PCA600F-32-T
PCA600F-32-T
    COSEL
    PCA600F-32-T 是一款封闭式AC-DC电源模块,输入电压范围为85-264VAC,输出电压为32V,最大输出电流为20A。该模块具备多种保护功能,包括过流保护、过压保护等,并且符合多种安全标...
PCA600F-32-T 数据手册
AC-DC Power Supplies Enclosed Type Medical electric equipment Power Factor Correction World wide Safety Approvals EMI Inrush current limiting OCP OVP Remote ON/OFF Parallel Operation 1U PCA-series PCA300F PCA600F PCA1000F Feature Up to 5-year warranty (Refer to Instruction Manual) Low profile (41mm, 1.61 inch = meet 1U height) Universal input 85 - 264VAC (Refer to “Input vltage Derating”) DC input 88 - 370VDC possible : Excluding PCA1000F and PCA1500F (Refer to “Input vltage Derating”) For medical electric equipment (ANSI/AAMI ES60601-1, EN60601-1 3rd) Medical Isolation Grade 2MOPP With AUX output 12V 0.1A (Voltage adjustable range 5 - 12V) Constant current function Output voltage can be adjusted to near 0V (the item 2.6 on Instruction Manual) With various alarms Parallel Operation / N+1 Parallel Redundancy Operation possible Monitoring function and various setting values can be changed by communication (the item 2.11 on Instruction Manual) Safety agency approval -UL62368-1, C-UL (CSA62368-1), EN62368-1, ANSI/AAMI ES60601-1, EN60601-1 3rd PCA1500F CE marking Low Voltage Directive RoHS Directive EMI -PCA300F, PCA600F Complies with FCC-B, CISPR32-B, EN55011-B, EN55032-B, VCCI-B -PCA1000F, PCA1500F Complies with FCC-A, CISPR32-A, EN55011-A, EN55032-A, VCCI-A EMS Compliance : EN61204-3, EN61000-6-2 IEC60601-1-2 (2014), EN60601-1-2 (2015) EN61000-4-2 EN61000-4-3 EN61000-4-4 EN61000-4-5 EN61000-4-6 EN61000-4-8 EN61000-4-11 April 02, 2021 PCA-1 AC-DC Power Supplies Enclosed Type PCA300F Ordering information PC 1 A 300 F 2 3 4 Example recommended EMI/EMC filter NAC-06-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series Low profile type : EAC series 2MOPP * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. -5 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional *7 C : with Coating G : Low leakage current T : Terminal Block Style I : with PMBus interface F2 : Reverse air exhaust type P3 : Master-slave Operation W1 : Alarm function For option details, refer to instruction manual 6.1. Terminal Block Style *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT PCA300F-5 300 5V 60A PCA300F-12 324 12V 27A PCA300F-15 330 15V 22A PCA300F-24 336 24V 14A PCA300F-32 320 32V 10A PCA300F-48 336 48V 7A SPECIFICATIONS MODEL [VAC] [VDC] ACIN 100V ACIN 230V VOLTAGE CURRENT[A] *1 FREQUENCY[Hz] (Io=50%) (Io=100%) EFFICIENCY[%] INPUT (Io=50%) ACIN 230V (Io=100%) ACIN 100V POWER FACTOR ACIN 230V ACIN 100V*2 INRUSH CURRENT[A] ACIN 230V*2 LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +50C *3*4 RIPPLE[mVp-p] -20 to 0C *3 0 to +50C *3*4 RIPPLE NOISE[mVp-p] OUTPUT -20 to 0C *3 0 to +50C *4 TEMPERATURE REGULATION[mV] -20 to +50C *4 *5 DRIFT[mV] START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION[V] PROTECTION REMOTE SENSING CIRCUIT AND REMOTE ON/OFF (RC) OTHERS DC_OK LAMP ALARM LAMP COMMUNICATION FUNCTION INPUT-OUTPUT INPUT-FG ISOLATION OUTPUT-FG OUTPUT - AUX-RC-PG-INFO-DS-ADDR0-ADDR1-ADDR2 OPERATING TEMP.,HUMIDITY.AND ALTITUDE STORAGE TEMP.,HUMIDITY.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT ACIN 100V SAFETY AND NOISE REGULATIONS PCA-2 AGENCY APPROVALS CONDUCTED NOISE HARMONIC ATTENUATOR *6 PCA300F-5 PCA300F-12 PCA300F-15 PCA300F-24 PCA300F-32 PCA300F-48 85 - 264 1f 88 - 370 3.8typ 1.6typ 50/60 (45 - 66) 86typ 87typ 87typ 88typ 88typ 88typ 87typ 88typ 88typ 89typ 89typ 89typ 87typ 88typ 88typ 89typ 89typ 89typ 89typ 90typ 90typ 91typ 91typ 91typ 0.98typ (Io=100%) 0.95typ (Io=100%) 20/40 typ (Io=100%) (Primary inrush current / Secondary inrush current) (More than 3 sec. to re-start) 40/40 typ (Io=100%) (Primary inrush current / Secondary inrush current) (More than 3 sec. to re-start) 0.5max (ACIN 240V 60Hz, Io=100%, According to IEC60601-1) 5 12 15 24 32 48 60 27 22 14 10 7 20max 48max 60max 96max 128max 192max 40max 100max 120max 150max 150max 480max 160max 240max 240max 240max 320max 480max 280max 320max 320max 320max 420max 640max 240max 300max 300max 300max 400max 600max 320max 360max 360max 360max 480max 720max 50max 120max 150max 240max 320max 480max 75max 180max 180max 290max 400max 600max 20max 48max 60max 96max 128max 192max 700typ (ACIN 100/230V Io=100%) 20typ (ACIN 230V Io=80%) / 16typ (ACIN 230V Io=100%) 3.00 to 6.00 7.20 to 14.40 9.00 to 18.00 14.40 to 28.80 19.20 to 38.40 28.80 to 57.60 5.00 to 5.05 12.00 to 12.12 15.00 to 15.15 24.00 to 24.24 32.00 to 32.32 48.00 to 48.48 Works over 105% of rating (Recovers automatically, Hiccup overcurrent) 6.25 to 7.00 15.00 to 16.80 18.75 to 21.00 30.00 to 33.60 40.00 to 44.80 60.00 to 67.20 Provided Provided LED (Blue) LED (Orange) Provided (Extended UART) AC4,000V 1minute, Cutoff current = 10mA, DC500V 50MΩ min (At Room Temperature) 2MOPP AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MΩ min (At Room Temperature) 1MOPP AC500V 1minute, Cutoff current = 100mA, DC500V 50MΩ min (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MΩ min (At Room Temperature) -20 to +70C, 20 - 90%RH (Non condensing) -20 to +75C, 20 - 90%RH (Non condensing) 10 - 55Hz 19.6m/s2 (2G) 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G) 11ms, once each X, Y and Z axis UL62368-1, EN62368-1, C-UL (equivalent to CAN/CSA-C22.2 No.62368-1), ANSI/AAMI ES60601-1, EN60601-1 3rd, C-UL (equivalent to CAN/CSA-C22.2 No.60601-1), Complies with IEC60601-1-2 4th Ed. Complies with FCC Part15 classB, VCCI-B, CISPR32-B, EN55011-B, EN55032-B Complies with IEC61000-3-2 (class A) April 02, 2021 PCA300F SPECIFICATIONS CASE SIZE/WEIGHT COOLING METHOD OTHERS 89X41X152mm [3.50X1.61X5.98 inches] (without terminal block and screw) (WXHXD) / 840g max Forced cooling (internal fan) *1 DC input safety agency approvals deleted. *2 The value is primary surge. The current of input surge to a built-in EMI/EMS Filter(0.2ms or less) is excluded. *3 Measured by 20MHz oscilloscope or Ripple-Noise meter (equivalent to KEISOKUGIKEN:RM103). Please refer to the instruction manual 1.2. *4 5V output product, the maximum temperature of 40C. *5 Drift is the change in DC output for an eight hours period after a half-hour warm-up at 25C. *6 Please contact us about another class. *7 The listed options may affect the published standard specifications. Please contact us for detailed product specifications and safety approvals. * A sound may occur from power supply at pulse loading. Features - Low profile (41mm, 1.61 inch = meet 1U height) - Universal input 85 - 264VAC - DC input 88 - 370VDC possible - For medical electric equipment (ANSI/AAMI ES60601-1, EN60601-1 3rd, IEC60601-1-2 4th Ed.) - Medical Isolation Grade 2MOPP - With AUX output 12V 0.1A (Voltage adjustable range 5 12V) - Constant current function - Output voltage can be adjusted to near 0V (the item 2.6 on Instruction Manual) - With various alarms - Parallel Operation / N+1 Parallel Redundancy Operation possible - Monitoring function and various setting values can be changed by communication (the item 2.11 on Instruction Manual) - Complies with SEMI F47 (the item 2.1 on Instruction Manual) Block diagram AC(L) AC IN 85 - 264V FUSE 250V10A AC(N) NOISE FILTER INRUSH CURRENT LIMIT RECTIFIER SWITCHING DEVICE RECTIFIER AND FILTER 250V10A FG CURRENT SENSING CONTROL TRANSFORMER FAN INTERNAL REGULATOR AUX (12V0.1A) TRANSFORMER REGULATOR RECTIFIER AND FILTER INVERTER ±S (Remote sensing) Photocoupler OVER VOLTAGE PROTECTION CURRENT SENSING DC OUT RC (Remote ON/OFF) PG (Alarm) CB (Current balance) Photocoupler CONTROL DS (Data Shared signal) CONTROL THERMAL PROTECTION Photocoupler VTRM (Adjustment of output voltage) ITRM (Adjustment of output current) INFO (Extended UART) Photocoupler April 02, 2021 PCA-3 PCA300F External view 2-M4 (Depth:6mm max) Mounting Hole 7 7 [0.28] [0.28] [0.28] 7 14.5 16 [0.63] 20.5 [0.81] 14.5 [0.57] [0.57] 13 [0.51] 39 [2.99] Name plate 2-M4 (Depth:6mm max) Mounting Hole (Bottom side) 44.5 [1.75] M4 89 [3.50] [0.34] 8.6 [2.31] 58.75 64.5 [2.54] 57.5 10 [0.79] 76±0.5 M4 CN1 [0.10] 2.5 14.5 [0.57] 32.5 35 [1.38] 4 [0.16] [1.28] 24 [0.94] 87±0.5 [3.43] 152 [5.98] 2-M3 2-M4 (Depth:6mm max) Mounting Hole 2-f8.5 PCA-4 20.5 [0.16] 4 ¶ Tolerance : ±1 [±0.04] ¶ Weight : 840g max ¶ PCB Material / thickness : FR-4 / 1.6mm [0.06] ¶ Chassis Material : Aluminum ¶ Fan cover Material : PBT ¶ Dimensions in mm, [ ] = inches ¶ Mounting torque : 1.2N-m max ¶ Input and output terminal screw tightening torque M3 0.6N-m max M4 1.6N-m max ¶ Please connect safety ground to FG terminal on the unit. [0.81] [0.33] 41 15.5 9 [0.35] 24 [0.94] 39 [1.54] April 02, 2021 76±0.5 [2.99] [1.61] [1.32] Output voltage adjustable potentiometer 16.5 33.6 [0.61] LED(Alarm) Orange LED(DC OK) Blue [0.65] Output terminal(+) [0.39] AC(L) AC(N) FG CN2 CN4 CN3 Output terminal(-) 20max Terminal cover [2.26] [0.51] 10.3 12.85 [0.41] [1.54] AIR FLOW PCA300F External view 20.5 [0.81] 2-M4 (Depth:6mm max) Mounting Hole 39 [0.53] 33.6 44.5 [1.75] M4 89 [3.50] 64.5 [2.54] 13 [0.51] 8.6 (f14.2) [0.34] [0.56] 10 13.35 LED(Alarm) Orange LED(DC OK) Blue Output voltage adjustable potentiometer M5 M5 [1.32] Name plate 2-M4 (Depth:6mm max) Mounting Hole (Bottom side) 15 57.5 [0.39] CN1 [0.79] [2.99] 9 [0.35] 28max 35 [1.38] [1.10] 87±0.5 [3.43] 152 [5.98] 2-M4 (Depth:6mm max) Mounting Hole 20.5 ¶ Tolerance : ±1 [±0.04] ¶ Weight : 840g max ¶ PCB Material / thickness : FR-4 / 1.6mm [0.06] ¶ Chassis Material : Aluminum ¶ Fan cover Material : PBT ¶ Dimensions in mm, [ ] = inches ¶ Mounting torque : 1.2N-m max ¶ Input and output terminal screw tightening torque M4 1.6N-m max M5 2.5N-m max ¶ Please connect safety ground to FG terminal on the unit. [0.81] 41 Terminal cover [1.61] Output terminal(+) [2.26] AC(L) AC(N) FG CN2 CN4 CN3 Output terminal(-) 20max Terminal cover 76±0.5 [0.59] [0.51] 10.3 12.85 [0.41] [1.54] 39 [1.54] April 02, 2021 AIR FLOW 76±0.5 [2.99] PCA-5 AC-DC Power Supplies Enclosed Type PCA600F Ordering information PC 1 A 600 F 2 3 4 Example recommended EMI/EMC filter NAC-16-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series Low profile type : EAC series 2MOPP * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. -5 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional *7 C : with Coating G : Low leakage current T : Terminal Block Style (Only 12V, 15V, 24V, 32V and 48V) I : with PMBus interface F2 : Reverse air exhaust type P3 : Master-slave Operation W1 : Alarm function For option details, refer to instruction manual 6.1. Terminal Block Style *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT PCA600F-5 600 5V 120A PCA600F-12 636 12V 53A PCA600F-15 645 15V 43A PCA600F-24 648 24V 27A PCA600F-32 640 32V 20A PCA600F-48 624 48V 13A SPECIFICATIONS MODEL [VAC] [VDC] ACIN 100V ACIN 230V VOLTAGE CURRENT[A] *1 FREQUENCY[Hz] (Io=50%) (Io=100%) (Io=50%) ACIN 230V (Io=100%) ACIN 100V POWER FACTOR ACIN 230V ACIN 100V*2 INRUSH CURRENT[A] ACIN 230V*2 LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +50C *3*4 RIPPLE[mVp-p] -20 to 0C *3 0 to +50C *3*4 RIPPLE NOISE[mVp-p] OUTPUT -20 to 0C *3 0 to +50C *4 TEMPERATURE REGULATION[mV] -20 to +50C *4 *5 DRIFT[mV] START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION[V] PROTECTION REMOTE SENSING CIRCUIT AND REMOTE ON/OFF (RC) OTHERS DC_OK LAMP ALARM LAMP COMMUNICATION FUNCTION INPUT-OUTPUT INPUT-FG ISOLATION OUTPUT-FG OUTPUT - AUX-RC-PG-INFO-DS-ADDR0-ADDR1-ADDR2 OPERATING TEMP.,HUMIDITY.AND ALTITUDE STORAGE TEMP.,HUMIDITY.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT AGENCY APPROVALS SAFETY AND NOISE CONDUCTED NOISE REGULATIONS HARMONIC ATTENUATOR *6 ACIN 100V INPUT PCA-6 EFFICIENCY[%] PCA600F-5 PCA600F-12 PCA600F-15 PCA600F-24 PCA600F-32 PCA600F-48 85 - 264 1f (Output derating is required at less than 90V. Refer to “Derating” ) 88 - 370 (Output derating is required at less than 110V. Refer to “Derating” ) 7.3typ 3.2typ 50/60 (45 - 66) 90typ 91typ 91typ 91typ 91typ 91typ 89typ 90typ 90typ 91typ 91typ 91typ 92typ 92typ 92typ 93typ 93typ 93typ 91typ 92typ 92typ 93typ 93typ 93typ 0.98typ (Io=100%) 0.95typ (Io=100%) 20/40 typ (Io=100%) (Primary inrush current / Secondary inrush current) (More than 3 sec. to re-start) 40/40 typ (Io=100%) (Primary inrush current / Secondary inrush current) (More than 3 sec. to re-start) 0.5max (ACIN 240V 60Hz, Io=100%, According to IEC60601-1) 5 12 15 24 32 48 120 53 43 27 20 13 20max 48max 60max 96max 128max 192max 40max 100max 120max 150max 150max 480max 160max 240max 240max 240max 320max 480max 280max 320max 320max 320max 420max 640max 240max 300max 300max 300max 400max 600max 320max 360max 360max 360max 480max 720max 50max 120max 150max 240max 320max 480max 75max 180max 180max 290max 400max 600max 20max 48max 60max 96max 128max 192max 700typ (ACIN 100/230V Io=100%) 20typ (ACIN 230V Io=80%) / 16typ (ACIN 230V Io=100%) 3.00 to 6.00 7.20 to 14.40 9.00 to 18.00 14.40 to 28.80 19.20 to 38.40 28.80 to 57.60 5.00 to 5.05 12.00 to 12.12 15.00 to 15.15 24.00 to 24.24 32.00 to 32.32 48.00 to 48.48 Works over 105% of rating (Recovers automatically, Hiccup overcurrent) 6.25 to 7.00 15.00 to 16.80 18.75 to 21.00 30.00 to 33.60 40.00 to 44.80 60.00 to 67.20 Provided Provided LED (Blue) LED (Orange) Provided (Extended UART) AC4,000V 1minute, Cutoff current = 10mA, DC500V 50MΩ min (At Room Temperature) 2MOPP AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MΩ min (At Room Temperature) 1MOPP AC500V 1minute, Cutoff current = 100mA, DC500V 50MΩ min (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MΩ min (At Room Temperature) -20 to +70C, 20 - 90%RH (Non condensing) -20 to +75C, 20 - 90%RH (Non condensing) 10 - 55Hz 19.6m/s2 (2G) 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G) 11ms, once each X, Y and Z axis UL62368-1, EN62368-1, C-UL (equivalent to CAN/CSA-C22.2 No.62368-1), ANSI/AAMI ES60601-1, EN60601-1 3rd, C-UL (equivalent to CAN/CSA-C22.2 No.60601-1), Complies with IEC60601-1-2 4th Ed. Complies with FCC Part15 classB, VCCI-B, CISPR32-B, EN55011-B, EN55032-B Complies with IEC61000-3-2 (class A) April 02, 2021 PCA600F SPECIFICATIONS CASE SIZE/WEIGHT COOLING METHOD OTHERS 89X41X152mm [3.50X1.61X5.98 inches] (without terminal block and screw) (WXHXD) / 840g max Forced cooling (internal fan) *1 DC input safety agency approvals deleted. *2 The value is primary surge. The current of input surge to a built-in EMI/EMS Filter(0.2ms or less) is excluded. *3 Measured by 20MHz oscilloscope or Ripple-Noise meter (equivalent to KEISOKUGIKEN:RM103). Please refer to the instruction manual 1.2. *4 5V output product, the maximum temperature of 40C. *5 Drift is the change in DC output for an eight hours period after a half-hour warm-up at 25C. *6 Please contact us about another class. *7 The listed options may affect the published standard specifications. Please contact us for detailed product specifications and safety approvals. * A sound may occur from power supply at pulse loading. Features - Low profile (41mm, 1.61 inch = meet 1U height) - Universal input 85 - 264VAC (Refer to “Derating”, when using at 85 - 90VAC) - DC input 88 - 370VDC possible (Refer to when using at 88 - 110VDC) - For medical electric equipment (ANSI/AAMI ES60601-1, EN60601-1 3rd, IEC60601-1-2 4th Ed.) - Medical Isolation Grade 2MOPP - With AUX output 12V 0.1A (Voltage adjustable range 5 - 12V) - Constant current function - Output voltage can be adjusted to