Comair Rotron Specification Sheet
Specification Date: Feb 27, 2018
Version:01
COMAIR ROTRON PART NUMBER:
COMAIR ROTRON MODEL NUMBER:
17000653A
CREC2258-2800E1B
A.) MOTOR:
RATED VOLTAGE:
115VAC±10%
OPERATING VOLTAGE RANGE:
103~126VAC
LOW-START VOLTAGE:
87VAC
RATED CURRENT:
0.58 Amps
OPERATING FREGUENCY:
50~60Hz
INPUT POWER:
45 Watts
RATTED SPEED:
2800 RPM 5%
(At Free Delivery)
MOTOR TYPE:
Brushless EC
MOTOR PROTECTION:
By Integrated Circuit
LOCKED ROTORT PROTECTION:
IC protected
POLARITY PROTECTION:
Yes
AUTOMATIC RESTART CAPABILITY:
ROTATION:
Counter Clockwise when viewed from the
impeller
B.) MECHANICAL
DIMENSIONS:
225mm x225mm x 80mm
WEIGHT:
1800g
BEARING TYPE:
Ball Bearings
VENTURI:
Die Cast magnesium alloy,
ED coating and powder coating
PROPELLER:
-1-
Version:01
Figure 1
C.) ENVIRONMENTAL
OPERATING TEMPERATURE:
-20C to +70C
STORAGE TEMPERATURE:
The storage temperature will be suggested at
-20℃ ~ 50℃ to ensure a better performance.
HUMIDITY:
20 to 85% RH, non-condensing
-2-
Version:01
D.) PERFORMANCE CHARACTERISTICS
AIR FLOW:
832 CFM 5%
(Measuring at zero static pressure)
STATIC PRESSURE:
1.00” Inches of H20
(Measuring at zero airflow)
ACOUSTIC LEVEL:
65 dBA Max. at MAX. speed
(Measured via Freely Suspended at 1 meter )
-3-
Version:01
E.) TERMINATION
Terminal connection:
Suit with terminal block
Blue
Brown
Yellow/Green
F.) RELIABILITY
Bearing type
Ball bearing
Temperature
20℃
Hours
60,000
40℃
50,000
60℃
40,000
90℃
20,000
G.) SAFETY
UL, CUL, CE
H.) FLAMMABILITY
The fan including all components meets a UL94V-0 rating or better.
-4-
= Neutral wire
= Live wire
= Ground wire
很抱歉,暂时无法提供与“17000653A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 120+1517.74917120+189.65749
