17000660A
17000660A
    COMAIRROTRON
    17000660A
17000660A 数据手册
Comair Rotron Specification Sheet Specification Date: Feb 27, 2018 RoHS Compliant Version: 01 COMAIR ROTRON PART NUMBER: COMAIR ROTRON MODEL NUMBER: 17000660A CREC2258-4000E2B A.) MOTOR: RATED VOLTAGE: 230 VAC START VOLTAGE: 173 VAC OPERATING VOLTAGE RANGE: 207~253 VAC OPERATING FREGUENCY: 50/60 Hz MAX. RUNNING CURRENT: 0.72 Amps INPUT POWER: 110 Watts NOMINAL SPEED: 4000 RPM 10% (At Free Delivery) MOTOR TYPE: Brushless EC MOTOR PROTECTION: By Integrated Circuit LOCKED ROTORT PROTECTION: IC protected POLARITY PROTECTION: Yes AUTOMATIC RESTART CAPABILITY: By Integrated Circuit ROTATION: Counterclockwise when viewed from the impeller B.) MECHANICAL DIMENSIONS: 225x225x80 mm Figure 1 WEIGHT: 1.83 Kg BEARING TYPE: Permanently Lubricated Ball Bearings VENTURI: High quality magnesium alloy die-casting frame with ED coating& powder coating. PROPELLER: High quality magnesium alloy die-casting frame with ED coating& powder coating. -1- Comair Rotron Specification Sheet Specification Date: Feb 27, 2018 RoHS Compliant Version: 01 Figure 1 C.) ENVIRONMENTAL OPERATING TEMPERATURE: -20C to +70C STORAGE TEMPERATURE: The storage temperature will be suggested at -20℃ ~ 50℃ to ensure a better performance. HUMIDITY: 20 to 85% RH, non-condensing D.) PERFORMANCE CHARACTERISTICS 838 CFM  5%, Curve D (At Free Delivery and MAX. speed) AIR FLOW: -2- Comair Rotron Specification Sheet Specification Date: Feb 27, 2018 RoHS Compliant Version: 01 STATIC PRESSURE: 1.58” Inches of H20, Curve D (At Shut-Off and MAX. speed) ACOUSTIC LEVEL: 74 dBA Max. at MAX. speed (Measured via Freely Suspended at 1 meter ) -3- Comair Rotron Specification Sheet Specification Date: Feb 27, 2018 RoHS Compliant Version: 01 E.) TERMINATION Suit with terminal block, PV1.25-3A-0.5 terminal F.) RELIABILITY Bearing type Ball bearing Temperature 20℃ Hours 60,000 40℃ 50,000 60℃ 40,000 90℃ 20,000 G.) SAFETY UL, CUL, TUV, CE -4-
17000660A
物料型号:17000660A
器件简介: - 型号:CREC2258-4000E2B - 电机类型:无刷EC电机 - 额定电压:230 VAC - 启动电压:173 VAC - 工作电压范围:207~253 VAC - 工作频率:50/60 Hz - 最大运行电流:0.72安培 - 输入功率:110瓦特 - 额定转速:4000 RPM ±10%(自由送风) - 电机保护:集成电路保护 - 锁定转子保护:IC保护 - 极性保护:是 - 自动重启能力:通过集成电路 - 旋转方向:从叶轮端看为逆时针
引脚分配:文档中未提供引脚分配信息。
参数特性: - 尺寸:225x225x80 mm - 重量:1.83公斤 - 轴承类型:永久润滑球轴承 - 进气口:高质量镁合金压铸框架,ED涂层和粉末涂层 - 叶轮:高质量镁合金压铸框架,ED涂层和粉末涂层 - 工作温度:-20℃至+70℃ - 存储温度:建议-20℃至50℃以确保更好的性能 - 湿度:20至85% RH,无冷凝
功能详解: - 风量:838 CFM ± 5%(自由送风和最大速度) - 静压:1.58英寸水柱,曲线D(关闭和最大速度) - 噪音水平:最大74 dBA(通过在1米处自由悬挂测量)
应用信息:文档中未提供应用信息
封装信息: - 端子:适合端子块,PV1.25-3A-0.5端子 - 可靠性:在不同温度下的轴承寿命 - 20°C:60,000小时 - 40°C:50,000小时 - 60°C:40,000小时 - 90°C:20,000小时
17000660A 价格&库存
很抱歉,暂时无法提供与“17000660A”相匹配的价格&库存,您可以联系我们找货
17000660A
  • 120+1516.32480120+189.65749
