ZUW62415
ZUW62415
    COSEL
    插件,44.5x28mm
    ZUW62415
ZUW62415 数据手册
Ordering information DC-DC Converters PCB Mount type ZUW1R5 ZU 1 W 2 1R5 3 12 4 1Series name 2Dual output 3Output wattage 4Input voltage 5Output voltage R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT ZUW1R50512 1.56 VOLTAGE[V] t12 or +24 CURRENT[A] 0.065 ZUW1R50515 1.50 t15 or +30 0.050 ZUW1R51212 1.56 t12 or +24 0.065 ZUW1R51215 1.50 t15 or +30 0.050 SPECIFICATIONS ZU/ZT MODEL VOLTAGE[V] *1 CURRENT[A] INPUT *1 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] *2 RIPPLE[mVp-p] OUTPUT RIPPLE NOISE[mVp-p] *2 TEMPERATURE REGULATION[mV] -20 to +55C *3 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] PROTECTION OVERCURRENT PROTECTION CIRCUIT INPUT-OUTPUT ISOLATION INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT SAFETY AGENCY APPROVALS CASE SIZE/WEIGHT OTHERS COOLING METHOD *1 *2 *3 * * ZUW1R52412 1.56 t12 or +24 0.065 ZUW1R52415 1.50 t15 or +30 0.050 ZUW1R54812 1.56 t12 or +24 0.065 ZUW1R54815 1.50 t15 or +30 0.050 Output pins can be connected in series to make a 24V/30V output. ZUW1R50512 DC4.5 - 9 0.466typ 67typ t12 (+24) ZUW1R50515 ZUW1R51212 DC9 - 18 0.448typ 0.183typ 67typ 71typ t15 (+30) t12 (+24) ZUW1R51215 ZUW1R52412 DC18 - 36 0.176typ 0.092typ 71typ 71typ t15 (+30) t12 (+24) ZUW1R52415 ZUW1R54812 DC36 - 72 0.088typ 0.046typ 71typ 71typ t15 (+30) t12 (+24) ZUW1R54815 0.044typ 71typ t15 (+30) 0.050 75max 750max 120max 150max 180max 60max 0.065 0.050 0.065 0.050 0.065 0.050 0.065 60max 75max 60max 75max 60max 75max 60max 600max 750max 600max 750max 600max 750max 600max 120max 120max 120max 120max 120max 120max 120max 150max 150max 150max 150max 150max 150max 150max 150max 180max 150max 180max 150max 180max 150max 50max 60max 50max 60max 50max 60max 50max 20max (Minimum input, Io=100%) Fixed 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 Works over 105% of rating and recovers automatically AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -20 to +71C, 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -40 to +85C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each X, Y and Z axis UL60950-1, EN60950-1, CSA C22.2 No.60950-1 Complies with IEC60950-1 27.5X7X18mm (WXHXD) / 10g max Convection Rated input 5V, 12V, 24V or 48V DC, Io=100%. Measured by 20MHz oscilloscope. The drift is a change at 25C of ambient temperature and 30 minutes - 8 hours after the input voltage applied at rated input/output. The output specification is at t12V and t15V. Series/Parallel operation with other model is not possible. ZU/ZT-18 12 5 June 29, 2011 ZUW1R5 External view ¶Recomended size for processing PCB 2-B part ¶Specification at A part 4 8.89 (9.305) 11.43 (8.035) 2.5 21.59 (2.955) 1 ±0.1 (1.25) 21.59 2.5 [0.7] [0.5] 17.78 12.7 6.35 8.89 [0.25] 6.35 [0.25] 6.35 5-º1.5 [0.25] [0.35] ±0.1 2.7 5-º 1 ¶Specification at B part 0.4 7 ±0.3 2-A part (2.54) -V 0.4 OUT -V 17.78 +V 18 COM Size between case pins 6.35 