17000042A
17000042A
    COMAIRROTRON
    17000042A
17000042A 数据手册
SPECIFICATIONS Model Number: Part Number: PQ48R0X-E2 17000042A June 01, 2015 Mechanical Drawing: Additional Features: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Noise = 48 vdc = 24 - 56 vdc = 0.460 amps = 1.000 amps = 22.0 watts = 3475 RPM = Ball = 235 CFM = 51.2 dBA Brushless DC Motor Electronic Locked Rotor Protection Polarity Protected Automatic Restart Capability Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Programmable Enviroshield Type 2 Tachometer Specifications: Construction: Output: Venturi: Die-Cast Aluminum, Black Propeller: Plastic, Black, UL 94V-0 I c: Pulses Per Revolution: Isolated: Life Expectancy: This fan is designed for continuous duty life of 75,000 hours at 40C. Agency Approvals: UL, cUL, CE 5 volt TTL Compatible 5 vdc Typical 2 No Termination: 19.5” Harness assembly, 22 AWG, UL 1061 AMP Connector 640440-4, Terminal Pin 1 = Red, Fan Power (+) Pin 2 = Black, Fan Ground (-) Pin 3 = Blue/White, Tachometer (Output) Pin 4 = Yellow, Program
17000042A
1. 物料型号:型号为PQ48R0X-E2,部件编号为17000042A。 2. 器件简介:文档描述了一种直流风扇,具有无刷直流电机、电子锁定转子保护、极性保护和自动重启功能。 3. 引脚分配:提供了一个19.5英寸的线束组件,包括AMP连接器,其中: - Pin 1(红色):风扇电源(+) - Pin 2(黑色):风扇地线(-) - Pin 3(蓝白色):转速表(输出) - Pin 4(黄色):编程 4. 参数特性:包括: - 额定电压:48V直流,工作电压范围24-56V直流 - 额定运行电流:0.46安培 - 锁定转子电流:1.00安培 - 运行功率:22.0瓦特 - 平均速度:3475转/分钟 - 轴承类型:球轴承 - 空气流量:235立方英尺/分钟(CFM) - 噪音水平:51.2分贝(dBA) 5. 功能详解:风扇设计用于连续工作寿命为75,000小时,在40°C下。 6. 应用信息:风扇适用于UL、cUL和CE认证。 7. 封装信息:构造包括压铸铝制文氏管(黑色)和塑料螺旋桨(黑色,UL 94V-0)。
17000042A 价格&库存
很抱歉,暂时无法提供与“17000042A”相匹配的价格&库存,您可以联系我们找货