near 0V (the item 2.6 on Instruction Manual) - With various alarms - Parallel Operation / N+1 Parallel Redundancy Operation possible - Monitoring function and various setting values can be changed by communication (the item 2.11 on Instruction Manual) - Complies with SEMI F47 (the item 2.1 on Instruction Manual) Block diagram AC(L) AC IN 85 - 264V FUSE 250V16A AC(N) NOISE FILTER INRUSH CURRENT LIMIT RECTIFIER SWITCHING DEVICE RECTIFIER AND FILTER 250V16A FG CURRENT SENSING CONTROL TRANSFORMER FAN INTERNAL REGULATOR AUX (12V0.1A) TRANSFORMER REGULATOR RECTIFIER AND FILTER INVERTER ±S (Remote sensing) Photocoupler OVER VOLTAGE PROTECTION CURRENT SENSING DC OUT RC (Remote ON/OFF) PG (Alarm) CB (Current balance) Photocoupler CONTROL DS (Data Shared signal) CONTROL THERMAL PROTECTION Photocoupler VTRM (Adjustment of output voltage) ITRM (Adjustment of output current) INFO (Extended UART) Photocoupler April 02, 2021 PCA-7 PCA600F External view 2-M4 (Depth:6mm max) Mounting Hole 7 7 [0.28] [0.28] [0.28] 7 14.5 16 [0.63] 20.5 [0.81] 14.5 [0.57] [0.57] 13 [0.51] 39 [2.99] Name plate 2-M4 (Depth:6mm max) Mounting Hole (Bottom side) 44.5 [1.75] M4 89 [3.50] [0.34] 8.6 [2.31] 58.75 64.5 [2.54] 57.5 10 [0.79] 76±0.5 M4 CN1 [0.10] 2.5 14.5 [0.57] 32.5 35 [1.38] 4 [0.16] [1.28] 24 [0.94] 87±0.5 [3.43] 152 [5.98] 2-M3 2-M4 (Depth:6mm max) Mounting Hole 2-f8.5 PCA-8 20.5 [0.16] 4 ¶ Tolerance : ±1 [±0.04] ¶ Weight : 840g max ¶ PCB Material / thickness : FR-4 / 1.6mm [0.06] ¶ Chassis Material : Aluminum ¶ Fan cover Material : PBT ¶ Dimensions in mm, [ ] = inches ¶ Mounting torque : 1.2N-m max ¶ Input and output terminal screw tightening torque M3 0.6N-m max M4 1.6N-m max ¶ Please connect safety ground to FG terminal on the unit. [0.81] [0.33] 41 15.5 9 [0.35] 24 [0.94] 39 [1.54] April 02, 2021 76±0.5 [2.99] [1.61] [1.32] Output voltage adjustable potentiometer 16.5 33.6 [0.61] LED(Alarm) Orange LED(DC OK) Blue [0.65] Output terminal(+) [0.39] AC(L) AC(N) FG CN2 CN4 CN3 Output terminal(-) 20max Terminal cover [2.26] [0.51] 10.3 12.85 [0.41] [1.54] AIR FLOW PCA600F External view 20.5 [0.81] 2-M4 (Depth:6mm max) Mounting Hole 39 [0.53] 33.6 44.5 [1.75] M4 89 [3.50] 64.5 [2.54] 13 [0.51] 8.6 (f14.2) [0.34] [0.56] 10 13.35 LED(Alarm) Orange LED(DC OK) Blue Output voltage adjustable potentiometer M5 M5 [1.32] Name plate 2-M4 (Depth:6mm max) Mounting Hole (Bottom side) 15 57.5 [0.39] CN1 [0.79] [2.99] 9 [0.35] 28max 35 [1.38] [1.10] 87±0.5 [3.43] 152 [5.98] 2-M4 (Depth:6mm max) Mounting Hole 20.5 ¶ Tolerance : ±1 [±0.04] ¶ Weight : 840g max ¶ PCB Material / thickness : FR-4 / 1.6mm [0.06] ¶ Chassis Material : Aluminum ¶ Fan cover Material : PBT ¶ Dimensions in mm, [ ] = inches ¶ Mounting torque : 1.2N-m max ¶ Input and output terminal screw tightening torque M4 1.6N-m max M5 2.5N-m max ¶ Please connect safety ground to FG terminal on the unit. [0.81] 41 Terminal cover [1.61] Output terminal(+) [2.26] AC(L) AC(N) FG CN2 CN4 CN3 Output terminal(-) 20max Terminal cover 76±0.5 [0.59] [0.51] 10.3 12.85 [0.41] [1.54] 39 [1.54] April 02, 2021 AIR FLOW 76±0.5 [2.99] PCA-9 AC-DC Power Supplies Enclosed Type PCA1000F Ordering information PC 1 A 1000 F 2 3 4 Example recommended EMI/EMC filter NAC-20-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series Low profile type : EAC series 2MOPP * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. Terminal Block Style -5 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional *6 C : with Coating G : Low leakage current T : Terminal Block Style (Only 24V, 32V and 48V) I : with PMBus interface F2 : Reverse air exhaust type P3 : Master-slave Operation W1 : Alarm function E1 : EMI classB (Only 24V, 32V and 48V) For option details, refer to instruction manual 6.1. *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT PCA1000F-5 1000 5V 200A PCA1000F-12 1056 12V 88A PCA1000F-15 1050 15V 70A PCA1000F-24 1056 24V 44A PCA1000F-32 1056 32V 33A PCA1000F-48 1056 48V 22A SPECIFICATIONS MODEL VOLTAGE [VAC] ACIN 100V ACIN 230V CURRENT[A] FREQUENCY[Hz] (Io=50%) (Io=100%) (Io=50%) INPUT ACIN 230V (Io=100%) ACIN 100V POWER FACTOR ACIN 230V ACIN 100V*1 INRUSH CURRENT[A] ACIN 230V*1 LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +50C *2*3 RIPPLE[mVp-p] -20 to 0C *2 0 to +50C *2*3 RIPPLE NOISE[mVp-p] OUTPUT -20 to 0C *2 0 to +50C *3 TEMPERATURE REGULATION[mV] -20 to +50C *3 *4 DRIFT[mV] START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION[V] PROTECTION REMOTE SENSING CIRCUIT AND REMOTE ON/OFF (RC) OTHERS DC_OK LAMP ALARM LAMP COMMUNICATION FUNCTION INPUT-OUTPUT INPUT-FG ISOLATION OUTPUT-FG OUTPUT - AUX-RC-PG-INFO-DS-ADDR0-ADDR1-ADDR2 OPERATING TEMP.,HUMIDITY.AND ALTITUDE STORAGE TEMP.,HUMIDITY.