INND-SS56 Series
0.56” SMD Single Digit Display
Features
Description
0.56” (14.20mm) Matrix Height
The INND-SS56 series is a 0.56” single digit display. It
Black/Grey Face , White Segment
IC compatible, Easy assembly
Dynamic drive connect
RoHS Compliant, Pb Free
is a SMD type LED display which can be used in
various applications.
Common Anode
Common Cathode
Applications
Consumer Electronics
Industrial Equipment
Figure 1. INND-SS56 series Internal Circuit Diagram
Package Dimensions
Figure 2. INND-SS56 series Package Dimensions
Inolux Corporation
Proprietary & Confidential
Page 1
July12, 2017
www.inolux-corp.com
INND-SS56 Series
Absolute Maximum Rating at 25oC (Note 1)
Derate From
Product
(Per Segment)
Emission
Color
INND-SS56YGXX
Yellow
Green
AlGaInP
70
25
90
5
0.33
-40 C~+105 C
INND-SS56YXX
Yellow
AlGaInP
70
25
90
5
0.33
-40 C~+105 C
INND-SS56AXX
Amber
AlGaInP
70
25
90
5
0.33
-40 C~+105 C
INND-SS56RXX
Red
AlGaInP
70
25
90
5
0.33
-40 C~+105 C
INND-SS56DRXX
Deep Red
AlGaInP
70
25
90
5
0.33
-40 C~+105 C
INND-SS56GXX
Green
InGaN
114
30
100
5
0.4
-40 C~+105 C
INND-SS56BXX
Blue
InGaN
114
30
100
5
0.4
-40 C~+105 C
INND-SS56WXX
White
InGaN
114
30
100
5
0.4
-40 C~+105 C
Technology Pd (mW) IF (mA) IFP* (mA) VR (V)
25°C (mA/°C)
TOP (oC)
TST (oC)
o
o
-40 C~+105 C
o
o
o
o
-40 C~+105 C
o
o
o
o
-40 C~+105 C
o
o
o
o
-40 C~+105 C
o
o
o
o
-40 C~+105 C
o
o
o
o
-40 C~+105 C
o
o
o
o
-40 C~+105 C
o
o
o
o
-40 C~+105 C
o
o
Notes
1. Condition for IFP is pulse of 1/10 duty and 0.1msec width
Inolux Corporation
Page 2
July12, 2017
www.inolux-corp.com
INND-SS56 Series
Electrical Characteristics T
A
= 25°C (Note 1)
VF(V)@20mA
Product
(Per Segment)
Emission
Color
INND-SS56YGXX
λ(nm)@20mA
I*V(mcd)@10mA
IR(μA)@VR=5V
IV-M @IF
=10mA
min
typ.
max
λD
λP
min
typ.
max
max
max
Yellow
Green
2.0
2.8
570
572
3
100
2:1
INND-SS56YXX
Yellow
2.0
2.8
590
592
17
100
2:1
INND-SS56AXX
Amber
2.0
2.8
605
612
18
100
2:1
INND-SS56RXX
Red
2.0
2.8
630
644
9
100
2:1
INND-SS56DRXX
Deep Red
2.0
2.8
645
660
8
100
2:1
INND-SS56GXX
Green
3.2
3.8
525
70
100
2:1
INND-SS56BXX
Blue
3.2
3.8
465
12
50
2:1
INND-SS56WXX
White
3.2
3.8
X: 0.27
Y: 0.25
60
50
2:1
Notes
1. Performance guaranteed only under conditions listed in above tables.
ESD Precaution
ATTENTION: Electrostatic Discharge (ESD) protection
The symbol above denotes that ESD precaution is needed. ESD protection for GaP and AlGaAs based chips is necessary even
though they are relatively safe in the presence of low static-electric discharge. Parts built with AlInGaP, GaN, or/and InGaN based
chips are STATIC SENSITIVE devices. ESD precaution must be taken during design and assembly.
If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process.
Please be advised that normal static precautions should be taken in the handling and assembly of this device to prevent damage or degradation which
may be induced by electrostatic discharge (ESD).
