Ordering information
Small, Single phase input type (1-Stage filter)
EAC/EAM/EAP series
EAC -10 -472
1
2
3
-O
4
1 Series Name
2 Rated Current
3 Line to ground capacitor code: Refer to table 1.1.
R
Code
000
101
221
331
471
681
102
222
332
472
EA P
EA M
EA C
table1.1 Line to ground capacitor code
Line to ground
Leakage Current
capacitor
(Input 125/250V 60Hz) (nominal value)
A / 10 A max Not Provided
● 5
100pF
● 12.5 A / 25 A max
A / 50 A max
220pF
● 25
330pF
● 37.5 A / 75 A max
A / 100 A max
470pF
● 50
680pF
● 75.5 A / 150 A max
● 0.13 mA / 0.25mA max 1,000pF
● 0.25 mA / 0.5 mA max 2,200pF
● 0.38 mA / 0.75mA max 3,300pF
● 0.5 mA / 1.0 mA max 4,700pF
*When the line to ground capacitor code is
different, the attenuation characteristic is
different.
4 Option
D :DIN rail installation type
The terminal cover is retracted inside the unit
DIN rail installation type is option
* The dimensions change when the option is set.
Refer to External view.
Features of EAC/EAM/EAP series
-Single Phase 250VAC (1-Stage filter)
-Small size
-Quick and easy push-down terminal
Just connect the wires, push-down and tighten the screws with a screwdriver
EAC : Attenuation type from 150kHz to 1MHz
EAP : Outside impulse attenuation type
EAM : Low leakage current type
Specifications
No.
Items
1
2
3
4
5
6
7
8
9
10
11
12
13
14
Rated Voltage[V]
Rated Current[A]
Test Voltage (Terminal-Mounting Plate)
Isolation Resistance (Terminal-Mounting Plate)
Leakage current
DC resistance
Safety agency approval temperatures
Operating temperature
Operating humidity
Storage temperature/humidity
Vibration
Impact
Safety agency approvals
Case size (without projection) /Weight
EAC-03-472
EAC-06-472
EAC-10-472
EAC-16-472
EAC-20-472
EAC-30-472
EAM-03-000
EAM-06-000
EAM-10-000
EAM-16-000
EAM-20-000
EAM-30-000
EAP-03-472
EAP-06-472
EAP-10-472
EAP-16-472
EAP-20-472
EAP-30-472
AC 1f 250 / DC250
3
6
10
16
2,500 VAC (Cutoff Current = 20mA), 1minute at room temperature and humidity
500 VDC 500MW min at room temperature and humidity
Refer to table 1.1
180mW max
110mW max
40mW max
20mW max
10mW max
6mW max
-25 to +85C (Refer to Derating Curve)
-40 to +85C (Refer to Derating Curve)
20 to 95%RH (Non condensing)
-40 to +85C/20 to 95%RH (Non condensing)
10 to 55Hz, 19.6m/s2 (2G), 3min. Period, 1hour each X, Y and Z axis
196.1m/s2 (20G), 11ms Once each X, Y and Z axis
UL1283, CSA C22.2 No.8 (C-UL), DIN EN60939 VDE0565 Teil3-1, ENEC (At only AC input)
39X30X85 mm [1.54X1.18X3.35 inches] (WXHXD) /170g max (Option : -D refer to external view)
Circuit Diagram
Derating Curve
Case
1
LINE
2
CY
CY
3
LOAD
4
Load Factor [%]
100
80
60
40
CY : Line to ground capacitor
EA/ES-1
-30
-20
40
50 55 60
Ambient Temperature [C]
: Mounting Plate
October 06, 2021
70
80
90
EAC/EAM/EAP series
External view
This product is shipped in the following condition,because it is equipped with push-down terminals.
1The terminal cover is retracted inside the unit.
2The screws for connecting the terminals are held in the up right position.
Standard Type
85
[3.35]
75 ±0.5
[2.95]
72
2.5
2-f4.8
[0.19] Mounting Hole
11.5
39
[1.54]
12.7
21
[0.83]
±0.5
[0.45]
31.5
2-M4
Output
Terminal
[0.38]
9.7
Terminal cover
Mounting Plate
Name Plate
Input
Terminal
[0.1]
Terminal cover
M4
Protection Earth
¶ Tolerance : ±1 [±0.04]
¶ Weight : 170g max
¶ Mounting Plate : Iron (surface finishing:nickel plating)㹲=1.0 [0.04]
¶ Case㸸PBT
¶ Dimensions in mm, [ ]=inches
¶ Terminal block screw tightening torque M4㸸1.6N࣭m(16.9kgf࣭cm)max
30
[1.18]
2
¶ Closed the terminal cover
[0.08]
2-M4
Protection Earth
[0.5]
Terminal cover
M4
[1.24]
[2.83]
DIN rail installation Type
[0.33]
72
[2.83]
2.5
Mounting Plate
11.5
M4
39
12.7
9.7
21
[0.83]
[1.54]
2-M4
Output
Terminal
Name Plate
Terminal cover
[0.1]
[0.45]
[0.38]
2-M4
Input
Terminal
M4
Protection Earth
[0.5]
Terminal cover
+2
-1
8.5
85
[3.35]
Terminal cover
Protection Earth
[0.28]
¶ Weight : 170g max
¶ Case㸸PBT
7
[0.35]
(9)
30
[1.18]
2
[0.08]
DIN rail
(4.2)
[0.17]
¡Note when installing the EMI/EMC
Filter on a DIN rail.
When the EMI/EMC Filter is grounded through
the DIN rail, the proper noise attenuation may not
be achieved.
Be sure to connect the protection earth (PE) of
the EMI/EMC Filter body to the earth.
At least one PE connection is required.
DIN rail
Name Plate
October 06, 2021
EA/ES-2
很抱歉,暂时无法提供与“EAP-20-472”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+326.697931+42.31881
- 国内价格
- 1+400.56120
- 200+159.82920
- 500+154.49400
