DLP-RFID-LP8C
DLP-RFID-LP8C
    DLPDESIGN
    DLP-RFID-LP8C
DLP-RFID-LP8C 数据手册
DLP-RFIDLP8C LEAD-FREE 8-Channel Reader/Writer FEATURES: • • • • • • • • • • ISO15693, ISO14443A, ISO14443B Compatible Can read the UID/SID of up to 15 Tags Simultaneously 13.56MHz Reader/Writer 8 Channels for External Antenna Connections FCC/IC Modular Approvals in Place USB Port Powered from Windows, CE or Linux PC Both USB and RS232 Interfaces Provided USB Interface; No Driver Development Required for Windows, CE or Linux PC Operating Temperatures: 0°C to 70°C Dimensions: (L x W x H) 4.36” x 3.32” x 0.6” APPLICATIONS INCLUDE: • • • • • • • Real-Time Security Personal Identification Pharmaceutical Tracking Inventory/Asset Management & Tracking Library/Book Management & Tracking Baggage Tagging Sports Event Timing 1.0 INTRODUCTION The DLP-RFID-LP8C is a low-cost, USB-powered module for reading from and writing to ISO15693, ISO14443A and ISO14443B intelligent RFID transponder tags via up to eight external antennas. It has the ability to both read and write tag user data in addition to reading the unique identifier (UID). All of the DLP-RFID-LP8C’s electronics reside on a single, compact PCB; and all operational power is taken from the host Windows/Windows CE/Linux PC via the USB interface. Up to eight external antennas can be connected via reverse-polarity SMA connectors. Rev. 1.7 (May 2018) 1 © DLP Design, Inc. 2.0 HARDWARE SETUP The four jumpers provided on the DLP-RFID-LP8C module are used to select between the USB and Rs232 interfaces. For RS232 interface operation, move the three jumpers to the RS and RS232 positions and remove JP3. For USB operation, move the three jumpers to the USB position and add jumper JP3. If using the RS232 interface, connect the J3 wiring terminals to ±8V to ±12V serial signals typically found in the DB9, RS232 port connectors on a host PC. An external, regulated 5 volt power source must also be connected to J2. If using USB, simply connect the DLP-RFID-LP8C to a host PC using the 5-pin mini-B USB connector CN1 and a compatible USB cable. All power and data are provided via the USB cable. 3.0 APPLICATION DEVELOPMENT The serial interface for the DLP-RFID-LP8C operates at 115,200 baud, no parity, 8 data bits and 1 stop bit. A demonstration GUI is provided with the purchase of a DLP-RFID-LP8C module that demonstrates the communications protocols. Using the Virtual COM Port USB drivers, the DLP-RFID-LP8C appears to the host PC (Windows, Linux, Mac) as an RS232 port. The GUI presents the actual control packets sent, and the reply data coming back from the DLP-RFID-LP8C as an aid to the software developer. 3.1 DEMONSTRATION GUI The demonstration GUI is available as a free download from the DLP Design website. The URL for the download page is printed on the outer packaging of the DLP-RFID-LP8C. Rev. 1.7 (May 2018) 2 © DLP Design, Inc. 3.2 LP8C SPECIFIC COMMANDS To select one of the 8 external antennas on the DLP-RFID-LP8C you must send the correct command packet (Ex: 010900030422F00000). To send this packet using the TI GUI, first make the connection to the DLP-RFID-LP8C, and then click on the Test tab. Enter a command packet as shown below and click on Send Raw. The LED associated with the antenna channel selected will light and successive tag reads will use that channel. LP8C Specific commands: Commands to activate 1 of the 8 Antenna Channels: 1. 