Inolux Corporation
Page 3
July12, 2017
www.inolux-corp.com
INND-SS56 Series
Characteristic Curves for YG, Y, A, R, DR, G
Inolux Corporation
Page 4
July12, 2017
www.inolux-corp.com
INND-SS56 Series
Characteristic Curves for B
Inolux Corporation
Page 5
July12, 2017
www.inolux-corp.com
INND-SS56 Series
Characteristic Curves for W
Inolux Corporation
Page 6
July12, 2017
www.inolux-corp.com
INND-SS56 Series
Chromaticity Bin (for White only)
Inolux Corporation
Page 7
July12, 2017
www.inolux-corp.com
INND-SS56 Series
Ordering Information
Product
INND-SS56YGXX
INND-SS56YXX
INND-SS56AXX
INND-SS56RXX
Inolux Corporation
Emission Color
Yellow Green
Yellow
Amber
Red
Technology
AlGaInP
AlGaInP
AlGaInP
AlGaInP
I*V(mcd)
@10mA
2
17
18
19
Page 8
VF(V)
@20mA
2.0
Polarity
Face
Color
Orderable
Part Number
Common
Anode
Black
INND-SS56YGAB
Common
Cathode
Black
INND-SS56YGCB
Common
Anode
Grey
INND-SS56YGAG
Common
Cathode
Grey
INND-SS56YGCG
Common
Anode
Black
INND-SS56YAB
Common
Cathode
Black
INND-SS56YCB
Common
Anode
Grey
INND-SS56YAG
Common
Cathode
Grey
INND-SS56YCG
Common
Anode
Black
INND-SS56AAB
Common
Cathode
Black
INND-SS56ACB
Common
Anode
Grey
INND-SS56AAG
Common
Cathode
Grey
INND-SS56ACG
Common
Anode
Black
INND-SS56RAB
Common
Cathode
Black
INND-SS56RCB
Common
Anode
Grey
INND-SS56RAG
Common
Cathode
Grey
INND-SS56RCG
2.0
2.0
2.0
July12, 2017
www.inolux-corp.com
INND-SS56 Series
Product
INND-SS56DRXX
INND-SS56GXX
INND-SS56BXX
INND-SS56WXX
Inolux Corporation
Emission
Color
Deep Red
Green
Blue
White
Technology
AlGaInP
InGaN
InGaN
InGaN
I*V(mcd)
@10mA
8
70
12
60
Page 9
VF(V)
@20mA
Polarity
Face
Color
Orderable
Part Number
Common
Anode
Black
INND-SS56DRAB
Common
Cathode
Black
INND-SS56DRCB
Common
Anode
Grey
INND-SS56DRAG
Common
Cathode
Grey
INND-SS56DRCG
Common
Anode
Black
INND-SS56GAB
Common
Cathode
Black
INND-SS56GCB
Common
Anode
Grey
INND-SS56GAG
Common
Cathode
Grey
INND-SS56GCG
Common
Anode
Black
INND-SS56BAB
Common
Cathode
Black
INND-SS56BCB
Common
Anode
Grey
INND-SS56BAG
Common
Cathode
Grey
INND-SS56BCG
Common
Anode
Black
INND-SS56WAB
Common
Cathode
Black
INND-SS56WCB
Common
Anode
Grey
INND-SS56WAG
Common
Cathode
Grey
INND-SS56WCG
2.0
3.2
3.2
3.2
July12, 2017
www.inolux-corp.com
INND-SS56 Series
Label Specifications
Inolux P/N:
I
N
N
D
S
Display
Type
Inolux
S
Display Type
ND =
Numeric
Display
S: SMD Type
S: Single
5
6
Dimension
56 = 0.56”
Display Height
X
X
X
Color
Polarity
Face
Color
YG: 570 nm
Y: 590 nm
A: 605 nm
R: 630 nm
DR: 660 nm
G: 525 nm
B: 465 nm
W:
X: 0.27
Y: 0.25
A = Common
Anode
C=Common
Cathode
X
X
X
X
Customized
Stamp-off
B = Black
G = Grey
Lot No.:
Z
Internal
Tracker
Inolux Corporation
2
7
Year (2017, 2018, …..)
Page 10
01
24
001
Month
Date
Serial
July12, 2017
www.inolux-corp.com
INND-SS56 Series
Reflow Soldering
Soldering Iron
Basic Spec is ≦ 4 sec. when 260°C (+10°C -1 second). Power dissipation of Iron should be
less than 15W. Surface temperature should be under 230°C
Rework
Rework should be completed within 4 second under 245°C
Inolux Corporation
Page 11
July12, 2017
www.inolux-corp.com
INND-SS56 Series
Revision History
Changes since last revision
Initial Release
Page
Version No.
1.0
Revision Date
07-12-2017
DISCLAIMER
INOLUX reserves the right to make changes without further notice to any products herein to improve reliability, function or design. INOLUX does not
assume any liability arising out of the application or use of any product or circuit described herein; neither does it convey any license under its patent
rights, nor the rights of others.
LIFE SUPPORT POLICY
INOLUX’s products are not authorized for use as critical components in life support devices or systems without the express written approval of the
President of INOLUX or INOLUX CORPORATION. As used herein:
1. Life support devices or systems are devices or systems which, (a) are intended for surgical implant into the body, or (b) support or sustain life,
and (c) whose failure to perform when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to
result in a significant injury of the user.
2. A critical component in any component of a life support device or system whose failure to perform can be reasonably expected to cause the
failure of the life support device or system, or to affect its safety or effectiveness.
Inolux Corporation
Page 12
July12, 2017
www.inolux-corp.com
很抱歉,暂时无法提供与“INND-SS56YGAG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+14.15880
- 200+5.64840
- 750+5.46480
- 1500+5.36760
