MAX22344CAAP+
MAX22344CAAP+
    MAX(迈旭)
    SSOP-20_7.2X5.29MM
    MAX22344CAAP+
MAX22344CAAP+ 数据手册
Click here for production status of specific part numbers. MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators General Description The MAX22344–MAX22346 are reinforced, fast, lowpower 4-channel digital galvanic isolators using Maxim’s proprietary process technology. These devices transfer digital signals between circuits with different power domains, using as little as 0.74mW per channel at 1Mbps (1.8V supply). All of the devices in the family feature reinforced isolation for a withstand voltage rating of 3.75kVRMS for 60 seconds. The MAX22344–MAX22346 family offers all possible unidirectional channel configurations to accommodate any 4-channel design, including SPI, RS-485, and digital I/O applications. Output enable for the A side of the MAX22345R/S is active-low, making them ideal for isolating a port on a shared SPI bus since the CS signal can directly enable the MISO signal on the isolator. All other output enables in the MAX22344–MAX22346 family are the traditional active-high. Devices are available with a maximum data rate of either 25Mbps or 200Mbps, and feature a selectable default state for the outputs. The default is the state the output assumes when the input is either not powered or is open-circuit. See the Ordering Information and Product Selector Guide for suffixes associated with each option. Independent 1.71V to 5.5V supplies on each side of the isolator also make the devices suitable for use as level translators. All of the devices in the MAX22344–MAX22346 family are available in a 20-pin SSOP package with 5.5mm of creepage and clearance. All devices are rated for operation at ambient temperatures of -40°C to +125°C. Benefits and Features ●● Reinforced Galvanic Isolation for Fast Digital Signals • Up to 200Mbps Maximum Data Rate • Withstands 3.75kVRMS for 60s (VISO) • Continuously Withstands 784VRMS (VIOWM) • Withstands ±10kV Surge between GNDA and GNDB with 1.2/50μs waveform • High CMTI (50kV/μs, Typical) ●● Low Power Consumption • 0.74mW per Channel at 1Mbps with VDD = 1.8V • 1.4mW per Channel at 1Mbps with VDD = 3.3V • 3.2mW per Channel at 100Mbps with VDD = 1.8V ●● Options to Support a Broad Range of Applications • 2 Maximum Data Rates (200Mbps, 25Mbps) • 3 Direction Configurations • Active-High or Active-Low Enable Inputs • Pin-Selectable Output Default States (High/Low) Applications ●● ●● ●● ●● Isolated SPI Interface Fieldbus Communications for Industrial Automation Isolated RS-485/RS-422, CAN Battery Management ●● Medical Systems Safety Regulatory Approvals (Pending) ●● UL According to UL1577 ●● cUL According to CSA Bulletin 5A ●● VDE 0884-11 Reinforced Isolation Ordering Information and Product Selector Guide appear at end of data sheet. 19-100265; Rev 2; 2/19 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators Absolute Maximum Ratings VDDA to GNDA.........................................................-0.3V to +6V VDDB to GNDB.........................................................-0.3V to +6V IN_ on Side A, ENA, ENA, DEFA to GNDA.............-0.3V to +6V IN_ on Side B, ENB, DEFB to GNDB......................-0.3V to +6V OUT_ on Side A to GNDA....................... -0.3V to (VDDA + 0.3V) OUT_ on Side B to GNDB...................... -0.3V to (VDDB + 0.3V) Short Circuit Continuous Current OUT_ on Side A to GNDA, OUT_ on Side B to GNDB.............................................±30mA Continuous Power Dissipation (TA = +70°C) SSOP (derate 8mW/°C above +70°C)......................952.4mW Operating Temperature Range.......................... -40°C to +125°C Maximum Junction Temperature......................................+150°C Storage Temperature Range............................. -60°C to +150°C Lead Temperature (soldering, 10s).................................. +300°C Soldering Temperature (reflow)........................................+260°C Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only; functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Package Information PACKAGE TYPE: 20 SSOP Package Code A20MS+7 Outline Number 21-0056 Land Pattern Number 90-0094 THERMAL RESISTANCE, FOUR-LAYER BOARD Junction to Ambient (θJA) 84°C/W Junction to Case (θJC) 32°C/W For the latest package outline information and land patterns (footprints), go to www.maximintegrated.com/packages. Note that a “+”, “#”, or “-” in the package code indicates RoHS status only. Package drawings may show a different suffix character, but the drawing pertains to the package regardless of RoHS status. Package thermal resistances were obtained using the method described in JEDEC specification JESD51-7, using a four-layer board. For detailed information on package thermal considerations, refer to www.maximintegrated.com/thermal-tutorial. www.maximintegrated.com Maxim Integrated │  2 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators DC Electrical Characteristics (VDDA - VGNDA = 1.71V to 5.5V, VDDB - VGNDB = 1.71V to 5.5V, CL = 15pF, TA = -40°C to +125°C, unless otherwise noted. Typical values are at VDDA - VGNDA = 3.3V, VDDB - VGNDB = 3.3V, VGNDA = VGNDB, TA = +25°C, unless otherwise noted.) (Notes 1, 3) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS POWER SUPPLY Supply Voltage VDDA Relative to GNDA 1.71 5.5 VDDB Relative to GNDB 1.71 5.5 VDD_ rising 1.5 Undervoltage-Lockout Threshold VUVLO_ Undervoltage-Lockout Threshold Hysteresis VUVLO_HYST IDDA 12.5MHz square wave, CL = 0pF 50MHz square wave, CL = 0pF 500kHz square wave, CL = 0pF Side B Supply Current (MAX22344_) (Note 2) IDDB 12.5MHz square wave, CL = 0pF 50MHz square wave, CL = 0pF www.maximintegrated.com 1.66 V mV 45 500kHz square wave, CL = 0pF Side A Supply Current (MAX22344_) (Note 2) 1.6 V VDDA = 5V 0.54 1.00 VDDA = 3.3V 0.53 0.97 VDDA = 2.5V 0.52 0.96 VDDA = 1.8V 0.50 0.68 