EC4SAW-24D05N
EC4SAW-24D05N
    CINCON
    SIP,21.8x9.2mm
    EC4SAW-24D05N
EC4SAW-24D05N 数据手册
V12 EC4SAW SERIES ︳ 5-6 WATT WIDE INPUT DC-DC CONVERTERS FEATURE * 5-6W Isolated Output * Compact SIP-8 Package * Efficiency to 89% * 4:1 Input Range * Regulated Outputs * Remote On/Off Control * 1500VDC Isolation * Continuous Short Circuit Protection MODEL NUMBER EC4SAW-24S33N INPUT CURRENT %EFF. CAPACITOR INPUT OUTPUT OUTPUT CURRENT VOLTAGE VOLTAGE MIN. MAX. NO LOAD FULL LOAD (3) (2) LOAD MAX. 3.3 VDC 0 mA 1500 mA 4 mA 310 mA 82 82 4700uF EC4SAW-24S05N 9-36 VDC 9-36 VDC 5 VDC 0 mA 1200 mA 4 mA 298 mA 86 86 2200uF EC4SAW-24S12N 9-36 VDC 12 VDC 0 mA 500 mA 5 mA 288 mA 88 88 1100uF EC4SAW-24S15N 9-36 VDC 15 VDC 0 mA 400 mA 5 mA 288 mA 89 88 470uF 0 mA ±600 mA 4 mA 298 mA 86 86 1400uF EC4SAW-24D12N 9-36 VDC 9-36 VDC ±5 VDC ±12 VDC 0 mA ±250 mA 6 mA 288 mA 88 88 660uF EC4SAW-24D15N 9-36 VDC ±15 VDC 0 mA ±200 mA 6 mA 288 mA 88 88 220uF EC4SAW-48S33N 18-75 VDC EC4SAW-48S05N 18-75 VDC 3.3 VDC 0 mA 1500 mA 3 mA 155 mA 82 82 4700uF 5 VDC 0 mA 1200 mA 3 mA 150 mA 85 85 2200uF EC4SAW-48S12N 18-75 VDC 12 VDC 0 mA 500 mA 3 mA 145 mA 88 89 1100uF EC4SAW-48S15N 18-75 VDC 15 VDC 0 mA 400 mA 3 mA 145 mA 89 88 470uF EC4SAW-48D05N 18-75 VDC ±5 VDC 0 mA ±600 mA 4 mA 150 mA 85 85 1400uF EC4SAW-48D12N 18-75 VDC ±12 VDC 0 mA ±250 mA 3 mA 145 mA 88 89 660uF EC4SAW-48D15N 18-75 VDC ±15 VDC 0 mA ±200 mA 3 mA 145 mA 88 89 220uF EC4SAW-24D05N NOTE: 1. Nominal Input Voltage 24 or 48 VDC 2. Measured at Nominal Input Voltage 3. Measured at 12VDC for 24Vin, 24VDC for 48Vin 1 V12 SPECIFICATIONS All Specifications Typical At Nominal Line, Full Load, and 25℃ Unless Otherwise Noted INPUT SPECIFICATIONS: GENERAL SPECIFICATIONS: Input Voltage Range ........……………..................... 24V ..................... 9-36V 48V.................. 18-75V Input Surge Voltage (100 ms max.) …………...…….. 24V ……… 50VDC max. 48V……. 100VDC max. Input Filter ………………………………………………..……..……... Capacitive Remote On/Off control: Efficiency .................................................................…..……... See Table Isolation Voltage ..........…........………………....……..…. 1500VDC min. 9 Isolation Resistance .................................…...............……. 10 ohm min. Isolation Capacitance …………………………………………... 50pF max. Switching Frequency ...........................…..................…….... 580KHz typ. Module On …………………………… Open or high impedance De-rating, Above 61℃ …… 3.3V/5V … Linearly to Zero power at 105℃ Module Off ………..………….……………………. 2mA to 4mA Module Off (input idle current) ……..…………...… 2.5mA max. De-rating, Above 65℃ …… 12V/15V … Linearly to Zero power at 105℃ Case Temperature (note3) ………………………….…………. 105℃ max. Operating Ambient Temperature ……………..