960-19-15-D-AB-0
960-19-15-D-AB-0
    WAKEFIELD-VETTE
    960-19-15-D-AB-0
960-19-15-D-AB-0 数据手册
Plastic Push Pin Heat Sinks 960 Series Wakefield-Vette’s 960 Series Push Pin Heat Sinks have plastic push pins that engage with a hole in one application's PCB design. The compression spring presses the heatsink to the device in which is being cooled. Wakefield-Vette offers a wide range of plastic push pin sizes and footprints to ensure the integrity of the PCB contact PCB with optimal cooling options. Features & Benefits: The 960 Series Push Pin Heat Sink utilizes the plastic push pin offering for any air flow conditions as it is design in a cross-cut format. This heat sink is ideal for many industries including but not limited to telecommunications, medical, and military. Wakefield-Vette’s 960 Series can be modified to a customer’s specification in addition to off the shelf standard. • Lightweight, Black Anodized, Cross Cut Aluminum 6063 • Easy and Quick Attachment, Pre Assembled Plastic Push Pin that have flexible barb to engage precisely with the PCB holes • Compression Springs allow for a confident grip to the PCB • Heat Sink Design allows for all airflow applications Part Number Configurator: Series Footprint Height Pin Location 960 Anodize Interface Material 19 12 F (Front) AB (Black) 0 (No) 21 15 S (Side) A (No Anodize) 1 (Yes) 23 18 D (Diagonal) 27 21 29 23 31 28 33 Plastic Push Pin Heat Sinks 19mm Wakefield Part Number Description 960-19-12-F-AB-0 HEATSINK 19X12MM FRONT PLASTIC PUSH PIN Size (mm) Height (mm) Anodize Attachment Method Pin Location 19 12 Black Push Pin 960-19-12-S-AB-0 HEATSINK 19X12MM SIDE PLASTIC PUSH PIN 19 12 Black Push Pin Sides 960-19-12-D-AB-0 HEATSINK 19X12MM DIAGONAL PLASTIC PUSH PIN 19 12 Black Push Pin Diagonal 960-19-15-F-AB-0 HEATSINK 19X15MM FRONT PLASTIC PUSH PIN 19 15 Black Push Pin Front 960-19-15-S-AB-0 HEATSINK 19X15MM SIDE PLASTIC PUSH PIN 19 15 Black Push Pin Sides 960-19-15-D-AB-0 HEATSINK 19X15MM DIAGONAL PLASTIC PUSH PIN 19 15 Black Push Pin Diagonal 960-19-18-F-AB-0 HEATSINK 19X18MM FRONT PLASTIC PUSH PIN 19 18 Black Push Pin Front 960-19-18-S-AB-0 HEATSINK 19X18MM SIDE PLASTIC PUSH PIN 19 18 Black Push Pin Sides 960-19-18-D-AB-0 HEATSINK 19X18MM DIAGONAL PLASTIC PUSH PIN 19 18 Black Push Pin Diagonal 960-19-21-F-AB-0 HEATSINK 19X21MM FRONT PLASTIC PUSH PIN 19 21 Black Push Pin Front 960-19-21-S-AB-0 HEATSINK 19X21MM SIDE PLASTIC PUSH PIN 19 21 Black Push Pin Sides 960-19-21-D-AB-0 HEATSINK 19X21MM DIAGONAL PLASTIC PUSH PIN 