TUNS700F28
TUNS700F28
    COSEL
    插件,117.3x61.5mm
    700W AC-DC电源模块
TUNS700F28 数据手册
AC-DC Power Supplies Bus Converter . Power Module Type Medical electric equipment Power Factor Correction World wide Low Profile Safety Approvals Inrush current limiting Isolated OCP OVP Remote ON/OFF Parallel Operation TUNS-series Feature CE marking AC-DC Power Module Type Converter Harmonic attenuator (Complies with IEC61000-3-2 class A) Thin and small size Built-in overcurrent, overvoltage and thermal protection circuits Mounting hole (M3 tapped) Universal input 85 - 264VAC Peak current (TUNS500F) Wide input 85 - 305VAC For medical electric equipment Constant current regulation Output voltage can be varied to near 0V Parallel operation possible Low voltage directive RoHS Directive Safety Approval UL60950-1, C-UL, EN62368-1 (TUNS50F/100F/300F/500F/700F) UL62368-1, C-UL, EN62368-1 (TUNS1200F) ANSI/AAMI ES60601-1, EN60601-1 3rd (TUNS1200F) 5-year warranty Optional parts Heat sink July 13, 2022 TUNS-1 AC-DC Power Supplies Bus Converter . Power Module Type TUNS50F Ordering information TUN 1 S 2 50 3 F *Providing heat sink as option R 05 4 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal Input 5 Output voltage 6 Optional T : with Mounting hole (f3.4 thru) *Avoid short circuit between +BC and -BC. It may cause the failure of inside components. *Keep TRM open, if output voltage adjustment is not necessary. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT TUNS50F05 50.0 5V 10A TUNS50F12 50.4 12V 4.2A TUNS50F24 50.4 24V 2.1A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT ACIN 100V ACIN 200V ACIN 100V POWER FACTOR (Io=100%) ACIN 200V INRUSH CURRENT LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +100C *1 RIPPLE[mVp-p] -40 to 0C *1 0 to 15% Load *1 0 to +100C *1 RIPPLE NOISE[mVp-p] -40 to 0C *1 0 to 15% Load* 1 0 to +65C TEMPERATURE REGULATION[mV] -40 to +100C *2 DRIFT[mV] EFFICIENCY[%] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION[V] REMOTE SENSING REMOTE ON/OFF INPUT-OUTPUT INPUT-FG OUTPUT-FG OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD TUNS50F05 TUNS50F12 TUNS50F24 AC85 - 264 1f (Refer to “Derating”) 0.67typ (Io=100%) 0.35typ (Io=100%) 50/60 (47 - 63) 79typ 83typ 84typ 81typ 84typ 86typ 0.95typ 0.90typ Limited by external components (Thermistor) 0.75max (ACIN 240V 60Hz, Io=100%, According to IEC62368-1) 5 12 24 10 4.2 2.1 10max 24max 48max 10max 24max 48max 80max 120max 120max 120max 150max 150max 200max 280max 380max 120max 150max 150max 200max 200max 250max 280max 360max 460max 50max 120max 240max 100max 240max 480max 20max 40max 90max Fixed (TRM pin open), adjustable by external resistor or external signal 4.50 - 6.00 10.80 - 13.20 21.60 - 26.40 4.97 - 5.13 11.91 - 12.29 23.62 - 24.38 Works over 105% of rating and recovers automatically 6.30 - 7.00 13.90 - 16.35 27.60 - 32.40 Not provided Not provided AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (20±15C) -40 to +100C (On aluminum base plate), 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000 feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000 feet) max 10 - 55Hz, 49.0m/s2 (5G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each along X, Y and Z axis UL60950-1, C-UL (CSA60950-1), EN62368-1 Complies with IEC61000-3-2 (Class A) *3 58.4X12.7X37.3mm [2.3X0.5X1.47 inches] (WXHXD) / 80g max Conduction cooling (e.g. heat radiation from the aluminum base plate to the attached heat sink) *1 Refer to instruction manual for measuring method of electric characteristics. *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. *3 Please contact us about another class. TUNS-2 July 13, 2022 TUNS50F External view Base Plate (Aluminum) Lot No. 2- 2.5 48.3 [1.9] Dimensions in : 25.4 [0.3] [1.0] [0.19] 7.62 (4.7) -BC +BC Name Plate 7.62 7.62 37.3 max AC2 [1.47] [1.1] [0.5] +VOUT 27.94 ±0.5 TRM AC1 [0.5] ±0.2 -VOUT [0.05] 1.27 5- 1 ±0.1 12.7 [0.5] 2- 2 12.7 [1.9] 7.62 7.62 [0.2] [0.3] [0.3] 48.3 ±0.5 2- 3.5 25.4 [1.0] [0.3] [2.3] (5.0) 7.62 [0.3] [0.3] 58.4 max 5- 1.5 1.27 [0.05] 5.0 ±0.5 Case (PBT) [0.2] 12.7 ±0.5 Recommending size for processing PCB (TOP VIEW) 2-M3 Mounting Hole July 13, 2022 Div. : 0.2inch Tolerance : 0.3 [ 0.012] Weight : 80g max Dimensions in mm, [ ]=inches Mounting hole screwing torque : 0.49N m (5.0kgf mm [inch] cm) max TUNS-3 AC-DC Power Supplies Bus Converter . Power Module Type TUNS100F Ordering information TUN 1 S 2 100 3 F 4 *Providing heat sink as option R 05 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal Input 5 Output voltage 6 Optional T : with Mounting hole (f3.4 thru) *Avoid short circuit between +BC and -BC. It may cause the failure of inside components. *Keep TRM open, if output voltage adjustment is not necessary. *If remote sensing is not necessary, connect between +Vout & +S and between -Vout & -S. