19039031A
19039031A
    COMAIRROTRON
    19039031A
19039031A 数据手册
SPECIFICATIONS Model Number: Part Number: GL24B7-E2 19039031A Feb. 22, 2005 Mechanical Drawing: Additional Features: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic = 24 vdc = 12 - 24 vdc = 0.630 amps = 1.350 amps = 15 watts = 3200 RPM = Ball = 150 CFM = 53.6 dBA Brushless DC Motor Locked Rotor Protection Automatic Restart Capability Reverse Polarity Protected Operating Temperature: Storage Temperature: Enviroshield Type 2 Tachometer: Output: Venturi: Die cast zinc alloy, painted black. Propeller: Plastic, Black, UL 94V-0. Ic: Isolated: Pulses per Revolution: Life Expectancy: Termination: Construction: This fan is designed for continuous duty life of 82,500 hours at 50C. Agency Certifications: UL -10C to 70C -40C to 85C 5vdc TTL 5mA Typical No 2 12” Lead wires, UL 1061, 22 AWG Red - Power (+) Black - Ground (-) Blue/White - Tachometer (Output)
19039031A 价格&库存
很抱歉,暂时无法提供与“19039031A”相匹配的价格&库存,您可以联系我们找货