VDDA = 5V 1.67 2.50 VDDA = 3.3V 1.64 2.43 VDDA = 2.5V 1.62 2.41 VDDA = 1.8V 1.58 2.07 VDDA = 5V 4.63 6.31 VDDA = 3.3V 4.53 6.17 VDDA = 2.5V 4.48 6.11 VDDA = 1.8V 4.34 5.60 VDDB = 5V 1.19 2.06 VDDB = 3.3V 1.17 2.02 VDDB = 2.5V 1.17 2.01 VDDB = 1.8V 1.14 1.92 VDDB = 5V 2.28 3.29 VDDB = 3.3V 1.85 2.79 VDDB = 2.5V 1.68 2.58 VDDB = 1.8V 1.51 2.33 VDDB = 5V 5.66 7.07 VDDB = 3.3V 3.98 5.16 VDDB = 2.5V 3.28 4.34 VDDB = 1.8V 2.69 3.59 mA mA Maxim Integrated │  3 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators DC Electrical Characteristics (continued) (VDDA - VGNDA = 1.71V to 5.5V, VDDB - VGNDB = 1.71V to 5.5V, CL = 15pF, TA = -40°C to +125°C, unless otherwise noted. Typical values are at VDDA - VGNDA = 3.3V, VDDB - VGNDB = 3.3V, VGNDA = VGNDB, TA = +25°C, unless otherwise noted.) (Notes 1, 3) PARAMETER SYMBOL CONDITIONS 500kHz square wave, CL = 0pF Side A Supply Current (MAX22345_) (Note 2) IDDA 12.5MHz square wave, CL = 0pF 50MHz square wave, CL = 0pF 500kHz square wave, CL = 0pF Side B Supply Current (MAX22345_) (Note 2) IDDB 12.5MHz square wave, CL = 0pF 50MHz square wave, CL = 0pF 500kHz square wave, CL = 0pF Side A Supply Current (MAX22346_) (Note 2) IDDA 12.5MHz square wave, CL = 0pF 50MHz square wave, CL = 0pF www.maximintegrated.com TYP MAX VDDA = 5V MIN 0.70 1.26 VDDA = 3.3V 0.69 1.23 VDDA = 2.5V 0.68 1.22 VDDA = 1.8V 0.66 0.99 VDDA = 5V 1.83 2.70 VDDA = 3.3V 1.70 2.53 VDDA = 2.5V 1.63 2.45 VDDA = 1.8V 1.56 2.14 VDDA = 5V 4.89 6.51 VDDA = 3.3V 4.39 5.93 VDDA = 2.5V 4.18 5.67 VDDA = 1.8V 3.93 5.11 VDDB = 5V 1.03 1.80 VDDB = 3.3V 1.01 1.76 VDDB = 2.5V 1.01 1.75 VDDB = 1.8V 0.98 1.61 VDDB = 5V 2.13 3.09 VDDB = 3.3V 1.80 2.70 VDDB = 2.5V 1.66 2.54 VDDB = 1.8V 1.53 2.27 VDDB = 5V 5.41 6.88 VDDB = 3.3V 4.11 5.41 VDDB = 2.5V 3.58 4.78 VDDB = 1.8V 3.11 4.11 VDDA = 5V 0.87 1.53 VDDA = 3.3V 0.85 1.49 VDDA = 2.5V 0.84 1.49 VDDA = 1.8V 0.82 1.30 VDDA = 5V 1.98 2.89 VDDA = 3.3V 1.75 2.61 VDDA = 2.5V 1.65 2.49 VDDA = 1.8V 1.55 2.20 VDDA = 5V 5.15 6.69 VDDA = 3.3V 4.25 5.66 VDDA = 2.5V 3.88 5.22 VDDA = 1.8V 3.52 4.60 UNITS mA mA mA Maxim Integrated │  4 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators DC Electrical Characteristics (continued) (VDDA - VGNDA = 1.71V to 5.5V, VDDB - VGNDB = 1.71V to 5.5V, CL = 15pF, TA = -40°C to +125°C, unless otherwise noted. Typical values are at VDDA - VGNDA = 3.3V, VDDB - VGNDB = 3.3V, VGNDA = VGNDB, TA = +25°C, unless otherwise noted.) (Notes 1, 3) PARAMETER SYMBOL CONDITIONS 500kHz square wave, CL = 0pF Side B Supply Current (MAX22346_) (Note 2) IDDB 12.5MHz square wave, CL = 0pF 50MHz square wave, CL = 0pF LOGIC INTERFACE (IN_, EN_, ENA, DEF_, OUT_) TYP MAX VDDB = 5V 0.87 1.53 VDDB = 3.3V 0.85 1.49 VDDB = 2.5V 0.84 1.49 VDDB = 1.8V 0.82 1.30 VDDB = 5V 1.98 2.89 VDDB = 3.3V 1.75 2.61 VDDB = 2.5V 1.65 2.49 VDDB = 1.8V 1.55 2.20 VDDB = 5V 5.15 6.69 VDDB = 3.3V 4.25 5.66 VDDB = 2.5V 3.88 5.22 VDDB = 1.8V 3.52 4.60 2.25V ≤ VDD_ ≤ 5.5V 0.7 x VDD_ 1.71V ≤ VDD_ < 2.25V 0.75 x VDD_ 2.25V ≤ VDD_ ≤ 5.5V 0.7 x VDD_ 1.71V ≤ VDD_ < 2.25V 0.75 x VDD_ EN_, ENA, IN_ Input High Voltage VIH DEF_ (Note 2) www.maximintegrated.com MIN UNITS mA V Maxim Integrated │  5 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators DC Electrical Characteristics (continued) (VDDA - VGNDA = 1.71V to 5.5V, VDDB - VGNDB = 1.71V to 5.5V, CL = 15pF, TA = -40°C to +125°C, unless otherwise noted. Typical values are at VDDA - VGNDA = 3.3V, VDDB - VGNDB = 3.3V, VGNDA = VGNDB, TA = +25°C, unless otherwise noted.) (Notes 1, 3) PARAMETER SYMBOL CONDITIONS EN_, ENA, IN_ Input Low Voltage VIL DEF_ (Note 2) Input Hysteresis VHYS EN_, ENA, DEF_, IN_ MIN TYP MAX 2.25V ≤ VDD_ ≤ 5.5V 0.8 1.71V ≤ VDD_ < 2.25V 0.7 2.25V ≤ VDD_ ≤ 5.5V 0.8 1.71V ≤ VDD_ < 2.25V UNITS V 0.7 MAX2234_B/R 410 MAX2234_C/S 80 mV IN_ Input Pullup Current IPU DEFA = DEFB = high -10 -5 -1.5 µA IN_ Input Pulldown Current IPD DEFA = DEFB = low 1.5 5 10 µA IN_ Input Capacitance CIN fSW = 1MHz ENA Pullup Current IPU_ENA ENB Pullup Current IPU_ENB ENA Pulldown Current IPD_EN DEF_ Pullup Current IPU_DEF MAX2234_B/C MAX22345R/S OUT_ Output Voltage High VOH IOUT_ = -4mA source OUT_ Output Voltage Low VOL IOUT_ = 4mA sink www.maximintegrated.com 2 pF -10 -5 -1.5 µA -10 -5 -1.5 μA 1.5 5 10 µA -10 -5 -1.5 µA VDD_ - 0.4 V 0.4 V Maxim Integrated │  6 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators Dynamic Characteristics MAX2234_C/S (VDDA - VGNDA = 1.71V to 5.5V, VDDB - VGNDB = 1.71V to 5.5V, CL = 15pF, TA = -40°C to +125°C, unless otherwise noted. Typical values are at VDDA - VGNDA = 3.3V, VDDB - VGNDB = 3.3V, VGNDA = VGNDB, TA = +25°C, unless otherwise noted.) (Notes 2, 4) PARAMETER Common-Mode Transient Immunity SYMBOL CMTI Maximum Data Rate DRMAX Minimum Pulse Width PWMIN tPLH Propagation Delay (Figure 3) tPHL Pulse Width Distortion PWD tSPLH Propagation Delay Skew Part-to-Part (Same Channel) tSPHL Propagation Delay Skew Channel-to-Channel (Same Direction) www.maximintegrated.com CONDITIONS MIN IN_ = GND_ or VDD_ (Note 5) 200 1.71V ≤ VDD_ < 2.25V 150 IN_ to OUT_, CL = 15pF IN_ to OUT_, CL = 15pF |tPLH - tPHL| MAX 50 2.25V ≤ VDD_ ≤ 5.5V IN_ to OUT_ TYP UNITS kV/µs Mbps 2.25V ≤ VDD_ ≤ 5.5V 5.00 1.71V ≤ VDD_ < 2.25V 6.67 4.5V ≤ VDD_ ≤ 5.5V 4.1 5.7 9.2 3.0V ≤ VDD_ ≤ 3.6V 4.2 6.5 10.2 2.25V ≤ VDD_ ≤ 2.75V 4.9 7.9 13.4 1.71V ≤ VDD_ ≤ 1.89V 7.1 12.0 20.3 4.5V ≤ VDD_ ≤ 5.5V 4.3 6.1 9.4 3.0V ≤ VDD_ ≤ 3.6V 4.4 6.9 10.5 2.25V ≤ VDD_ ≤ 2.75V 5.1 8.2 14.1 1.71V ≤ VDD_ ≤ 1.89V 7.2 12.1 21.7 4.5V ≤ VDD_ ≤ 5.5V 0.4 2.0 3.0V ≤ VDD_ ≤ 3.6V 0.4 2.0 2.25V ≤ VDD_ ≤ 2.75V 0.3 2.0 1.71V ≤ VDD_ ≤ 1.89V 0.0 2.0 4.5V ≤ VDD_ ≤ 5.5V 3.7 3.0V ≤ VDD_ ≤ 3.6V 4.3 2.25V ≤ VDD_ ≤ 2.75V 6.0 1.71V ≤ VDD_ ≤ 1.89V 10.3 4.5V ≤ VDD_ ≤ 5.5V 3.8 3.0V ≤ VDD_ ≤ 3.6V 4.7 2.25V ≤ VDD_ ≤ 2.75V 6.5 1.71V ≤ VDD_ ≤ 1.89V 11.5 tSCSLH 1.71V ≤ VDD_ ≤ 5.5V 2.0 tSCSHL 1.71V ≤ VDD_ ≤ 5.5V 2.0 ns ns ns ns ns Maxim Integrated │  7 