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT TUNS100F05 100.0 5V 20A TUNS100F12 100.8 12V 8.4A TUNS100F24 100.8 24V 4.2A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT ACIN 100V ACIN 200V ACIN 100V POWER FACTOR (Io=100%) ACIN 200V INRUSH CURRENT LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +100C *1 RIPPLE[mVp-p] -40 to 0C *1 0 to 15% Load *1 0 to +100C *1 RIPPLE NOISE[mVp-p] -40 to 0C *1 0 to 15% Load* 1 0 to +65C TEMPERATURE REGULATION[mV] -40 to +100C *2 DRIFT[mV] EFFICIENCY[%] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION[V] REMOTE SENSING REMOTE ON/OFF INPUT-OUTPUT INPUT-FG OUTPUT-FG OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD TUNS100F05 TUNS100F12 TUNS100F24 AC85 - 264 1f (Refer to “Derating”) 1.3typ (Io=100%) 0.7typ (Io=100%) 50/60 (47 - 63) 82typ 83typ 84typ 85typ 85typ 86typ 0.95typ 0.90typ Limited by external components (Thermistor) 0.75max (ACIN 240V 60Hz, Io=100%, According to IEC62368-1) 5 12 24 20 8.4 4.2 10max 24max 48max 10max 24max 48max 80max 120max 120max 120max 150max 150max 160max 240max 240max 120max 150max 150max 200max 200max 250max 240max 300max 300max 50max 120max 240max 100max 240max 480max 20max 40max 90max Fixed (TRM pin open), adjustable by external resistor or external signal 4.50 - 6.00 10.80 - 13.20 21.60 - 26.40 4.97 - 5.13 11.91 - 12.29 23.62 - 24.38 Works over 105% of rating and recovers automatically 6.30 - 7.00 13.90 - 16.35 27.60 - 32.40 Provided Not provided AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (20±15C) -40 to +100C (On aluminum base plate), 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000 feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000 feet) max 10 - 55Hz, 49.0m/s2 (5G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each along X, Y and Z axis UL60950-1, C-UL (CSA60950-1), EN62368-1 Complies with IEC61000-3-2 (Class A) *3 58.4X12.7X61.0mm [2.3X0.5X2.4 inches] (WXHXD) / 120g max Conduction cooling (e.g. heat radiation from the aluminum base plate to the attached heat sink) *1 Refer to instruction manual for measuring method of electric characteristics. *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. *3 Please contact us about another class. TUNS-4 July 13, 2022 TUNS100F External view Base Plate (Aluminum) 12.7 ±0.5 [0.5] Lot No. Case (PBT) 5.0 ±0.5 [0.2] Recommending size for processing PCB (TOP VIEW) 58.4 max [2.3] 48.3 ±0.5 (5.0) [0.2] [1.9] 2- 2.5 +VOUT 7.62 5.08 5.08 7.62 7.62 10.16 [0.3] [0.2][0.2] [0.3] [0.3] [0.4] 50.8 [2.0] 61max [0.4] 4- 3.5 48.3 [1.9] 25.4 [0.3] [1.0] Dimensions in : [0.2] -BC 7.62 ( 5.1) +BC [0.3] [0.3] +S [2.4] TRM [2.0] AC2 50.8 ±0.5 [0.5] -S [0.4] -VOUT 10.16 7.62 7.62 10.16 7- 1.5 AC1 12.7 25.4 [1.0] 2- 2 ±0.2 7- 1 ±0.1 Name Plate 7.62 [0.3] 4-M3 Mounting Hole Div. : 0.2inch Tolerance : 0.3 [ 0.012] Weight : 120g max Dimensions in mm, [ ]=inches Mounting hole screwing torque : 0.49N m (5.0kgf July 13, 2022 mm [inch] cm) max TUNS-5 AC-DC Power Supplies Bus Converter . Power Module Type TUNS300F Ordering information TUN 1 S 2 300 3 F 4 48 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal Input 5 Output voltage 6 Optional T : with Mounting hole (f3.4 thru) Y1: Outputvoltage adjustment range ±20% (Only 48V) R1: with Remote ON/OFF (Negative logic control) R2: with Remote ON/OFF  (Negative logic and Low standby power) R3: with Remote ON/OFF (Positive logic control) N1: Auto restart from thermal protection R *Avoid short circuit between +BC/R and -BC. It may cause the failure of inside components. *Keep TRM open, if output voltage adjustment is not necessary. *If remote sensing is not necessary, connect between +Vout & +S and between -Vout & -S. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT TUNS300F12 300 12V 25A TUNS300F28 308 28V 11A TUNS300F48 312 48V 6.5A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT ACIN 100V ACIN 200V ACIN 100V POWER FACTOR (Io=100%) ACIN 200V INRUSH CURRENT LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +100C *1 RIPPLE[mVp-p] -40 to 0C *1 0 to +100C *1 RIPPLE NOISE[mVp-p] -40 to 0C *1 0 to +65C TEMPERATURE REGULATION[mV] -40 to +100C *2 DRIFT[mV] EFFICIENCY[%] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION[V] REMOTE SENSING REMOTE ON/OFF *4 INPUT-OUTPUT-RC INPUT-FG *4 OUTPUT-RC-FG *4 OUTPUT-RC OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD TUNS300F12 TUNS300F28 TUNS300F48 AC85 - 264 1f 3.6typ (Io=100%) 1.8typ (Io=100%) 50/60 (47 - 63) 84typ 87typ 87typ 86typ 89typ 90typ 0.96typ 0.93typ Limited by external resistance 0.75max (ACIN 240V 60Hz, Io=100%, According to IEC62368-1) 12 28 48 25 11 6.5 24max 56max 96max 24max 56max 96max 120max 180max 250max 150max 200max 300max 150max 200max 300max 200max 300max 450max 120max 280max 480max 240max 560max 960max 40max 90max 180max Fixed (TRM pin open), adjustable by external resistor or external signal 9.60 - 14.40 22.40 - 33.60 38.40 - 52.80 (-Y1 Option : 38.4 - 57.6) 11.91 - 12.29 27.56 - 28.44 47.24 - 48.76 Works over 105% of rating and recovers automatically 15.00 - 16.80 35.00 - 39.20 55.20 - 64.80 (-Y1 Option : 60.0 - 67.2) Provided Optional (External power supply is required) AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (20±15C) AC100V 1minute, Cutoff current = 100mA, DC100V 10MW min (20±15C) -40 to +100C (On aluminum base plate), 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000 feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000 feet) max 10 - 55Hz, 49.0m/s2 (5G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each along X, Y and Z axis UL60950-1, C-UL (CSA60950-1), EN62368-1 Complies with IEC61000-3-2 (Class A) *3 117.3X12.7X61.5mm [4.62X0.5X2.42 inches] (WXHXD) / 190g max Conduction cooling (e.g. heat radiation from the aluminum base plate to the attached heat sink) *1 Refer to instruction manual for measuring method of electric characteristics. *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. *3 Please contact us about another class. *4 ”RC” is applicable when remote control (optional) is added. TUNS-6 July 13, 2022 TUNS300F Lot No. Recommending size for processing PCB (TOP VIEW) [0.5] Base Plate (Aluminum) 12.7 ±0.5 External view 11- 1.5 15 15 [0.59] [0.59] 44.05 [1.73] 4- 3.5 10.2 10 9 3×4=12 [0.4] [0.39] [0.35] [0.47] 50.8 [2.0] 5.0 117.3 max [0.2] ±0.5 Case (PBT) [4.62] 106.7 ±0.5 [4.2] (5.3) 2- 2 ±0.2 10 10.2 [0.47] [0.35] [0.39] [0.4] 3×4=12 9 [2.42] 61.5 max ±0.5 [2.0] 50.8 10 10.2 [0.39] [0.4] [0.21] 2- 2.5 106.7 [4.2] 4 [0.16] 11- 1 ±0.1 15 15 44.05 [0.59] [0.59] [1.73] Control pin for Remote ON/OFF (Option) [0.16] Div. : 0.5inch [0.21] 4 Name Plate (5.35) Dimensions in : 4-M3 Mounting Hole AC1 -VOUT AC2 +VOUT -S +S TRM IOG R +BC -BC RC2 (Option) RC1 (Option) mm [inch] Tolerance : 0.3 [ 0.012] Weight : 190g max Dimensions in mm, [ ]=inches Mounting hole screwing torque : 0.49N m (5.0kgf cm) max 4-FG July 13, 2022 TUNS-7 AC-DC Power Supplies Bus Converter . Power Module Type TUNS500F Ordering information TUN 1 S 2 500 3 F 4 48 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal Input 5 Output voltage 6 Optional T : with Mounting hole (f3.4 thru) Y1: Outputvoltage adjustment range ±20% (Only 48V) R1: with Remote ON/OFF (Negative logic control) R2: with Remote ON/OFF  (Negative logic and Low standby power) R3: with Remote ON/OFF (Positive logic control) N1: Auto restart from thermal protection R *Avoid short circuit between +BC/R and -BC. It may cause the failure of inside components. *Keep TRM open, if output voltage adjustment is not necessary. *If remote sensing is not necessary, connect between +Vout & +S and between -Vout & -S. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT TUNS500F12 504 12V 42A (Peak 55A) TUNS500F28 504 28V 18A (Peak 24A) TUNS500F48 504 48V 10.5A (Peak 14A) SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT ACIN 100V ACIN 200V ACIN 100V POWER FACTOR (Io=100%) ACIN 200V INRUSH CURRENT LEAKAGE CURRENT[mA] VOLTAGE[V] *3 CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +100C *1 RIPPLE[mVp-p] -40 to 0C *1 0 to +100C *1 RIPPLE NOISE[mVp-p] -40 to 0C *1 0 to +65C TEMPERATURE REGULATION[mV] -40 to +100C *2 DRIFT[mV] EFFICIENCY[%] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION[V] REMOTE SENSING REMOTE ON/OFF *5 INPUT-OUTPUT-RC INPUT-FG *5 OUTPUT-RC-FG *5 OUTPUT-RC OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD TUNS500F12 TUNS500F28 TUNS500F48 AC85 - 264 1f 6.0typ (Io=100%) 3.0typ (Io=100%) 50/60 (47 - 63) 84typ 87typ 88typ 86typ 90typ 90.5typ 0.96typ 0.93typ Limited by external resistance 0.75max (ACIN 240V 60Hz, Io=100%, According to IEC62368-1) 12 28 48 42 (Peak 55) 18 (Peak 24) 10.5 (Peak 14) 24max 56max 96max 24max 56max 96max 120max 180max 250max 150max 200max 300max 150max 200max 300max 200max 300max 450max 120max 280max 480max 240max 560max 960max 40max 90max 180max Fixed (TRM pin open), adjustable by external resistor or external signal 9.60 - 14.40 22.40 - 33.60 38.40 - 52.80 (-Y1 Option : 38.4 - 57.6) 11.91 - 12.29 27.56 - 28.44 47.24 - 48.76 Works over 101% of peak current and recovers automatically 15.00 - 16.80 35.00 - 39.20 55.20 - 64.80 (-Y1 Option : 60.0 - 67.2) Provided Optional (External power supply is required) AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (20±15C) AC100V 1minute, Cutoff current = 100mA, DC100V 10MW min (20±15C) -40 to +100C (On aluminum base plate), 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000 feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000 feet) max 10 - 55Hz, 49.0m/s2 (5G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each along X, Y and Z axis UL60950-1, C-UL (CSA60950-1), EN62368-1 Complies with IEC61000-3-2 (Class A) *4 117.3X12.7X61.5mm [4.62X0.5X2.42 inches] (WXHXD) / 190g max Conduction cooling (e.g. heat radiation from the aluminum base plate to the attached heat sink) *1 Refer to instruction manual for measuring method of electric characteristics. *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. *3 ( ) means peak current. Avoid operating with peak current continuously. It may cause failure of the components inside the product. There are limitation of available condition of the peak current, such as peak time, duty etc. (Refer to the instruction manual in detail.) *4 Please contact us about another class. *5 ”RC” is applicable when remote control (optional) is added. TUNS-8 July 13, 2022 TUNS500F Lot No. Recommending size for processing PCB (TOP VIEW) [0.5] Base Plate (Aluminum) 12.7 ±0.5 External view 11- 1.5 15 15 [0.59] [0.59] 44.05 [1.73] 4- 3.5 10.2 10 9 3×4=12 [0.4] [0.39] [0.35] [0.47] 50.8 [2.0] 5.0 117.3 max [0.2] ±0.5 Case (PBT) [4.62] 106.7 ±0.5 [4.2] (5.3) 2- 2 ±0.2 10 10.2 [0.47] [0.35] [0.39] [0.4] 3×4=12 9 [2.42] 61.5 max ±0.5 [2.0] 50.8 10 10.2 [0.39] [0.4] [0.21] 2- 2.5 106.7 [4.2] 4 [0.16] 11- 1 ±0.1 15 15 44.05 [0.59] [0.59] [1.73] Control pin for Remote ON/OFF (Option) [0.16] Div. : 0.5inch [0.21] 4 Name Plate (5.35) Dimensions in : 4-M3 Mounting Hole AC1 -VOUT AC2 +VOUT -S +S TRM IOG R +BC -BC RC2 (Option) RC1 (Option) mm [inch] Tolerance : 0.3 [ 0.012] Weight : 190g max Dimensions in mm, [ ]=inches Mounting hole screwing torque : 0.49N m (5.0kgf cm) max 4-FG July 13, 2022 TUNS-9 AC-DC Power Supplies Bus Converter . Power Module Type TUNS700F Ordering information TUN 1 S 2 700 3 F 4 *Avoid short circuit between +BC/R and -BC. It may cause the failure of inside components. *Keep TRM open, if output voltage adjustment is not necessary. *If remote sensing is not necessary, connect between +Vout & +S and between -Vout & -S. TUNS700F12 700.8 12V 58.4A -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal Input 5 Output voltage 6 Optional T : with Mounting hole (f3.4 thru) Y1: Outputvoltage adjustment range ±20% (Only 48V) R1: with Remote ON/OFF (Negative logic control) R2: with Remote ON/OFF (Negative logic and Low standby power)  R3: with Remote ON/OFF (Positive logic control) P : Parallel operation (Output voltage trimming disabled, Remote sensing