IN-S124BRG
IN-S124BRG
    INOLUX(英诺斯)
    发光二极管/LED 翠绿色 1204 525nm 1440mcd SMT
IN-S124BRG 数据手册
IN-S124BR series Reverse Mount SMD LED 1204 PCB Type Featured • 1204 1.85mm SMD LED • High Brightness • AlInGaP / InGaN Technology • Narrow View Angle • High Reliability • Clear Lens Description The IN-S124BR series is a popular 1204 package with reverse mount and versatile design capabilities. It is a PCB type molding style LED which can be used in various applications. Recommended Solder Pattern Applications • Consumer Electronics • Wearables • Automobile After Market • Industrial Equipment Figure 1. IN-S124BR Solder Pattern Package Dimensions in mm Inolux Corporation Proprietary & Confidential Figure 2. IN-S124BR Package Dimensions April 10, 2017 Page 1 www.inolux-corp.com IN-S124BR series Reverse Mount SMD LED 1204 PCB Type Absolute Maximum Rating at 25oC (Note 1) Product Emission Color Pd (mW) IF (mA) IFP* (mA) 48 20 30 VR (V) TOP (oC) TST (oC) 5 -40 C~+85 C IN-S124BRYG Yellow Green IN-S124BRY Yellow IN-S124BRA Amber IN-S124BRR Red IN-S124BRB Blue IN-S124BRG Green IN-S124BRUW White 78 20 o o o o -40 C~+100 C 60 Notes 1. Condition for IFP is pulse of 1/10 duty and 0.1msec width ESD Precaution ATTENTION: Electrostatic Discharge (ESD) protection The symbol above denotes that ESD precaution is needed. ESD protection for GaP and AlGaAs based chips is necessary even though they are relatively safe in the presence of low static-electric discharge. Parts built with AlInGaP, GaN, or/and InGaN based chips are STATIC SENSITIVE devices. ESD precaution must be taken during design and assembly. If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process. Please be advised that normal static precautions should be taken in the handling and assembly of this device to prevent damage or degradation which may be induced by electrostatic discharge (ESD). Inolux Corporation Proprietary & Confidential April 10, 2017 Page 2 www.inolux-corp.com IN-S124BR series Reverse Mount SMD LED 1204 PCB Type Electrical Characteristics T A = 25°C (Note 1) VF(V) Emission Color IF(mA) IN-S124BRYG Yellow Green IN-S124BRY Product λ(nm) Viewing Angle I*V(mcd) typ. max λD λP △λ 2θ1/2 typ. 20 2.1 2.4 571 573 15 20 715.0 Yellow 20 2.0 2.4 589 591 20 20 1125.0 IN-S124BRA Amber 20 2.0 2.4 605 609 17 20 1800.0 IN-S124BRR Red 20 2.0 2.4 624 632 20 20 900.0 IN-S124BRB Blue 20 3.3 3.9 470 468 40 20 715.0 IN-S124BRG Green 20 3.3 3.9 525 520 30 20 1440.0 IN-S124BRUW White 20 3.3 3.9 X=0.29 Y=0.29 - - 20 715.0 Notes 1. Performance guaranteed only under conditions listed in above tables. Inolux Corporation Proprietary & Confidential April 10, 2017 Page 3 www.inolux-corp.com IN-S124BR series Reverse Mount SMD LED 1204 PCB Type Chromaticity Bin (for White only) x y 0.2500 0.2500 x y 0.2900 0.3050 Rank C1 0.2700 0.2700 0.2775 0.2325 Rank D1 0.3100 0.3100 0.3325 0.2875 0.2500 0.2050 x y 0.2700 0.2775 0.2900 0.2600 x y 0.3100 0.3325 Rank C2 0.2900 0.2900 0.3050 0.2600 Rank D2 0.3300 0.3300 0.3600 0.3150 0.2700 0.2325 0.3100 0.2875 0.5 0.4 D2 0.3 D1 C2 C1 0.2 0.1 0 0 0.1 0.2 0.3 Inolux Corporation Proprietary & Confidential 0.4 0.5 0.6 April 10, 2017 Page 4 www.inolux-corp.com IN-S124BR series Reverse Mount SMD LED 1204 PCB Type Typical Characteristic Curves – YG, Y, A, R Inolux Corporation Proprietary & Confidential April 10, 2017 Page 5 www.inolux-corp.com IN-S124BR series Reverse Mount SMD LED 1204 PCB Type Typical Characteristic Curves – B, G, W Inolux Corporation Proprietary & Confidential April 10, 2017 Page 6 www.inolux-corp.com IN-S124BR series Reverse Mount SMD LED 1204 PCB Type Typical Characteristic Curves – Radiation Pattern Ordering Information Technolog Test Current y IF (mA) Forward Luminous Intensity Voltage IV (mcd) VF (V) (Typ.) (Typ.) Product Emission Color IN-S124BRYG Yellow Green AllnGaP 20 715.0 2.1 IN-S124BRYG IN-S124BRY Yellow AllnGaP 20 1125.0 2.0 IN-S124BRY IN-S124BRA Amber AllnGaP 20 1800.0 2.0 IN-S124BRA IN-S124BRR Red AllnGaP 20 900.0 2.0 IN-S124BRR IN-S124BRB Blue InGaN 20 715.0 3.3 IN-S124BRB IN-S124BRG Green InGaN 20 1440.0 