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators Dynamic Characteristics MAX2234_C/S (continued) (VDDA - VGNDA = 1.71V to 5.5V, VDDB - VGNDB = 1.71V to 5.5V, CL = 15pF, TA = -40°C to +125°C, unless otherwise noted. Typical values are at VDDA - VGNDA = 3.3V, VDDB - VGNDB = 3.3V, VGNDA = VGNDB, TA = +25°C, unless otherwise noted.) (Notes 2, 4) PARAMETER SYMBOL tSCOLH Propagation Delay Skew Channel-to-Channel (Opposite Direction) tSCOHL Peak Eye Diagram Jitter Clock Jitter RMS Rise Time (Figure 3) Fall Time (Figure 3) Enable to Data Valid (Figure 4) Enable to Tristate (Figure 4) www.maximintegrated.com TJIT(PK) TJCLK(RMS) tR tF tEN tTRI CONDITIONS MIN TYP MAX 4.5V ≤ VDD_ ≤ 5.5V 2.9 3.0V ≤ VDD_ ≤ 3.6V 3.4 2.25V ≤ VDD_ ≤ 2.75V 4.9 1.71V ≤ VDD_ ≤ 1.89V 10.2 4.5V ≤ VDD_ ≤ 5.5V 3.2 3.0V ≤ VDD_ ≤ 3.6V 3.8 2.25V ≤ VDD_ ≤ 2.75V 5.3 1.71V ≤ VDD_ ≤ 1.89V 10.9 200Mbps 100 500kHz clock input, rising/falling edges 7.5 ps 0.8 3.0V ≤ VDD_ ≤ 3.6V 1.1 2.25V ≤ VDD_ ≤ 2.75V 1.5 1.71V ≤ VDD_ ≤ 1.89V 2.4 4.5V ≤ VDD_ ≤ 5.5V 1.0 3.0V ≤ VDD_ ≤ 3.6V 1.4 2.25V ≤ VDD_ ≤ 2.75V 1.9 1.71V ≤ VDD_ ≤ 1.89V 3.0 ENA to OUT_, EN_ to OUT_, CL = 15pF 4.5V ≤ VDD_ ≤ 5.5V 3.9 ENA to OUT_, EN_ to OUT_, CL = 15pF CL = 5pF ns ps 4.5V ≤ VDD_ ≤ 5.5V CL = 5pF UNITS 3.0V ≤ VDD_ ≤ 3.6V 6.4 2.25V ≤ VDD_ ≤ 2.75V 10.1 1.71V ≤ VDD_ ≤ 1.89V 18.4 4.5V ≤ VDD_ ≤ 5.5V 6.3 3.0V ≤ VDD_ ≤ 3.6V 9.0 2.25V ≤ VDD_ ≤ 2.75V 12.6 1.71V ≤ VDD_ ≤ 1.89V 19.2 ns ns ns ns Maxim Integrated │  8 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators Dynamic Characteristics MAX2234_B/R (VDDA - VGNDA = 1.71V to 5.5V, VDDB - VGNDB = 1.71V to 5.5V, CL = 15pF, TA = -40°C to +125°C, unless otherwise noted. Typical values are at VDDA - VGNDA = 3.3V, VDDB - VGNDB = 3.3V, VGNDA = VGNDB, TA = +25°C, unless otherwise noted.) (Notes 2, 4) PARAMETER Common-Mode Transient Immunity SYMBOL CMTI Maximum Data Rate DRMAX Minimum Pulse Width PWMIN Glitch Rejection Propagation Delay (Figure 3) tPHL PWD MAX 50 25 Mbps IN_ to OUT_ IN_ to OUT_, CL = 15pF IN_ to OUT_, CL = 15pF |tPLH - tPHL| 40 ns ns 10 17 29 4.5V ≤ VDD_ ≤ 5.5V 17.4 24.2 32.5 3.0V ≤ VDD_ ≤ 3.6V 17.6 25.0 33.7 2.25V ≤ VDD_ ≤ 2.75V 18.3 26.4 36.7 1.71V ≤ VDD_ ≤ 1.89V 20.7 30.6 43.5 4.5V ≤ VDD_ ≤ 5.5V 16.9 24.0 33.6 3.0V ≤ VDD_ ≤ 3.6V 17.2 24.8 35.1 2.25V ≤ VDD_ ≤ 2.75V 17.8 26.1 38.2 1.71V ≤ VDD_ ≤ 1.89V 19.8 30.0 45.8 4.5V ≤ VDD_ ≤ 5.5V 0.2 4.0 3.0V ≤ VDD_ ≤ 3.6V 0.2 4.0 2.25V ≤ VDD_ ≤ 2.75V 0.3 4.0 1.71V ≤ VDD_ ≤ 1.89V 0.6 4.0 15.1 15.0 2.25V ≤ VDD_ ≤ 2.75V 15.4 1.71V ≤ VDD_ ≤ 1.89V 20.5 4.5V ≤ VDD_ ≤ 5.5V 13.9 3.0V ≤ VDD_ ≤ 3.6V 14.2 2.25V ≤ VDD_ ≤ 2.75V 16.0 1.71V ≤ VDD_ ≤ 1.89V 21.8 tSCSLH 1.71V ≤ VDD_ ≤ 5.5V 2.0 tSCSHL 1.71V ≤ VDD_ ≤ 5.5V 2.0 4.5V ≤ VDD_ ≤ 5.5V 13.9 3.0V ≤ VDD_ ≤ 3.6V 13.7 2.25V ≤ VDD_ ≤ 2.75V 14.2 1.71V ≤ VDD_ ≤ 1.89V 19.4 4.5V ≤ VDD_ ≤ 5.5V 13.0 3.0V ≤ VDD_ ≤ 3.6V 12.9 2.25V ≤ VDD_ ≤ 2.75V 14.4 1.71V ≤ VDD_ ≤ 1.89V 20.1 tSPHL tSCOLH Propagation Delay Skew Channel-to-Channel (Opposite Direction) tSCOHL UNITS kV/µs 3.0V ≤ VDD_ ≤ 3.6V Propagation Delay Skew Part-to-Part (Same Channel) www.maximintegrated.com TYP 4.5V ≤ VDD_ ≤ 5.5V tSPLH Propagation Delay Skew Channel-to-Channel (Same Direction) MIN IN_ = GND_ or VDD_ (Note 5) IN_ to OUT_ tPLH Pulse Width Distortion CONDITIONS ns ns ns ns ns Maxim Integrated │  9 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators Dynamic Characteristics MAX2234_B/R (continued) (VDDA - VGNDA = 1.71V to 5.5V, VDDB - VGNDB = 1.71V to 5.5V, CL = 15pF, TA = -40°C to +125°C, unless otherwise noted. Typical values are at VDDA - VGNDA = 3.3V, VDDB - VGNDB = 3.3V, VGNDA = VGNDB, TA = +25°C, unless otherwise noted.) (Notes 2, 4) PARAMETER Peak Eye Diagram Jitter Rise Time (Figure 3) Fall Time (Figure 3) Enable to Data Valid (Figure 4) Enable to Tristate (Figure 4) SYMBOL TJIT(PK) tR tF tEN tTRI CONDITIONS MIN 25Mbps TYP MAX 250 ps 4.5V ≤ VDD_ ≤ 5.5V 0.8 3.0V ≤ VDD_ ≤ 3.6V 1.1 2.25V ≤ VDD_ ≤ 2.75V 1.5 1.71V ≤ VDD_ ≤ 1.89V 2.4 4.5V ≤ VDD_ ≤ 5.5V 1.0 3.0V ≤ VDD_≤ 3.6V 1.4 2.25V ≤ VDD_ ≤ 2.75V 1.9 1.71V ≤ VDD_ ≤ 1.89V 3.0 ENA to OUT_, EN_ to OUT_, CL = 15pF 4.5V ≤ VDD_ ≤ 5.5V 3.9 3.0V ≤ VDD_ ≤ 3.6V 6.4 2.25V ≤ VDD_ ≤ 2.75V 10.1 1.71V ≤ VDD_ ≤ 1.89V 18.4 ENA to OUT_, EN_ to OUT_, CL = 15pF 4.5V ≤ VDD_ ≤ 5.5V 6.3 3.0V ≤ VDD_ ≤ 3.6V 9.0 2.25V ≤ VDD_ ≤ 2.75V 12.6 1.71V ≤ VDD_ ≤ 1.89V 19.2 CL = 5pF CL = 5pF UNITS ns ns ns ns Note 1: All devices are 100% production tested at TA = +125°C. Specifications over temperature are guaranteed by design and characterization. Note 2: Not production tested. Guaranteed by design and characterization. Note 3: All currents into the device are positive. All currents out of the device are negative. All voltages are referenced to their respective ground (GNDA or GNDB), unless otherwise noted. Note 4: All measurements taken with VDDA = VDDB, unless otherwise noted. Note 5: CMTI is the maximum sustainable common-mode voltage slew rate while maintaining the correct output. CMTI applies to both rising and falling common-mode voltage edges. Tested with the transient generator connected between GNDA and GNDB (VCM = 1000V). ESD Protection PARAMETER ESD www.maximintegrated.com SYMBOL CONDITIONS Human Body Model, All Pins MIN TYP ±4 MAX UNITS kV Maxim Integrated │  10 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators Table 1. Insulation Characteristics PARAMETER Partial Discharge Test Voltage SYMBOL VPR VALUE UNITS Method B1 = VIORM x 1.875 (t = 1s, partial discharge < 5pC) CONDITIONS 2078 VP Maximum Repetitive Peak Isolation Voltage VIORM (Note 6) 1108 VP Maximum Working Isolation Voltage VIOWM Continuous RMS voltage (Note 6) 784 VRMS Maximum Transient Isolation Voltage VIOTM t = 1s 5300 VP Maximum Withstand Isolation Voltage VISO fSW = 60Hz, duration = 60s (Note 7) 3750 VRMS VIOSM Basic Insulation, 1.2/50µs pulse per IEC61000-4-5 10 kV Maximum Surge Isolation Voltage Insulation Resistance RIO Barrier Capacitance Side A to Side B CIO