010900030422F00000 2. 010900030423F00000 3. 010900030424F00000 4. 010900030425F00000 5. 010900030426F00000 6. 010900030427F00000 7. 010900030428F00000 8. 010900030429F00000 Read Opto-isolated inputs: 010900030435F00000 Write opto-isolated output 1 high: 010900030430F00000 Write opto-isolated output 1 low: 010900030431F00000 Write opto-isolated output 2 high: 010900030432F00000 Write opto-isolated output 2 low: 010900030433F00000 Issue Pass beep 010900030477F00000 Issue Fail Beep 010900030479F00000 Rev. 1.7 (May 2018) 3 © DLP Design, Inc. 3.3 LP8C OPERATING FIRMWARE The source code for the firmware running in the DLP-RFID-LP8C reader (developed using Code Composer Studio) is available for download upon purchase of the DLP-RFID-LP8C from the DLP Design website. 4.0 MECHANICAL DIMENSIONS IN INCHES (MM) 2.08 typ (53.0 typ) 0.45 typ (11.4typ) 0.12 typ (3.1 typ) 0.60 typ (15.1 typ) 0.37 typ (9.3 typ) 3.0 typ (76.2typ) 1.55 typ (39.4typ) 2.70 typ (68.6typ) 3.84 typ (97.6typ) 4.36 typ (111 typ) 2.75 typ (68.9 typ) 3.32 typ (84typ) Rev. 1.7 (May 2018) 2.85 typ (72.3typ) 4 © DLP Design, Inc. 5.0 REGULATORY AGENCY CONSIDERATIONS 5.1 AGENCY IDENTIFICATION NUMBERS Compliance with the appropriate regulatory agencies is essential in the deployment of all intentional radiators. DLP Design has obtained modular approval for this RF product such that an OEM need only meet a few basic requirements in order to utilize their end product under this approval. Corresponding agency identification numbers are listed below: PART NUMBER US/FCC CAN/IC DLP-RFID-LP8C SX90LP8C 5675A-0LP8C 5.2 EXTERNAL ANTENNAS The DLP-RFID1-LP8C is approved for use with external 50 Ohm loop/ferrite antennas that are resonant at 13.56MHz. Connection is made via reverse-polarity SMA connectors. Two different antennas are available from DLP Design: the DLP-FANT and the DLP-RFID-ANT. DLP-FANT DLP-RFID-ANT The DLP-FANT ferrite-based antenna provides a compact footprint for space-constrained applications and provides up to a 1.25-inch read range. The DLP-FANT requires a coax cable with a reverse-polarity SMA connector at one end for connection to the DLP-RFID-LP8C reader. This coax cable is available in a 3-foot length from DLP Design under part number DLP-COAX1. The DLP-RFID-ANT ships with an attached 15-foot coax cable with a reverse-polarity SMA connector and provides up to 4 inches of read range with larger (credit card size) tags. Rev. 1.7 (May 2018) 5 © DLP Design, Inc. 5.3 FCC/IC REQUIREMENTS FOR MODULAR APPROVAL Any changes or modifications to the DLP-RFID-LP8C’s printed circuit board could void the user’s authority to operate the equipment. Operation of an unapproved antenna could void the user’s authority to operate the equipment. 5.4 WARNINGS Operation is subject to the following two conditions: (1) This device may not cause harmful interference; and (2) this device must accept any interference received, including interference that may cause undesirable operation. To reduce potential radio interference with other users, the antenna type and its gain should be so chosen that the equivalent isotropically-radiated power (e.i.r.p.) is not more than that permitted for successful communication. This device is intended for use under the following conditions: 1. The transmitter module may not be co-located with any other transmitter or antenna; and, 2. The module is approved using the FCC “unlicensed