1832
1832
    HEYCO
1832 数据手册
“Stay Connected” with Strain Relief Bushings ® Heyco ST Lockit Strain Relief Bushings ® ™ Snap onto Round Cables for Faster Assembly into Rectangular Mounting Holes – Semi-Automatic Equipment Available • Assembly friendly! Independent of insertion into the panel, Lockit Strain Reliefs self-lock onto the cable. Preassemble off line for final assembly at a later time or remote location, for lower installed cost! • Lockit Strain Reliefs hold so well they pass the UL pull-out test requirements with or without panel support. • Protect the lifeline of your electric/electronic products by absorbing the forces of push and pull that may be exerted on the flexible power cord. Rectangular design eliminates the possibility of part rotation under forces of twist. • Lockit’s three finger design securely anchors into panels as thin as .032˝ (0,8 mm) and as thick as .157˝ (4,0 mm) for a neat, clean appearance. Five locking steps accommodate a wide range of panel thicknesses. Low profile head satisfies design aesthetics! • Heyco’s automated Pre-Assembly Equipment speeds assembly of the Lockit onto the cable and thus lowers costs while greatly reducing risk of carpal tunnel syndrome. See pages 4-15 & 4-16. • Consult Heyco for other wire types and sizes. • See page 4-38 for corresponding Mounting Hole Plugs which can be used to fill blank/unused Mounting Holes and thus allow for a single panel design for multiple applications. WILL FIT THESE CABLES UL Type AWG/ Approximate Conductors Size in. mm. See table on page 4-10 See table on page 4-10 See table on page 4-10 PANEL DIMENSIONS ST LOCKIT STRAIN RELIEF Corresponding Mounting Hole Thickness for Faster Assembly Mounting Hole Plug Size PART NO. DESC. PART in. mm. in. mm. Black White NO. DESC. various .032 .040 .220 - .290 5,6 - 7,4 .453 x .512 11,5 x 13,0 .048 .063 .099 0,8 1,1 1,2 1832 1,6 2,5 1833 ST 101N 1890 RP 115-130 various .032 .063 .290 - .360 7,4 - 9,1 .689 x .689 17,5 x 17,5 .099 .126 .157 0,8 1,6 2,5 1836 3,2 4,0 1837 ST 201N 1892 RP 175-175 various .032 .063 .355 - .420 9,0 - 10,6 .689 x .689 17,5 x 17,5 .099 .126 .157 0,8 1,6 2,5 1848 3,2 4,0 1849 ST 301N 1892 RP 175-175 Standard color black. Consult Heyco for white and other colors. .55 (14,0mm) .512 (13,0mm) LOCKING TAB .453 (11,5mm) .51 (13,0mm) MOUNTING HOLE .56 (14,2mm) ST 101N Locking Tab varies with Cable Size .72 (18,3mm) .689 (17,5mm) .689 (17,5mm) .76 (19,3mm) ST 201N, ST 301N Quick Specs 4-5 Material Certifications Flammability Rating Temperature Range .76 (19,3mm) MOUNTING HOLE Nylon 6/6 Recognized under the Component Program of Underwriters’ Laboratories File E15331 Certified by the Canadian Standards Association File 8919 94V-2 -.04°F (-18°C) to 221°F (105°C). 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com
很抱歉,暂时无法提供与“1832”相匹配的价格&库存,您可以联系我们找货
  • 1+1.600361+0.20705
