SW401404-1
SW401404-1
    DBUNLIMITED
    SW401404-1
SW401404-1 数据手册
4 3 2 1 Part Number: DRAWN 3/13/2017 CJ SW401404-1 CHECKED 10/2/2017 P.D. Description: APPROVED 10/2/2017 Waterproof Dynamic Speaker C.E. D D This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View Side View 6.5 20 Bottom View 0.3 3 16 18 2.3 C 38 15.9 40 36 0.15 2-1 C XX X Date Code Marking "17 C" 17=2017, C=Mar. 4- 2.2 B A B Items Specifications Conditions Sound Pressure Level 97 dB (@ 10cm), Avg. Resonant Frequency 1,400 Hz Frequency Range 300 ~ 10,000 Hz Nominal Power 2 W Max. Power 3 W Impedance 4 Cone Material Mylar NOTES Mount Type Frame Mount 1) All dimensions are in mm unless otherwise noted IP Rating IP67 Storage Temperature -20 ~ +55 C 3) All parts meet RoHS Operating Temperature -20 ~ +55 4) Subject to change or redrawn without notice Weight 5.21 C g 4 REVISION HISTORY REV DESCRIPTION DATE APPROVED Released from Engineering 10/2/2017 C.E. 1 Updated frequency range 12/27/2017 C.E. 2 Update markings 2/28/2018 C.E. 2) All tolerances are 3 2 0.2 mm unless otherwise noted 1 A
SW401404-1 价格&库存
很抱歉,暂时无法提供与“SW401404-1”相匹配的价格&库存,您可以联系我们找货
SW401404-1
  • 1+60.407951+7.82033
  • 10+46.3045810+5.99453
  • 25+41.8511425+5.41800
  • 50+38.8299950+5.02688
  • 100+36.07511100+4.67024
  • 300+32.18544300+4.16669
  • 500+30.55529500+3.95565
  • 1000+28.769271000+3.72443
库存:88