Minimum Creepage Distance CPG Minimum Clearance Distance CLR Internal Clearance Comparative Tracking Index VIO = 500V, TA = 25°C >1012 VIO = 500V, 100°C ≤ TA ≤ 125°C >1011 VIO = 500V at TS = 150°C >109 fSW = 1MHz (Note 8) Distance through insulation CTI Material Group II (IEC 60112) Climate Category Pollution Degree (DIN VDE 0110, Table 1) Ω 1.5 pF 5.5 mm 5.5 mm 0.021 mm >400 40/125/21 2 Note 6: VISO, VIOWM, and VIORM are defined by the IEC 60747-5-5 standard. Note 7: Product is qualified at VISO for 60s and 100% production tested at 120% of VISO for 1s. Note 8: Capacitance is measured with all pins on field-side and logic-side tied together. www.maximintegrated.com Maxim Integrated │  11 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators Safety Limits Damage to the IC can result in a low-resistance path to ground or to the supply and, without current limiting, the MAX22344–MAX22346 could dissipate excessive amounts of power. Excessive power dissipation can damage the die and result in damage to the isolation barrier, potentially causing downstream issues. Table 2 shows the safety limits for the MAX22344–MAX22346. The maximum safety temperature (TS) for the device is the 150°C maximum junction temperature specified in the Absolute Maximum Ratings. The power dissipation (PD) and junction-to-ambient thermal impedance (θJA) deter- mine the junction temperature. Thermal impedance values (θJA and θJC) are available in the Package Thermal Characteristics section of the datasheet and power dissipation calculations are discussed in the Calculating Power Dissipation section. Calculate the junction temperature (TJ) as: TJ = TA + (PD x θJA) Figure 1 and Figure 2 show the thermal derating curve for safety limiting the power and the current of the device. Ensure that the junction temperature does not exceed 150°C. THERMAL DERATING CURVE FOR SAFETY LIMITING CURRENT 1600 350 1400 300 1200 250 SAFE CURRENT LIMIT (mA) SAFE POWER LIMIT (mW) THERMAL DERATING CURVE FOR SAFETY POWER LIMITING 1000 800 600 400 150 100 50 200 0 200 0 0 25 50 75 100 125 150 175 200 0 25 50 75 100 125 150 175 200 AMBIENT TEMPERATURE (°C) AMBIENT TEMPERATURE (°C) Figure 1. Thermal Derating Curve for Safety Power Limiting Figure 2. Thermal Derating Curve for Safety Current Limiting Table 2. Safety Limiting Values for the MAX22344–MAX22346 PARAMETER SYMBOL TEST CONDITIONS MAX UNIT Safety Current on Any Pin IS TJ = 150°C, TA = 25°C 300 mA Total Safety Power Dissipation PS TJ = 150°C, TA = 25°C 1448 mW Maximum Safety Temperature TS 150 °C www.maximintegrated.com Maxim Integrated │  12 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators Test Circuits and Timing Diagrams VDDA IN1, IN2 VDDA 0.1µF 0.1µF VDDA GNDA VDDB VDDB 50% 50% tPHL tPLH VDDB MAX2234_ OUT1 50Ω OUT_ IN_ CL TEST SOURCE GNDA 50% 50% GNDB RL GNDB VDDB OUT2 GNDB (A) tSCSLH tSCSHL 90% 50% 50% 10% tF tR (B) Figure 3. Test Circuit (A) and Timing Diagram (B) ISOLA TION BARRIER VDDA OR VDDB GNDA OR GNDB SW1 OUT_ IN_ EN_, ENA SW2 GENERATOR 50Ω GNDA OR GNDB RL 1kΩ CL 15pF SW3 SW4 VDDA OR VDDB GNDA OR GNDB GNDA OR GNDB MAX2234_B/C/R/S MAX22345R/S VDDA OR VDDB ENA OR E NB 50% SW1: OPEN SW2: CLOSED SW3: CLOSED SW4: OPEN 50% GNDA OR GNDB tEN VDDA ENA 50% GNDA tEN tTRI VDDA OR VDDB SW1: OPEN SW2: CLOSED SW3: CLOSED SW4: OPEN 50% tTRI VDDA VDD_ 2 OUT_ VDD_ 2 OUT_ 0.25V VOL 0.25V VOL MAX2234_B/C/R/S MAX22345R/S VDDA OR VDDB ENA OR E NB 50% SW1: CLOSED SW2: OPEN SW3: OPEN SW4: CLOSED 50% GNDA OR GNDB tTRI tEN VOH OUT_ VDD_ 2 0.25V GNDA OR GNDB VDDA ENA 50% SW1: CLOSED SW2: OPEN SW3: OPEN SW4: CLOSED 50% GNDA tTRI tEN VOH OUT_ VDD_ 2 0.25V GNDA Figure 4. Enable to Output Timing (tEN, tTRI) www.maximintegrated.com Maxim Integrated │  13 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators Typical Operating Characteristics (VDDA - VGNDA = +3.3V, VDDB - VGNDB = +3.3V, VGNDA = VGNDB, TA = +25°C, unless otherwise noted.) SIDE A SUPPLY CURRENT vs. DATA RATE 1 3 DRIVING ONE CHANNEL ON SIDE A OTHER CHANNELS ARE IN DEFAULT STATE MAX22344B 0.9 VDDA = 1.8V VDDA = 2.5V 0.5 1.4 VDDA = 2.5V 0.6 VDDA = 3.3V VDDA = 5.0V 0 5 10 15 20 VDDA = 1.8V 1 0.2 25 VDDA = 3.3V VDDA = 5.0V 0 25 50 SIDE A SUPPLY CURRENT vs. DATA RATE 1.8 VDDA = 1.8V VDDA = 2.5V 1 50 75 100 125 150 175 200 VDDA = 2.5V 20 25 toc06 1.8 VDDA = 2.5V VDDA = 5.0V 0 5 10 15 20 VDDA = 1.8V 1.4 1 0.6 25 VDDA = 3.3V VDDA = 5.0V 0 25 50 75 100 125 150 175 200 DATA RATE (Mbps) SIDE B SUPPLY CURRENT vs. DATA RATE 2.7 SUPPLY CURRENT (mA) SUPPLY CURRENT (mA) 1.2 10 15 toc08 DRIVING ONE CHANNEL ON SIDE A OTHER CHANNELS ARE IN DEFAULT STATE CL = 15pF, MAX22344B VDDB = 1.8V 1.5 15 DATA RATE (Mbps) www.maximintegrated.com 10 2.2 VDDA = 3.3V 2.4 VDDB = 5.0V 5 5 DRIVING ONE CHANNEL ON SIDE A OTHER CHANNELS ARE IN DEFAULT STATE MAX22346C 3 toc07 VDDB = 2.5V 0 VDDA = 5.0V 0 DATA RATE (Mbps) VDDB = 3.3V 0.9 VDDA = 3.3V 3.4 VDDB = 1.8V 1.8 VDDA = 2.5V SIDE A SUPPLY CURRENT vs. DATA RATE toc05 DRIVING ONE CHANNEL ON SIDE A OTHER CHANNELS ARE IN DEFAULT STATE CL = 0pF, MAX22344B 2.1 VDDA = 1.8V 0.7 DATA RATE (Mbps) VDDA = 1.8V 0.8 0.7 SIDE B SUPPLY CURRENT vs. DATA RATE 2.4 0.8 2.6 0.9 DATA RATE (Mbps) 2.7 0.9 0.6 200 1 VDDA = 5.0V 25 175 1.1 VDDA = 3.3V 0 150 DRIVING ONE CHANNEL ON SIDE A OTHER CHANNELS ARE IN DEFAULT STATE MAX22346B 1.2 SUPPLY CURRENT (mA) SUPPLY CURRENT (mA) 1.3 2.2 1.4 125 SIDE A SUPPLY CURRENT vs. DATA RATE toc04 DRIVING ONE CHANNEL ON SIDE A OTHER CHANNELS ARE IN DEFAULT STATE MAX22345C/S 2.6 100 1 DATA RATE (Mbps) DATA RATE (Mbps) 3 75 SUPPLY CURRENT (mA) 0.6 1.8 toc03 DRIVING ONE CHANNEL ON SIDE A OTHER CHANNELS ARE IN DEFAULT STATE MAX22345B/R 1.1 SUPPLY CURRENT (mA) 0.7 0.6 1.2 2.2 0.8 0.4 SIDE A SUPPLY CURRENT vs. DATA RATE toc02 DRIVING ONE CHANNEL ON SIDE A OTHER CHANNELS ARE IN DEFAULT STATE MAX22344C 2.6 SUPPLY CURRENT (mA) SUPPLY CURRENT (mA) SIDE A SUPPLY CURRENT vs. DATA RATE toc01 20 