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT AGENCY APPROVALS SAFETY AND NOISE CONDUCTED NOISE REGULATIONS HARMONIC ATTENUATOR *5 ACIN 100V EFFICIENCY[%] PCA-10 PCA1000F-5 PCA1000F-12 PCA1000F-15 PCA1000F-24 PCA1000F-32 PCA1000F-48 85 - 264 1f (Output derating is required at less than 90V. Refer to “Derating”) 12.0typ 5.3typ 50/60 (45 - 66) 90typ 91typ 91typ 91typ 91typ 91typ 89typ 90typ 90typ 91typ 91typ 91typ 92typ 92typ 92typ 93typ 93typ 93typ 91typ 92typ 92typ 93typ 93typ 93typ 0.98typ (Io=100%) 0.95typ (Io=100%) 20/40 typ (Io=100%) (Primary inrush current / Secondary inrush current) (More than 3 sec. to re-start) 40/40 typ (Io=100%) (Primary inrush current / Secondary inrush current) (More than 3 sec. to re-start) 0.5max (ACIN 240V 60Hz, Io=100%, According to IEC60601-1) 5 12 15 24 32 48 200 88 70 44 33 22 20max 48max 60max 96max 128max 192max 40max 100max 120max 150max 150max 480max 160max 240max 240max 240max 320max 480max 280max 320max 320max 320max 420max 640max 240max 300max 300max 300max 400max 600max 320max 360max 360max 360max 480max 720max 50max 120max 150max 240max 320max 480max 75max 180max 180max 290max 400max 600max 20max 48max 60max 96max 128max 192max 700typ (ACIN 100/230V Io=100%) 20typ (ACIN 230V Io=80%) / 16typ (ACIN 230V Io=100%) 3.00 to 6.00 7.20 to 14.40 9.00 to 18.00 14.40 to 28.80 19.20 to 38.40 28.80 to 57.60 5.00 to 5.05 12.00 to 12.12 15.00 to 15.15 24.00 to 24.24 32.00 to 32.32 48.00 to 48.48 Works over 105% of rating (Recovers automatically, Hiccup overcurrent) 6.25 to 7.00 15.00 to 16.80 18.75 to 21.00 30.00 to 33.60 40.00 to 44.80 60.00 to 67.20 Provided Provided LED (Blue) LED (Orange) Provided (Extended UART) AC4,000V 1minute, Cutoff current = 10mA, DC500V 50MΩ min (At Room Temperature) 2MOPP AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MΩ min (At Room Temperature) 1MOPP AC500V 1minute, Cutoff current = 100mA, DC500V 50MΩ min (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MΩ min (At Room Temperature) -20 to +70C, 20 - 90%RH (Non condensing) -20 to +75C, 20 - 90%RH (Non condensing) 10 - 55Hz 19.6m/s2 (2G) 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G) 11ms, once each X, Y and Z axis UL62368-1, EN62368-1, C-UL (equivalent to CAN/CSA-C22.2 No.62368-1), ANSI/AAMI ES60601-1, EN60601-1 3rd, C-UL (equivalent to CAN/CSA-C22.2 No.60601-1), Complies with IEC60601-1-2 4th Ed. Complies with FCC Part15 classA, VCCI-A, CISPR32-A, EN55011-A, EN55032-A Complies with IEC61000-3-2 (class A) April 02, 2021 PCA1000F SPECIFICATIONS CASE SIZE/WEIGHT COOLING METHOD OTHERS 102X41X178mm [4.02X1.61X7.01 inches] (without terminal block and screw) (WXHXD) / 1.2kg max Forced cooling (internal fan) *1 The value is primary surge. The current of input surge to a built-in EMI/EMS Filter(0.2ms or less) is excluded. *2 Measured by 20MHz oscilloscope or Ripple-Noise meter (equivalent to KEISOKUGIKEN:RM103). Please refer to the instruction manual 1.2. *3 5V, 12V, 15V output product, the maximum temperature of 40C. *4 Drift is the change in DC output for an eight hours period after a half-hour warm-up at 25C. *5 Please contact us about another class. *6 The listed options may affect the published standard specifications. Please contact us for detailed product specifications and safety approvals. * A sound may occur from power supply at pulse loading. Features - Low profile (41mm, 1.61 inch = meet 1U height) - Universal input 85 - 264VAC (Refer to “Derating”, when using at 85 - 90VAC) - For medical electric equipment (ANSI/AAMI ES60601-1, EN60601-1 3rd, IEC60601-1-2 4th Ed.) - Medical Isolation Grade 2MOPP - With AUX output 12V 0.1A (Voltage adjustable range 5 12V) - Constant current function - Output voltage can be adjusted to near 0V (the item 2.6 on Instruction Manual) - With various alarms - Parallel Operation / N+1 Parallel Redundancy Operation possible - Monitoring function and various setting values can be changed by communication (the item 2.11 on Instruction Manual) - Complies with SEMI F47 (the item 2.1 on Instruction Manual) Block diagram AC(L) AC IN 85 - 264V FUSE 250V20A AC(N) NOISE FILTER INRUSH CURRENT LIMIT RECTIFIER SWITCHING DEVICE RECTIFIER AND FILTER 250V20A FG CURRENT SENSING CONTROL TRANSFORMER FAN INTERNAL REGULATOR AUX (12V0.1A) TRANSFORMER REGULATOR RECTIFIER AND FILTER INVERTER ±S (Remote sensing) Photocoupler OVER VOLTAGE PROTECTION CURRENT SENSING DC OUT RC (Remote ON/OFF) PG (Alarm) CB (Current balance) Photocoupler CONTROL DS (Data Shared signal) CONTROL THERMAL PROTECTION Photocoupler VTRM (Adjustment of output voltage) ITRM (Adjustment of output current) INFO (Extended UART) Photocoupler April 02, 2021 PCA-11 PCA1000F External view [0.28] [0.28] 7 [0.57] [0.57] 2-M4(Depth:6mm max) Mounting Hole 7 20.5 [0.81] [0.28] 47 83±0.5 [1.85] Terminal cover 23.0max [0.91] [3.27] Name plate 51 9 102 [4.02] 2.5 [0.10] 17.5 [0.69] [1.32] 9 14.5 [0.57] 35 4 [0.16] [1.38] 26.5 [1.04] [0.35] 33 [1.30] 2-M3 116±0.5 [4.57] 178 [7.01] 2-M4(Depth:6mm max) Mounting Hole 2-f8.5 PCA-12 20.5 4 [0.16] ¶ Tolerance : ±1 [±0.04] ¶ Weight : 1.2kg max ¶ PCB Material / thickness : FR-4 / 1.6mm [0.06] ¶ Chassis Material : Aluminum ¶ Fan cover Material : PBT ¶ Dimensions in mm, [ ] = inches ¶ Mounting torque : 1.2N-m max ¶ Input and output terminal screw tightening torque M3 0.6N-m max M4 1.6N-m max ¶ Please connect safety ground to FG terminal on the unit. [0.81] [0.33] 41 Output voltage adjustable potentiometer [0.67] 33.6 17 LED(Alarm) Orange LED(DC OK) Blue [2.01] [0.35] 74 [2.65] 67.25 M4 M4 CN1 CN3 Output terminal(-) Output