6.35 +V Name plate IN Outline (1.25) (0.5) 27.5 (TOP VIEW) (19.465) (1.25) 2-º1.6 (1.25) [0.85] ¶Weight: 10g or less. ¶Tolerance: ± 0.5 ¶Case material: Brass The converter is in contact with the slanted area of the P.C.B. To keep mm ¶Dimensions in isolation, adequate wiring on the mounted side is required. ¶Div.: 0.1inch [inch] Performance data ¡STATIC CHARACTERISTICS (ZUW1R50515) ¡RISE TIME & FALL TIME (ZUW1R50515:+15V) ZU/ZT ¡OVERCURRENT CHARACTERISTICS (ZUW1R50515) ¡DERATING CURVE OUTPUT VOLTAGE V 15 10 5 (-)Io=100% 0 0.05 0.10 OUTPUT CURRENT(+) 0.15 A June 29, 2011 ZU/ZT-19 Ordering information DC-DC Converters PCB Mount type ZUW3 ZU 1 W 2 3 3 12 4 1Series name 2Dual output 3Output wattage 4Input voltage 5Output voltage R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT ZUW30512 3.12 VOLTAGE[V] t12 or +24 CURRENT[A] 0.13 ZUW30515 3.00 t15 or +30 0.10 ZUW31212 3.12 t12 or +24 0.13 ZUW31215 3.00 t15 or +30 0.10 SPECIFICATIONS ZU/ZT MODEL VOLTAGE[V] *1 CURRENT[A] INPUT *1 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] *2 RIPPLE[mVp-p] OUTPUT RIPPLE NOISE[mVp-p] *2 TEMPERATURE REGULATION[mV] -20 to +55C *3 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] PROTECTION OVERCURRENT PROTECTION CIRCUIT INPUT-OUTPUT ISOLATION INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT SAFETY AGENCY APPROVALS CASE SIZE/WEIGHT OTHERS COOLING METHOD *1 *2 *3 * * ZUW32412 3.12 t12 or +24 0.13 ZUW32415 3.00 t15 or +30 0.10 ZUW34812 3.12 t12 or +24 0.13 ZUW34815 3.00 t15 or +30 0.10 Output pins can be connected in series to make a 24V/30V output. ZUW30512 DC4.5 - 9 0.891typ 70typ t12 (+24) ZUW30515 ZUW31212 DC9 - 18 0.857typ 0.351typ 70typ 74typ t15 (+30) t12 (+24) ZUW31215 ZUW32412 DC18 - 36 0.338typ 0.176typ 74typ 74typ t15 (+30) t12 (+24) ZUW32415 ZUW34812 DC36 - 72 0.169typ 0.087typ 74typ 75typ t15 (+30) t12 (+24) ZUW34815 0.083typ 75typ t15 (+30) 0.10 75max 750max 120max 150max 180max 60max 0.13 0.10 0.13 0.10 0.13 0.10 0.13 60max 75max 60max 75max 60max 75max 60max 600max 750max 600max 750max 600max 750max 600max 120max 120max 120max 120max 120max 120max 120max 150max 150max 150max 150max 150max 150max 150max 150max 180max 150max 180max 150max 180max 150max 50max 60max 50max 60max 50max 60max 50max 20max (Minimum input, Io=100%) Fixed 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 Works over 105% of rating and recovers automatically AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -20 to +71C, 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -40 to +85C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each X, Y and Z axis UL60950-1, EN60950-1, CSA C22.2 No.60950-1 Complies with IEC60950-1 35X7X23mm (WXHXD) / 16g max Convection Rated input 5V, 12V, 24V or 48V DC, Io=100%. Measured by 20MHz oscilloscope. The drift is a change at 25C of ambient temperature and 30 minutes - 8 hours after the input voltage applied at rated input/output. The output specification is at t12V and