INL-3ANPT30
INL-3ANPT30
    INOLUX(英诺斯)
    插件
    INL-3ANPT30
INL-3ANPT30 数据手册
INL-3ANPT30 3mm Phototransistor Though Hole Lamp LED Features • Low power consumption • General purpose leads • Bulk, Available on tape and reel • Fast response time • High photo sensitivity • Small junction capacitance • Compliance with EU REACH • The product itself remain within RoHS compliant version Infrared application system • Optoelectronic automatic control system Optoelectronic switch • Printer • Counters and sorters • Encoders • Floppy disk drive • Video camera, tape and card readers • Position sensors Description Applications • • • The INL-3ANPT30 is a high speed and high sensitive silicon NPN phototransistor in a standard 3mm epoxy package. • Due to its black epoxy, the device is matched to visible light and infrared radiation. Package Dimensions in mm Notes: 1. All dimensions are in millimeters (inches). 2. Tolerance is ± 0.25 mm (.010″) unless otherwise noted. Figure 1. INL-3ANPT30 Package Dimensions Inolux Corporation Proprietary & Confidential January, 24, 2019 Page 1 www.inolux-corp.com INL-3ANPT30 3mm Phototransistor Though Hole Lamp LED Absolute Maximum Rating at 25oC Symbol Parameters Ratings Units Notes BVCEO Collector-Emitter Breakdown Voltage 30 V 1 BVECO Emitter-Collector Breakdown Voltage 5 V 2 Collector Current 20 mA Ic Topr Operating Temperature -40~+80 ℃ Tstg Storage Temperature -40~+85 ℃ Tsol Soldering Temperature 260 ℃ PD Total Power Dissipation 75 mW 3 Notes 1. Test conditions: IC=100μA, Ee=0mW/cm2. 2. Test conditions: IE=100μA, Ee=0mW/cm2. 3. Soldering time≦5 seconds. Electro-Optical Characteristics Symbol Parameters λD Rang of Spectral Bandwidth Wavelength of Peak Sensitivity Collector-Emitter Breakdown Voltage Emitter-Collector Breakdown Voltage Collector-Emitter Saturation Voltage λP BVCEO BVECO VCE(sat) ICEO IC(ON) Collector Dark Current On State Collector Current tr Rise Time tf Fall Time Test conditions ----IC=100μA Ee=0mW/cm² IE=100μA Ee=0mW/cm² IC=0.7mA Ee=1mW/cm² VCE=20V Ee=0mW/cm² Ee=1mW/cm² λP=940nm, VCE=5V VCE=5V, IC=1mA RL=1000Ω Min Typ Max Units 400 - 1100 nm - 940 30 - - V 5 - - V - - 0.4 V - - 100 nA 0.7 2.5 - mA - 15 - uS - 15 - uS nm ESD Precaution ATTENTION: Electrostatic Discharge (ESD) protection The symbol above denotes that ESD precaution is needed. ESD protection for GaP and AlGaAs based chips is necessary even though they are relatively safe in the presence of low static-electric discharge. Parts built with AlInGaP, GaN, or/and InGaN based chips are STATIC SENSITIVE devices. ESD precaution must be taken during design and assembly. If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process. Please be advised that normal static precautions should be taken in the handling and assembly of this device to prevent damage or degradation which may be induced by electrostatic discharge (ESD). Inolux Corporation Proprietary & Confidential January, 24, 2019 Page 2 www.inolux-corp.com INL-3ANPT30 3mm Phototransistor Though Hole Lamp LED Typical Characteristic Curves Inolux Corporation Proprietary & Confidential January, 24, 2019 Page 3 www.inolux-corp.com INL-3ANPT30 3mm Phototransistor Though Hole Lamp LED Inolux Corporation Proprietary & Confidential January, 24, 2019 Page 4 www.inolux-corp.com INL-3ANPT30 3mm Phototransistor Though Hole Lamp LED Ordering Information Product Symbol INL-3ANPT30 IC(ON) Parameters On State Collector Current Test conditions Min Typ Max Units Orderable Part Number Ee=1mW/cm² λP=940nm, VCE=5V 0.7 2.5 - mA INL-3ANPT30 X X Label Specifications Inolux P/N: I N L Inolux Lamp Type - 3 A N PT 3 0 Package Lens Color View Angle 3A = standard 3mm N= Black Epoxy PT = Photo Transistor 30 = 30 deg. . X X Customized Stamp-off Lot No.: Z Internal Tracker Inolux Corporation Proprietary & Confidential 2 0 1 7 Year (2017, 2018, …..) 