SMI6B-15-4-P5
SMI6B-15-4-P5
    CUIDEVICES
    SMI6B-15-4-P5
SMI6B-15-4-P5 数据手册
Additional Resources: Product Page | 3D Model date 06/23/2022 page 1 of 5 SERIES: SMI6B │ DESCRIPTION: AC-DC POWER SUPPLY FEATURES • • • • • • • • • • DoE Level VI, CoC Tier 2 efficiency up to 6 W power compact design interchangeable AC blades universal input (90~264 Vac) single regulated output from 5~15 Vdc over voltage and short circuit protections UL/cUL, GS, RCM, CCC, PSE safety approvals certified to 62368-1 custom designs available MODEL input voltage input frequency output voltage output current output power ripple and noise1 efficiency level2 no load power consumption range (Vac) range (Hz) nom (Vdc) max (A) max (W) max (mVp-p) average3 (%) 10% (%) typ (W) SMI6B-5 90 ~ 264 47 ~ 63 5 1.2 6.0 300 80.5 74.6 0.06 SMI6B-6 90 ~ 264 47 ~ 63 6 1.0 6.0 300 81.3 74.5 0.06 SMI6B-9 90 ~ 264 47 ~ 63 9 0.66 5.94 300 79.6 71.4 0.06 SMI6B-12 90 ~ 264 47 ~ 63 12 0.5 6.0 300 80.9 70.6 0.07 SMI6B-15 90 ~ 264 47 ~ 63 15 0.4 6.0 300 80.9 71.0 0.06 Notes: 1. At full load, 100-240 Vac input, 20 MHz bandwidth oscilloscope, output terminated with 0.1 μF and 10 μF capacitors. 2. CoC Tier 2 compliant 3. Average efficiency is measured at 25%, 50%, 75%, and 100% load. PART NUMBER KEY SMI6B - XX - X - XXX - CXX Base Number Reserved for Custom Configurations Output Voltage Blades: 4 = North America, Europe, United Kingdom, and Australia blades included V = North America, Europe, United Kingdom, Australia, and China blades included N = North America blade included E = Europe blade included B = United Kingdom blade included A = Australia blade included C = China blade included K = No blades included cui.com DC Plug Type: XXX = See output plug options on page 4 for more details Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: SMI6B │ DESCRIPTION: AC-DC POWER SUPPLY date 06/23/2022 │ page 2 of 5 INPUT parameter conditions/description min voltage 90 frequency 47 typ current leakage current at nominal AC input and frequency no load power consumption at 115/ 230 Vac, 60/50 Hz max units 264 Vac 63 Hz 0.2 A 0.25 mA 0.075 W max units OUTPUT parameter conditions/description min line regulation typ ±5 load regulation % ±5 start-up time at 115 Vac input rise time at 90~264 Vac input hold-up time at nominal input % 3 s 100 ms 5 ms PROTECTIONS parameter conditions/description min over current protection output shut down, auto recovery 5 Vdc output models 6 Vdc output models 9, 12 Vdc output models 15 Vdc output models short circuit protection output shut down, auto recovery typ max units 1.8 1.6 1.0 0.8 A A A A max units SAFETY & COMPLIANCE parameter conditions/description min isolation voltage input to output at 10 mA for 1 minute safety approvals UL/cUL, GS, RCM, CCC, PSE, UKCA EMI/EMC FCC Part 15B Class B, CE MTBF as per Telcordia SR-332, Issue 2 at 115/230 Vac, full load, 0~40°C RoHS yes typ 3,000 4,242 Vac Vdc 50,000 hours ENVIRONMENTAL parameter conditions/description min operating temperature storage temperature max units 0 typ 40 °C -20 60 °C operating