t15V. Series/Parallel operation with other model is not possible. ZU/ZT-20 12 5 June 29, 2011 ZUW3 External view ¶Recomended size for processing PCB (TOP VIEW) (9.245) 16.51 (2.895) 29.21 5-º 1 ±0.1 ¶Specification at B part 2.5 1 ±0.1 (1.25) [0.9] [0.6] [0.25] (1.25) 16.51 22.86 7.62 (0.3) 15.24 6.35 0.4 0.4 ¶Specification at A part 2-º1.6 [0.3] (3.81) 2-B part 4 7 ±0.3 2-A part -V 5-º1.5 [0.65] 29.21 2.5 2.7 OUT IN 7.62 23 +V 22.86 7.62 7.62 +V COM Size between case pins Name plate -V Outline (1.25) (1.25) (0.5) 35 [1.15] ¶Weight: 16g or less. ¶Tolerance: ± 0.5 ¶Case material: Brass The converter is in contact with the slanted area of the P.C.B. To keep isolation, adequate wiring on the mounted side is required. mm ¶Dimensions in ¶Div.: 0.1inch [inch] Performance data ¡STATIC CHARACTERISTICS (ZUW30515) ¡RISE TIME & FALL TIME (ZUW30515:+15V) ZU/ZT ¡OVERCURRENT CHARACTERISTICS (ZUW30515) ¡DERATING CURVE June 29, 2011 ZU/ZT-21 Ordering information DC-DC Converters PCB Mount type ZUW6 ZU 1 W 2 6 3 12 4 1Series name 2Dual output 3Output wattage 4Input voltage 5Output voltage R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT ZUW60512 6.00 VOLTAGE[V] t12 or +24 CURRENT[A] 0.25 ZUW60515 6.00 t15 or +30 0.20 ZUW61212 6.00 t12 or +24 0.25 ZUW61215 6.00 t15 or +30 0.20 SPECIFICATIONS ZU/ZT MODEL VOLTAGE[V] *1 CURRENT[A] INPUT *1 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] *2 RIPPLE[mVp-p] OUTPUT RIPPLE NOISE[mVp-p] *2 TEMPERATURE REGULATION[mV] -20 to +55C *3 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] PROTECTION OVERCURRENT PROTECTION CIRCUIT INPUT-OUTPUT ISOLATION INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT SAFETY AGENCY APPROVALS CASE SIZE/WEIGHT OTHERS COOLING METHOD *1 *2 *3 * * ZUW62412 6.00 t12 or +24 0.25 ZUW62415 6.00 t15 or +30 0.20 ZUW64812 6.00 t12 or +24 0.25 ZUW64815 6.00 t15 or +30 0.20 Output pins can be connected in series to make a 24V/30V output. ZUW60512 DC4.5 - 9 1.60typ 75typ t12 (+24) ZUW60515 ZUW61212 DC9 - 18 1.60typ 0.65typ 75typ 77typ t15 (+30) t12 (+24) ZUW61215 ZUW62412 DC18 - 36 0.65typ 0.33typ 77typ 77typ t15 (+30) t12 (+24) ZUW62415 ZUW64812 DC36 - 72 0.33typ 0.17typ 77typ 77typ t15 (+30) t12 (+24) ZUW64815 0.17typ 77typ t15 (+30) 0.20 75max 750max 120max 150max 180max 60max 0.25 0.20 0.25 0.20 0.25 0.20 0.25 60max 75max 60max 75max 60max 75max 60max 600max 750max 600max 750max 600max 750max 600max 120max 120max 120max 120max 120max 120max 120max 150max 150max 150max 150max 150max 150max 150max 150max 180max 150max 180max 150max 180max 150max 50max 60max 50max 60max 50max 60max 50max 20max (Minimum input, Io=100%) Fixed 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 Works over 105% of rating and recovers automatically AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -20 to +71C, 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -40 to +85C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each X, Y and Z axis UL60950-1, EN60950-1, CSA