TK733-10.0M-0.1%-10ppm 数据手册
Type TK Low TC Precision Radial-Lead Film Resistors
Page 1 of 2
RoHS Compliant -- TK200 Series and TK700 Series Resistors
Low TC of 5 ppm/°C or 10 ppm/°C, Resistance Range from 1 Kohm to 1.5 Meg
Low TC of 10 ppm/°C or 20 ppm/°C, Resistance Range from 1.51 Meg to 10 Meg
Type TK Low TC Precision Radial-Lead Resistors with
the Tetrinox® resistance system solve the reliability problems
related to other low TC precision resistor technologies. The
robust construction of Caddock's Type TK Resistors provides
reliable operation even in harsh temperature cycling and/or
power cycling environments.
provide a combination of performance advantages:
• Low Temperature Coefficient - available in 5 ppm/°C,
10 ppm/°C, or 20 ppm/°C over the entire temperature range
from -40°C to +125°C, referenced to +25°C.
• Long-Term Absolute Stability - typically better than
±0.05% per 2,000 hours of operation.
• Extended Resistance Range -
from 1 Kohm up to 10 Megohm.
• Precision Tolerance - ±0.1% is
standard, and tolerances of ±1%
and ±0.05% are available.
• Wide Operating Temperature
(Resistors shown full size)
Range - from -40°C to +150°C.
• Small Size - with two miniature rectangular cases for
maximum packaging density and minimum mounting area.
• High Power Density - molded cases with power ratings of
0.2 Watt and 0.3 Watt at +85°C, the largest of the molded
cases is a standard CK06 package.
• Caddock's Non-Inductive Performance - provides faster
settling times and minimum distortion in all types of high
frequency circuits.
• High Density Packaging - the radial-lead mounting and
small rectangular case of the Type TK resistors permit high
packaging densities in low profile circuitry. Because the
four models of the Type TK resistors are available in an
exceptionally wide range of resistance values, lead spacing
and mounting space can be standardized in a larger
number of designs.
Recommended use:
The Type TK resistors that are shown on this data sheet
are recommended by Caddock for use in commercial and
industrial applications. These resistors have pure matte
tin (Sn) lead finish for use in commercial and industrial
applications.
Presently, military applications either prohibit the use of a
matte tin lead finish or are trending toward this prohibition.
Therefore, Caddock does not recommend and does not
support the Type TK Resistors that are shown on this data
sheet for use in military applications.
Any use of this product in a military program, against this
recommended limitation of use, must be completely supported
by the customer program design activity and component
engineering activity based on the complete evaluation and
testing by these activities, there will be no support provided
by Caddock for the military use. In this case, a military
customer drawing must clearly specify the lead material, lead
finish and the military customer’s responsibility for use.
Type TK200 series and TK700 series Low TC Precision
Radial Film Resistors utilize Caddock’s long proven Tetrinox®
resistance system - the first high resistance system to
provide a TC that is well within 10 ppm/°C and that is also
essentially linear over the entire temperature range from
-40°C to +125°C.
Standard Part Number Includes: Standard resistance value
(listed below), standard tolerance of 0.1%, and standard
temperature coefficient of 10 ppm/°C.
TK229
1.00
2.00
4.00
5.00
9.00
10.0
20.0
40.0
50.0
90.0
100
200
400
500
K
K
K
K
K
K
K
K
K
K
K
K
K
K
TK729
TK233
1.00
2.00
4.00
5.00
9.00
10.0
20.0
40.0
50.0
90.0
100
200
400
500
900
1.00
900 K
1.00 Meg
2.00 Meg
K
K
K
K
K
K
K
K
K
K
K
K
K
K
K
Meg
TK733
2.00
4.00
5.00
9.00
9.90
10.0
Meg
Meg
Meg
Meg
Meg
Meg
Non-Standard Part Number Includes:
Non-standard resistance value and/or non-standard tolerance
and/or non-standard TC. Available in a minimum order
quantity of 25 pcs.
Ordering Information:
TK733 - 10.0 Meg - 0.1% - 10 ppm
Model Number
Tolerance
Resistor Value
Temperature
Coefficient
(ppm/°C)
Page 2 of 2
Type TK Low TC Precision Radial-Lead Film Resistors - Standard Resistance Range
Resistance
+85°C Maximum Ratings
+125°C Maximum Ratings
(see Derating Curve)
Model
No.
Temperature
Coefficient
ppm/°C
Min.
Max.
TK229
5 or 10
1.00 K
500 K
0.07%
Fig 1
300
0.20
200
0.07%
0.08
80
0.15%
TK233
5 or 10
1.00 K
1.50 Meg
0.07%
Fig 2
400
0.30
300
0.07%
0.12
120
0.15%
Resistance Tolerance: ±0.1% is standard.
