SPECIFICATIONS
Model Number:
Part Number:
PQD48B6D3-E2
16002542A
May 02, 2013
Mechanical Drawing:
Additional Features:
Motor:
Nominal Voltage
Operating Voltage Range
Nominal Running Current
Locked Rotor Current
Running Power
Average Speed
Bearings
Air Flow
Noise
= 48 vdc
= 36 - 72 vdc
= 0.45 amps
= 1.00 amps
= 22.0 watts
= 3600 RPM
= Ball
= 240 CFM
= 52.0 dBA
Brushless DC Motor
Electronic Locked Rotor Protection
Polarity Protected
Automatic Restart Capability
Operating Temperature:
-10C to 70C
Storage Temperature:
-40C to 85C
Enviroshield Type 2
FAN PERFORMANCE SENSOR:
Output:
Construction:
Venturi: Die-Cast Aluminum, Black
Propeller: Polycarbonate, Black, UL 94V-0
Mounting Holes:
4 x M5 x 0.8 on propeller side
4 x ø4.37mm on struts side
Life Expectancy:
This fan is designed for continuous duty life of 80,000 hours
at 40C(L10).
Agency Approvals:
UL, CUL, CE
Ic:
Vcc
Icbo:
Logic Level:
Isolated:
Latching:
Delay:
Open Collector
80 mA max.
60 Vdc max.
1μA @ 80V
High on pass, low on fail
No
No
10 ± 4 seconds
Termination:
HARNESS:
58” 1”, 22 AWG, UL 1007 (From the edge of the
venturi to the tip of the connector)
SLEEVE TUBE:
PVC (UL or CSA approved)
Sleeve tube to extend 0.35 inch max beyond the edge of the
venturi)
CONNECTOR: MOLEX 39-01-2065
CONTACTS: Molex 39-00-0059
COLOR DESIGNATION:
Pin 1: Black -Power (-)
Pin 2: Blue/White- FPS
Pin 3: Red- Return (+)
Pin 4: NOT USED
Pin 5: Thermistor lead
Pin 6: Thermistor lead
Thermal Control:
Fan will operate according to the programmed thermal
profile.
很抱歉,暂时无法提供与“16002542A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 300+449.12330300+56.17504