C22.2 No.60950-1 Complies with IEC60950-1 44.5X7X28mm (WXHXD) / 25g max Convection Rated input 5V, 12V, 24V or 48V DC, Io=100%. Measured by 20MHz oscilloscope. The drift is a change at 25C of ambient temperature and 30 minutes - 8 hours after the input voltage applied at rated input/output. The output specification is at t12V and t15V. Series/Parallel operation with other model is not possible. ZU/ZT-22 12 5 June 29, 2011 ZUW6 External view ¶Recomended size for processing PCB (TOP VIEW) ¶Specification at A part 25.4 (3.2) 38.1 5- º1 0.4 ±0.1 2.5 2.7 (9.55) ¶Specification at B part 0.4 2-B part 4 7 ±0.3 2-A part 6.35 [0.25] ¶Weight: 25g or less. ¶Tolerance: ± 0.5 ¶Case material: Brass (1.25) 25.4 (1.25) [1.1] [0.8] 27.94 [0.4] 5-º1.5 [1] 38.1 2.5 1 ±0.1 2-º1.6 10.16 (3.81) -V (1.25) [0.6] OUT IN 15.24 15.24 28 COM 27.94 10.16 10.16 +V -V Outline (1.25) +V Size between case pins Name plate 20.32 (0.5) 44.5 [1.5] The converter is in contact with the slanted area of the P.C.B. To keep isolation, adequate wiring on the ¶Dimensions in mm mounted side is required. ¶Div.: 0.1inch [inch] Performance data ¡STATIC CHARACTERISTICS (ZUW60515) OUTPUT VOLTAGE (+)Io=100% (-)Io=100% 10 50 40 30 5 20 Ripple RIPPLE mVp-p OUTPUT VOLTAGE V 15 ¡RISE TIME & FALL TIME (ZUW60515:+15V) ZU/ZT 10 0 5 INPUT VOLTAGE 10 V ¡OVERCURRENT CHARACTERISTICS (ZUW60515) ¡DERATING CURVE June 29, 2011 ZU/ZT-23 Ordering information DC-DC Converters PCB Mount type ZUW10 ZU 1 W 2 10 3 12 4 1Series name 2Dual output 3Output wattage 4Input voltage 5Output voltage R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT ZUW100512 8.4 VOLTAGE[V] t12 or +24 CURRENT[A] 0.35 ZUW100515 9.0 t15 or +30 0.30 ZUW101212 10.8 t12 or +24 0.45 ZUW101215 10.5 t15 or +30 0.35 SPECIFICATIONS ZU/ZT MODEL VOLTAGE[V] *1 CURRENT[A] INPUT *1 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] *2 RIPPLE[mVp-p] OUTPUT RIPPLE NOISE[mVp-p] *2 TEMPERATURE REGULATION[mV] -20 to +55C *3 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] PROTECTION OVERCURRENT PROTECTION CIRCUIT INPUT-OUTPUT ISOLATION INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT SAFETY AGENCY APPROVALS CASE SIZE/WEIGHT OTHERS COOLING METHOD *1 *2 *3 * * ZUW102412 10.8 t12 or +24 0.45 ZUW102415 10.5 t15 or +30 0.35 ZUW104812 10.8 t12 or +24 0.45 ZUW104815 10.5 t15 or +30 0.35 Output pins can be connected in series to make a 24V/30V output. ZUW100512 DC4.5 - 9 2.24typ 75typ t12 (+24) ZUW100515 ZUW101212 DC9 - 18 2.40typ 1.12typ 75typ 81typ t15 (+30) t12 (+24) ZUW101215 ZUW102412 DC18 - 36 1.09typ 0.56typ 81typ 81typ t15 (+30) t12 (+24) ZUW102415 ZUW104812 DC36 - 72 0.55typ 0.28typ 81typ 81typ t15 (+30) t12 (+24) ZUW104815 0.28typ 81typ t15 (+30) 0.35 75max 750max 120max 150max 180max 60max 0.35 0.30 0.45 0.35 0.45 0.35 0.45 60max 75max 60max 75max 60max 75max 60max 600max 750max 600max 750max 600max 750max 600max 120max 120max 120max 120max 120max 120max 120max 150max 150max 150max 