terminal(+) [2.91] 11 [0.43] FG CN2 CN4 61.0 AC(N) [2.40] AC(L) 2-M4(Depth:6mm max) Mounting Hole (Bottom side) 26.5 [1.04] 47 [1.85] April 02, 2021 83±0.5 [3.27] [1.61] [0.41] [0.63] 10.3 16.1 7 14.5 16 [0.63] 13 14.5 [0.51] AIR FLOW PCA1000F External view 20.5 [0.81] 2-M4(Depth:6mm max) Mounting Hole 47 [1.85] Terminal cover 23.0max [0.91] Name plate Output terminal(+) 13.35 [0.53] 33.6 Output voltage adjustable potentiometer 51 [2.01] [4.02] 102 [0.56] 73.7 [2.90] 15 LED(Alarm) Orange LED(DC OK) Blue M4 [0.59] CN1 CN3 Output terminal(-) 13 [0.51] 9 (f14.2) [0.35] 11 [0.43] FG CN2 CN4 61.0 AC(N) [2.40] AC(L) 2-M4(Depth:6mm max) Mounting Hole (Bottom side) M5 M5 9 [1.32] [0.35] 28max 33 [1.30] [1.10] 116±0.5 [4.57] 178 [7.01] 2-M4(Depth:6mm max) Mounting Hole 20.5 [0.81] Terminal cover ¶ Tolerance : ±1 [±0.04] ¶ Weight : 1.2kg max ¶ PCB Material / thickness : FR-4 / 1.6mm [0.06] ¶ Chassis Material : Aluminum ¶ Fan cover Material : PBT ¶ Dimensions in mm, [ ] = inches ¶ Mounting torque : 1.2N-m max ¶ Input and output terminal screw tightening torque M4 1.6N-m max M5 2.5N-m max ¶ Please connect safety ground to FG terminal on the unit. 47 [1.85] April 02, 2021 [1.61] [0.63] [3.27] 41 10.3 [0.41] 16.1 83±0.5 AIR FLOW 83±0.5 [3.27] PCA-13 Ordering information AC-DC Power Supplies Enclosed Type PCA1500F PC 1 A 1500 F 2 3 4 Example recommended EMI/EMC filter NAC-30-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series Low profile type : EAC series 2MOPP * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. -5 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional *6 C : with Coating G : Low leakage current I : with PMBus interface F2 : Reverse air exhaust type P3 : Master-slave Operation W1 : Alarm function For option details, refer to instruction manual 6.1. Terminal Block Style *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT PCA1500F-5 ACIN 100V/230V 1500/1500 ACIN 100V/230V 5V 300A/300A PCA1500F-12 1500/1500 12V 125A/125A PCA1500F-15 1500/1500 15V 100A/100A PCA1500F-24 1560/1680 24V 65A/70A PCA1500F-32 1504/1664 32V 47A/52A PCA1500F-48 1536/1680 48V 32A/35A SPECIFICATIONS MODEL VOLTAGE PCA1500F-5 PCA1500F-12 PCA1500F-15 PCA1500F-24 PCA1500F-32 PCA1500F-48 85 - 264 1f (Output derating is required at less than 95V. Refer to “Derating”) 18typ CURRENT[A] 7.8typ 8.5typ FREQUENCY[Hz] 50/60 (45 - 66) (Io=50%) 90typ 91typ 91typ 91typ 91typ 91typ ACIN 100V (Io=100%) 88typ 90typ 90typ 91typ 91typ 91typ EFFICIENCY[%] (Io=50%) 92typ 92typ 92typ 93typ 93typ 93typ INPUT ACIN 230V (Io=100%) 91typ 92typ 92typ 93typ 93typ 93typ ACIN 100V 0.98typ (Io=100%) POWER FACTOR ACIN 230V 0.95typ (Io=100%) ACIN 100V*1 20/40 typ (Io=100%) (Primary inrush current / Secondary inrush current) (More than 10 sec. to re-start) INRUSH CURRENT[A] ACIN 230V*1 40/40 typ (Io=100%) (Primary inrush current / Secondary inrush current) (More than 10 sec. to re-start) LEAKAGE CURRENT[mA] 0.5max (ACIN 240V 60Hz, Io=100%, According to IEC60601-1) VOLTAGE[V] 5 12 15 24 32 48 CURRENT[A] ACIN 100V/230V 300/300 125/125 100/100 65/70 47/52 32/35 LINE REGULATION[mV] 20max 48max 60max 96max 128max 192max LOAD REGULATION[mV] 40max 100max 120max 150max 150max 480max 0 to +50C *2*3 160max 240max 240max 240max 320max 480max RIPPLE[mVp-p] -20 to 0C *2 280max 320max 320max 320max 420max 640max 0 to +50C *2*3 240max 300max 300max 300max 400max 600max RIPPLE NOISE[mVp-p] OUTPUT -20 to 0C *2 320max 360max 360max 360max 480max 720max 0 to +50C *3 50max 120max 150max 240max 320max 480max TEMPERATURE REGULATION[mV] -20 to +50C *3 75max 180max 180max 290max 400max 600max *4 20max DRIFT[mV] 48max 60max 96max 128max 192max START-UP TIME[ms] 700typ (ACIN 100/230V Io=100%) HOLD-UP TIME[ms] 20typ (ACIN 230V Io=80%) / 16typ (ACIN 230V Io=100%) OUTPUT VOLTAGE ADJUSTMENT RANGE[V] 3.00 to 6.00 7.20 to 14.40 9.00 to 18.00 14.40 to 28.80 19.20 to 38.40 28.80 to 57.60 OUTPUT VOLTAGE SETTING[V] 5.00 to 5.05 12.00 to 12.12 15.00 to 15.15 24.00 to 24.24 32.00 to 32.32 48.00 to 48.48 OVERCURRENT PROTECTION Works over 105% of rating (Recovers automatically, Hiccup overcurrent) OVERVOLTAGE PROTECTION[V] 6.25 to 7.00 15.00 to 16.80 18.75 to 21.00 30.00 to 33.60 40.00 to 44.80 60.00 to 67.20 Provided PROTECTION REMOTE SENSING CIRCUIT AND REMOTE ON/OFF (RC) Provided OTHERS DC_OK LAMP LED (Blue) ALARM LAMP LED (Orange) COMMUNICATION FUNCTION Provided (Extended UART) INPUT-OUTPUT AC4,000V 1minute, Cutoff current = 10mA, DC500V 50MΩ min (At Room Temperature) 2MOPP INPUT-FG AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MΩ min (At Room Temperature) 1MOPP ISOLATION OUTPUT-FG AC500V 1minute, Cutoff current = 100mA, DC500V 50MΩ min (At Room Temperature) OUTPUT - AUX-RC-PG-INFO-DS-ADDR0-ADDR1-ADDR2 AC500V 1minute, Cutoff current = 100mA, DC500V 50MΩ min (At Room Temperature) OPERATING TEMP.,HUMIDITY.AND ALTITUDE -20 to +70C, 20 - 90%RH (Non condensing) STORAGE TEMP.,HUMIDITY.AND ALTITUDE -20 to +75C, 20 - 90%RH (Non condensing) ENVIRONMENT VIBRATION 10 - 55Hz 19.6m/s2 (2G) 3minutes period, 60minutes each along X, Y and Z axis IMPACT 196.1m/s2 (20G) 11ms, once each X, Y and Z axis AGENCY APPROVALS UL62368-1, EN62368-1, C-UL (equivalent to CAN/CSA-C22.2 No.62368-1), ANSI/AAMI ES60601-1, EN60601-1 3rd, SAFETY C-UL (equivalent to CAN/CSA-C22.2 No.60601-1), Complies with IEC60601-1-2 4th Ed. AND NOISE CONDUCTED NOISE Complies with FCC Part15 classA, VCCI-A, CISPR11-A, CISPR32-A, EN55011-A, EN55032-A REGULATIONS HARMONIC ATTENUATOR *5 Complies with IEC61000-3-2 (class A) PCA-14 [VAC] ACIN 100V ACIN 230V April 02, 2021 PCA1500F SPECIFICATIONS CASE SIZE/WEIGHT COOLING METHOD OTHERS 140X41X203mm [5.52X1.61X7.99 inches] (without terminal block and screw) (WXHXD) / 2.0kg max Forced cooling (internal fan) *1 The value is primary surge. The current of input surge to a built-in EMI/EMS Filter(0.2ms or less) is excluded. *2 Measured by 20MHz oscilloscope or Ripple-Noise meter (equivalent to KEISOKUGIKEN:RM103). Please refer to the instruction manual 1.2. *3 5V, 12V, 15V output product, the maximum temperature of 40C. *4 Drift is the change in DC output for an eight hours period after a half-hour warm-up at 25C. *5 Please contact us about another class. *6 The listed options may affect the published standard specifications. Please contact us for detailed product specifications and safety approvals. * A sound may occur from power supply at pulse loading. Features - Low profile (41mm, 1.61 inch = meet 1U height) - Universal input 85 - 264VAC (Refer to “Derating”, when using at 85 - 95VAC) - For medical electric equipment (ANSI/AAMI ES60601-1, EN60601-1 3rd, IEC60601-1-2 4th Ed.) - Medical Isolation Grade 2MOPP - With AUX output 12V 0.1A (Voltage adjustable range 5 - 12V) - Constant current function - Output voltage can be adjusted to near 0V (Refer to the item 2.6 on Instruction Manual.) - With various alarms - Parallel Operation / N+1 Parallel Redundancy Operation available - Monitoring function and various setting values can be changed by communication (Refer to the item 2.11 on Instruction Manual.) - Complies with SEMI F47 (Refer to the item 2.1 on Instruction Manual.) Block diagram AC(L) AC IN 85 - 264V FUSE 250V31.5A AC(N) NOISE FILTER INRUSH CURRENT LIMIT RECTIFIER SWITCHING DEVICE RECTIFIER AND FILTER 250V31.5A FG CURRENT SENSING CONTROL TRANSFORMER FAN INTERNAL REGULATOR AUX (12V0.1A) TRANSFORMER REGULATOR RECTIFIER AND FILTER INVERTER ±S (Remote sensing) Photocoupler OVER VOLTAGE PROTECTION CURRENT SENSING DC OUT RC (Remote ON/OFF) PG (Alarm) CB (Current balance) Photocoupler CONTROL DS (Data Shared signal) CONTROL THERMAL PROTECTION Photocoupler VTRM (Adjustment of output voltage) ITRM (Adjustment of output current) INFO (Extended UART) Photocoupler April 02, 2021 PCA-15 PCA1500F 11 [0.43] 20 [0.79] 20.5 10 [0.39] [0.43] 2-M4(Depth:6mm max) Mounting Hole 10 [0.39] 15 [0.59] External view 38 [1.50] LED (Alarm) Orange 39 [1.54] LED (DC OK) Blue 33.7 10 148 [5.83] 45 203 [1.77] [7.99] 33.3 [0.39] 22 [0.87] [1.31] 2-f9.0 2-M4 140 AIR FLOW [0.21] 5.3 20.5 [0.81] 20 ¶ Tolerance : ±1 [±0.04] ¶ Weight : 2.0kg max ¶ PCB Material / thickness : FR-4 / 1.6mm [0.06] ¶ Chassis Material : Aluminum ¶ Fan cover Material : PBT ¶ Dimensions in mm, [ ] = inches ¶ Mounting torque : 1.2N-m max ¶ Input and output terminal screw tightening torque M3 0.6N-m max M4 1.6N-m max ¶ Please connect safety ground to FG terminal on the unit. PCA-16 [5.52] 2-M4(Depth:6mm max) Mounting Hole [0.79] 14.7 [0.58] [1.33] 33.3 38 130 [1.31] [1.50] [5.12] April 02, 2021 41 Output terminal(+) 4 Output voltage adjustable potentiometer [0.16] Output terminal(−) [1.61] CN3 4-M4(Depth:6mm max) Mounting Hole (Bottom side) M4 64 CN1 [2.52] CN4 84 CN2 Name plate (Display item) Model name Rated Input/Output Production Country Lot No. Safety Agency Mark Logo Company Logo [3.31] 75.9 [2.99] FG 9 11 AC(N) NC [0.91] [0.35] 13.3 [0.52] AC(L) 130 [5.19] 23max Terminal cover [0.43] 16.1 [0.63] 38 [1.50] PCA-series Terminal Blocks ¿PCA300F, PCA600F 9å 1 2 3 1AC (L) Input Terminals 85 - 264VAC 1f45 - 66Hz 88 - 370VDC (Excluding PCA1000F PCA1500F) 2AC (N) (M4) 3Frame ground (M4) 4-Output 5+Output 6LED for fault condition detection (ALARM) Color : Orange 7LED for output voltage confirmation (DC_OK) Color : Bule 8Output voltage adjustable potentiometer 9CN1 0CN2 Connectors åCN3 ∫CN4 çN.C. Pin Configuration and Functions of CN1, CN2 Pin No. Function Ground level 1 +S +Remote sensing COM 2 N.C. No connection 3 N.C. No connection 4 -S -Remote sensing COM 5 VTRM Adjustment of output voltage COM 6 COM Common ground (for signal) COM 7 INFO Extended UART signal SGND 8 CB Current Balance COM 9 DS Data Shared signal SGND 10 SGND Signal ground SGND 11 RC2 Remote ON/OFF RCG 12 RCG Remote ON/OFF ground RCG * Each terminal of CN1 and CN2 are connected inside the power supply. 