disabled) R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT 48 5 TUNS700F28 700.0 28V 25A TUNS700F48 700.8 48V 14.6A SPECIFICATIONS MODEL VOLTAGE[V] TUNS700F48 POWER FACTOR (Io=100%) INRUSH CURRENT LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +100C* 1 RIPPLE[mVp-p] -40 to 0C *1 0 to +100C *1 OUTPUT RIPPLE NOISE[mVp-p] -40 to 0C *1 0 to +65C TEMPERATURE REGULATION[mV] -40 to +100C *2 DRIFT[mV] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION PROTECTION OVERVOLTAGE PROTECTION[V] CIRCUIT AND REMOTE SENSING OTHERS REMOTE ON/OFF TUNS700F12 TUNS700F28 AC85 - 264 1f 8.6typ (Io=100%) 4.1typ (Io=100%) 50/60 (47 - 63) 83typ 86typ 86typ 89typ 0.96typ 0.93typ Limited by external resistance 0.75max (ACIN 240V 60Hz, Io=100%, According to IEC62368-1) 12 28 58.4 25 24max 56max 24max 56max 120max 180max 150max 200max 150max 200max 200max 300max 120max 280max 240max 560max 40max 90max Fixed (TRM pin open), adjustable by external resistor or external signal 9.60 - 14.40 22.40 - 33.60 11.91 - 12.29 27.56 - 28.44 Works over 105% of rating and recovers automatically 15.00 - 16.80 35.00 - 39.20 Provided Optional (External power supply is required) MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT TUNS700F12-P 700.8 12V 58.4A TUNS700F48-P 700.8 48V 14.6A CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT EFFICIENCY[%] ACIN 100V ACIN 200V ACIN 100V ACIN 200V TUNS700F28-P 700.0 28V 25A 87typ 90typ 48 14.6 96max 96max 250max 300max 300max 450max 480max 960max 180max 38.40 - 52.80 (-Y1 Option : 38.4 - 57.6) 47.24 - 48.76 55.20 - 64.80 (-Y1 Option : 60.0 - 67.2) SPECIFICATIONS MODEL VOLTAGE[V] TUNS700F12-P TUNS700F28-P AC85 - 264 1f ACIN 100V 8.6typ (Io=100%) CURRENT[A] ACIN 200V 4.1typ (Io=100%) FREQUENCY[Hz] 50/60 (47 - 63) ACIN 100V 83typ 86typ INPUT EFFICIENCY[%] ACIN 200V 86typ 89typ POWER FACTOR ACIN 100V 0.96typ (Io=100%) ACIN 200V 0.93typ INRUSH CURRENT Limited by external resistance LEAKAGE CURRENT[mA] 0.75max (ACIN 240V 60Hz, Io=100%, According to IEC62368-1) VOLTAGE[V] 12 28 CURRENT[A] 58.4 25 VOLTAGE ACCURACY[%] +5, -3 +5, -3 0 to +100C *1 240max 360max OUTPUT RIPPLE[mVp-p] -40 to 0C *1 300max 400max 0 to +30% Load *1 360max 540max 0 to +100C *1 300max 400max RIPPLE NOISE[mVp-p] -40 to 0C *1 400max 600max 0 to +30% Load *1 450max 600max PROTECTION OVERCURRENT PROTECTION Works over 105% of rating and recovers automatically 35.00 - 39.20 CIRCUIT AND OVERVOLTAGE PROTECTION[V] 15.00 - 16.80 REMOTE ON/OFF Optional (External power supply is required) OTHERS TUNS-10 July 13, 2022 TUNS700F48-P 87typ 90typ 48 14.6 +5, -3 600max 700max 900max 700max 1000max 1000max 55.20 - 64.80 TUNS700F GENERAL SPECIFICATIONS *4 INPUT-OUTPUT-RC INPUT-FG ISOLATION *4 OUTPUT-RC-FG *4 OUTPUT-RC OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT AGENCY APPROVALS SAFETY AND NOISE REGULATIONS HARMONIC ATTENUATOR CASE SIZE/WEIGHT OTHERS COOLING METHOD AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (20±15C) AC100V 1minute, Cutoff current = 100mA, DC100V 10MW min (20±15C) -40 to +100C (On aluminum base plate), 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000 feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000 feet) max 10 - 55Hz, 49.0m/s2 (5G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each along X, Y and Z axis UL60950-1, C-UL (CSA60950-1), EN62368-1 Complies with IEC61000-3-2 (Class A) *3 117.3X12.7X61.5mm [4.62X0.5X2.42 inches] (WXHXD) / 190g max Conduction cooling (e.g. heat radiation from the aluminum base plate to the attached heat sink) *1 Refer to instruction manual for measuring method of electric characteristics. *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. *3 Please contact us about another class. *4 ”RC” is applicable when remote control (optional) is added. Lot No. Recommending size for processing PCB (TOP VIEW) [0.5] Base Plate (Aluminum) 12.7 ±0.5 External view 11- 1.5 15 15 [0.59] [0.59] 44.05 [1.73] 4- 3.5 10.2 10 9 3×4=12 [0.4] [0.39] [0.35] [0.47] 50.8 [2.0] 5.0 117.3 max [0.2] ±0.5 Case (PBT) [4.62] 106.7 ±0.5 [4.2] (5.3) 2- 2 ±0.2 10 10.2 [0.47] [0.35] [0.39] [0.4] 3×4=12 9 [2.42] ±0.5 [2.0] 50.8 61.5 max 10 10.2 [0.39] [0.4] [0.21] 2- 2.5 106.7 [4.2] 4 [0.16] 11- 1 ±0.1 