150max 150max 150max 150max 150max 180max 150max 180max 150max 180max 150max 50max 60max 50max 60max 50max 60max 50max 20max (Minimum input, Io=100%) Fixed 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 Works over 105% of rating and recovers automatically AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -20 to +71C, 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -40 to +85C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each X, Y and Z axis UL60950-1, EN60950-1, CSA C22.2 No.60950-1 Complies with IEC60950-1 45X7X35mm (WXHXD) / 40g max Convection Rated input 5V, 12V, 24V or 48V DC, Io=100%. Measured by 20MHz oscilloscope. The drift is a change at 25C of ambient temperature and 30 minutes - 8 hours after the input voltage applied at rated input/output. The output specification is at t12V and t15V. Series/Parallel operation with other model is not possible. ZU/ZT-24 12 5 June 29, 2011 ZUW10 External view ¶Recomended size for processing PCB 38.1 5-º1 ±0.1 1 (1.25) 25.4 (1.25) [1.35] 34.29 [1.1] [0.25] 5-º1.5 [1] 38.1 34.29 2.5 ±0.1 27.94 [0.55] 13.97 6.35 0.4 2.5 25.4 ¶Specification at B part 0.4 4 7 ±0.3 ¶Specification at A part 2.7 2-B part 2-A part (3.18) -V 20.32 OUT IN -V Size between case pins 20.32 35 COM 13.97 13.97 +V +V (3.45) Outline (1.25) (1.25) [0.8] Name plate (9.8) (TOP VIEW) 2-º1.6 (0.5) 45 [1.5] ¶Weight: 40g or less. ¶Tolerance: ± 0.5 ¶Case material: Brass The converter is in contact with the slanted area of the P.C.B. To keep isolation, adequate wiring on the ¶Dimensions in mm mounted side is required. ¶Div.: 0.1inch [inch] Performance data ¡STATIC CHARACTERISTICS (ZUW100515) ¡RISE TIME & FALL TIME (ZUW100515:+15V) ZU/ZT ¡OVERCURRENT CHARACTERISTICS (ZUW100515) ¡DERATING CURVE June 29, 2011 ZU/ZT-25 Ordering information DC-DC Converters PCB Mount type ZUW15 ZU 1 W 2 15 3 12 4 1Series name 2Dual output 3Output wattage 4Input voltage 5Output voltage R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT ZUW150512 14.4 VOLTAGE[V] t12 or +24 CURRENT[A] 0.6 ZUW150515 15.0 t15 or +30 0.5 ZUW151212 15.6 t12 or +24 0.65 ZUW151215 15.0 t15 or +30 0.5 SPECIFICATIONS ZU/ZT MODEL VOLTAGE[V] *1 INPUT CURRENT[A] *1 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] *2 RIPPLE[mVp-p] RIPPLE NOISE[mVp-p] *2 OUTPUT TEMPERATURE REGULATION[mV] 0 to +55C *3 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION PROTECTION OVERVOLTAGE PROTECTION CIRCUIT REMOTE ON/OFF INPUT-OUTPUT ISOLATION INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT SAFETY AGENCY APPROVALS CASE SIZE/WEIGHT OTHERS COOLING METHOD *1 *2 *3 * * ZUW152412 15.6 t12 or +24 0.65 ZUW152415 15.0 t15 or +30 0.5 ZUW154812 15.6 t12 or +24 0.65 ZUW154815 15.0 t15 or +30 0.5 Output pins can be connected in series to make a 24V/30V output. ZUW150512 DC4.5 - 9 3.56typ 81typ t12 (+24) ZUW150515 ZUW151212 DC9 - 18 3.70typ 1.57typ 81typ 83typ t15 (+30) t12 (+24) ZUW151215 ZUW152412 DC18 - 36 1.51typ 0.78typ 83typ 