67 8 0 ∫ 4 5 ¿PCA1000F 9å 1 2 3 6 7 8 0 ∫ 4 5 ¿PCA1500F 9 1 2 ç 3 2 6 7 8 0∫ å 4 5 1 CN1 2 12 11 2 1 CN2 12 1 CN3 10 9 2 1 11 8 7 CN4 Connector pin numbers Pin Configuration and Functions of CN3 Function Ground level AUX Auxiliary output AUXG AUXG Auxiliary output ground AUXG RC1 Remote ON/OFF AUXG AUXG Auxiliary output ground AUXG PG Alarm PGG PGG Alarm ground PGG ITRM Adjustment of output current COM COM Common ground (for signal) COM VTRM_EN Enable Vtrm COM SLV_EN Enable Slave mode *1 COM Pin Configuration and Functions of CN4 Pin No. Function Ground level 1 SDA Serial data *2 SGND 2 SGND Signal ground SGND 3 SCL Serial clock *2 SGND 4 SMBA SMBAlert *2 SGND 5 ADDR0 Address bit 0 SGND 6 ADDR1 Address bit 1 SGND 7 ADDR2 Address bit 2 SGND 8 SGND Signal ground SGND Matching connectors and terminals Connector Housing Terminal Mfr. CN1 S12B-PHDSS PHDR-12VS Reel : SPHD-002T-P0.5 CN2 Loose : BPHD-001T-P0.5 *3 J.S.T CN3 S10B-PHDSS PHDR-10VS BPHD-002T-P0.5 *3 CN4 S8B-PHDSS PHDR-8VS  or -P3 option. *1 F Pin No. 1 2 3 4 5 6 7 8 9 10  or -I option. *2 F  he manufacturer prepares only the ratchet hand. *3 T Assembling and Installation Method ¡Please observe the mounting screw length in right figure to obtain enough isolation between screws and internal components. 1.5mm Chassis of customer system Chassis Screw M4 April 02, 2021 6mm max PCA-17 PCA-series Assembling and Installation Method ¡Please do not block built-in fans and ventilation holes.When the power supply is mounted by screws, please consider its weight and set it in place. (Please see below.) ¡Please avoid installing the power supply by only one narrow side like the Fig.(c). In that case , another narrow side or the wide side should be also used to install as shown in Fig .(d), (e), and (f). ¡If power supplies are used in a dusty environment, it might cause a failure. Please consider taking such countermeasures as installing an air filter near the suction area of the system to prevent a failure. AC (L) AC (N) (L) AC (L) AC (L) AC (N)AC (N)AC (N)AC (N)AC FG FG FG FG -V -V +V FG (L) AC -V -V -V -V +V +V +V FG +V (N)AC +V (L) AC (a) (b) (c) (d) (e) (f) Derating Input voltage Derating curve ¿PCA600F 80 100 Load [%] Load [%] Load [%] 90 ¿PCA1500F 100 100 100 Load [%] ¿PCA1000F 90 〔 85 90 88 AC input voltage [VAC] 85 110 85 95 AC input voltage [VAC] 100 Load factor [%] Load factor [%] 90 ¿PCA300F-12, -15, -24, -32, -48 Ambient Temperature Derating Curve 100 Vin=85 to 264VAC Vin=88 to 370VDC 50 0 -20 〕 AC input voltage [VAC] DC input voltage [VDC] ¿PCA300F-5 Ambient Temperature Derating Curve 80 -10 0 10 20 30 40 50 60 70 Ambient temperature [C] 0 -20 80 Vin=85 to 264VAC Vin=88 to 370VDC 50 -10 0 10 20 30 40 50 60 70 Ambient temperature [C] (a) PCA300F-5 80 (b) PCA300F-12,-15,-24,-32,-48 ¿PCA600F-12, -15, -24, -32, -48 Ambient Temperature Derating Curve ¿PCA600F-5 Ambient Temperature Derating Curve 100 100 Vin=85 to 264VAC * Vin=88 to 370VDC * 50 0 -20 Load factor [%] Load factor [%] 2 -10 0 10 20 30 40 50 60 70 80 1Vin=85 to 170VAC * Vin=88 to 240VDC * 2Vin=170 to 264VAC Vin=240 to 370VDC 50 0 -20 -10 0 10 20 30 40 50 60 Ambient temperature [C] Ambient temperature [C] (b) PCA600F-12,-15,-24,-32,-48 *With derating due to input voltage (a) PCA600F-5 *With derating due to input voltage PCA-18 1 April 02, 2021 70 80 PCA-series Derating ¿PCA1000F-24, -32, -48 Ambient Temperature Derating Curve ¿PCA1000F-5, -12, -15 Ambient Temperature Derating Curve 100 100 Load factor [%] Load factor [%] 1 Vin=85 to 264VAC * 50 0 -20 -10 0 10 20 30 40 50 60 70 Ambient temperature [C] 1Vin=85 to 170VAC * 2Vin=170 to 264VAC 50 0 -20 80 2 -10 0 10 20 30 40 50 60 70 Ambient temperature [C] PCA1000F-5,-12,-15 *With(a) derating due to input voltage 80 (b)derating PCA1000F-24,-32,-48 *With due to input voltage ¿PCA1500F-24,-32,-48 Ambient Temperature Derating Curve ¿PCA1500F-5,-12,-15 Ambient Temperature Derating Curve 100 100 Load factor [%] Load factor [%] 2 Vin=85~264VAC * 50 0 - 20 -10 0 10 20 30 40 50 60 70 Ambient temperature [C] 1 0 - 20 80 1Vin=85~170VAC * 2Vin=170~264VAC 50 -10 0 10 20 30 40 50 60 70 Ambient temperature [C] PCA1500F-5,-12,-15 *With(a) derating due to input voltage 80 (a)derating PCA1500F-5,-12,-15 *With due to input voltage ¡Specifications for ripple and ripple noise are different in the hatched area. ¡The ambient temperature is defined as the temperature of the air at air-intake side of the power supply. Instruction Manual ◆ It is neccessary to read the “Instruction Manual” and “Before using our product” before you use our product. Instruction Manual Before using our product https://en.cosel.co.jp/technical/caution/index.html PCA https://en.cosel.co.jp/product/powersupply/PCA/ NOTICE Basic Characteristics Data Model Circuit method Switching frequency [kHz] Active filter 15 - 400 PCA300F Buck converter 88 PCA600F PCA1000F PCA1500F * Full - bridge converter 44 Active filter 15 - 400 Buck converter 88 Full - bridge converter 44 Active filter 15 - 400 Buck converter 88 Full - bridge converter 44 Active filter 15 - 400 Buck converter 88 Full - bridge converter 44 Series/Parallel operation availability Input current [A] Rated input fuse Inrush current protection circuit Material Single sided Double sided Series operation Parallel operation 3.8 250V 10A Relay FR-4 - Yes Yes Yes 7.3 250V 16A Relay FR-4 - Yes Yes Yes 12.0 250V 20A Relay FR-4 - Yes Yes Yes 18.0 250V 31.5A Relay FR-4 - Yes Yes Yes PCB/Pattern The value of input current is at ACIN 100VAC and rated load. April 02, 2021 PCA-19
PCA600F-32-T 价格&库存
很抱歉,暂时无法提供与“PCA600F-32-T”相匹配的价格&库存,您可以联系我们找货
