SPECIFICATIONS
Model Number:
Part Number:
TD48B6NDNX
TBD
Sep 6, 2013
Mechanical Drawing:
Motor:
Nominal Voltage
Operating Voltage Range
Nominal Running Current
Locked Rotor Current
Running Power
Average Speed
Bearings
Air Flow
Acoustics
Additional Features:
= 48 vdc
= 40-56 vdc
= 0.700 amps
= 1.500 amps
= 33.6 watts
= 3275 rpm
= Ball
= 330 cfm
= 65.2 dBA
Construction:
Venturi: Plastic, Black, UL 94V-0
Propeller: Polycarbonate, Black, UL 94V-0
Agency Approvals:
UL, cUL
Life Expectancy:
This fan is designed for continuous duty life of 35,000
hours at 40°C
Brushless DC Motor
Electronic Locked Rotor Protected
Reverse Polarity Protection
Automatic Restart Capability
Operating Temperature:
-10°C to +70°C
Storage Temperature:
-40°C to +85°C
Fan Performance Sensor (FPS):
Output:
Ic:
Vcc:
Logic Level:
Delay:
Latching:
Isolated:
Inverted Open Collector
80mA Max.
60VDC Max.
Low on Pass, High on Fail
10 ± 4 Seconds
No
No
Termination:
24.0” Harness, AWG 22, UL Style 1061
Connector: Molex 03-06-2032
Terminals: Molex 02-06-2103
Pin 1 (Red)
= Power (+)
Pin 2 (Black)
= Return (-)
Pin 3 (Blue/White)
= FPS Output
很抱歉,暂时无法提供与“TD48B6NDNX”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 200+743.83275200+95.40454