83typ t15 (+30) t12 (+24) ZUW152415 ZUW154812 DC36 - 75 0.75typ 0.39typ 83typ 83typ t15 (+30) t12 (+24) ZUW154815 0.38typ 83typ t15 (+30) 0.50 75max 750max 120max 150max 180max 60max 0.60 0.50 0.65 0.50 0.65 0.50 0.65 60max 75max 60max 75max 60max 75max 60max 600max 750max 600max 750max 600max 750max 600max 120max 120max 120max 120max 120max 120max 120max 150max 150max 150max 150max 150max 150max 150max 150max 180max 150max 180max 150max 180max 150max 50max 60max 50max 60max 50max 60max 50max 100max (Minimum input, Io=100%) Internally fixed (TRM pin open),t5% adjustable by external VR 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 Works over 105% of rating and recovers automatically Works at 115 - 140% of rating (Total of +V and -V) Between RC and -side of input:short - 1.2V ---output ON, 2.4V - 5.5V(or open)---output OFF, Compatible to TTL AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -20 to +71C, 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -40 to +85C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each X, Y and Z axis UL60950-1, EN60950-1, CSA C22.2 No.60950-1 Complies with IEC60950-1 45X8.5X50mm (WXHXD) / 55g max Convection Rated input 5V, 12V, 24V or 48V DC, Io=100%. Measured by 20MHz oscilloscope. The drift is a change at 25C of ambient temperature and 30 minutes - 8 hours after the input voltage applied at rated input/output. The output specification is at t12V and t15V. Series/Parallel operation with other model is not possible. ZU/ZT-26 12 5 June 29, 2011 ZUW15 External view ¶Recomended size for processing PCB 45 Name plate (4.72) 35.56 note 7- º 1 (5) [0.3] 7.62 5.08 [0.3] 7.62 [0.2] [0.2] 35.56 (5) ±0.1 note)Internal parts ¶Weight: 55g or less. ¶Tolerance: ± 0.5 ¶Case material: Aluminum (5) 1 (5) (4.68) (5) 1 4 8.5± 0.3 (4.68) 7.62 (5) -V TRM 5.08 15.24 5.08 -V RC 7-º1.5 [0.2] [0.6] OUT 5.08 7.62 IN 5.08 15.24 5.08 50 +V COM (5) +V (TOP VIEW) Outline (5) (5) (5) (5) [1.4] (5) The converter is in contact with the slanted area of the P.C.B. To keep isolation, adequate wiring on the ¶Dimensions in mm mounted side is required. ¶Div.: 0.2inch [inch] Performance data ¡STATIC CHARACTERISTICS (ZUW151212) ¡RISE TIME & FALL TIME (ZUW151212:+12V) ZU/ZT ¡OVERCURRENT CHARACTERISTICS (ZUW151212) ¡DERATING CURVE June 29, 2011 ZU/ZT-27 Ordering information DC-DC Converters PCB Mount type ZUW25 ZU 1 W 2 25 3 12 4 1Series name 2Dual output 3Output wattage 4Input voltage 5Output voltage R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT ZUW250512 20.2 VOLTAGE[V] t12 or +24 CURRENT[A] 0.84 ZUW250515 20.1 t15 or +30 0.67 ZUW251212 25.2 t12 or +24 1.05 ZUW251215 25.5 t15 or +30 0.85 SPECIFICATIONS ZU/ZT MODEL VOLTAGE[V] *1 INPUT CURRENT[A] *1 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] *2 RIPPLE[mVp-p] RIPPLE NOISE[mVp-p] *2 OUTPUT TEMPERATURE REGULATION[mV] 0 to +55C *3 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION PROTECTION OVERVOLTAGE PROTECTION CIRCUIT