17000654A
17000654A
    COMAIRROTRON
    17000654A
17000654A 数据手册
Comair Rotron Specification Sheet Specification Date: Feb 27, 2018 Version:01 COMAIR ROTRON PART NUMBER: COMAIR ROTRON MODEL NUMBER: 17000654A CREC2258-2800E2B A.) MOTOR: RATED VOLTAGE: 230VAC±10% OPERATING VOLTAGE RANGE: 207~253VAC LOW-START VOLTAGE: 172VAC RATED CURRENT: 0.30 Amps OPERATING FREGUENCY: 50~60Hz INPUT POWER: 46 Watts RATTED SPEED: 2800 RPM 5% (At Free Delivery) MOTOR TYPE: Brushless EC MOTOR PROTECTION: By Integrated Circuit LOCKED ROTORT PROTECTION: IC protected POLARITY PROTECTION: Yes AUTOMATIC RESTART CAPABILITY: By Integrated Circuit ROTATION: Counter Clockwise when viewed from the impeller B.) MECHANICAL DIMENSIONS: 225mm x225mm x 80mm WEIGHT: 1800g BEARING TYPE: Ball Bearings VENTURI: Die Cast magnesium alloy, ED coating and powder coating PROPELLER: Die Cast magnesium alloy, ED coating and powder coating -1- Comair Rotron Specification Sheet Specification Date: Feb 27, 2018 Version:01 Figure 1 C.) ENVIRONMENTAL OPERATING TEMPERATURE: -20C to +70C STORAGE TEMPERATURE: The storage temperature will be suggested at -20℃ ~ 50℃ to ensure a better performance. HUMIDITY: 20 to 85% RH, non-condensing -2- Comair Rotron Specification Sheet Specification Date: Feb 27, 2018 Version:01 D.) PERFORMANCE CHARACTERISTICS AIR FLOW: 532 CFM  5% (Measuring at zero static pressure) STATIC PRESSURE: 1.00” Inches of H20 (Measuring at zero airflow) ACOUSTIC LEVEL: 65 dBA Max. at MAX. speed (Measured via Freely Suspended at 1 meter ) -3- Comair Rotron Specification Sheet Specification Date: Feb 27, 2018 Version:01 E.) TERMINATION Terminal connection: Suit with terminal block Blue Brown Yellow/Green F.) RELIABILITY Bearing type Ball bearing Temperature 20℃ Hours 60,000 40℃ 50,000 60℃ 40,000 90℃ 20,000 G.) SAFETY UL, CUL, CE H.) FLAMMABILITY The fan including all components meets a UL94V-0 rating or better. -4- = Neutral wire = Live wire = Ground wire
17000654A 价格&库存
很抱歉,暂时无法提供与“17000654A”相匹配的价格&库存,您可以联系我们找货