15 15 44.05 [0.59] [0.59] [1.73] Control pin for Remote ON/OFF (Option) [0.16] Div. : 0.5inch [0.21] 4 Name Plate (5.35) Dimensions in : 4-M3 Mounting Hole AC1 -VOUT AC2 +VOUT -S, -M (Option : P) +S, +M (Option : P) TRM, NC (Option : P) IOG R +BC -BC RC2 (Option : R1/R2) RC1 (Option : R1/R2) mm [inch] Tolerance : 0.3 [ 0.012] Weight : 190g max Dimensions in mm, [ ]=inches Mounting hole screwing torque : 0.49N m (5.0kgf cm) max 4-FG July 13, 2022 TUNS-11 AC-DC Power Supplies Bus Converter . Power Module Type TUNS1200F Ordering information TUN 1 S 2 1200 3 F 4 48 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal Input 5 Output voltage 6 Optional T : with Mounting hole (f3.4 thru) Y1: Outputvoltage adjustment range ±20% (Only 48V) R3: with Remote ON/OFF (Positive logic control) N1: Auto restart from thermal protection R *Avoid short circuit between +BC/R and -BC. It may cause the failure of inside components. *Keep VTRM open, if output voltage adjustment is not necessary. *Keep ITRM open, if output current adjustment is not necessary. *If remote sensing is not necessary, connect between +Vout & +S and between -Vout & -S. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT TUNS1200F12 1008 12V 84A TUNS1200F28 1204 28V 43A TUNS1200F48 1200 48V 25A TUNS1200F65 1202.5 65V 18.5A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT ACIN 100V ACIN 200V ACIN 100V POWER FACTOR (Io=100%) ACIN 200V INRUSH CURRENT LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +100C *1 RIPPLE[mVp-p] -40 to 0C *1 0 to +100C *1 RIPPLE NOISE[mVp-p] -40 to 0C *1 0 to +80C *1 TEMPERATURE REGULATION[mV] -40 to +100C *1 *2 DRIFT[mV] EFFICIENCY[%] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION PROTECTION OVERVOLTAGE PROTECTION[V] CIRCUIT AND REMOTE SENSING OTHERS REMOTE ON/OFF INPUT-OUTPUT INPUT-FG ISOLATION OUTPUT-FG OUTPUT-RC, PG OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT AGENCY APPROVALS SAFETY AND NOISE REGULATIONS HARMONIC ATTENUATOR CASE SIZE/WEIGHT OTHERS COOLING METHOD TUNS1200F12 TUNS1200F28 TUNS1200F48 TUNS1200F65 AC85 - 305V 1f 12typ 14typ 14typ 14typ 5.9typ 6.7typ 6.6typ 6.7typ 50/60 (47 - 63) 85typ 89typ 90typ 89typ 87typ 91typ 92typ 91typ 0.98typ 0.95typ Limited by external resistance 0.5max (ACIN 240V 60Hz, Io=100%, According to IEC60601-1) 12 28 48 65 84 43 25 18.5 24max 56max 96max 130max 24max 56max 96max 130max 150max 180max 250max 350max 180max 200max 300max 400max 180max 200max 300max 400max 200max 300max 450max 450max 120max 280max 480max 650max 240max 560max 960max 1300max 40max 90max 180max 240max Fixed (VTRM pin open), adjustable by external resistor or external signal 9.60 - 14.40 22.40 - 33.60 38.40 - 52.80 (Y1:38.4 - 57.6) 52.00 - 78.00 11.91 - 12.29 27.56 - 28.44 47.24 - 48.76 63.96 - 66.04 Works over 105% of rating and recovers automatically 15.00 - 16.80 35.00 - 39.20 55.20 - 60.00 (Y1:60.0 - 67.2) 81.25 - 91.00 Provided Provided AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) 2MOOP AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) 1MOOP TUNS1200F12/28/48 : AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (20±15C) : AC1,200V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C) 1MOOP TUNS1200F65 AC100V 1minute, Cutoff current = 100mA, DC100V 10MW min (20±15C) -40 to +100C (On aluminum base plate), 20 - 95%RH (Non condensing) (Refer to DERATING CURVE) -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000 feet) max 10 - 55Hz, 49.0m/s2 (5G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each along X, Y and Z axis UL62368-1, EN62368-1, C-UL (equivalent to CAN/CSA-C22.2 No.62368-1), ANSI/AAMI ES60601-1, EN60601-1 3rd, C-UL (equivalent to CAN/CSA-C22.2 No.60601-1), Complies with IEC60601-1-2 4th Complies with IEC61000-3-2 (Class A) *3 117.3X12.7X86.8mm [4.62X0.5X3.42 inches] (WXHXD) / 280g max Conduction cooling (e.g. heat radiation from the aluminum base plate to the attached heat sink) *1 Refer to instruction manual for measuring method of electric characteristics. *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated input/output. *3 Please contact us about another class. TUNS-12 July 13, 2022 TUNS1200F 12.7±0.5 [0.5] Lot No. [0.2] Base plate(Aluminum) 5±0.5 