19 21 Black Push Pin Diagonal 960-19-23-F-AB-0 HEATSINK 19X23MM FRONT PLASTIC PUSH PIN 19 23 Black Push Pin Front Front 960-19-23-S-AB-0 HEATSINK 19X23MM SIDE PLASTIC PUSH PIN 19 23 Black Push Pin Sides 960-19-23-D-AB-0 HEATSINK 19X23MM DIAGONAL PLASTIC PUSH PIN 19 23 Black Push Pin Diagonal 960-19-28-F-AB-0 HEATSINK 19X28MM FRONT PLASTIC PUSH PIN 19 28 Black Push Pin Front 960-19-28-S-AB-0 HEATSINK 19X28MM SIDE PLASTIC PUSH PIN 19 28 Black Push Pin Sides 960-19-28-D-AB-0 HEATSINK 19X28MM DIAGONAL PLASTIC PUSH PIN 19 28 Black Push Pin Diagonal 960-19-33-F-AB-0 HEATSINK 19X33MM FRONT PLASTIC PUSH PIN 19 33 Black Push Pin Front 960-19-33-S-AB-0 HEATSINK 19X33MM SIDE PLASTIC PUSH PIN 19 33 Black Push Pin Sides 960-19-33-D-AB-0 HEATSINK 19X33MM DIAGONAL PLASTIC PUSH PIN 19 33 Black Push Pin Diagonal Front Pins Side Pins Diagonal Pins Plastic Push Pin Heat Sinks 19mm Thermal Performance Based on Height 19x19 Push Pin BGA Heatsinks 9 Thermal Resistance (C/W) 8 7 12 15 6 18 21 5 23 28 4 31 3 2 200 250 300 350 400 Airflow (LFM) 450 500 550 600 Plastic Push Pin Heat Sinks 21mm Wakefield Part Number Description 960-21-12-F-AB-0 HEATSINK 21X12MM FRONT PLASTIC PUSH PIN Size (mm) Height (mm) Anodize Attachment Method Pin Location 21 12 Black Push Pin Front 960-21-12-S-AB-0 HEATSINK 21X12MM SIDE PLASTIC PUSH PIN 21 12 Black Push Pin Sides 960-21-12-D-AB-0 HEATSINK 21X12MM DIAGONAL PLASTIC PUSH PIN 21 12 Black Push Pin Diagonal 960-21-15-F-AB-0 HEATSINK 21X15MM FRONT PLASTIC PUSH PIN 21 15 Black Push Pin Front 960-21-15-S-AB-0 HEATSINK 21X15MM SIDE PLASTIC PUSH PIN 21 15 Black Push Pin Sides 960-21-15-D-AB-0 HEATSINK 21X15MM DIAGONAL PLASTIC PUSH PIN 21 15 Black Push Pin Diagonal 960-21-18-F-AB-0 HEATSINK 21X18MM FRONT PLASTIC PUSH PIN 21 18 Black Push Pin Front 960-21-18-S-AB-0 HEATSINK 21X18MM SIDE PLASTIC PUSH PIN 21 18 Black Push Pin Sides 960-21-18-D-AB-0 HEATSINK 21X18MM DIAGONAL PLASTIC PUSH PIN 21 18 Black Push Pin Diagonal 960-21-21-F-AB-0 HEATSINK 21X21MM FRONT PLASTIC PUSH PIN 21 21 Black Push Pin Front 960-21-21-S-AB-0 HEATSINK 21X21MM SIDE PLASTIC PUSH PIN 21 21 Black Push Pin Sides 960-21-21-D-AB-0 HEATSINK 21X21MM DIAGONAL PLASTIC PUSH PIN 21 21 Black Push Pin Diagonal 960-21-23-F-AB-0 HEATSINK 21X23MM FRONT PLASTIC PUSH PIN 21 23 Black Push Pin Front 960-21-23-S-AB-0 HEATSINK 21X23MM SIDE PLASTIC PUSH PIN 21 23 Black Push Pin Sides 960-21-23-D-AB-0 HEATSINK 21X23MM DIAGONAL PLASTIC PUSH PIN 21 23 Black Push Pin Diagonal 960-21-28-F-AB-0 HEATSINK 21X28MM FRONT PLASTIC