25 2.1 VDDB = 2.5V VDDB = 3.3V VDDB = 5.0V 1.8 1.5 1.2 0.9 0 5 10 15 20 25 DATA RATE (Mbps) Maxim Integrated │  14 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators Typical Operating Characteristics (continued) (VDDA - VGNDA = +3.3V, VDDB - VGNDB = +3.3V, VGNDA = VGNDB, TA = +25°C, unless otherwise noted.) SIDE B SUPPLY CURRENT vs. DATA RATE 12 DRIVING ONE CHANNEL ON SIDE A OTHER CHANNELS ARE IN DEFAULT STATE CL = 0pF, MAX22344C 10 VDDB = 2.5V VDDB = 3.3V VDDB = 5.0V 6 4 2 0 0 25 50 75 100 125 150 175 8 VDDB = 5.0V 4 2 0 200 0 25 50 12 10 SUPPLY CURRENT (mA) SUPPLY CURRENT (mA) VDDB = 2.5V VDDB = 5.0V 1.5 1.2 0 5 10 15 20 8 175 12 5 VDDB = 5.0V 6 4 2 0 25 50 75 100 125 150 175 1.3 1 10 15 DATA RATE (Mbps) www.maximintegrated.com 20 25 toc14 VDDB = 2.5V VDDB = 3.3V VDDB = 5.0V 6 4 2 0 25 50 75 100 125 150 175 200 DATA RATE (Mbps) SIDE B SUPPLY CURRENT vs. DATA RATE 2.5 toc16 DRIVING ONE CHANNEL ON SIDE A OTHER CHANNELS ARE IN DEFAULT STATE CL = 15pF, MAX22346B VDDB = 1.8V VDDB = 5.0V 5 15 DRIVING ONE CHANNEL ON SIDE A OTHER CHANNELS ARE IN DEFAULT STATE CL = 15pF, MAX22345C/S 8 0 200 2.2 VDDB = 2.5V 0 10 VDDB = 1.8V VDDB = 2.5V SUPPLY CURRENT (mA) SUPPLY CURRENT (mA) 0 10 toc15 VDDB = 3.3V 0.7 1.2 SIDE B SUPPLY CURRENT vs. DATA RATE toc13 VDDB = 1.8V 1.6 1.5 DATA RATE (Mbps) DRIVING ONE CHANNEL ON SIDE A OTHER CHANNELS ARE IN DEFAULT STATE CL = 0pF, MAX22346B 1.9 VDDB = 5.0V DATA RATE (Mbps) SIDE B SUPPLY CURRENT vs. DATA RATE 2.2 VDDB = 3.3V 1.8 0.9 200 VDDB = 3.3V 0 25 DATA RATE (Mbps) 2.5 150 VDDB = 2.5V VDDB = 1.8V VDDB = 3.3V 0.9 125 DRIVING ONE CHANNEL ON SIDE A OTHER CHANNELS ARE IN DEFAULT STATE CL = 0pF, MAX22345C/S VDDB = 1.8V 1.8 100 SIDE B SUPPLY CURRENT vs. DATA RATE toc12 DRIVING ONE CHANNEL ON SIDE A OTHER CHANNELS ARE IN DEFAULT STATE CL = 15pF, MAX22345B/R 2.1 75 2.1 DATA RATE (Mbps) SIDE B SUPPLY CURRENT vs. DATA RATE 2.4 VDDB = 1.8V VDDB = 3.3V DATA RATE (Mbps) 2.7 2.4 VDDB = 2.5V 6 toc11 DRIVING ONE CHANNEL ON SIDE A OTHER CHANNELS ARE IN DEFAULT STATE CL = 0pF, MAX22345B/R VDDB = 1.8V SUPPLY CURRENT (mA) SUPPLY CURRENT (mA) VDDB = 1.8V 8 2.7 DRIVING ONE CHANNEL ON SIDE A OTHER CHANNELS ARE IN DEFAULT STATE CL = 15pF, MAX22344C SUPPLY CURRENT (mA) 10 SIDE B SUPPLY CURRENT vs. DATA RATE toc10 SUPPLY CURRENT (mA) 12 SIDE B SUPPLY CURRENT vs. DATA RATE toc09 20 25 1.9 VDDB = 2.5V VDDB = 3.3V VDDB = 5.0V 1.6 1.3 1 0.7 0 5 10 15 20 25 DATA RATE (Mbps) Maxim Integrated │  15 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators Typical Operating Characteristics (continued) (VDDA - VGNDA = +3.3V, VDDB - VGNDB = +3.3V, VGNDA = VGNDB, TA = +25°C, unless otherwise noted.) SIDE B SUPPLY CURRENT vs. DATA RATE SIDE B SUPPLY CURRENT vs. DATA RATE toc17 12 DRIVING ONE CHANNEL ON SIDE A OTHER CHANNELS ARE IN DEFAULT STATE CL = 0pF, MAX22346C 10 10 SUPPLY CURRENT (mA) SUPPLY CURRENT (mA) VDDB = 3.3V VDDB = 5.0V 4 2 8 28 VDDB = 2.5V VDDB = 3.3V VDDB = 5.0V 6 toc19 VDDA = VDDB INA TO OUTB, tPLH MAX2234_B/R 30 VDDB = 1.8V VDDB = 2.5V 6 32 DRIVING ONE CHANNEL ON SIDE A OTHER CHANNELS ARE IN DEFAULT STATE CL = 15pF, MAX22346C VDDB = 1.8V 8 PROPAGATION DELAY vs. TEMPERATURE toc18 PROPAGATION DELAY (ns) 12 4 2 26 24 VDD_ = 1.8V 22 VDD_ = 2.5V VDD_ = 3.3V 20 VDD_ = 5.0V 0 25 50 75 100 125 150 175 0 200 0 25 50 DATA RATE (Mbps) 125 150 175 18 200 -50 -25 0 30 VDDA = VDDB INA TO OUTB, tPLH MAX2234_C/S 9 6 VDD_ = 1.8V VDD_ = 2.5V 3 VDD_ = 3.3V 20 50 75 PROPAGATION DELAY vs. VDDB VOLTAGE toc21 30 VDDB = 3.3V INA TO OUTB, tPLH 25 25 100 125 TEMPERATURE (⁰C) PROPAGATION DELAY vs. VDDA VOLTAGE toc20 PROPAGATION DELAY (ns) PROPAGATION DELAY (ns) 12 100 DATA RATE (Mbps) PROPAGATION DELAY vs. TEMPERATURE 15 75 MAX2234_B/R 15 MAX2234_C/S 10 5 toc22 VDDA = 3.3V INA TO OUTB, tPLH 25 PROPAGATION DELAY (ns) 0 20 MAX2234_B/R 15 MAX2234_C/S 10 5 VDD_ = 5.0V 0 -50 -25 0 25 50 75 100 0 125 TEMPERATURE (⁰C) MINIMUM PULSE WIDTH 1.5 2.5 3.5 4.5 0 5.5 1.5 VDDA VOLTAGE (V) 2.5 3.5 4.5 MINIMUM PULSE WIDTH toc23 MAX2234_B/R 40ns PULSE toc24 MAX2234_CS 5ns PULSE IN_ 1V/div IN_ 1V/div OUT_ 1V/div OUT_ 1V/div 20ns/div www.maximintegrated.com 5.5 VDDB VOLTAGE (V) 5ns/div Maxim Integrated │  16 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators Typical Operating Characteristics (continued) (VDDA - VGNDA = +3.3V, VDDB - VGNDB = +3.3V, VGNDA = VGNDB, TA = +25°C, unless otherwise noted.) EYE DIAGRAM AT 200MBPS MAX2234_C/S CLOCK JITTER RMS ON RISING EDGE MAX2234_C/S toc26 toc25 500kHz CLOCK INPUT tJCLK(RMS) = 7.5ps VDDB = 3.0V 400mV/div 400mV/div OUT_ 125ps/div 1ns/div CLOCK JITTER RMS ON FALLING EDGE MAX2234_C/S CLOCK JITTER RMS vs. TEMPERATURE toc27 toc28 16 500kHz CLOCK INPUT tJCLK(RMS) = 8.0ps 500kHz CLOCK INPUT VDD_ = 5.0V MAX2234_C/S 14 400mV/div OUT_ CLOCK JITTER RMS (ps) 12 FALLING EDGE 10 8 6 RISING EDGE 4 2 0 125ps/div -50 -25 0 25 50 75 100 125 TEMPERATURE (°C) www.maximintegrated.com Maxim Integrated │  17 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators Pin Configurations TOP VIEW VDDA 1 GNDA 2 IN1 + + 20 VDDB VDDA 1 19 GNDB GNDA 2 3 18 OUT1 IN1 3 18 OUT1 IN2 4 17 OUT2 IN2 4 17 OUT2 IN3 5 16 OUT3 IN3 5 16 OUT3 IN4 6 15 OUT4 OUT4 6 15 IN4 DEFA 7 14 DEFB DEFA 7 14 DEFB I.C. 8 13 ENB ENA 8 13 ENB N.C. 9 12 N.C. N.C. 9 12 N.C. MAX22344B/C GNDA 10 11 GNDB MAX22345B/C GNDA 10 1 GNDA 2 IN1 + 19 GNDB 11 GNDB SSOP VDDA 20 VDDB SSOP + 20 VDDB VDDA 1 19 GNDB GNDA 2 3 18 OUT1 IN1 3 18 OUT1 IN2 4 17 OUT2 IN2 4 17 OUT2 IN3 5 16 OUT3 OUT3 5 16 IN3 OUT4 6 15 IN4 OUT4 6 15 IN4 DEFA 7 14 DEFB DEFA 7 14 DEFB ENA 8 13 ENB ENA 8 13 ENB N.C. 9 12 N.C. N.C. 9 12 N.C. MAX22345R/S GNDA 10 11 GNDB SSOP www.maximintegrated.com MAX22346B/C GNDA 10 20 VDDB 19 GNDB 11 GNDB SSOP Maxim Integrated │  18 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators Pin Description PIN NAME MAX22344B/C MAX22345B/C MAX22345R/S MAX22346B/C VDDA 1 1 1 1 GNDA 2, 10 2, 10 2, 10 2, 10 IN1 3 3 3 3 IN2 4 4 