External view Case(PBT) 4-M3(FG) Mounting Hole 15 15 [0.59] [0.59] AC1 2.5 3.5 9-f [1.3] 10-f 1.5 [3.0] 10 [0.39] 33.1 [0.39] [0.2] 10 5 4-f 4 [0.16] [4.2] ¶ Dimensions in : PGG RC2 CB -S +S ¶ Div. : 0.5inch mm [inch] ¶ Tolerance : �0.3 [�0.012] ¶ Weight : 280g max ¶ Dimensions in mm, [ ]=inches ¶ Mounting hole screwing torque : 0.49N-m (5.0kgf-cm) max -VOUT AC2 15 106.7 Pin Configuration PG RC1 AUX VTRM ITRM 15 [0.59] [0.59] 76.2 [0.45] 10 5 10 4x4=16 [0.39] [0.63] [0.2] [3.42] 86.8max 34.3 [1.35] [0.2] 34.3 ±0.2 5.05 9-f2 [3.0] [0.39] 76.2±0.5 10-f1 ±0.1 10 11.45 [0.16] [1.3] 33.1 Name Plate [1.35] Recommending size for processing PCB (TOP VIEW) 4 [0.45] [0.63] [0.39][0.2] [4.2] 5 [0.2] [0.39] [0.2] [4.62] 106.7±0.5 11.45 4x4=16 10 5 117.3max 5.06 +VOUT R +BC -BC Bottom View July 13, 2022 TUNS-13 TUNS-series Pin Configuration ¿ TUNS50F No. Pin Function TUNS50F TUNS100F Connection 1 1 AC1 AC input 2 2 AC2 3 3 +BC +BC output 4 4 -BC -BC output 5 5 +VOUT +DC output 7 9 -VOUT -DC output 8 -S Remote sensing (-) 6 +S Remote sensing (+) 6 7 TRM Adjustment of output voltage FG Mounting hole (FG) 7-VOUT 6TRM 5+VOUT 1AC1 2AC2 2-FG 3+BC 4-BC *bottom view ¿ TUNS100F 9-VOUT 1AC1 8-S 7TRM 6+S 2AC2 5+VOUT 4-FG 3+BC 4-BC *bottom view ¿ TUNS300F/TUNS500F/TUNS700F 1 AC1 7 -VOUT 2 AC2 6 +VOUT 8 -S 9 +S 0 TRM å IOG 4-FG 3 R 4 +BC 5 -BC *bottom view ¿ TUNS700FOO-P (OPTION) 1 AC1 7 -VOUT 2 AC2 6 +VOUT 8 -M 9 +M 0 NC å IOG 4-FG 3 R 4 +BC 5 -BC No. 1 2 3 4 5 6 7 8 9 0 å ∫ ç - Pin Connection AC1 AC2 R +BC -BC +VOUT -VOUT -S +S TRM IOG RC1 RC2 FG Function AC input External resistor for inrush current protection +BC output -BC output +DC output -DC output Remote sensing (-) Remote sensing (+) Adjustment of output voltage Inverter operation monitor Remote ON/OFF (Option) Mounting hole (FG) Pin Function Connection 8 -M Output voltage monitor terminal 9 +M 0 NC No connection Other than the above are the same as standard products. No. *bottom view ¿ TUNS1200F No. ˆPG ˙RC1 ©AUX ƒVTRM ´ITRM 1AC1 9 -VOUT 8 2AC2 3R 4+BC 5-BC *bottom view TUNS-14 ∂PGG çRC2 ∫CB å-S 0+S 7 +VOUT 6 4-FG 1 2 3 4 5 67 89 0 å ∫ ç ∂ ´ ƒ © ˙ ˆ - Pin Connection AC1 AC2 R +BC -BC +VOUT -VOUT +S -S CB RC2 PGG ITRM VTRM AUX RC1 PG FG July 13, 2022 Function AC input External resistor for inrush current protection +BC output -BC output +DC output -DC output Remote sensing (+) Remote sensing (-) Current balance Remote ON/OFF ground Power good output ground Adjustment of output current Adjustment of output voltage Auxiliary output Remote ON/OFF Power good output Mounting hole (FG) TUNS-series Implementation・Mounting Method Mounting method ¡Use with the conduction cooling (e.g. heat dissipation from the aluminum base plate to the attached heat sink). ¡Use a heat sink that larger than the power supply and has a large thickness so that the alminum base plate can be cooled uniformly. ¡The unit can be mounted in any direction. When two or more power supplies are used side by side, position them with proper intervals to allow enough air ventilation. Aluminum base plate temperature of each power supply should not exceed the temperature range shown in “derating”. ¡Avoid placing the AC input line pattern layout underneath the unit. It will increase the line conducted noise. Make sure to leave an ample distance between the line pattern layout and the unit. Also avoid placing the DC output line pattern underneath the unit because it may increase the output noise. Lay out the pattern away from the unit. ¡Avoid placing the signal line pattern layout underneath the unit because the power supply might become unstable. Lay out the pattern away from the unit. ¡High-frequency noise radiates directly from the unit to the atmosphere. Therefore, design the shield pattern on the printed circuit board and connect it to FG or -BC.The shield pattern prevents noise radiation. ¡When a heat sink cannot be fixed on the base plate side, order the power module with “-T”option. A heat sink can be mounted by affixing a M3 tap on the heat sink. Please make sure a mounting hole will be connected to a grounding capacitor CY. Standard Optional : -T Mounting hole M3 tapped f3.4 thru ¿ TUNS50F/100F/300F/500F/700F Stress