MF52A223J3470
MF52A223J3470
    CANTHERM
    MF52A223J3470
MF52A223J3470 数据手册
MF52 Pearl-Shaped Precision NTC Thermistor for Temperature Measurement MF52 Pearl-Shaped Precision NTC Thermistor for Temperature Measurement.The MF52 series is ethoxyline resin coated. The small size is made possible by new materials and manufacturing methods which provide the benefit of close tolerances and fast response. MF52 thermistors are available with 5 lead styles in standard or custom lengths. Dimensions (mm) Tinned copper wire or cp wire Enamelled cu wire High temp fluorin-plastic insulated cu wire A: Tin. Ag. nickel plated cu wire Code D max L1 max L2 min d +/- 0.05 F +/- 0.5 A1 2.5 4.0 25 0.3 1.7 A2 3 4.5 25 0.45 2.2 B: Enamelled cu wire Code D max L1 max B1 2 3.5 B2 3 4 L2 min Customer Specified Customer Specified L3 d +/- 1 +/- 0.05 3 0.2 3 0.3 C: High temp fluorin-plastic wire Code D max L1 max C1 3 7.5 C2 4 7.5 L2 min Customer Specified Customer Specified L3 +/- 1 d +/- 0.05 5 0.26 5 0.32 Application Characteristics • Heating, Ventilation & Air Conditioning • Temperature Regulation and Measurement • Electronic Thermometers • Liquid Level Sensing • Automotive Electronics • Medical Equipment and Apparatus • Battery Packs and Portable Electronics PVC insulated cu wire Special specification • Small Size and fast response • Available tolerances: ±1%, ±2%, ±3%, ±5% and ±10% • Long-term Stability and Reliability • Excellent Tolerance and Interchangeability • Available in all popular resistance values • Dissipation Constant ≥2.0mW/°C • Time Constant of ≤7 seconds in still air • Available in custom probes D: PVC wire Code D max L1 max D1 3 7.5 D2 4 7.5 L2 min Customer Specified L3 +/- 1 d +/- 0.05 5 0.26 5 0.32 Customer Specified E: Lead and head according to specification Code D max L1 max L2 min L3 +/- 1 d +/- 0.05 E1 Customer Specified Customer Specified Customer Specified 5 Customer Specified E2 Customer Specified Customer Specified Customer Specified 5 Customer Specified Tinned steel wire F: Tinned lead-frame style Code D max L1 max L2 +/- 1.5 d max F +/- 0.5 T max F 3.8 9.5 17 0.5 2.5 3.5 Specification Main Techno-Parameter Remark: * B Value (25/50C) error is ±1% for components with rated resistance tolerance of ±1% and ±2% for all others. Notice: * The two ends of the lead wire cannot endure too big pull because of the small size and soldered spot in series of MF52. * Solder at least 5mm from the bottom of wire. UL 1434 (File E240991) CQC (File 07001019009) * Specifications are subject to change without notice. 8415 Mountain Sights Avenue • Montreal (Quebec), H4P 2B8, Canada Tel: (514) 739-3274 • 1-800-561-7207 • Fax: (514) 739-2902 • E-mail: sales@cantherm.com Website: www.cantherm.com | Division of Microtherm 2012/Nov MF52
MF52A223J3470 价格&库存
很抱歉,暂时无法提供与“MF52A223J3470”相匹配的价格&库存,您可以联系我们找货