REMOTE ON/OFF INPUT-OUTPUT ISOLATION INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT SAFETY AGENCY APPROVALS CASE SIZE/WEIGHT OTHERS COOLING METHOD *1 *2 *3 * * ZUW252412 25.2 t12 or +24 1.05 ZUW252415 25.5 t15 or +30 0.85 ZUW254812 25.2 t12 or +24 1.05 ZUW254815 25.5 t15 or +30 0.85 Output pins can be connected in series to make a 24V/30V output. ZUW250512 DC4.5 - 9 4.92typ 82typ t12 (+24) ZUW250515 ZUW251212 DC9 - 18 4.90typ 2.47typ 82typ 85typ t15 (+30) t12 (+24) ZUW251215 ZUW252412 DC18 - 36 2.50typ 1.23typ 85typ 85typ t15 (+30) t12 (+24) ZUW252415 ZUW254812 DC36 - 75 1.25typ 0.62typ 85typ 85typ t15 (+30) t12 (+24) ZUW254815 0.63typ 85typ t15 (+30) 0.85 75max 750max 120max 150max 180max 60max 0.84 0.67 1.05 0.85 1.05 0.85 1.05 60max 75max 60max 75max 60max 75max 60max 600max 750max 600max 750max 600max 750max 600max 120max 120max 120max 120max 120max 120max 120max 150max 150max 150max 150max 150max 150max 150max 150max 180max 150max 180max 150max 180max 150max 50max 60max 50max 60max 50max 60max 50max 100max (Minimum input, Io=100%) Internally fixed (TRM pin open), t5% adjustable by external VR 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 Works over 105% of rating and recovers automatically Works at 115 - 140% of rating (Total of +V and -V) Between RC and -side of input:short - 1.2V ---output ON, 2.4V - 5.5V(or open)---output OFF, Compatible to TTL AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -20 to +71C, 20 - 95%RH (Non condensing) (Refer to DERATING CURVE), 3,000m (10,000feet) max -40 to +85C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each X, Y and Z axis UL60950-1, EN60950-1, CSA C22.2 No.60950-1 Complies with IEC60950-1 65X8.5X50mm (WXHXD) / 65g max Convection Rated input 5V, 12V, 24V or 48V DC, Io=100%. Measured by 20MHz oscilloscope. The drift is a change at 25C of ambient temperature and 30 minutes - 8 hours after the input voltage applied at rated input/output. The output specification is at t12V and t15V. Series/Parallel operation with other model is not possible. ZU/ZT-28 12 5 June 29, 2011 ZUW25 External view ¶Recomended size for processing PCB 65 (TOP VIEW) Name plate (4.56) (4.68) 1 (5) 1 4 8.5± 0.3 note note 55.88 7-º 1 ±0.1 note)Internal parts ¶Weight: 65g or less. ¶Tolerance: ± 0.5 ¶Case material: Aluminum [0.3] [0.2] 7.62 5.08 [0.3] 7.62 [0.2] 5.08 (5) 7-º1.5 (5) 5.08 7.62 -V TRM (5) (5) [0.2] [0.6] COM 5.08 15.24 5.08 OUT (5) 15.24 IN -V RC 7.62 5.08 50 +V (5) +V (4.68) Outline (5) (5) (5) 55.88 (5) [2.2] (5) The converter is in contact with the slanted area of the P.C.B. To keep isolation, adequate wiring on the ¶Dimensions in mm mounted side is required. ¶Div.: 0.2inch [inch] Performance data ¡STATIC CHARACTERISTICS (ZUW251212) ¡RISE TIME & FALL TIME (ZUW251212:+12V) ZU/ZT ¡OVERCURRENT CHARACTERISTICS (ZUW251212) ¡DERATING CURVE June 29, 2011 Powered by TCPDF (www.tcpdf.org) ZU/ZT-29
ZUW62415 价格&库存
很抱歉,暂时无法提供与“ZUW62415”相匹配的价格&库存,您可以联系我们找货