Tolerances of ±1% and ±0.05% are available on special order.
Temperature Coefficient: 10 ppm/°C is
standard. TC referenced to +25°C, ∆R taken at -40°C and +125°C. TC of 5 ppm/°C is
Operating Temperature: -40°C to +150°C.
Overload*: 6.25 times rated power for 5
seconds at voltage not to exceed 1.5 times
maximum working voltage, ∆R less than
0.05%.
Dieletric
Dimensions Strength
Max.
2000 hr
Wattage Working
Load Life
Voltage ∆R less than
identified with color stripe
on the top edge of the part:
Max.
2000 hr
Wattage Working
Load Life
5 ppm/°C White Stripe
10 ppm/°C No Stripe
Shelf Stability (Typical): 25 ppm/year.
Insulation Resistance: 10,000 Megohms.
Vibration*: ∆R less than 0.03%.
Shock*: ∆R less than 0.05%.
Solderable Leads: Matte Tin Plated Copper.
Thermal Shock: MIL-STD-202, Method
107, Cond. B, except low temperature is
-40°C. ∆R less than 0.05%.
Low Temperature Operation*:
-40°C, ∆R less than 0.02%.
Dielectric Withstanding Voltage*:
∆R less than 0.02%.
Moisture Resistance*: MIL-STD-202,
Method 106, ∆R less than 0.05%.
Load Stability*: %∆R is shown in the
table for 2,000 hours at rated voltage not
to exceed rated power.
*Test methods per procedures of
MIL-PRF-55182/9 with the test temperatures
shown in these specifications used during
testing.
Type TK Low TC Precision Radial-Lead Film Resistors - Extended Resistance Range
Temperature
Coefficient
ppm/°C
Min.
Max.
TK729
10 or 20
501 K
2.00 Meg
0.07%
Fig 1
300
TK733
10 or 20
1.51 Meg 10.0 Meg
Fig 2
0.07%
400
Dieletric
Dimensions Strength
Max.
2000 hr
Wattage Working
Load Life
Max.
2000 hr
Wattage Working
Load Life
Limited
by Max.
Working
Voltage
Limited
by Max.
Working
Voltage
200
0.10%
300
0.10%
at -40°C and +125°C. TC of 20 ppm/°C is
Overload*: 1.5 times maximum rated
working voltage for 5 seconds, ∆R less
than 0.20%
-40°C. ∆R less than 0.10%.
-40°C, ∆R less than 0.05%.
∆R less than 0.05%.
Method 106, ∆R less than 0.10%.
table for 2,000 hours at rated voltage.
Fig 1
Fig 2
Model TK229 and TK729
.095 ±.005
(2.41 ±.13)
.245 ±.010
(6.22 ±.26)
TK729
2.00 MEG
0.1%
.245 ±.010
(6.22 ±.26)
.250 ±.050
(6.35 ±1.27)
.150 ±.015
(3.81 ±.38)
.025 ±.002
(.64 ±.05) DIA.,
LEADWIRE OFFSET
.012 (.31)
FROM CENTERLINE
Model TK233 and TK733
.095 ±.005
(2.41 ±.13)
.290 ±.010
(7.37 ±.26)
.250 ±.050
(6.35 ±1.27)
.200 ±.015
(5.08 ±.38)
TK733
10.0 MEG
0.1%
.290 ±.010
(7.37 ±.26)
.025 ±.002
(.64 ±.05) DIA.,
LEADWIRE OFFSET
.012 (.31)
FROM CENTERLINE
80
0.20%
120
0.20%
10 ppm/°C No Stripe
20 ppm/°C Green Stripe
Shelf Stability (Typical): 50 ppm/year.
Vibration*: ∆R less than 0.05%.
testing.
Derating Curve:
RATED POWER OR RATED VOLTAGE, %
Resistance
Model
No.
100% @ +85°C
100
80
60
40% @ +125°C
40
85
125
150
AMBIENT TEMPERATURE, °C
DIMENSIONS IN INCHES AND (MILLIMETERS)
ELECTRONICS, INC.
e-mail: caddock@caddock.com • web: www.caddock.com
For Caddock Distributors listed by country see caddock.com/contact/dist.html
© 2003-2017 Caddock Electronics, Inc.
Sales and Applications Engineering
17271 North Umpqua Hwy.
Roseburg, Oregon 97470-9422
Phone: (541) 496-0700
Fax: (541) 496-0408
29_IL142.0817
TK733-10.0M-0.1%-10ppm 价格&库存
很抱歉,暂时无法提供与“TK733-10.0M-0.1%-10ppm”相匹配的价格&库存,您可以联系我们找货
