PCB.SMAFSTJ.A.HT
PCB.SMAFSTJ.A.HT
    TAOGLASLIMITED
    插件
    SMA
PCB.SMAFSTJ.A.HT 数据手册
SPECIFICATION Part No. : PCB.SMAFSTJ.A.HT Product Name : SMA (F) Through Hole PCB Mount Jack Feature : SMA(F) Jack Through Hole PCB Jack Frequency Range: 0~12.4GHz Finish: Gold Leg Length: 2mm Total Length: 11.00mm RoHS Compliant SPE-12-8-142/B/WY Page 1 of 3 1. Introduction The PCB.SMAFSTJ.A.HT connector was designed to be mounted on a PCB, it has a Solder Post for connection. The connector pin is directly soldered onto pads on the PCB. The connector is a standard SMA (F) Jack. The SMA connector is the most popular type connector for RF applications. Taoglas connectors are all RoHS compliant. 2. Specification ELECTRICAL Impedance 50Ω Frequency Range 0~12.4 GHz Working Voltage Max. 335 Vrms Dielectric withstanding Voltage ≤1000 Vrms Insulation Resistance ≥5000M Ω MECHANICAL Connector Dimension 11 X 7 mm Connector Pin Diameter 1.27 mm Max. Thickness PCB acceptable 0.8 mm Connector Type SMA (F) ENVIRONMENTAL RoHS compliant SPE-12-8-142/B/WY Page 2 of 3 3. Connector Drawing Name Material Finish QTY 1 Body Brass Gold 1 2 Insulator Teflon White 1 3 Female Contact Phosphor Bronze Gold 1 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © 2012, Taoglas Ltd. SPE-12-8-142/B/WY Page 3 of 3
PCB.SMAFSTJ.A.HT 价格&库存
很抱歉,暂时无法提供与“PCB.SMAFSTJ.A.HT”相匹配的价格&库存,您可以联系我们找货
PCB.SMAFSTJ.A.HT
  • 20+43.1353520+5.59818
  • 50+37.7147150+4.89468
  • 100+33.80376100+4.38711
  • 250+31.82320250+4.13007
  • 500+29.71401500+3.85634
库存:960
PCB.SMAFSTJ.A.HT
  • 1000+22.061291000+2.86316
  • 2000+21.447572000+2.78351
库存:5000
PCB.SMAFSTJ.A.HT