01 24 001 Month Date Serial January, 24, 2019 Page 5 www.inolux-corp.com INL-3ANPT30 3mm Phototransistor Though Hole Lamp LED Reliability Item Precondition Frequency/ lots/ samples/ failures For all reliability monitoring tests according to JEDEC Level 2 1Q/ 1/ 22/ 0 Solderability Standards Reference J-STD-020 CNS-554 1.) Baking at 85°C for 24hrs 2.) Moisture storage at 85°C/ 60% R.H. for 168hrs Accelerated aging 155°C/ 24hrs Tinning speed: 2.5+0.5cm/s Tinning: A: 215°C/ 3+1s or B: 260°C/ 10+1s Dipping soldering terminal only Soldering bath temperature A: 260+/-5°C; 10+/-1s B: 350+/-10°C; 3+/-0.5s 1.) Precondition: 85°C baking for 24hrs 85°C/ 60%R.H. for 168hrs 2.) Tamb25°C; IF=20mA; duration 1000hrs Tamb: 85°C Humidity: 85% R.H., IF=5mA Duration: 1000hrs Tamb: 55°C IF=20mA Duration: 1000hrs Tamb25°C, If=20mA,, Ip=100mA, Duty cycle=0.125 (tp=125μs,T=1sec) Duration 500hrs) A cycle: -40 degree C 15min; +85 degree C 15min Thermal steady within 5 min.. 300 cycles 2 chamber/ Air-to-air type 60+3°C 90+5/-10% R.H. for 500hrs 100+10°C for 500hrs CNS-6118 -40+5°C for 500hrs JESD22-B102-B And CNS-5068 CNS-5067 Resistance to soldering heat 1Q/ 1/ 40/ 0 CNS-11829 Operating life test High humidity, 1Q/ 1/ 45/ 0 high temperature bias 1Q/ 1/ 20 High temperature bias JESD-A101-B IN specs. 1Q/ 1/ 40/ 0 Pulse life test 1Q/ 1/ 76/ 0 Temperature cycle High humidity 1Q/ 1/ 40/ 0 storage test High temperature 1Q/ 1/ 40/ 0 storage test Low temperature 1Q/ 1/ 40/ 0 storage test Inolux Corporation Proprietary & Confidential Conditions JESD-A104-A IEC 68-2-14, Nb CNS-6117 January, 24, 2019 Page 6 www.inolux-corp.com INL-3ANPT30 3mm Phototransistor Though Hole Lamp LED Revision History Changes since last revision Initial Release Page Version No. 1.0 Revision Date 01-24-2019 DISCLAIMER INOLUX reserves the right to make changes without further notice to any products herein to improve reliability, function or design. INOLUX does not assume any liability arising out of the application or use of any product or circuit described herein; neither does it convey any license under its patent rights, nor the rights of others. LIFE SUPPORT POLICY INOLUX’s products are not authorized for use as critical components in life support devices or systems without the express written approval of the President of INOLUX or INOLUX CORPORATION. As used herein: 1. Life support devices or systems are devices or systems which, (a) are intended for surgical implant into the body, or (b) support or sustain life, and (c) whose failure to perform when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in a significant injury of the user. 2. A critical component in any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. Inolux Corporation Proprietary & Confidential January, 24, 2019 Page 7 www.inolux-corp.com
INL-3ANPT30 价格&库存
很抱歉,暂时无法提供与“INL-3ANPT30”相匹配的价格&库存,您可以联系我们找货