humidity non-condensing 20 85 % storage humidity non-condensing 5 95 % cui.com Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: SMI6B │ DESCRIPTION: AC-DC POWER SUPPLY date 06/23/2022 │ page 3 of 5 MECHANICAL parameter conditions/description dimensions 47 x 34.5 x 26.5 min typ inlet plug interchangeable blades (North America, Europe, UK, Australia, China) ac blade clip type hidden clip weight 5 Vdc output models (without interchangeable blades) all other models (without interchangeable blades) max units mm 54 50 g g MECHANICAL DRAWING units: mm tolerance: ±1 mm INTERCHANGEABLE BLADES BLADE DESIGNATOR N E B A C REGION North America Europe UK Australia China BLADE ACCESSORY SMI-US-3 SMI-EU-3 SMI-UK-3 SMI-AU-3 SMI-CN-3 BLADE DC CORD units: mm Table 1 MODEL NO. CABLE CORD LENGTH SMI6B-5 UL2468, 22 AWG 1,530 mm ±50 SMI6B-6 UL2468, 22 AWG 1,530 mm ±50 SMI6B-9 UL2468, 24 AWG 1,530 mm ±50 SMI6B-12 UL2468, 24 AWG 1,530 mm ±50 SMI6B-15 UL2468, 24 AWG 1,530 mm ±50 cui.com Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: SMI6B │ DESCRIPTION: AC-DC POWER SUPPLY date 06/23/2022 │ page 4 of 5 DC PLUG TYPE PART NUMBER KEY XXX Plug Polarity: P = Center Positive Plug Code: X = Choose a code from the options below Plug Angle: “blank” = Straight R = Right Angle N = Center Negative Plug Polarity Code Dimensions (mm) Plug Angle Center Pos. Center Neg. Option Type A B C Straight Right ● ● 5 Standard 5.5 2.1 9.5 ● ● ● ● 6 Standard 5.5 2.5 9.5 ● ● ● ● 7 Standard 3.5 1.35 9.5 ● ● ● ● 10 Locking2 5.5 2.1 9.5 ● N/A ● ● 11 Locking2 5.5 2.5 9.5 ● N/A ● ● 12 EIAJ-1 2.35 0.7 9.5 ● ● ● ● 13 EIAJ-2 4.0 1.7 9.5 ● ● ● ● 14 EIAJ-3 4.75 1.7 9.5 ● ● N/A N/A CUB USB USB Type C ● N/A N/A N/A MUB USB Micro USB Type B ● N/A 1. Contact CUI for additional plug options 2. Maximum insertion depth is 10mm EIAJ Straight C C A Straight Right Angle (R) Locking C C B A B A C Right Angle (R) USB 5.8±0.5 6.7±0.3 2.5±0.3 VBUS: A4,A9,B4,B9 GND: A1,A12,B1,B12 A B A B Standard B Note: USB Type C cui.com P5(-) P1(+) Micro USB Type B Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: SMI6B │ DESCRIPTION: AC-DC POWER SUPPLY date 06/23/2022 │ page 5 of 5 REVISION HISTORY rev. description date 1.0 initial release 06/04/2019 1.01 company logo updated 09/30/2020 1.02 model table updated 11/27/2020 1.03 UKCA added to spec 08/10/2021 1.04 plug polarity symbols updated 09/16/2021 1.05 dc plugs updated 04/24/2022 1.06 ac blade clip type added 06/23/2022 The revision history provided is for informational purposes only and is believed to be accurate. Headquarters 20050 SW 112th Ave. Tualatin, OR 97062 800.275.4899 Fax 503.612.2383 cui.com techsupport@cui.com This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation. CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
SMI6B-15-4-P5 价格&库存
很抱歉,暂时无法提供与“SMI6B-15-4-P5”相匹配的价格&库存,您可以联系我们找货
SMI6B-15-4-P5
  • 1+74.023981+8.84961
  • 5+71.081545+8.49784
  • 10+69.8374010+8.34910
  • 25+68.2359525+8.15765
  • 50+67.0462750+8.01542
  • 120+65.57548120+7.83959
  • 360+63.77526360+7.62437
  • 600+62.95513600+7.52632
库存:641