modular transmitter approval” method. As long as these two conditions are met, further transmitter testing will not be required. However, the OEM integrator is still responsible for testing their end product for any additional compliance measures necessitated by the installation of this module (i.e. digital device emissions, PC peripheral requirements, etc.). Note: In the event that these conditions cannot be met (i.e. co-location with another transmitter), then the FCC authorization is no longer valid, and the corresponding FCC ID may not be used on the final product. Under these circumstances, the OEM integrator will be responsible for re-evaluating the end product (including the transmitter) and obtaining a separate FCC authorization. 5.5 OEM PRODUCT LABELING The final end product must be labeled in a visible area with the following text: “Contains TX FCC ID: SX90LP8C” 5.6 RF EXPOSURE In order to comply with FCC RF exposure-compliance requirements, the antenna used for this transmitter must not be co-located or operating in conjunction with any other antenna or transmitter. Rev. 1.7 (May 2018) 6 © DLP Design, Inc. 5.7 ADDITIONAL INFORMATION FOR OEM INTEGRATORS The end user should NOT be provided with any instructions on how to remove or install the DLP-RFIDLP8C. This device has been pre-certified to operate with the antenna models listed below, or any other 50 Ohm, magnetic loop antenna that resonates at 13.56MHz. ƒ ƒ ƒ DLP Design Large Loop Antenna DLP Design Small Loop Antenna DLP Design Ferrite Antenna 6.0 DISCLAMER Neither the whole nor any part of the information contained herein nor the product described in this datasheet may be adapted or reproduced in any material or electronic form without the prior written consent of the copyright holder. This product and its documentation are supplied on an as-is basis, and no warranty as to their suitability for any particular purpose is either made or implied. DLP Design will not accept any claim for damages whatsoever arising as a result of use or failure of this product. Your statutory rights are not affected. This product or any variant of it is not intended for use in any medical appliance, device or system in which the failure of the product might reasonably be expected to result in personal injury. This document provides preliminary information that may be subject to change without notice. 7.0 CONTACT INFORMATION DLP Design, Inc. 1605 Roma Lane Allen, TX 75013 Phone: Fax: Email: Internet: 469-964-8027 415-901-4859 support@dlpdesign.com http://www.dlpdesign.com Rev. 1.7 (May 2018) 7 © DLP Design, Inc. D 5 RELAY SPST RP-SMA1 RL1 901-144-8RFX 1 4 2 3 RELAY SPST RL3 1 4 2 3 SWVCC SWVCC R1 R2 R3 360 360 360 D1 D3 D5 D7 LED LED LED LED R4 360 SWVCC 16 15 14 13 12 11 10 4 COM 1B 2B 3B 4B 5B 6B 7B 9 1 2 3 4 5 6 7 U3 ULN2003A/TSSOP 1C 2C 3C 4C 5C 6C 7C SWVCC U4 ULN2003A/TSSOP UCVCC 15 14 13 12 11 10 9 7 Y0 Y1 Y2 Y3 Y4 Y5 Y6 Y7 3 6 4 5 1 2 3 C18 0.1uF A B C G1 G2A G2B 1 2 3 4 J3 RS232 Header CN1 Mini-B USB Connector 1 2 3 4 5 U5 74HC238/TSSOP ANT_SEL_A ANT_SEL_B ANT_SEL_C UCVCC C1 0.1uF C2 0.1uF J2 5VDC IN 2 FB1 240-1018-1 1 C10 10/10 Tant C13 47pF C11 .01 TX --> RX C12 47pF 1 2 5V IN 1 U6 C8 1uF/10V/0603 C5 0.1uF 4 3 IN 5 1 1 3.3V D9 LED Q4 MMBT3904 USBVCC RESET R28 360 FROMHOST TX SELECT C15 .1uF 47K R23 SWVCC C6 10/10 Tant 5V SELECT .01uF/0603 C7 C9 .1uF TOHOST Q5 MMBT3904 RX Select 1 R21 30K Q3 