19040215A
19040215A
    COMAIRROTRON
    19040215A
19040215A 数据手册
SPECIFICATIONS Model Number: Part Number: GL12S7Z 19040215A Apr. 4, 2015 Mechanical Drawing: Motor: Additional Features: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic = 12 vdc = 6 - 14 vdc = 2.500 amps = 5.000 amps = 30.0 watts = 4150 rpm = Ball = 190 CFM = 58.9 dBA Construction: Venturi: Propeller: Die Cast Zinc Alloy, Black. Plastic, Black, UL 94V-0. Life Expectancy: This fan is designed for continuous duty life of 62,000 hours at 50C. Agency Approvals: UL,CE Brushless DC Motor Locked Rotor Protection Reverse Polarity Protected Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Thermal Speed Control (PTC in hub) Tachometer: Output: 5vdc TTL Compatible Ic: 5mA Typical Isolated: No Pulses per Revolution: 2 Termination: 12” Lead wires, 22 AWG, UL 1061 Red – Power Black – Return Blue/White – Tachometer Output
19040215A 价格&库存
很抱歉,暂时无法提供与“19040215A”相匹配的价格&库存,您可以联系我们找货
19040215A
  • 300+489.42985300+63.57446
