0.80±0.05
0.50
Pin 1
E
0.15 E
1.95
3.25
G
B±0.10
0.50
0.30±0.05
0.95
0.80±0.05
A±0.15
B±0.10
0.15±0.05
3.30±0.05
H
Pin 1
No. of
Contacts
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
0.40±0.05
F
Recommended PCB Layout
As viewed from component side
Solder Area
3.80 ref.
2.90
A
Specifications
E
0.15±0.05
0.50
C±0.10
D±0.10
0.10
0.38
1.00±0.10
1.75 ref.
A
2.90
D
0.28
+0.05
-0.02
B
Section A-A
0.30±0.02
2.50 Min.
1.50±0.30
R
Ordering Grid
FFC2B28
No. of Contacts
04 - 40
XX
G
Electrical
Voltage Rating: 30V AC/DC
Current Rating : 0.4A AC/DC (40 contacts powered)
Dielectric Strength: 250V AC for 1 minute
Insulation Resistance: 50 MΩ Min.
Contact Resistance: 40 mΩ Max.
(B+1) ± 0.05
B ± 0.05
0.50±0.05
0.50±0.02
0.30±0.03
Material
Housing: High Temperature Thermoplastic,
UL 94V-0, Natural
Actuator: High Temperature Thermoplastic,
UL 94V-0, Black
Contact: Copper Alloy
Fitting Nail: Copper Alloy
Plating
Contact: Gold Flash over all
Fitting Nail: Matte Tin Plating over Nickel
1.30±0.15
C
Component Outline
Request samples
and quotation
Mechanical & Environmental
Durability: 20 Cycles
Operating Temperature: -25°C to +85°C
Solder Profile:
Peak Temp 260°C (+0/-5°C) max. (5 seconds)
Contact Plating
G = Gold Flash over all
Part Number
Product Description
FFC2B28
FPC 0.5mm Pitch, Side Entry, Dual Contact,
SMT,Height=1.0mm, Back Flip
Drawing Date
A
12th September 2019
By
Detail
1
2
3
4
D
3.39
3.89
4.39
4.89
5.39
5.89
6.39
6.89
7.39
7.89
8.39
8.89
9.39
9.89
10.39
10.89
11.39
11.89
12.39
12.89
13.39
13.89
14.39
14.89
15.39
15.89
16.39
16.89
17.39
17.89
18.39
18.89
19.39
19.89
20.39
20.89
21.39
= Tooled Parts
*Please
contact GCT for non-tooled parts
(see dimension table)
Recommended FFC/FPC Dimensions
Dimensions
A
B
C
4.00
1.50
2.57
4.50
2.00
3.07
5.00
2.50
3.57
5.50
3.00
4.07
4.57
6.00
3.50
6.50
4.00
5.07
7.00
4.50
5.57
7.50
5.00
6.07
8.00
5.50
6.57
8.50
6.00
7.07
9.00
6.50
7.57
9.50
7.00
8.07
10.00
7.50
8.57
10.50
8.00
9.07
11.00
8.50
9.57
11.50
9.00
10.07
12.00
9.50
10.57
12.50 10.00 11.07
13.00 10.50 11.57
13.50 11.00 12.07
14.00 11.50 12.57
14.50 12.00 13.07
15.00 12.50 13.57
15.50 13.00 14.07
16.00 13.50 14.57
16.50 14.00 15.07
17.00 14.50 15.57
17.50 15.00 16.07
18.00 15.50 16.57
18.50 16.00 17.07
19.00 16.50 17.57
19.50 17.00 18.07
20.00 17.50 18.57
20.50 18.00 19.07
21.00 18.50 19.57
21.50 19.00 20.07
22.00 19.50 20.57
Revision
Date
5
CC
Tolerances (Except as Noted)
Drawing
Release
A4
11/03/22
X.X° ± 5°
X.X ± 0.30
X.XX ± 0.20 X.XX° ± 2°
X.XXX ± 0.10 X.XXX° ± 1°
Length
Angle
6
Units:
Metric (mm)
C
3rd Angle Projection
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
1/2
Direction of Unreeling
H
G
165°
Cover Tape
Reel
Ø13
~180
° Peeling angle
Upper EPS
Carrier Tape
PE Bag
Desiccant
Ø330
Air Bladder Bag
F
Rivet Mast
W+4
E
Label
Green Product Label
Carton
Empty 16pcs
Ø1
.50 +
4.00±0.10
D
Ø1
.50 +
8.00±0.10
2.00
Empty 16pcs
4000pcs
4.00±0.10
8.00±0.10
2.00
S0±0.10
1.75±0.10
W±0.3
C
1.75±0.10
W±0.3
Down EPS
Green Product Label
Label
300
16mm,24mm Carrier
32mm,44mm Carrier
B
No. of
Contacts
4 ~ 14
16 ~ 27
28 ~ 39
40
A
W
S0
16
24
32
44
28.4
40.4
2
Pcs/Reel Reel/Carton Pcs/Carton
4000
4000
4000
4000
14
10
8
6
56000
40000
32000
24000
Part Number
Product Description
FFC2B28
Drawing Date
12th September 2019
By
Detail
1
36
4
Revision
Date
5
CC
Drawing
Release
A4
11/03/22
X.X° ± 5°
X.X ± 0.30
Length
Angle
6
Units:
Metric (mm)
C
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
2/2
很抱歉,暂时无法提供与“FFC2B28-14-G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4.237971+0.54849
- 10+3.5836010+0.46380
- 25+3.3617725+0.43509
- 50+3.2010150+0.41429
- 100+3.04825100+0.39451
- 250+2.85667250+0.36972
- 500+2.72020500+0.35206
- 1000+2.590251000+0.33524
- 国内价格 香港价格
- 4000+2.348814000+0.30399
- 8000+2.236738000+0.28949
- 12000+2.1736812000+0.28133
- 20000+2.0967820000+0.27137
- 28000+2.0476328000+0.26501
- 40000+1.9968040000+0.25843