PUSH PIN 21 28 Black Push Pin Front 960-21-28-S-AB-0 HEATSINK 21X28MM SIDE PLASTIC PUSH PIN 21 28 Black Push Pin Sides 960-21-28-D-AB-0 HEATSINK 21X28MM DIAGONAL PLASTIC PUSH PIN 21 28 Black Push Pin Diagonal 960-21-33-F-AB-0 HEATSINK 21X33MM FRONT PLASTIC PUSH PIN 21 33 Black Push Pin Front 960-21-33-S-AB-0 HEATSINK 21X33MM SIDE PLASTIC PUSH PIN 21 33 Black Push Pin Sides 960-21-33-D-AB-0 HEATSINK 21X33MM DIAGONAL PLASTIC PUSH PIN 21 33 Black Push Pin Diagonal Front Pins Side Pins Diagonal Pins Plastic Push Pin Heat Sinks 21mm Thermal Performance Based on Height 21x21 Push Pin BGA Heatsinks 8 Thermal Resistance (C/W) 7 6 12 15 18 5 21 23 4 28 33 3 2 200 250 300 350 400 Airflow (LFM) 450 500 550 600 Plastic Push Pin Heat Sinks 23mm Wakefield Part Number Description 960-23-12-F-AB-0 HEATSINK 23X12MM FRONT PLASTIC PUSH PIN Size (mm) Height (mm) Anodize Attachment Method Pin Location 23 12 Black Push Pin Front 960-23-12-S-AB-0 HEATSINK 23X12MM SIDE PLASTIC PUSH PIN 23 12 Black Push Pin Sides 960-23-12-D-AB-0 HEATSINK 23X12MM DIAGONAL PLASTIC PUSH PIN 23 12 Black Push Pin Diagonal 960-23-15-F-AB-0 HEATSINK 23X15MM FRONT PLASTIC PUSH PIN 23 15 Black Push Pin Front 960-23-15-S-AB-0 HEATSINK 23X15MM SIDE PLASTIC PUSH PIN 23 15 Black Push Pin Sides 960-23-15-D-AB-0 HEATSINK 23X15MM DIAGONAL PLASTIC PUSH PIN 23 15 Black Push Pin Diagonal 960-23-18-F-AB-0 HEATSINK 23X18MM FRONT PLASTIC PUSH PIN 23 18 Black Push Pin Front 960-23-18-S-AB-0 HEATSINK 23X18MM SIDE PLASTIC PUSH PIN 23 18 Black Push Pin Sides 960-23-18-D-AB-0 HEATSINK 23X18MM DIAGONAL PLASTIC PUSH PIN 23 18 Black Push Pin Diagonal 960-23-21-F-AB-0 HEATSINK 23X21MM FRONT PLASTIC PUSH PIN 23 21 Black Push Pin Front 960-23-21-S-AB-0 HEATSINK 23X21MM SIDE PLASTIC PUSH PIN 23 21 Black Push Pin Sides 960-23-21-D-AB-0 HEATSINK 23X21MM DIAGONAL PLASTIC PUSH PIN 23 21 Black Push Pin Diagonal 960-23-23-F-AB-0 HEATSINK 23X23MM FRONT PLASTIC PUSH PIN 23 23 Black Push Pin Front 960-23-23-S-AB-0 HEATSINK 23X23MM SIDE PLASTIC PUSH PIN 23 23 Black Push Pin Sides 960-23-23-D-AB-0 HEATSINK 23X23MM DIAGONAL PLASTIC PUSH PIN 23 23 Black Push Pin Diagonal 960-23-28-F-AB-0 HEATSINK 23X28MM FRONT PLASTIC PUSH PIN 23 28 Black Push Pin Front 960-23-28-S-AB-0 HEATSINK 23X28MM SIDE PLASTIC PUSH PIN 23 28 Black Push Pin Sides 960-23-28-D-AB-0 HEATSINK 23X28MM DIAGONAL PLASTIC PUSH PIN 23 28 Black Push Pin Diagonal 960-23-33-F-AB-0 HEATSINK 23X33MM FRONT PLASTIC PUSH PIN 23 33 Black Push Pin Front 960-23-33-S-AB-0 HEATSINK 23X33MM SIDE PLASTIC PUSH