IRLML6402CT P RX USBVCC COUT OUT U7 PQ1L303M2SP CIN C3 0.1uF C4 0.1uF R30 10K 23 22 13 14 12 1 5 3 11 2 9 10 6 RX 2 2 15 24 23 22 21 20 19 18 17 16 26 25 28 27 C21 0.1uF/0603 VCC C1- C1+ V+ FB2 240-1018-1 C2+ GND C2VT1OUT T2OUT T3OUT R1IN R2IN T4OUT R3IN T5OUT INVALID FORCEON FORCEOFF T1IN T2IN T3IN R1OUT R2OUT T4IN R3OUT T5IN R1OUTB C19 10/10 Tant C20 .01uF 1 2 3 4 5 6 7 8 9 10 11 12 13 14 MAX3238/SO C14 .1uF U8 USBDM USBDP VCC5 IN FT232R 20 16 15 VCCIN/NC RESET# AVCC/NC OSCI OSCO 3V3OUT 1 1 2 3 4 5 6 7 9 8 19 24 27 28 17 FT232R 1 SWVCC ANTENNA R5 R6 R7 360 360 360 D2 D4 D6 D8 LED LED LED LED R8 360 16 15 14 13 12 11 10 1B 2B 3B 4B 5B 6B 7B COM C22 .47uF C16 .1uF 2 1 1 RELAY SPST RL5 4 2 3 2 3 1 2 3 1 2 3 1C 2C 3C 4C 5C 6C 7C SWVCC 3 GND 2 16 VCC GND 8 CH1 RP-SMA3 901-144-8RFX CH3 RP-SMA5 901-144-8RFX CH5 4 2 3 RL7 RP-SMA7 RELAY SPST 901-144-8RFX 1 CH7 4 RELAY SPST RL6 4 RELAY SPST RL4 4 RELAY SPST RP-SMA2 RL2 901-144-8RFX 1 CH2 RP-SMA4 901-144-8RFX CH4 RP-SMA6 901-144-8RFX CH6 RL8 RP-SMA8 RELAY SPST 901-144-8RFX 1 4 2 3 4 4 VCCIO C B A CH8 5 AGND GND GND GND TEST 25 7 18 21 26 GND 8 GND 8 D C B A D C B A EXT_OUT1 EXT_OUT2 5 3VCC R36 1.8K R34 1.8K 5 16 R33 470 R32 470 1 15 14 11 10 2 3 9 13 12 6 7 4 5 8 ISO1 LTV846 C46 4 R31 10K EXT_IN2 EXT_IN1 R35 10K Y1 13.56MHz 3VCC C33 2.2uF SWVCC 22pF 4 3VCC 22pF VDD_X SYS_CLK EN VDD_A VIN VDD_RF VDD_PA TX_OUT VSS_PA VSS_RX MOD VDD_IO VSS_D VSS_A ASK/OOK IRQ RX1_AM BG VSS RX2_PM IO7 IO6 IO5 IO4 IO3 IO2 IO1 IO0 DATA_CLK EN2 XTAL_IN XTAL_OUT U1 TRF7970A Matching network & filtration C47 30 31 1 32 2 3 4 5 6 7 8 9 10 11 C34 0.01uF 3 J1 1 2 3 1 2 IN1 IN2 COM OUT1 OUT2 J4 3VCC 3VCC SLAVE_SELECT SIMO SOMI DATA_CLK SWVCC ANTENNA 28 27 26 25 24 23 22 21 20 19 18 17 16 29 15 14 13 12 3 EXT_OUT1 EXT_OUT2 EXT_IN2 EXT_IN1 LED SLAVE_SELECT SIMO SOMI 2 MMBT3904 Q1 R22 470 J5 PROGRAMMING HEADER 1 2 3 4 5 6 7 8 U2 MSP430F2370 P1.7/TA2 P2.0/ACLK/CA2 P2.1/TAINCLK/CA3 P2.2/CAOUT/TA0/CA4 P2.3/CA0/TA1 P2.4/CA1/TA2 P2.5/Rosc/CA5 P3.0/UCB0STE/UCA0CLK P3.1/UCB0SIMO/UCB0SDA P3.2/UCB0SOMI/UCB0SCL DVCC XIN/P2.6/CA6 XOUT/P2.7/CA7 P1.0/TACLK P1.1/TA0 P1.2/TA1 P1.3/TA2 P1.4/SMCLK P1.5/TA0 P1.6/TA1 SPKR 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 2 SWVCC Q2 MMBT3904 37 36 35 34 BZ1 Buzzer AVCC D/AVSS RST/NMI P4.4/TB1 P4.3/TB0 P4.2/TB2 P4.1/TB1 P4.0/TB0 P3.7 P3.6 P3.5/UCA0RXD/UCA0SOMI P3.4/UCA0TXD/UCA-SIMO P3.3/UCB0CLK/UCA0STE P4.7/TBCLK P4.6/TBOUTH/ACLK P4.5/TB2 TCK TMS TDI/TCLK TDO/TDI LED 40 39 38 33 32 31 30 29 28 27 26 25 24 23 22 21 R29 1 470 RESET TG C24 2.2uF R19 100 Simplified Schematic D10 GR TAG LED R20 47K UCVCC C25 0.01uF 47K R37 1 2 Not used Mode Sel 3VCC DLP-RFID-LP8C SPKR ANT_SEL_C ANT_SEL_B ANT_SEL_A FROMHOST TOHOST DATA_CLK 1 D C B A
DLP-RFID-LP8C
物料型号:DLP-RFID-LP8C
器件简介:DLP-RFID-LP8C是一款低成本、USB供电的模块,用于通过最多八个外部天线读取和写入ISO15693、ISO14443A和ISO14443B智能RFID应答器标签。它能够读写标签用户数据以及读取唯一标识符(UID)。所有电子元件都位于一个紧凑的PCB上,所有操作电源都通过USB接口从Windows、Windows CE或Linux PC主机获取。
引脚分配:文档中提供了详细的硬件设置说明,包括跳线配置和RS232接口操作,以及USB连接方式。
参数特性:支持ISO15693、ISO14443A、ISO14443B兼容;能够同时读取多达15个标签的UID/SID;13.56MHz读写器/写入器;8个外部天线连接通道;FCC/IC模块批准;USB端口由Windows、CE或Linux PC供电;提供USB和RS232接口;USB接口无需为Windows、CE或Linux PC开发驱动程序;工作温度范围0°C至70°C;尺寸(L x W x H) 4.36” x 3.32” x 0.6”。
功能详解:文档提供了硬件设置、应用开发、特定命令、操作固件和机械尺寸等详细信息。
应用信息:包括实时安全、个人识别、药品追踪、库存/资产管理与追踪、图书馆/图书管理与追踪、行李标签、体育赛事计时等。
DLP-RFID-LP8C 价格&库存
很抱歉,暂时无法提供与“DLP-RFID-LP8C”相匹配的价格&库存,您可以联系我们找货
DLP-RFID-LP8C
  • 1+1899.006681+246.39455
