SNA-03-000
SNA-03-000
    COSEL
    SNA-03-000
SNA-03-000 数据手册
Ordering information Ripple noise attenuation type for switch mode power supplies(DC) SNA series (1A,3A) SNA -03 -223 1 2 3 -O 4 1 Model Name 2 Rated Current 3 Line to ground capacitor code:See table 1.1. R table1.1 Line to ground capacitor code Code Line to ground capacitor (nominal value) 000 Not Provided 223 22000pF 4 Options D :DIN rail installation type * The dimensions change when the option is set. Refer to External view. DIN rail installation type is option Features of SNA series (1A and 3A) Ripple noise attenuation type for switch mode power supplies(DC) -±50 VDC -Best filter for switch mode power supplies of analog circuits (ex. power supply filter for an operational amplifier) Specifications No. SNA-01-223 Items SNA-03-223 Interface:Connector 1 Rated Voltage DC[V] ±50 (+Vin - COM-in, -Vin - COM-in) 2 Rated Current DC[A] 1 3 Test Voltage (Terminal-Mounting Plate) 500 VAC (Cutoff Current = 100mA), 1minute at room temperature and humidity 3 4 Isolation Resistance (Terminal-Mounting Plate) 500 VDC 50MW min at room temperature and humidity 5 DC resistance 190mW max 6 Operating temperature -40 to +71C (Refer to Derating Curve) 7 Operating humidity 20 to 95%RH (Non condensing) 8 Storage temperature/humidity -40 to +75C/20 to 95%RH (Non condensing) 9 Vibration 10 to 55Hz, 19.6m/s2(2G), 3min. Period, 1hour each X, Y and Z axis 10 Impact 196.1m/s2(20G), 11ms Once each X, Y and Z axis 11 Safety agency approvals UL60950-1, C-UL (CSA60950-1), IEC60950-1 12 Case size (without projection) /Weight 52X35X93 mm [2.05X1.38X3.66 inches] (WXHXD) /130g max (Option : -D refer to external view) Circuit Diagram Derating Curve +Vout + 100 OUT Co COM-out COM-in + Co -Vin -Vout CY CY : Line to ground capacitor Co : Electrolytic capacitor 80 60 40 20 0 -40 : Mounting Plate ¡Expected life : 10 years SN-1 Load Factor [%] CY +Vin IN 90mW max February 04, 2022 -30 -20 -10 0 40 50 Ambient Temperature [C] 60 70 71 80 SNA series (1A,3A) External view Standard Type 2-f4.5 Mounting Hole [0.18] CN1 Pin No. 1,2 CN3 4 [1.57] 40 ±0.5 52 [2.05] CN1 1 CN2 Pin No. 1,2 1 4 4 1 1 CN2 3,4 Function I/O Connector CN1~CN4 B4B-XH-AM Function -Vout COM-out 3,4 Mating connector Terminal Reel:SXH-001T-P0.6 Bulk:BXH-001T-P0.6 XHP-4 82 ±0.5 (Mfr:J.S.T) [3.23] Mounting Plate COM-out +Vout CN4 Pin No. 1,2 -Vin COM-in 3,4 CN4 Function 1,2 COM-in +Vin 3,4 4 Name Plate CN3 Pin No. Function Option harness : Refer to Instruction Manual 4 93 [3.66] ¶ Tolerance : ±1 [±0.04] ¶ PCB Material /thickness : CEM3 /1.6mm [0.06 inches] [1.38] 35 ¶ Weight : 130g max ¶ Mounting plate : Iron (surface finishing : nickel plating) t=1.0 [0.04] ¶ Case : PBT ¶ Dimensions in mm, [ ]=inches ¶ Keeping drawing current per pin below 2A for CN1 to CN4 1 1 4 4 1 1 CN4 3,4 CN2 Pin No. 1,2 3,4 3,4 XHP-4 Function -Vout COM-out Terminal Mating connector Mounting Plate Reel:SXH-001T-P0.6 Bulk:BXH-001T-P0.6 (Mfr:J.S.T) [3.31] Option harness : Refer to Instruction Manual 4 87.5 FG 3,4 