperature35℃ 35℃ 12VThermistor サーミスタ温度 → Static Pressure → 静圧 → Static → 静圧 Pressure (inch H2O)(Pa) 30 12V temperature28℃ 28℃ 12VThermistor サーミスタ温度 20 10 0 0.1 0.2 0.3 0.4 0.5 (m3/min) 0.20 0.18 0.16 0.14 0.12 0.10 0.08 0.06 0.04 0.02 0 50 40 12V Temperature of air flow passing through the fan40℃ 40℃ 12V 空気の温度 30 12V Temperature of air flow passing空気の温度 through the fan30℃ 30℃ 12V 20 10 0 0 2 4 6 8 10 12 14 16 18 (CFM) 0.1 0.2 0.3 0.4 0.5 (m3/min) 0 2 4 6 8 10 12 14 16 18 (CFM) →→ Air風量 Flow →→ Air風量 Flow 109P0612T7H12 109P0612T7H122 ■ Temperature-Rotation Speed Characteristics Chracteritics External thermistor model with an external thermistor Built-in model with athermistor built-in thermistor ■ Characteristics of Thermistor-detected ■ Typical characteristics of temperature of .1 0.2 0.3 0.4 → 風量 (m3/min) 0.5 50 空気の温度40℃ 40 3000 2000 TL 2050min-1 空気の温度30℃ 30 20 10 1000 25 30 35 40 → Thermistor (℃) → サーミスタ温度 (℃) Temperature 109P0612T7H12 0 0.1 0.2 0.3 0.4 → 風量(m3/min) 0.5 Voltage 12V DC 電圧:: DC12V TH 4300min-1 4000 3000 TL 2100min-1 60mm サーミスタ温度 28℃ :12V DC 4100min-1 Voltage 電圧:DC12V TH air flowing through the fan versus rotation speed -1 →→Rotation Speed(-1min 回転速度(min ) ) サーミスタ温度 35℃ 4000 → 静圧(Pa) -1 -1 min ) →→ Rotation Speed 回転速度 (min( ) Temperature vs Speed 2000 30 40 50 20 → Thermistor Temperature(℃) → ファンを通過する   空気の温度(℃) 109P0612T7H122 216
169-002 价格&库存
很抱歉,暂时无法提供与“169-002”相匹配的价格&库存,您可以联系我们找货
