WTS26P-34161120A00
WTS26P-34161120A00
    SICK
    WTS26P-34161120A00
WTS26P-34161120A00 数据手册
Product data sheet WTS26P-34161120A00 W26 COMPACT PHOTOELECTRIC SENSORS WTS26P-34161120A00 | W26 COMPACT PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. WTS26P-34161120A00 1218949 Other models and accessories www.sick.com/W26 Illustration may differ Detailed technical data Features Device type Photoelectric sensors Sensor/ detection principle Photoelectric proximity sensor, Background suppression TwinEye technology Dimensions (W x H x D) 24.6 mm x 82.5 mm x 53.3 mm Housing design (light emission) Rectangular Sensing range max. 10 mm ... 1,000 mm 1) Type of light Visible red light Light source PinPoint LED 2) Light spot size (distance) Ø 10 mm (550 mm) Wave length 635 nm Adjustment Teach-Turn adjustment BluePilot: For setting the sensing range IO-Link For configuring the sensor parameters and Smart Task functions Indication LED blue BluePilot: sensing range indicator LED green Operating indicator 1) 2) 2  Object with 90 % reflectance (referred to standard white, DIN 5033).  Average service life: 100,000 h at TU = +25 °C. PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-12-16 21:27:49 Subject to change without notice WTS26P-34161120A00 | W26 COMPACT PHOTOELECTRIC SENSORS Static: power on Flashing: IO-Link mode LED yellow Status of received light beam Static on: object present Static off: object not present Pin 2 configuration External Input (test), Teach-in, switching signal Special applications Detecting uneven, shiny objects, Detecting objects wrapped in film 1) 2)  Object with 90 % reflectance (referred to standard white, DIN 5033).  Average service life: 100,000 h at TU = +25 °C. Mechanics/electronics Supply voltage 10 V DC ... 30 V DC 1) Ripple
WTS26P-34161120A00 价格&库存
很抱歉,暂时无法提供与“WTS26P-34161120A00”相匹配的价格&库存,您可以联系我们找货
WTS26P-34161120A00
  • 1+3301.922821+428.27000
  • 5+3047.875145+395.31920
