TP134005-1
TP134005-1
    DBUNLIMITED
    插件,D=13.8mm
    TP134005-1
TP134005-1 数据手册
4 3 2 1 Part Number: DRAWN TP134005-1 10/7/2016 CJ CHECKED 10/7/2016 P.D. Description: APPROVED Piezo Transducer 10/7/2016 J.S. D D This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View Bottom View Side View C C 4.50 6.80 2- 7.60 0.70 13.80 Masking Label Masking Label B A B Items Specifications Conditions Sound Pressure Level 80 dB (@ 10cm) Resonant Frequency 4,000 Hz Rated Voltage 5 V Voltage Range 1 ~ 20 V Capacitance 13,000 pF Max. Rated Current 1 mA Storage Temperature -30 ~ +80 C NOTES Operating Temperature -20 ~ +70 C 1) All dimensions are in mm unless otherwise noted Connection Method PC Pins Mount Type Thru Hole 3) All parts meet RoHS Housing Material Noryl 4) Subject to change or redrawn without notice Weight 1 4 REVISION HISTORY REV 1 DESCRIPTION DATE APPROVED Released from Engineering 10/21/2013 J.S. Updated to new template 10/7/2016 J.S. 2) All tolerances are 0.5 mm unless otherwise noted g 3 2 1 A
TP134005-1
1. 物料型号:文档中没有明确列出物料型号。 2. 器件简介:文档描述了一个压电换能器(Piezo Transducer),但没有提供详细的器件简介。 3. 引脚分配:文档提到连接方式为PCPins,但未具体说明引脚分配。 4. 参数特性: - 电容:13,000 pF - 最大额定电流:1 mA - 存储温度:-30~+80℃ - 工作温度:-20~+70℃ 5. 功能详解:文档中没有提供功能详解。 6. 应用信息:文档中没有提供应用信息。 7. 封装信息: - 封装材料:Noryl - 安装类型:通孔(Thru Hole)
TP134005-1 价格&库存
很抱歉,暂时无法提供与“TP134005-1”相匹配的价格&库存,您可以联系我们找货
