CMM-4030D-261-I2S-TR
    CUIDEVICES
CMM-4030D-261-I2S-TR 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 11/01/2021 page 1 of 8 MODEL: CMM-4030D-261-I2S-TR │ DESCRIPTION: MEMS MICROPHONE FEATURES • I²S technology • digital • omnidirectional ELECTRICAL parameter conditions/description directivity omnidirectional sensitivity (S) at 1 kHz, 1 Pa supply voltage (VDD) min typ max units -27 -26 -25 dB FS 1.6 current consumption (IDD) at normal mode at low power mode clock frequency (FCLOCK) at normal mode at low power mode sensitivity reduction no change across voltage range 1.0 150 frequency (f) 1.8 3.6 V 0.75 0.40 1.0 mA mA 3.0 4.0 800 MHz kHz 100 10,000 59 Hz signal to noise ratio (S/N) at 20 kHz bandwidth (A-weighted) total harmonic distortion (THD) at 94 dB SPL, 1 kHz, Rload > 2 kΩ 0.1 % acoustic overload point (AOP) at 94 dB SPL, 1 kHz, Rload > 2 kΩ 124 dB SPL power supply rejection (PSR) dBA -72 power-up time 6 dB FS(A) 20 ms DIGITAL INTERFACE parameter conditions/description min typ 0 low voltage input (L/R, WS, SCK) (VIL) max units 0.25xVDD V high voltage input (L/R, WS, SCK) (VIH) 0.7xVDD VDD V high voltage output (SD) (VOL) 0.1xVDD 0.3xVDD V high voltage output (SD) (VOH) 0.7xVDD 0.9xVDD V Notes: 1. All specifications measured at 25°C, humidity at 45±5%, L/R pins grounded, VDD = 1.8 V, FCLOCK = 3.072 MHz, unless otherwise noted. cuidevices.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI Devices │ MODEL: CMM-4030D-261-I2S-TR │ DESCRIPTION: MEMS MICROPHONE date 11/01/2021 │ page 2 of 8 TIMING CHARACTERISTICS Parameter Description Min Normal Max. Unit tSCH SCK high -- 50 -- ns tSCL SCK low -- 50 -- ns tSCP SCK period -- 325 -- ns fSCK SCK frequency -- 3.072 -- MHz tWSS WS setup -- 0 -- ns tWSH WS hold -- 20 -- ns fWS WS frequency -- 48 -- kHz cuidevices.com Additional Resources: Product Page | 3D Model CUI Devices │ MODEL: CMM-4030D-261-I2S-TR │ DESCRIPTION: MEMS MICROPHONE | PCB Footprint date 11/01/2021 │ page 3 of 8 RECOMMENDED INTERFACE CIRCUIT I²S DATA INTERFACE The serial data is in slave mode I²S format, which has 24-bit depth in a 32 bit word. In a stereoframe there are 64 SCK cycles, or 32 SCK cycles per data-word. When L/R=0, the output data in the left channel, while L/R=Vdd, data in the right channel. The output data pin (SD) is tri-stated after the LSB is output so that another microphone can drive the common data line. DATA WORD LENGTH The output data-word length is 24 bits per channel. The Mic must always have 64 clock cycles for every stereo data-word(fSCK=64 x fWS). DATA WORD FORMAT The default data format is I²S, MSB-first. In this format, the MSB of each word delayed by one SCK cycle from the start of each half-frame. cuidevices.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI Devices │ MODEL: CMM-4030D-261-I2S-TR │ DESCRIPTION: MEMS MICROPHONE date 11/01/2021 │ page 4 of 8 ENVIRONMENTAL parameter conditions/description min operating temperature storage temperature in packaging RoHS yes max units -20 typ 70 °C -40 100 °C max units MECHANICAL parameter conditions/description dimensions 4.0 x 3.0 x 1.25 acoustic port top terminals surface mount min typ mm weight 0.03 g MECHANICAL DRAWING units: mm tolerance: length, width, height: ±0.10 mm acoustic port: ±0.05 mm unless otherwise specified: ±0.15 mm TERMINAL CONNECTIONS TERM. SYM FUNCTION DESCRIPTION 1 GND ground 2 N/C -- 3 WS input Serial Data-Word Select for I²S Interface. 