PIN 23 33 Black Push Pin Sides 960-23-33-D-AB-0 HEATSINK 23X33MM DIAGONAL PLASTIC PUSH PIN 23 33 Black Push Pin Diagonal Front Pins Side Pins Diagonal Pins Plastic Push Pin Heat Sinks 23mm Thermal Performance Based on Height 23x23 Push Pin BGA Heatsinks 7 Thermal Resistance (C/W) 6 5 12 15 18 4 21 23 3 28 33 2 1 200 250 300 350 400 Airflow (LFM) 450 500 550 600 Plastic Push Pin Heat Sinks 27mm Wakefield Part Number Description Size (mm) Height (mm) Anodize Attachment Method Pin Location 960-27-12-F-AB-0 HEATSINK 27X12MM FRONT PLASTIC PUSH PIN 27 12 Black Push Pin 960-27-12-S-AB-0 HEATSINK 27X12MM SIDE PLASTIC PUSH PIN 27 12 Black Push Pin Sides 960-27-12-D-AB-0 HEATSINK 27X12MM DIAGONAL PLASTIC PUSH PIN 27 12 Black Push Pin Diagonal 960-27-15-F-AB-0 HEATSINK 27X15MM FRONT PLASTIC PUSH PIN 27 15 Black Push Pin Front 960-27-15-S-AB-0 HEATSINK 27X15MM SIDE PLASTIC PUSH PIN 27 15 Black Push Pin Sides 960-27-15-D-AB-0 HEATSINK 27X15MM DIAGONAL PLASTIC PUSH PIN 27 15 Black Push Pin Diagonal 960-27-18-F-AB-0 HEATSINK 27X18MM FRONT PLASTIC PUSH PIN 27 18 Black Push Pin Front 960-27-18-S-AB-0 HEATSINK 27X18MM SIDE PLASTIC PUSH PIN 27 18 Black Push Pin Sides 960-27-18-D-AB-0 HEATSINK 27X18MM DIAGONAL PLASTIC PUSH PIN 27 18 Black Push Pin Diagonal 960-27-21-F-AB-0 HEATSINK 27X21MM FRONT PLASTIC PUSH PIN 27 21 Black Push Pin Front Front 960-27-21-S-AB-0 HEATSINK 27X21MM SIDE PLASTIC PUSH PIN 27 21 Black Push Pin Sides 960-27-21-D-AB-0 HEATSINK 27X21MM DIAGONAL PLASTIC PUSH PIN 27 21 Black Push Pin Diagonal 960-27-23-F-AB-0 HEATSINK 27X23MM FRONT PLASTIC PUSH PIN 27 23 Black Push Pin Front 960-27-23-S-AB-0 HEATSINK 27X23MM SIDE PLASTIC PUSH PIN 27 23 Black Push Pin Sides 960-27-23-D-AB-0 HEATSINK 27X23MM DIAGONAL PLASTIC PUSH PIN 27 23 Black Push Pin Diagonal 960-27-28-F-AB-0 HEATSINK 27X28MM FRONT PLASTIC PUSH PIN 27 28 Black Push Pin Front 960-27-28-S-AB-0 HEATSINK 27X28MM SIDE PLASTIC PUSH PIN 27 28 Black Push Pin Sides 960-27-28-D-AB-0 HEATSINK 27X28MM DIAGONAL PLASTIC PUSH PIN 27 28 Black Push Pin Diagonal 960-27-33-F-AB-0 HEATSINK 27X33MM FRONT PLASTIC PUSH PIN 27 33 Black Push Pin Front 960-27-33-S-AB-0 HEATSINK 27X33MM SIDE PLASTIC PUSH PIN 27 33 Black Push Pin Sides 960-27-33-D-AB-0 HEATSINK 27X33MM DIAGONAL PLASTIC PUSH PIN 27 33 Black Push Pin Diagonal Front Pins Side Pins Diagonal Pins Plastic Push Pin Heat Sinks 27mm Thermal Performance Based on Height 27x27 Push Pin BGA Heatsinks 6.0 5.5 Thermal Resistance (C/W) 5.0 4.5 12 4.0 15 18 3.5 21 3.0 23 28 2.5 33 2.0 1.5 1.0 