SPECIFICATIONS
Model Number: WT12Z7-E2
Part Number: 16003354A
Mar. 29, 2011
Mechanical Drawing:
Motor:
Additional Features:
Nominal Voltage
= 12 vdc
Operating Voltage Range = 6 - 14 vdc
Nominal Running Current = 0.85 Amps
Max. Locked Rotor Current = 2.80 Amps
Running Power
= 10.2 Watts
Average Speed
= 5250 RPM
Bearings
= Ball
Air Flow
= 20 CFM
Acoustic
= 51.4 dBA
Brushless DC Motor
Locked Rotor Protection
Automatic Restart Capability
Polarity Protected
Operating Temperature:
-10C to 70C
Storage Temperature:
-40C to 85C
Enviroshield Type 2
Construction:
Venturi: Plastic, Black, UL 94V-0
Propeller: Polypropylene, Black, UL 94V-0
Life Expectancy:
This fan is designed for continuous duty life of
80,000 hours at 25C.
Agency Approvals:
UL
Tachometer:
Output:
Ic:
Pulses per Revolution:
Isolated:
5v TTL Compatible
10mA Typical
2
No
Termination:
12” leadwires, 22AWG, UL 1061
Red - Power (+)
Black - Return (-)
Blue/white - Tach
很抱歉,暂时无法提供与“16003354A”相匹配的价格&库存,您可以联系我们找货