4 4 IN3 5 5 5 16 IN4 6 15 15 15 DEFA 7 7 7 7 I.C. 8 — — — N.C. 9, 12 9, 12 9, 12 9, 12 ENA — 8 — 8 ENA — — 8 — GNDB 11, 19 11, 19 11, 19 11, 19 ENB 13 13 13 13 DEFB 14 14 14 14 OUT4 15 6 6 6 OUT3 16 16 16 5 OUT2 17 17 17 17 OUT1 18 18 18 18 VDDB 20 20 20 20 www.maximintegrated.com Maxim Integrated │  19 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators Pin Description (continued) NAME FUNCTION POWER VDDA Power Supply Input for Side A. Bypass VDDA to GNDA with a 0.1μF ceramic capacitor as close as possible to the pin. GNDA Ground Reference for Side A. VDDB Power Supply Input for Side B. Bypass VDDB to GNDB with a 0.1μF ceramic capacitor as close as possible to the pin. GNDB Ground reference for Side B. INPUTS IN1 Logic Input 1 on Side A. Corresponds to Logic Output 1 on Side B. IN2 Logic Input 2 on Side A. Corresponds to Logic Output 2 on Side B. IN3 Logic Input 3 on Side A/B. Corresponds to Logic Output 3 on Side B/A. IN4 Logic Input 4 on Side A/B. Corresponds to Logic Output 4 on Side B/A. OUTPUTS OUT1 Logic Output 1 on Side B. OUT1 is the logic output for the IN1 input on Side A. OUT2 Logic Output 2 on Side B. OUT2 is the logic output for the IN2 input on Side A. OUT3 Logic Output 3 on Side B/A. OUT3 is the logic output for the IN3 input on Side A/B. OUT4 Logic Output 4 on Side B/A. OUT4 is the logic output for the IN4 input on Side A/B. ENABLE INPUTS ENA Active-High Enable for Side A. ENA has an internal 5μA pull-up to VDDA. ENA Active-Low Enable for Side A. ENA has an internal 5μA pull-down to GNDA. ENB Active-High Enable for Side B. ENB has an internal 5μA pull-up to VDDB. DEFAULT CONTROL DEFA Default Control Input for Side A. Connect DEFA to VDDA to set side A outputs to a default-high state and to enable the pullup current on side A inputs. Connect DEFA to GNDA to set side A outputs to a default-low state and enable the pulldown current on side A inputs. DEFA must be tied to the same state (high or low) as DEFB. DEFB Default Control Input for Side B. Connect DEFB to VDDB to set side B outputs to a default-high state and to enable the pullup current on side B inputs. Connect DEFB to GNDB to set side B outputs to a default-low state and enable the pulldown current on side B inputs. DEFB must be tied to the same state (high or low) as DEFA. INTERNALLY CONNECTED, NOT CONNECTED I.C. N.C. www.maximintegrated.com Internally Connected. Leave unconnected or connect to GNDA or VDDA. Not Connected. Not internally connected. Maxim Integrated │  20 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators Functional Diagram VDDA MAX22344B/C VDDB VDDA MAX22345B/C ENB ENB IN1 OUT1 IN1 OUT1 IN2 OUT2 IN2 OUT2 IN3 OUT3 IN3 OUT3 IN4 OUT4 IN4 DEFA DEFB GNDB GNDA GNDB VDDB VDDA DEFA DEFB GNDA VDDA OUT4 ENA I.C. MAX22345R/S ENB MAX22346B/C VDDB ENB IN1 OUT1 IN1 OUT1 IN2 OUT2 IN2 OUT2 IN3 OUT3 OUT4 IN4 ENA DEFA GNDA www.maximintegrated.com VDDB OUT3 IN3 OUT4 IN4 ENA DEFB GNDB DEFA DEFB GNDA GNDB Maxim Integrated │  21 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators Detailed Description Digital Isolation The MAX22344–MAX22346 provide reinforced galvanic isolation for digital signals that are transmitted between two ground domains. The devices withstand differences of up to 3.75kVRMS for up to 60 seconds, and up to 1108VPEAK of continuous isolation. The MAX22344–MAX22346 are a family of 4-channel reinforced digital isolators. The MAX22344–MAX22346 have an isolation rating of 3.75kVRMS. The MAX22344– MAX22346 family offers all possible unidirectional channel configurations to accommodate any 4-channel design, including SPI, RS-232, RS-485, and digital I/O applications. For applications requiring bidirectional channels, such as I2C, see the MAX14933 and MAX14937. Level-Shifting The wide supply voltage range of both VDDA and VDDB allows the MAX22344–MAX22346 to be used for level translation in addition to isolation. VDDA and VDDB can be indepen­dently set to any voltage from 1.71V to 5.5V. The supply voltage sets the logic level on the corresponding side of the isolator. The MAX22344 features four channels transferring digital signals in one direction for applications such as isolated digital I/O. The MAX22345 has three channels transmitting data in one direction and one channel transmitting in the opposite direction, making them ideal for applications such as isolated SPI and RS-485 communication. The MAX22346 provides further design flexibility with two channels in each direction for isolated RS-232 or other applications. Unidirectional Channels Each channel of the MAX22344–MAX22346 is unidirectional; it only passes data in one direction, as indicated in the functional diagram. Each device features four unidirectional channels that operate independently with guaranteed data rates from DC up to 25Mbps (B/R versions), or from DC to 200Mbps (C/S versions). The output driver of each channel is push-pull, eliminating the need for pullup resistors. The outputs are able to drive both TTL and CMOS logic inputs. Devices are available in a 20-pin SSOP package and are rated for up to 3.75kVRMS. This family of digital isolators offers low-power operation, high electromagnetic interference (EMI) immunity, and stable temperature performance through Maxim’s proprietary process technology. The devices isolate different ground domains and block high-voltage/high-current transients from sensitive or human interface circuitry. Startup and Undervoltage-Lockout The VDDA and VDDB supplies are both internally monitored for undervoltage conditions. Undervoltage events can occur during power-up, power-down, or during normal operation due to a sagging supply voltage. When an undervoltage condition is detected on either supply while the outputs are enabled, all outputs go to their default states regardless of the state of the inputs (Table 3 , Table 4). Figure 5 through Figure 8 show the