200 250 300 350 400 Airflow (LFM) 450 500 550 600 Plastic Push Pin Heat Sinks 29mm Wakefield Part Number Description Size (mm) Height (mm) Anodize Attachment Method Pin Location 960-29-12-F-AB-0 HEATSINK 29X12MM FRONT PLASTIC PUSH PIN 29 12 Black Push Pin 960-29-12-S-AB-0 HEATSINK 29X12MM SIDE PLASTIC PUSH PIN 29 12 Black Push Pin Sides 960-29-12-D-AB-0 HEATSINK 29X12MM DIAGONAL PLASTIC PUSH PIN 29 12 Black Push Pin Diagonal 960-29-15-F-AB-0 HEATSINK 29X15MM FRONT PLASTIC PUSH PIN 29 15 Black Push Pin Front 960-29-15-S-AB-0 HEATSINK 29X15MM SIDE PLASTIC PUSH PIN 29 15 Black Push Pin Sides 960-29-15-D-AB-0 HEATSINK 29X15MM DIAGONAL PLASTIC PUSH PIN 29 15 Black Push Pin Diagonal 960-29-18-F-AB-0 HEATSINK 29X18MM FRONT PLASTIC PUSH PIN 29 18 Black Push Pin Front 960-29-18-S-AB-0 HEATSINK 29X18MM SIDE PLASTIC PUSH PIN 29 18 Black Push Pin Sides 960-29-18-D-AB-0 HEATSINK 29X18MM DIAGONAL PLASTIC PUSH PIN 29 18 Black Push Pin Diagonal 960-29-21-F-AB-0 HEATSINK 29X21MM FRONT PLASTIC PUSH PIN 29 21 Black Push Pin Front Front 960-29-21-S-AB-0 HEATSINK 29X21MM SIDE PLASTIC PUSH PIN 29 21 Black Push Pin Sides 960-29-21-D-AB-0 HEATSINK 29X21MM DIAGONAL PLASTIC PUSH PIN 29 21 Black Push Pin Diagonal 960-29-23-F-AB-0 HEATSINK 29X23MM FRONT PLASTIC PUSH PIN 29 23 Black Push Pin Front 960-29-23-S-AB-0 HEATSINK 29X23MM SIDE PLASTIC PUSH PIN 29 23 Black Push Pin Sides 960-29-23-D-AB-0 HEATSINK 29X23MM DIAGONAL PLASTIC PUSH PIN 29 23 Black Push Pin Diagonal 960-29-28-F-AB-0 HEATSINK 29X28MM FRONT PLASTIC PUSH PIN 29 28 Black Push Pin Front 960-29-28-S-AB-0 HEATSINK 29X28MM SIDE PLASTIC PUSH PIN 29 28 Black Push Pin Sides 960-29-28-D-AB-0 HEATSINK 29x28MM DIAGONAL PLASTIC PUSH PIN 29 28 Black Push Pin Diagonal 960-29-33-F-AB-0 HEATSINK 29X33MM FRONT PLASTIC PUSH PIN 29 33 Black Push Pin Front 960-29-33-S-AB-0 HEATSINK 29X33MM SIDE PLASTIC PUSH PIN 29 33 Black Push Pin Sides 960-29-33-D-AB-0 HEATSINK 29X33MM DIAGONAL PLASTIC PUSH PIN 29 33 Black Push Pin Diagonal Front Pins Side Pins Diagonal Pins Plastic Push Pin Heat Sinks 29mm Thermal Performance Based on Height 29x29 Push Pin BGA Heatsinks 5.5 5.0 Thermal Resistance (C/W) 4.5 4.0 12 3.5 15 18 3.0 21 2.5 23 28 2.0 33 1.5 1.0 0.5 200 250 300 350 400 Airflow (LFM) 450 500 550 600 Plastic Push Pin Heat Sinks 31mm Wakefield Part Number Description 960-31-12-F-AB-0 HEATSINK 31X12MM FRONT PLASTIC PUSH PIN 31 12 Black Push Pin Front 960-31-12-S-AB-0 HEATSINK 31X12MM SIDE PLASTIC PUSH PIN 31 12 Black Push Pin Sides 960-31-12-D-AB-0 HEATSINK 31X12MM