SPECIFICATIONS
Model Number:
Part Number:
GL24Z7
19039524A
July 28, 2005
Mechanical Drawing:
Additional Features:
Motor:
Nominal Voltage
Operating Voltage Range
Nominal Running Current
Locked Rotor Current
Running Power
Average Speed
Bearings
Air Flow
Acoustic
= 24 vdc
= 12 - 28 vdc
= 1.30 amps
= 3.50 amps
= 31.2 watts
= 4100 RPM
= Ball
= 190 cfm
= 59.4 dBA
Construction:
Venturi:
Propeller:
Die Cast Zinc Alloy, Black.
Plastic, Black, UL 94V-0.
Life Expectancy:
This fan is designed for continuous duty life of 62,000
hours at 50C.
Agency Approvals:
UL,cUL,CE
Brushless DC Motor
Locked Rotor Protection
Reverse Polarity Protected
Operating Temperature:
Storage Temperature:
-10C to 70C
-40C to 85C
Tachometer:
Output:
Ic:
Isolated:
Pulses per Revolution:
5vdc TTL Compatible
5mA Typical
No
2
Termination:
12” Lead wires, 22 AWG, UL 1061
Red – Power
Black – Return
Blue/White – Tachometer Output
很抱歉,暂时无法提供与“19039524A”相匹配的价格&库存,您可以联系我们找货