onto the pins +VOUT, -VOUT ¡When too much stress is applied to the pins may damage internal connections. Avoid applying stress in excess of that shown in right Others figure. ¡The pins are soldered onto the internal PCB. Therefore, Do not bend or pull the leads with excessive force. Less than 39.2N(4kgf) ¡Mounting hole diameter of PCB should be 3.5mm to reduce the stress to the pins. ¡Fix the unit on PCB (fixing fittings) by screws to reduce the stress to the pins. Be sure to mount the unit first, then solder the unit. Soldering temperature : 260C for up to 15 seconds. ¡Flow soldering ¡Soldering iron (26W) : 450Cfor up to 5 seconds. Less than 39.2N(4kgf) Less than 19.6N(2kgf) Less than 19.6N(2kgf) Less than 19.6N(2kgf) Less than 39.2N(4kgf) ¿ TUNS1200F AC1,AC2,R,+BC,-BC,+VOUT,-VOUT Less than 39.2N(4kgf) Less than 39.2N(4kgf) Others Less than 19.6N(2kgf) Less than 19.6N(2kgf) Less than 19.6N(2kgf) Less than 39.2N(4kgf) Derating Input voltage derating curve ¿ TUNS50F/100F ¿ TUNS700F/1200F *TUNS1200F12 has no input voltage derating. Load factor Load Factor [%] [%] 100 80 85 90 100 85 85 [AC V] 100 [AC V] ¿ TUNS300F/500F *TUNS300F/500F has no input voltage derating. July 13, 2022 TUNS-15 TUNS-series Derating Output voltage derating curve ¡Use the power modules with conduction cooling (e.g. heat dissipation from the aluminum base plate to the attached heat sink). Below shows the derating curves with respect to the aluminum base plate temperature. Note that operation within the hatched areas will cause a significant level of ripple and ripple noise. ¡Please measure the temperature on the aluminum base plate edge side when you cannot measure the temperature of the center part of the aluminum base plate.In this case, please take 5deg temperature margin from the derating characteristics shown in below. Please reduce the temperature fluctuation range as much as possible when the up and down of the temperature are frequently generated. Contact us for more information on cooling methods. ¿ TUNS50F/100F Load Factor [%] 100 Tc Measuring point 1 (75) 50 1TUNS50F/TUNS100F 0 -40 -20 0 20 40 (85) 80 60 100 Aluminum base plate temperature Tc [C] TUNS50F ¿ TUNS300F ¿ TUNS500F 100 1 Load Factor [%] Load Factor [%] 100 1TUNS300F 50 -20 0 20 40 60 80 Load Factor [%] 100 2 (75) -20 0 20 40 Tc Measuring point 1TUNS700F12 2TUNS700F28,TUNS700F48 50 (40) 1 0 -20 0 20 40 (50) 60 (70) 80 100 TUNS300F / TUNS500F / TUNS700F Aluminum base plate temperature Tc [C] ¿ TUNS1200F Tc Measuring point Load Factor [%] 100 0 -40 3 2 1 (75) (65) (60) 50 1 TUNS1200F12 2 TUNS1200F28,TUNS1200F48 (Vin = 85~170VAC), TUNS1200F65 3 TUNS1200F28,TUNS1200F48 (Vin = 170~305VAC) -20 0 20 40 60 (85) 80 100 Aluminum base plate temperature Tc [C] TUNS-16 60 (75) 80 Aluminum base plate temperature Tc [C] ¿ TUNS700F July 13, 2022 2 1TUNS500F12 2TUNS500F28,TUNS500F48 (60) 50 -40 100 Aluminum base plate temperature Tc [C] -40 1 0 0 -40 TUNS100F TUNS1200F 100 TUNS-series Instruction Manual ◆ It is neccessary to read the “Instruction Manual” and “Before using our product” before you use our product. Instruction Manual https://en.cosel.co.jp/product/powersupply/TUNS/ Before using our product https://en.cosel.co.jp/technical/caution/index.html TUNS NOTICE Basic Characteristics Data Model TUNS50F TUNS100F TUNS300F TUNS500F TUNS700F TUNS1200F Circuit method Switching frequency [kHz] Active filter 80-600 Flyback converter 100-300 Active filter 80-600 Forward converter 300 Active filter 100 Half-bridge converter 400 Active filter 100 Half-bridge converter 400 Active filter 100 Half-bridge converter 400 Active filter 100 Full-bridge converter 400 Input current [A] *1 Inrush current protection circuit Material 0.67 Thermistor Aluminum 1.3 Thermistor 3.6 PCB/Pattern Single Double sided sided Series/Parallel operation availability Series operation Parallel operation Yes Yes *2 Aluminum Yes Yes *2 SCR Aluminum Yes Yes *2 6.0 SCR Aluminum Yes Yes *2 8.6 SCR Aluminum Yes Yes *2 14 SCR Aluminum Yes Yes Yes *1 The  value of input current is at ACIN 100V and rated load. *2 Refer to instruction manual. July 13, 2022 TUNS-17
TUNS700F28 价格&库存
很抱歉,暂时无法提供与“TUNS700F28”相匹配的价格&库存,您可以联系我们找货
TUNS700F28