behavior of the outputs during powerup and power-down. Devices are available with a maximum data rate of either 25Mbps (B/R versions) or 200Mbps (C/S versions). All devices feature user-selectable default-high or defaultlow outputs. The default is the state the output assumes when the input is not powered or if the input is open-circuit. The devices have two supply inputs (VDDA and VDDB) that independently set the logic levels on either side of the device. VDDA and VDDB are referenced to GNDA and GNDB, respectively. The MAX22344–MAX22346 also feature a refresh circuit to ensure output accuracy when an input remains in the same state indefinitely. Table 3. MAX2234_B/C Output Behavior During Undervoltage Conditions VIN_ VDDA VDDB 1 Powered Powered 0 Powered Powered X X Undervoltage Powered www.maximintegrated.com Powered Undervoltage ENA ENB VOUTA VOUTB 1 1 High High 0 0 Hi-Z Hi-Z 1 1 Low Low 0 0 Hi-Z Hi-Z 1 1 Default Default 0 0 Hi-Z Hi-Z 1 1 Default Default 0 0 Hi-Z Hi-Z Maxim Integrated │  22 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators Table 4. MAX22345R/S Output Behavior During Undervoltage Conditions VIN_ VDDA VDDB 1 Powered Powered 0 Powered Powered X Undervoltage Powered X Powered Undervoltage MAX2234_B/C/R/S INPUTS SET TO HIGH ENA ENB VOUTA VOUTB 0 1 High High 1 0 Hi-Z Hi-Z 0 1 Low Low 1 0 Hi-Z Hi-Z 0 1 Default Default 1 0 Hi-Z Hi-Z 0 1 Default Default 1 0 Hi-Z Hi-Z MAX2234_B/C/R/S INPUTS SET TO HIGH fig05 fig06 DEFAULT SET TO LOW DEFAULT SET TO HIGH VDDA VDDA VDDB 2V/div VDDB 2V/div OUT_A OUT_A OUT_B OUT_B 200µs/div Figure 5. Undervoltage Lockout Behavior (MAX2234_ High) www.maximintegrated.com 200µs/div Figure 6. Undervoltage Lockout Behavior (MAX2234_ High) Maxim Integrated │  23 MAX22344/MAX22345/ MAX22346 MAX2234_B/C/R/S INPUTS SET TO LOW Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators MAX2234_B/C/R/S INPUTS SET TO LOW fig07 fig08 DEFAULT SET TO LOW DEFAULT SET TO HIGH VDDA VDDA VDDB VDDB 2V/div OUT_A OUT_A OUT_B OUT_B 2V/div 200µs/div 200µs/div Figure 7. Undervoltage Lockout Behavior (MAX2234_ Low) Figure 8. Undervoltage Lockout Behavior (MAX2234_ Low) Selectable Output Default (DEFA, DEFB) ●● Keep the input/output traces as short as possible. To keep signal paths low-inductance, avoid using vias. The default is the state the output assumes when the input is not powered or if the input is open circuit. The MAX22344-MAX22346 feature user-selectable defaulthigh or default-low outputs. Set both DEFA and DEFB high to set all channels to default-high, or set both DEFA and DEFB low to set all channels to default-low. Ensure the logic state (high or low) of DEFA is the same as that for DEFB. Do not toggle DEFA or DEFB during normal operation. Applications Information Power-Supply Sequencing The MAX22344-MAX22346 do not require special power supply sequencing. The logic levels are set independently on either side by VDDA and VDDB. Each supply can be present over the entire specified range regardless of the level or presence of the other supply. Power-Supply Decoupling To reduce ripple and the chance of introducing data errors, bypass VDDA and VDDB with 0.1μF low-ESR ceramic capacitors to GNDA and GNDB, respectively. Place the bypass capacitors as close to the power supply input pins as possible. Layout Considerations The PCB designer should follow some critical recommendations in order to get the best performance from the design. ●● Have a solid ground plane underneath the highspeed signal layer. ●● Keep the area underneath the MAX22344–MAX22346 free from ground and signal planes. Any galvanic or metallic connection between the Side A and Side B defeats the isolation. Calculating Power Dissipation The required current for a given supply (VDDA or VDDB) can be estimated by summing the current required for each channel. The supply current for a channel depends on whether the channel is an input or an output, the channel’s data rate, and the capacitive or resistive load if it is an output. The typical current for an input or output at any data rate can be estimated from the graphs in Figure 9 and Figure 10. Please note the data in Figure 9 and Figure 10 are extrapolated from the supply current measurements in a typical operating condition. The total current for a single channel is the sum of the “no load” current (shown in Figure 9 and Figure 10) which is a function of Voltage and Data Rate, and the “load current,” which depends on the type of load. Current into a capacitive load is a function of the load capacitance, the switching frequency, and the supply voltage. ICL = CL × fSW × VDD where ICL is the current required to drive the capacitive load. CL is the load capacitance on the isolator’s output pin. www.maximintegrated.com Maxim Integrated │  24 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators fSW is the switching frequency (bits per second/2). ●● Channel 4 is an output channel operating at 2.5V and 100Mbps, consuming 0.77mA, estimated from Figure 10. VDD is the supply voltage on the output side of the isolator. ●● ICL on channel 4 for 15pF capacitor at 2.5V and 100Mbps is 1.875mA. Current into a resistive load depends on the load resistance, the supply voltage and the average duty cycle of the data waveform. The DC load current can be conservatively estimated by assuming the output is always high. Total current for side A = 0.33 + 0.14 × 2 + 0.77 + 1.875 = 3.255mA, typical VDDB must supply: IRL = VDD ÷ RL where ●● Channel 1 is an output channel operating at 3.3V and 20Mbps, consuming 0.40mA, estimated from Figure 10. IRL is the current required to drive the resistive load. ●● Channel 2 and 3 are output channels operating at 3.3V with DC signal, consuming 0.27mA, estimated from Figure 10. VDD is the supply voltage on the output side of the isolator. RL is the load resistance on the isolator’s output pin. Example (shown in