4 CHIPEN input Microphone enable. When set low(ground), the microphone is disabled and put in power-down mode. When set high (VDD), the microphone is enabled. 5 L/R input Left/Right Channel Select. When set low, the microphone outputs its signal in the left channel of the I²S frame; when set high, the microphone outputs its signal in the right channel. 6 SCK input Serial Data Clock for I²S Interface. 7 SD output Serial Data Output for I²S Interface. This pin tristates when not actively driving the appropriate output channel. The SD trace should have a 100 kΩ pull-down resistor to discharge the line during the time that all microphones on the bus have tristated their outputs. 8 VDD power 1.8 to 3.3 V. This pin should be decoupled to Pin 1 with a 0.1 μF capacitor and a 10 µF capacitor. Connect to ground on the PCB. Do not connect cuidevices.com Additional Resources: Product Page | 3D Model CUI Devices │ MODEL: CMM-4030D-261-I2S-TR │ DESCRIPTION: MEMS MICROPHONE MECHANICAL DRAWING (CONTINUED) Recommended PCB Layout Top View FREQUENCY RESPONSE CURVE cuidevices.com | PCB Footprint date 11/01/2021 │ page 5 of 8 Additional Resources: Product Page | 3D Model | PCB Footprint CUI Devices │ MODEL: CMM-4030D-261-I2S-TR │ DESCRIPTION: MEMS MICROPHONE date 11/01/2021 │ page 6 of 8 SOLDERABILITY parameter conditions/description reflow soldering2 see reflow profile Note: min typ max units 260 °C 2. Not recommended to exceed 3 reflow cycles. 20~40 s 260 Temperature (°C) 3°C/s max ramp up 217 6°C/s max ramp down 60~150 s 200 150 60~120 s 25 480 s max Time (sec) HANDLING RECOMMENDATIONS 1. Not recommnended to blow air heavily over acoustic port as debris could impact mic function. 2. Not suitable for wash process after reflow. 3. Not recommended to brush board with or without solvents after reflow process. 4. Not recommended to directly expose to ultrasonic processing or cleaning. 5. Not recommended to inserty any object in port of device at any time. 6. Not recommended to apply over 30 psi of air pressure into the port hole. 7. Not recommended to pull a vacuum over port hole. 8. Not recommended to apply a vacuum when repackaging into sealed bag a rate faster than 0.5 atm/sec. 9. Not recommended to clean table or carried plate with air guarding system that could induce particle floating inside mic. Recommended Vacuum Nozzle Pickup Top View cuidevices.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI Devices │ MODEL: CMM-4030D-261-I2S-TR │ DESCRIPTION: MEMS MICROPHONE date 11/01/2021 │ page 7 of 8 PACKAGING parameter conditions/description MSL Class 2a reel size Ø7 inches reel QTY3 1,100 pcs per reel carton size 310 x 210 x 165 mm carton QTY 5,500 pcs Note: min typ max units 3. The leader tape of the reel, and the beginning tape fixed into the reel center, will leave 25 blank cavities each. Item W E F ØD0 K0 DIM(mm) 12.0±0.30 1.75±0.10 5.50±0.10 1.50+0.10/-0 1.25±0.10 Item P0 10P0 P1 A0 B0 DIM(mm) 4.0±0.10 40.0±0.20 8.0±0.10 3.80±0.10 2.95±0.10 Item P2 T -- -- -- DIM(mm) 2.0±0.10 0.25±0.05 -- -- -- Carton Box (5Reel) cuidevices.com Additional Resources: Product Page | 3D Model CUI Devices │ MODEL: CMM-4030D-261-I2S-TR │ DESCRIPTION: MEMS MICROPHONE | PCB Footprint date 11/01/2021 │ page 8 of 8 REVISION HISTORY rev. description date 1.0 initial release 08/12/2020 1.01 updated datasheet 11/01/2021 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
CMM-4030D-261-I2S-TR 价格&库存
很抱歉,暂时无法提供与“CMM-4030D-261-I2S-TR”相匹配的价格&库存,您可以联系我们找货