…... -40℃ to +85℃ OUTPUT SPECIFICATIONS: Cooling ……………………….…………….…………. Natural Convection Voltage Accuracy ............................................………................. ±1.5% max. Voltage Balance(Dual) …………………………………………….... ±1.0% max Transient Response: 25% Step Load Change Error Band …… ±5% Vout nominal, Recovery Time …….….. < 250µs Ripple & Noise, 20MHz BW .……………………………..... 100mV pk-pk max. Temperature Coefficient ....................……….....….......…................ ±0.03%/°C Storage Temperature ………………....….........…........ -55℃ to +125℃ Humidity …………………………………. 95% RH max. Non condensing MTBF …. MIL-HDBK-217F, GB, 25℃, Full Load ………… 1850Khrs typ. Dimensions …..…...........… 0.86x0.36x0.44 inches(21.8x9.2x11.1 mm) Case Material ……………………………… Non-Conductive Black Plastic Weight …………………………………………….……………………... 4.8g Short Circuit Protection .........................................................….…. Continuous NOTE: Line Regulation (note1 ) .…….………………..….......................…. ±0.2% max. 1. Measured from high line to low line. Load Regulation (note2 ) ……..………… Single ..........…............ ±0.5% max. Dual ………………….. ±1.0% max. Cross regulation(Dual note3) … Asymmetrical load 25%/100% .... ±5.0% max. 2. Measured from full load to no load. 3. For asymmetric loading, both channels must be at 25% load or more. 4. Maximum case temperature under any operating condition should Current Limit ………………………………………………………….... 180% typ. Start up time ……………………………………………………………. 15ms typ. not be exceeded 105℃. CASE SA DIMENSIONS: 120% All Dimensions In Inches(mm) Tolerances : Inches millimeters X.XX±0.02 X.X±0.5 Pin ±0.002 ±0.05 100% LOAD(%) 0.44[11.1] 0.36[9.2] 0.14[3.5] 0.01 [0.3] 5 6 7 8 60% 3.3&5Vout 12&15Vout 40% 105 -20 0 20 40 60 Ambient Temperature(oC) PIN CONNECTION Single Dual Pin -V Input -V Input 1 2 +V Input +V Input 3 On/Off On/Off 5 NC NC 6 +V Output +V Output Common 7 -V Output 8 NC -V Output 0.70 [17.8] 1 2 3 65 80% 0% -40 0.10 [2.5] Bottom View 61 -40 20% 0.86 [21.8] 0.02 [0.5] 0.16 [4.1] Typical Derating curve for Natural Convection 0.08 [2.0] 0.02 [0.5] 2 80 100
EC4SAW-24D05N
物料型号:EC4SAW系列,包括EC4SAW-24S33N、EC4SAW-24S05N、EC4SAW-24S12N、EC4SAW-24S15N、EC4SAW-24D05N、EC4SAW-24D12N、EC4SAW-24D15N、EC4SAW-48S33N、EC4SAW-48S05N、EC4SAW-48S12N、EC4SAW-48S15N、EC4SAW-48D05N、EC4SAW-48D12N和EC4SAW-48D15N。
器件简介:5-6瓦宽输入直流-直流转换器,具有隔离输出、紧凑的SIP-8封装、效率高达89%、4:1输入范围、调节输出、远程开关控制和1500VDC隔离。
引脚分配:文档中提供了引脚连接图,包括单输出和双输出配置。
参数特性:包括输入电压范围、效率、隔离电压、输入浪涌电压、输入滤波器、电容开关频率、远程开关控制、工作环境温度、存储温度、湿度、MTBF、尺寸、重量等。
功能详解:文档详细描述了转换器的效率、电压精度、瞬态响应、纹波和噪声、温度系数、短路保护、线路调节、负载调节和交叉调节。
应用信息:虽然文档没有直接提供应用信息,但根据其特性,这些转换器可能用于需要宽输入电压范围和高效率的场合。
EC4SAW-24D05N 价格&库存
很抱歉,暂时无法提供与“EC4SAW-24D05N”相匹配的价格&库存,您可以联系我们找货