3.3 IN-S124BRG IN-S124BRUW White InGaN 20 715.0 3.3 IN-S124BRUW Inolux Corporation Proprietary & Confidential Orderable Part Number April 10, 2017 Page 7 www.inolux-corp.com IN-S124BR series Reverse Mount SMD LED 1204 PCB Type Label Specifications Inolux P/N: I N - S Material Inolux SMD 1 2 Package S = PCB Type 4 B R Variation Orientation 124B = 3.2 x 1.6 x 1.85mm R = Reverse Mount X - Lens Color Customized Stamp-off (Blank) = Clear U = Diffused R=624nm A=605nm Y=589nm YG=571nm G=525nm B=470nm W=White Current (Blank) = 20mA X X X X Lot No.: Z Internal Tracker 2 0 1 7 Year (2017, 2018, …..) Inolux Corporation Proprietary & Confidential 01 24 001 Month Date Serial April 10, 2017 Page 8 www.inolux-corp.com IN-S124BR series Reverse Mount SMD LED 1204 PCB Type Packaging Information: 2000pcs Per Reel Tape Dimension Part No. IN-S124BR Dim. A Dim. B Dim. C 3.37±0.10 1.78±0.10 2.17±0.10 Q’ty/Reel 2K Unit: mm Reel Dimension Inolux Corporation Proprietary & Confidential April 10, 2017 Page 9 www.inolux-corp.com IN-S124BR series Reverse Mount SMD LED 1204 PCB Type Packing Dimension 5 boxes per carton are available depending on shipment quantity. Specification Material Quantity Carrier tape Per EIA 481-1A specs Conductive black tape 4000pcs per reel Reel Per EIA 481-1A specs Conductive black Label IN standard Paper Packing bag 220x240mm Aluminum laminated bag/ no-zipper One reel per bag Carton IN standard Paper Non-specified Others: Each immediate box consists of 5 reels. The 5 reels may not necessarily have the same lot number or the same bin combinations of Iv, λD and Vf. Each reel has a label identifying its specification; the immediate box consists of a product label as well. Inolux Corporation Proprietary & Confidential April 10, 2017 Page 10 www.inolux-corp.com IN-S124BR series Reverse Mount SMD LED 1204 PCB Type Dry Pack All SMD optical devices are MOISTURE SENSITIVE. Avoid exposure to moisture at all times during transportation or storage. Every reel is packaged in a moisture protected anti-static bag. Each bag is properly sealed prior to shipment. Upon request, a humidity indicator will be included in the moisture protected anti-static bag prior to shipment. The packaging sequence is as follows: Reflow Soldering • Recommended tin glue specifications: melting temperature in the range of 178~192 OC • The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface of the LED resin): Lead-free Solder Profile Inolux Corporation Proprietary & Confidential April 10, 2017 Page 11 www.inolux-corp.com IN-S124BR series Reverse Mount SMD LED 1204 PCB Type Precautions • • • • • • Avoid exposure to moisture at all times during transportation or storage. Anti-Static precaution must be taken when handling GaN, InGaN, and AlInGaP products. It is suggested to connect the unit with a current limiting resistor of the proper size. Avoid applying a reverse voltage. Avoid operation beyond the limits as specified by the absolute maximum ratings. Avoid direct contact with the surface through which the LED emits light. If possible, assemble the unit in a clean room or dust-free environment. Reworking • • • Rework should be completed within 5 seconds under 260 OC. The iron tip must not come in contact with the copper foil. Twin-head type is preferred. Cleaning Following are cleaning procedures after soldering: • An alcohol-based solvent such as isopropyl alcohol (IPA) is recommended. • Temperature x Time should be 50oC x 30sec. or
IN-S124BRG 价格&库存
很抱歉,暂时无法提供与“IN-S124BRG”相匹配的价格&库存,您可以联系我们找货
IN-S124BRG
    IN-S124BRG
    • 2000+1.358982000+0.17633
    • 4000+1.275854000+0.16554
    • 6000+1.233176000+0.16001
    • 10000+1.1849610000+0.15375
    • 14000+1.1562514000+0.15003
    • 20000+1.1282620000+0.14639
    库存:6264
    IN-S124BRG
      IN-S124BRG
      • 1+3.879001+0.50330
      • 10+2.6875910+0.34872
      • 100+1.91755100+0.24880
      • 500+1.56916500+0.20360
      • 1000+1.454411000+0.18871
      库存:6264
      IN-S124BRG
        • 1+3.02163
        • 200+1.20572
        • 500+1.16543
        • 1000+1.14545
        IN-S124BRG