Function Function COM-out +Vout CN4 Pin No. 1,2 -Vin COM-in I/O Connector 84 1,2 COM-in +Vin CN1~CN4 B4B-XH-AM M4 CN3 Pin No. Function 1,2 52 Name Plate CN2 [0.39] 10 4 CN3 4 [2.05] CN1 CN1 Pin No. OUT IN DIN rail installation Type [3.44] ¶ Tolerance : ±1 [±0.04] ¶ Weight : 140g max 35 [1.38] ¶ PCB Material /thickness : CEM3 /1.6mm [0.06 inches] ¶ Mounting plate : Iron (surface finishing : nickel plating) t=1.0 [0.04] 8 [0.31] ¶ Case : PBT ¶ Dimensions in mm, [ ]=inches (9) [0.35] ¶ Keeping drawing current per pin below 2A for CN1 to CN4 DIN rail ¡Note when installing the EMI/EMC Filter on a DIN rail. IN CN1 CN2 4 1 4 1 When the EMI/EMC Filter is grounded through the DIN rail, the proper noise attenuation may not be achieved. Be sure to connect the FG terminal of the EMI/ EMC Filter body to the earth. DIN rail Name Plate CN3 4 1 4 1 CN4 OUT February 04, 2022 SN-2 Ordering information Ripple noise attenuation type for switch mode power supplies(DC) SNA series (6A) SNA -06 -223 1 2 3 -O 4 1 Model Name 2 Rated Current 3 Line to ground capacitor code:See table 1.1. R table1.1 Line to ground capacitor code Code Line to ground capacitor (nominal value) 000 Not Provided 223 22000pF 4 Options D :DIN rail installation type T :Terminal block type DT :Terminal block and DIN rail type Terminal block type DIN rail installation type * The dimensions change when the option is set. Refer to External view. DIN rail installation type and Terminal block type are option Features of SNA series (6A) Ripple noise attenuation type for switch mode power supplies(DC) -±50 VDC -Best filter for switch mode power supplies of analog circuits (ex. power supply filter for an operational amplifier) Specifications No. SNA-06-223 Items Interface:Connector 1 Rated Voltage DC[V] ±50 (+Vin - COM-in, -Vin - COM-in) 2 Rated Current DC[A] 6 3 Test Voltage (Terminal-Mounting Plate) 500 VAC (Cutoff Current = 100mA), 1minute at room temperature and humidity 4 Isolation Resistance (Terminal-Mounting Plate) 500 VDC 50MW min at room temperature and humidity 5 DC resistance 50mW max 6 Operating temperature -40 to +71C (Refer to Derating Curve) 7 Operating humidity 20 to 95%RH (Non condensing) 8 Storage temperature/humidity -40 to +75C/20 to 95%RH (Non condensing) 9 Vibration 10 to 55Hz, 19.6m/s2 (2G), 3min. Period, 1hour each X, Y and Z axis 10 Impact 196.1m/s2 (20G), 11ms Once each X, Y and Z axis 11 Safety agency approvals UL60950-1, C-UL (CSA60950-1), IEC60950-1 12 Case size (without projection) /Weight 52X35X117 mm [2.05X1.38X4.61 inches] (WXHXD) /150g max (Option : -D, -T, -DT refer to external view) Circuit Diagram Derating Curve +Vout + IN 100 OUT Co COM-out COM-in + Co -Vin -Vout CY CY : Line to ground capacitor Co : Electrolytic capacitor 80 60 40 20 0 -40 : Mounting Plate ¡Expected life : 10 years SN-3 Load Factor [%] CY +Vin February 04, 2022 -30 -20 -10 0 40 50 Ambient Temperature [C] 60 70 71 80 SNA series (6A) External view Terminal block Type 40 ±0.5 +Vin COM-in -Vin +Vout COM-out -Vout TB2 Name