Figure 11): A MAX22345C is operating with VDDA = 2.5V, VDDB = 3.3V, channel 1 operating at 20Mbps with a 10pF capacitive load, channel 2 held high with a 10kΩ resistive load, and channel 4 operating at 100Mbps with a 15pF capacitive load. Channel 3 is not in use and the resistive load is negligible since the isolator is driving a CMOS input. Refer to Table 5 and Table 6 for VDDA and VDDB supply current calculation worksheets. ●● Channel 4 is an input channel operating at 3.3V and 100Mbps, consuming 1.11mA, estimated from Figure 9. ●● ICL on channel 1 for 10pF capacitor at 3.3V and 20Mbps is 0.33mA. ●● IRL on channel 2 for 10kΩ resistor held at 3.3V is 0.33mA. Total current for side B = 0.40 + 0.27 × 2 + 1.11 + 0.33 + 0.33 = 2.71mA, typical VDDA must supply: ●● Channel 1 is an input channel operating at 2.5V and 20Mbps, consuming 0.33mA, estimated from Figure 9. ●● Channel 2 and 3 are input channels operating at 2.5V with DC signal, consuming 0.14mA, estimated from Figure 9. Table 5. Side A Supply Current Calculation Worksheet SIDE A 1 IN/ OUT IN Data Rate (Mbps) 20 2 IN 0 3 IN 0 4 OUT 100 Channel Load Type V DDA = 2.5V “No Load” Current Load (mA) 0.33 Load Current (mA) 0.14 0.14 Capacitive 15pF 0.77 2.5V x 50MHz x 15pF = 1.875mA Total: 3.26mA Table 6. Side B Supply Current Calculation Worksheet SIDE B V DDB = 3.3V Channel IN/ OUT Data Rate (Mbps) Load Type Load “No Load” Current (mA) Load Current (mA) 1 OUT 20 Capacitive 10pF 0.40 3.3V x 10MHz x 10pF = 0.33mA 2 OUT 0 Resistive 10kΩ 0.27 3.3V / 10kΩ = 0.33mA 3 OUT 0 4 IN 100 0.27 1.11 Total: 2.71mA www.maximintegrated.com Maxim Integrated │  25 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators SUPPLY CURRENT PER OUTPUT CHANNEL vs. DATA RATE SUPPLY CURRENT PER INPUT CHANNEL vs. DATA RATE fig09 2.5 VDDB = 1.8V SUPPLY CURRENT (mA) SUPPLY CURRENT (mA) VDDB = 2.5V 2.5 2 1.5 1 VDDA = 1.8V VDDA = 2.5V 0.5 VDDA = 3.3V VDDA = 5.0V 0 fig10 3 0 25 50 75 100 125 150 175 VDDB = 5.0V 2 CL = 0pF 1.5 1 0.5 0 200 VDDB = 3.3V 0 25 50 75 100 125 150 175 200 DATA RATE (Mbps) DATA RATE (Mbps) Figure 9. Supply Current Per Input Channel (Estimated) Figure 10. Supply Current Per Output Channel (Estimated) 2.5V 3.3V VDDA VDDB MAX22345C ENB 20Mbps 20Mbps IN1 OUT1 10pF 2.5V IN2 OUT2 10kΩ IN3 OUT3 100Mbps 100Mbps OUT4 IN4 15pF ENA DEFA DEFB GNDA GNDB Figure 11. Example Circuit for Supply Current Calculation www.maximintegrated.com Maxim Integrated │  26 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators Typical Operating Circuits 3.3V 5V VDDA VDDB MAX22344B/C 0.1µF ENB IN1 OUT1 IN2 OUT2 IN3 OUT3 IN4 OUT4 DEFA DEFB GNDA GNDB 3.3V 5V VDDB 0.1µF VDDA MAX22344B/C 0.1µF 5V VOUT 24V DIGITAL I/O WITH 5V INTERFACE GPIO PORT 0.1µF 24V ENB OUT1 IN1 OUT2 IN2 OUT3 IN3 OUT4 IN4 DEFB DEFA GNDB GNDA ISOLATED DIGITAL I/O www.maximintegrated.com Maxim Integrated │  27 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators Typical Operating Circuits (continued) 2.5V 3.3V VDDA 0.1µF VDDB 0.1µF MAX22345R/S ENB CS IN1 OUT1 CS MICROCONTROLLER SCLK OUT2 IN2 SCLK MOSI ADC MISO MOSI MISO IN3 OUT3 OUT4 IN4 ENA DEFA DEFB GNDA GNDB ISOLATED SPI INTERFACE www.maximintegrated.com Maxim Integrated │  28 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators Typical Operating Circuits (continued) 5V 2.5V VDDA MAX22346B/C 0.1µF VDDB IN1 OUT1 IN2 OUT2 OUT3 IN3 OUT4 IN4 0.1µF T1IN T2IN R1OUT MAX13223 RS-232 TRANSCEIVER MICROCONTROLLER ENB R2OUT ENA DEFA DEFB GNDA GNDB ISOLATED RS-232 INTERFACE www.maximintegrated.com Maxim Integrated │  29 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators Product Selector Guide MAX2234 4 B A A P + Channel Configuration 4: 4/0 5: 3/1 6: 2/2 Maximum Data Rate ENA Polarity (see Table) MAXIMUM DATA RATE ENA ENA 25Mbps 200Mbps B C R S Temp Range: -40º C to +125º C Package: SSOP Pins: 20 Lead-Free/RoHS compliant Ordering Information PART CHANNEL CONFIGURATION DATA RATE (Mbps) ENA POLARITY ISOLATION VOLTAGE (kVRMS) TEMP RANGE (°C) PINPACKAGE MAX22344BAAP+* 4/0 25 – 3.75 -40 to +125 20 SSOP MAX22344CAAP+ 4/0 200 – 3.75 -40 to +125 20 SSOP MAX22345BAAP+* 3/1 25 Active-High 3.75 -40 to +125 20 SSOP MAX22345CAAP+* 3/1 200 Active-High 3.75 -40 to +125 20 SSOP MAX22345RAAP+* 3/1 25 Active-Low 3.75 -40 to +125 20 SSOP MAX22345SAAP+ 3/1 200 Active-Low 3.75 -40 to +125 20 SSOP MAX22346BAAP+* 2/2 25 Active-High 3.75 -40 to +125 20 SSOP MAX22346CAAP+* 2/2 200 Active-High 3.75 -40 to +125 20 SSOP *Future product—contact factory for availability. +Denotes a lead(Pb)-free/RoHS-compliant package. Chip Information PROCESS: BiCMOS www.maximintegrated.com Maxim Integrated │  30 MAX22344/MAX22345/ MAX22346 Reinforced, Fast, Low-Power, Four-Channel 3.75kVRMS Digital Isolators Revision History REVISION NUMBER REVISION DATE PAGES CHANGED 0 2/18 Initial release 1 10/18 Updated title, added future product designation to MAX22344CAAP+ and removed it from MAX22345SAAP+ in the Ordering Information table. 2 2/19 Removed future product designation from MAX22344CAAP+ in the Ordering Information table. DESCRIPTION — 1–30 30 For pricing, delivery, and ordering information, please visit Maxim Integrated’s online storefront at https://www.maximintegrated.com/en/storefront/storefront.html. Maxim Integrated cannot assume responsibility for use of any circuitry other than circuitry entirely embodied in a Maxim Integrated product. No circuit patent licenses are implied. Maxim Integrated reserves the right to change the circuitry and specifications without notice at any time. The parametric values (min and max limits) shown in the Electrical Characteristics table are guaranteed. Other parametric values quoted in this data sheet are provided for guidance. Maxim Integrated and the Maxim Integrated logo are trademarks of Maxim Integrated Products, Inc. © 2019 Maxim Integrated Products, Inc. │  31
MAX22344CAAP+ 价格&库存
很抱歉,暂时无法提供与“MAX22344CAAP+”相匹配的价格&库存,您可以联系我们找货
