SD560C
SD560C
    SMCDIODESOLUTIONS(桑德斯)
    DO-214AB(SMC)
SD560C 数据手册
SD560C Technical Data Data Sheet N1965, Rev.A SD560C STANDARD RECTIFIER Features          SMC Circuit Diagram Glass Passivated Die Construction Ideally Suited for Automatic Assembly Low Forward Voltage Drop Low Power Loss Built-in Strain Relief Plastic Case Material has UL Flammability Classification Rating 94V-0 This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Data     Case: Molded Plastic Terminals: Solder Plated , Solderable Per MIL-STD 750 ,Method 2026 Polarity: Cathode Band or Cathode Notch Weight: 0.21 grams Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Single Phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. Characteristic Symbol SD560C Units Maximum Peak Repetitive Reverse Voltage Maximum DC Blocking Voltage VRRM VR 600 V Maximum RMS Voltage VRMS 420 Maximum Average Forward Rectified Current 0.375”(9.5mm) Lead Length @TA = 75°C I(AV) 5.0 A Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 200 A Maximum Instantaneous Forward Voltage @IF = 5.0A VF 1.2 V Maximum DC Reverse Current At Rated DC Blocking Voltage IR 9.0 170 uA Cj 50 pF Typical Thermal Resistance (Note 2) RJA 20 °C/W Operating Storage Temperature Range TSTG -65 to +175 °C TJ -65 to +175 °C Typical Junction Capacitance (Note 1) Operating Junction Temperature @TA = 25°C @TA = 100°C Note: 1. Measured at 1.0 MHz and applied reverse voltage of 4.0V D.C. 2. Thermal resistance form junction to ambient at 0.375” (9.5mm) lead length, P.C.B. mounted  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SD560C Technical Data Data Sheet N1965, Rev.A Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SD560C Technical Data Data Sheet N1965, Rev.A Mechanical Dimensions SMC SYMBOL Ordering Information Device SD560C Package SMC (Pb-Free) Millimeters Inches Min. Max. Min. Max. A 5.59 6.22 0.220 0.245 B 6.60 7.11 0.260 0.280 C 2.90 3.20 0.114 0.126 D 0.152 0.305 0.006 0.012 E 7.75 8.25 0.305 0.325 F 2.00 2.95 0.079 0.116 G - 0.203 - 0.008 H 0.76 1.52 0.030 0.060 Marking Diagram Where XXXXX is YYWWL Shipping SD560C YY WW L 3000pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. = Part Name = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Carrier Tape Specification SMC SYMBOL A B C d E F P P0 P1 T W Millimeters Min. Max. 5.90 8.20 2.40 1.40 1.40 7.60 7.90 3.90 3.90 - 6.10 8.40 2.60 1.60 1.60 7.70 8.10 4.10 4.10 0.600 15.80 16.20  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SD560C Technical Data Data Sheet N1965, Rev.A DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
SD560C 价格&库存
很抱歉,暂时无法提供与“SD560C”相匹配的价格&库存,您可以联系我们找货