DIAGONAL PLASTIC PUSH PIN 31 12 Black Push Pin Diagonal 960-31-15-F-AB-0 HEATSINK 31X15MM FRONT PLASTIC PUSH PIN 31 15 Black Push Pin Front 960-31-15-S-AB-0 HEATSINK 31X15MM SIDE PLASTIC PUSH PIN 31 15 Black Push Pin Sides 960-31-15-D-AB-0 HEATSINK 31X15MM DIAGONAL PLASTIC PUSH PIN 31 15 Black Push Pin Diagonal 960-31-18-F-AB-0 HEATSINK 31X18MM FRONT PLASTIC PUSH PIN 31 18 Black Push Pin Front 960-31-18-S-AB-0 HEATSINK 31X18MM SIDE PLASTIC PUSH PIN 31 18 Black Push Pin Sides 960-31-18-D-AB-0 HEATSINK 31X18MM DIAGONAL PLASTIC PUSH PIN 31 18 Black Push Pin Diagonal 960-31-21-F-AB-0 HEATSINK 31X21MM FRONT PLASTIC PUSH PIN 31 21 Black Push Pin Front 960-31-21-S-AB-0 HEATSINK 31X21MM SIDE PLASTIC PUSH PIN 31 21 Black Push Pin Sides 960-31-21-D-AB-0 HEATSINK 31X21MM DIAGONAL PLASTIC PUSH PIN 31 21 Black Push Pin Diagonal 960-31-23-F-AB-0 HEATSINK 31X23MM FRONT PLASTIC PUSH PIN 31 23 Black Push Pin Front 960-31-23-S-AB-0 HEATSINK 31X23MM SIDE PLASTIC PUSH PIN 31 23 Black Push Pin Sides 960-31-23-D-AB-0 HEATSINK 31X23MM DIAGONAL PLASTIC PUSH PIN 31 23 Black Push Pin Diagonal 960-31-28-F-AB-0 HEATSINK 31X28MM FRONT PLASTIC PUSH PIN 31 28 Black Push Pin Front 960-31-28-S-AB-0 HEATSINK 31X28MM SIDE PLASTIC PUSH PIN 31 28 Black Push Pin Sides 960-31-28-D-AB-0 HEATSINK 31X28MM DIAGONAL PLASTIC PUSH PIN 31 28 Black Push Pin Diagonal 960-31-33-F-AB-0 HEATSINK 31X33MM FRONT PLASTIC PUSH PIN 31 33 Black Push Pin Front 960-31-33-S-AB-0 HEATSINK 31X33MM SIDE PLASTIC PUSH PIN 31 33 Black Push Pin Sides 960-31-33-D-AB-0 HEATSINK 31X33MM DIAGONAL PLASTIC PUSH PIN 31 33 Black Push Pin Diagonal Front Pins Side Pins Diagonal Pins Size (mm) Height (mm) Anodize Attachment Method Pin Location Plastic Push Pin Heat Sinks 31mm Thermal Performance Based on Height 31x31 Push Pin BGA Heatsinks 5.5 5.0 4.5 Thermal Resistance (C/W) 4.0 12 3.5 15 18 3.0 21 2.5 23 28 2.0 33 1.5 1.0 0.5 200 250 300 350 400 Airflow (LFM) 450 500 550 600
960-19-15-D-AB-0
物料型号:文档中列出了多种型号,例如960-19-12-F-AB-0、960-21-15-S-AB-0等,每个型号都有特定的尺寸、高度、阳极氧化处理、安装方法和引脚位置。
器件简介:960系列塑料推针散热器使用塑料推针与PCB上的孔配合,通过压缩弹簧将散热器压紧到被冷却的器件上。这些散热器设计用于多种行业,包括但不限于电信、医疗和军事。
引脚分配引脚分配有三种方式:前部(Front)、侧部(Sides)和对角线(Diagonal),以适应不同的PCB设计和散热需求。
参数特性:文档提供了不同型号的尺寸、高度和阳极氧化处理信息,以及是否包含接口材料。
功能详解:这些散热器设计用于各种空气流动条件下的散热,具有轻巧、阳极氧化的6063铝材质,易于快速安装,压缩弹簧确保了对PCB的牢固抓握。
应用信息:适用于多种行业,可以根据客户规格定制,也可以选择现成的标准产品。
封装信息:文档中提供了详细的封装尺寸和高度信息,以及阳极氧化和安装方法的选择。
960-19-15-D-AB-0 价格&库存
很抱歉,暂时无法提供与“960-19-15-D-AB-0”相匹配的价格&库存,您可以联系我们找货
960-19-15-D-AB-0
  • 1+38.697161+5.02093
960-19-15-D-AB-0
库存:711
