BMI270
6-axis, smart, low-power Inertial Measurement
Unit for high-performance applications
BMI270 – Data sheet
Document revision
1.0
Document release date
May 2019
Document number
BST-BMI270-DS000-02
Technical reference code
0 273 017 008
Notes
Data and descriptions in this document are subject to change without
notice. Product photos and pictures are for illustration purposes only
and may differ from the real product appearance
2 | 170
Bosch Sensortec | BMI270 Data sheet
Basic Description
BMI270
The device is a highly integrated, low power inertial measurement unit (IMU) that combines precise
acceleration and angular rate (gyroscopic) measurement with intelligent on-chip motion-triggered
interrupt features. BMI270 is an Ultra-low power IMU optimized for wearable applications.
The device integrates:
16-bit digital, triaxial accelerometer with ±2g/±4g/±8g/±16g range
16-bit digital, triaxial gyroscope with ±125dps/±250dps/±500dps/±1000dps/±2000dps range
Key features
Compact standard size LGA mold package, 14 pins, footprint 2.5x3.0mm² height 0.83mm
Primary digital interface with 10 MHz slave SPI (4-wire, 3-wire) and up to 1MHz I²C (Fm+)
Output data rates (ODR): 25 Hz … 6.4 kHz (gyroscope) and 0.78 Hz … 1.6 kHz (accelerometer)
Programmable low-pass filter (accelerometer ∣ gyroscope): bandwidth ca. 5 ∣ 3 … 680 ∣ 890 Hz
Wide power supply range: Analog VDD 1.71V … 3.6V and independent VDDIO 1.2V…3.6V
Ultra-low current consumption: typ. 685 µA (in full ODR and aliasing-free operation)
Performance mode for gyroscope to minimize noise level: typ. < 8 mdps /√Hz.
Built-in power management unit (PMU) for advanced power management and low power modes
Rapid startup time: 2 ms for gyroscope (in fast start mode) and 2 ms for accelerometer
Freely configurable secondary digital interface
400 kHz I²C (Fm) master interface hub for 1 I2C AUX sensor (e.g. ext. magnetometer, pressure)
o data synchronized to IMU
10 MHz slave SPI (4-wire, 3-wire) for high speed, calibration free OIS / Dual OIS (SPI) applications
o up to 6.4 kHz ODR, control register access and max. 676 µs group delay
2 KB on-chip FIFO buffer for accelerometer, gyroscope, timestamps, and AUX sensor data
Fast offset error compensation for accelerometer and gyroscope
Fast sensitivity error compensation for gyroscope (CRT, max. sensitivity error < 1%)
HW synchronization of accelerometer, gyroscope, and AUX sensor (< 1 µs)
Sensortime stamps for accurate system (host) and sensor (IMU) time synchronization (=1.62V,
IOL
很抱歉,暂时无法提供与“BMI270”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+21.88340
- 10+19.77640
- 30+18.28680
- 100+11.66200
