PRESSURE TRANSDUCERS WITH AMP.
PA-860/PA-868
INTERNAL STRUCTURE
PA-860/PA-868 (G 3/8)
3
1
2
4
5
Part name
Material
■ FEATURES
①
Fitting
②
Stainless steel diaphragm
③
Sensor chip
Silicone
④
Back cover
SUS 303
⑤
Drip-proof cover
Resistant against surge pressure
SUS 316L welded stainless steel diaphragm
Built-in amplifier circuit
Voltage or current output modes are available
Iron, Ni-plated
SUS 316L
Silicone rubber
■ MODEL NUMBER DESIGNATION
PA-860 - 503 P - B - R2
Series name
PA-860:
(Voltage output)
PA-868:
(Current output)
Fitting
Rated pressure range
503:0
104:0
204:0
354:0
5 MPa
10 MPa
20 MPa
35 MPa
Pressure unit
P:Pa pressure unit
※ Please refer to the LIST OF MODEL NUMBERS when placing orders.
R2:R 1/4
G3:G 3/8
Drip-proof cover
B:Non-provided
H:Provided
PA-860/PA-868
■ LIST OF MODEL NUMBERS
Output Fitting
Pressure reference
Gauge
Drip-proof cover Rated pressure range 0 ~ 5
R2
(R 1/4)
Voltage
output
G3
(G 3/8)
R2
(R1/4)
Current
output
G3
(G 3/8)
0 ~ 10
0 ~ 20
0 ~ 35
Non-provided
PA-860-503P-B-R2 PA-860-104P-B-R2 PA-860-204P-B-R2 PA-860-354P-B-R2
Provided
PA-860-503P-H-R2 PA-860-104P-H-R2 PA-860-204P-H-R2 PA-860-354P-H-R2
Non-provided
PA-860-503P-B-G3 PA-860-104P-B-G3 PA-860-204P-B-G3 PA-860-354P-B-G3
Provided
PA-860-503P-H-G3 PA-860-104P-H-G3 PA-860-204P-H-G3 PA-860-354P-H-G3
Non-provided
PA-868-503P-B-R2 PA-868-104P-B-R2 PA-868-204P-B-R2 PA-868-354P-B-R2
Provided
PA-868-503P-H-R2 PA-868-104P-H-R2 PA-868-204P-H-R2 PA-868-354P-H-R2
Non-provided
PA-868-503P-B-G3 PA-868-104P-B-G3 PA-868-204P-B-G3 PA-868-354P-B-G3
Provided
PA-868-503P-H-G3 PA-868-104P-H-G3 PA-868-204P-H-G3 PA-868-354P-H-G3
※ Verify the above model numbers when placing orders.
■ STANDARD SPECIFICATIONS
● Unless otherwise specified, the specs are defined at an ambient temperature of 25 ± 5 °C and excitation voltage of 12 V DC.
Item
Model number
503P 104P 204P 354P 503P 104P 204P 354P
Gauge ※ 1
Pressure reference
General specifications
PA-860 PA-868
MPa
5 10 20 35 5 10 20 35
Maximum pressure
MPa
10 20 40 52.5 10 20 40 52.5
Operating temp. range
°C
− 10 ~ 75
Compensated temp. range
°C
0 ~ 50
Operating humidity
Storage temp.
%RH
°C
Pressure medium ※ 2
Insulation resistance
MΩ
minimum
100 (500 V DC)
350 V AC, 60 s(Leakage current 0.5 mA maximum)
R 1/4、G 3/8
Pressure port
Protection grade
− 20 ~ 90(Atmospheric pressure, humidity 65 %RH maximum)
Hydraulic oil
Dielectric strength
Net weight
35 ~ 85(No condensation)
g
Approx. 170
Without drip-proof cover : IP54, With drip-proof cover : IP65
※ 1:The transducer measures gauge pressure using an absolute pressure sensing element.
※ 2:Hydraulic oil is used as a measurement medium at the time of delivery inspection.
PA-860/PA-868
Power
Item
Model number
Supply voltage
PA-860 PA-868
12 ~ 24 ± 10 %
V DC
maximum
Consumption current
10 mA
1~5V
4 ~ 20 mA
Zero voltage/current
1 ± 0.05 V
4 ± 0.1 mA
Span voltage/current
4 ± 0.05 V
16 ± 0.1 mA
DC
Output voltage/current
Analog output
%F.S.
± 0.5
ZERO %F.S./°C
± 0.05
SPAN %F.S./°C
± 0.05
Linearity/Hysteresis
Thermal error
500 Ω maximum ※3
(At power voltage 24 V)
10 kΩ minimum
Load resistance
ms
maximum
Response
※3:Maximum load resistance RL(Max.) = (Vopr-10.8)/0.026 Vopr = power supply voltage to be used.
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Test conditions (At 25 ± 5 °C)
Shock
10 ~ 500 Hz, 1.5 mm maximum/98.1 m/s2,
3 directions for 2 hours each
490 m/s2
3 directions for 3 times each
Pressure cycling
0 〜 Rated pressure 106 cycles
Moisture resistance
40 °C, 90 ~ 95 %RH, 240 hrs.
Vibration
Permissible change
Zero voltage/current, Span voltage/current:
± 3 %F.S. maximum each
■ INTERNAL ELECTRICAL SCHEMATICS
● PA-860
● PA-868
Pressure
Sensor
Main circuit
Power ⊕
Output
Power ⊕
Pressure
Sensor
Main circuit
Common
Output
Shield
Shield
PA-860/PA-868
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance : ± 0.5 (Unit: mm)
● Configurations of joint G3 (G 3/8) type
30 –0.3
16
φ16.8±0.1
25
Label
7
(φ30)
1 0.1
PRESSURE TRANSDUCER
G 3/8 (PF 3/8)
(Iron, Ni-plated)
φ1.6
3-core shielded cable (φ5.0)
L = 2000±20 AWG22 ULNo.20276
Pressure port
● Configurations of joint R2 (R 1/4) type
30 –0.3
26
Label
7
(φ30)
15
PRESSURE TRANSDUCER
G 3/8 (PF 3/8)
(Iron, Ni-plated)
φ1.6
Pressure port
● Drip-proof cover type
Drip-proof cover
Please make sure that the
drip-proof cover is properly
placed over the main body
and the cable.
PA-860
Wire color
Red
Black
White
Gray
PA-868
Connection
Power ⊕
Common
Output
Fitting
Wire color
Red
Black
White
Gray
Connection
Power ⊕
N.C.
Output
Fitting
很抱歉,暂时无法提供与“PA-868-104P-H-R2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1432.46880
- 200+1341.15480
- 500+1294.02360
- 1000+1270.73880