Plate CN4 106 ±0.5 106 ±0.5 [4.17] Mounting Plate TB1 6.2 1 CN2 [0.18] Mounting Hole [0.24] 1 1 4 52 Name Plate CN3 [1.57] 4 [2.05] 4 1 4 [1.57] 52 [2.05] 40 ±0.5 CN1 2-f4.5 6-M3 7.6 2-f4.5 [0.18] Mounting Hole [0.3] Standard Type 117 117 [4.61] 35 35 [1.38] [1.38] [4.61] Terminal cover [4.17] Mounting Plate CN3 Pin No. 1,2 3,4 CN4 Pin No. 1,2 3,4 CN1 Pin No. Function 1,2 COM-in 3,4 +Vin CN2 Pin No. Function 1,2 -Vin COM-in 3,4 Function COM-out +Vout Function -Vout COM-out ¶ Tolerance : ±1 [±0.04] ¶ Weight : 150g max ¶ PCB Material /thickness : CEM3 /1.6mm [0.06 inches] ¶ Mounting plate : Iron (surface finishing : nickel plating) t=1.0 [0.04] ¶ Case : PBT ¶ Dimensions in mm, [ ]=inches ¶ Keeping drawing current per pin below 5A for CN1 to CN4 Terminal I/O Connector Mating connector CN1~CN4 B4P-VH VHR-4N Reel:SVH-21T-P1.1 Bulk:BVH-21T-P1.1 ¶ Tolerance : ±1 [±0.04] ¶ Weight : 160g max ¶ PCB Material /thickness : CEM3 /1.6mm [0.06 inches] ¶ Mounting plate : Iron (surface finishing : nickel plating) t=1.0 [0.04] ¶ Case : PBT ¶ Dimensions in mm, [ ]=inches ¶ Terminal block screw tighting torque M3:0.8N-m (8.5kgf-cm) max (Mfr:J.S.T) Option harness : Refer to Instruction Manual 4 DIN rail installation Type Terminal block type+DIN rail installation Type 108.5 M4 FG Mounting Plate 112 8 35 Function -Vout COM-out [2.05] [0.31] [1.38] ¶ Tolerance : ±1 [±0.04] ¶ Weight : 160g max ¶ PCB Material /thickness : CEM3 / 1.6mm [0.06 inches] ¶ Mounting plate : Iron (surface finishing : nickel plating) t=1.0 [0.04] ¶ Case : PBT ¶ Dimensions in mm, [ ]=inches ¶ Keeping drawing current per pin below 5A for CN1 to CN4 (9) Function COM-out +Vout 7.6 112 DIN rail [0.35] 8 CN3 Pin No. 1,2 3,4 CN4 Pin No. 1,2 3,4 Terminal cover [4.41] [0.31] 35 [1.38] (9) [0.35] CN1 Pin No. Function 1,2 COM-in 3,4 +Vin CN2 Pin No. Function 1,2 -Vin COM-in 3,4 Mounting Plate [4.27] [4.41] DIN rail +Vout COM-out -Vout 52 108.5 M4 FG [4.27] TB2 OUT IN [0.39] 1 CN4 CN2 Name Plate [0.3] 1 4 TB1 [0.24] 1 +Vin COM-in -Vin 10 10 [0.39] 1 4 CN3 4 6.2 Name Plate [2.05] 4 OUT CN1 52 IN 6-M3 Terminal I/O Connector Mating connector CN1~CN4 B4P-VH VHR-4N Reel:SVH-21T-P1.1 Bulk:BVH-21T-P1.1 ¶ Tolerance : ±1 [±0.04] ¶ Weight : 170g max ¶ PCB Material /thickness : CEM3 /1.6mm [0.06 inches] ¶ Mounting plate : Iron (surface finishing : nickel plating) t=1.0 [0.04] ¶ Case : PBT ¶ Dimensions in mm, [ ]=inches ¶ Terminal block screw tighting torque M3:0.8N-m (8.5kgf-cm) max (Mfr:J.S.T) Option harness : Refer to Instruction Manual 4 ¡Note when installing the EMI/EMC Filter on a DIN rail. IN CN1 CN2 4 1 4 1 When the EMI/EMC Filter is grounded through the DIN rail, the proper noise attenuation may not be achieved. Be sure to connect the FG terminal of the EMI/ EMC Filter body to the earth. DIN rail Name Plate CN3 4 1 4 1 CN4 OUT February 04, 2022 SN-4
SNA-03-000 价格&库存
很抱歉,暂时无法提供与“SNA-03-000”相匹配的价格&库存,您可以联系我们找货
SNA-03-000
  • 1+255.054641+33.05994
SNA-03-000
库存:10
SNA-03-000
    • 1+345.40560
    • 200+137.81880
    • 500+133.21800
