PA-860-354P-H-R2
PA-860-354P-H-R2
    NIDEC(尼得科)
    PA-860-354P-H-R2
PA-860-354P-H-R2 数据手册
PRESSURE TRANSDUCERS WITH AMP. PA-860/PA-868 INTERNAL STRUCTURE PA-860/PA-868 (G 3/8) 3 1 2 4 5 Part name Material ■ FEATURES ① Fitting ● ● ● ● ② Stainless steel diaphragm ③ Sensor chip Silicone ④ Back cover SUS 303 ⑤ Drip-proof cover Resistant against surge pressure SUS 316L welded stainless steel diaphragm Built-in amplifier circuit Voltage or current output modes are available Iron, Ni-plated SUS 316L Silicone rubber ■ MODEL NUMBER DESIGNATION PA-860 - 503 P - B - R2 Series name PA-860: (Voltage output) PA-868: (Current output) Fitting Rated pressure range 503:0 104:0 204:0 354:0 ~ ~ ~ ~ 5 MPa 10 MPa 20 MPa 35 MPa Pressure unit P:Pa pressure unit ※ Please refer to the LIST OF MODEL NUMBERS when placing orders. R2:R 1/4 G3:G 3/8 Drip-proof cover B:Non-provided H:Provided PA-860/PA-868 PRESSURE TRANSDUCERS WITH AMP. ■ LIST OF MODEL NUMBERS Output Fitting Pressure reference Gauge Drip-proof cover Rated pressure range 0 ~ 5 R2 (R 1/4) Voltage output G3 (G 3/8) R2 (R1/4) Current output G3 (G 3/8) 0 ~ 10 0 ~ 20 0 ~ 35 Non-provided PA-860-503P-B-R2 PA-860-104P-B-R2 PA-860-204P-B-R2 PA-860-354P-B-R2 Provided PA-860-503P-H-R2 PA-860-104P-H-R2 PA-860-204P-H-R2 PA-860-354P-H-R2 Non-provided PA-860-503P-B-G3 PA-860-104P-B-G3 PA-860-204P-B-G3 PA-860-354P-B-G3 Provided PA-860-503P-H-G3 PA-860-104P-H-G3 PA-860-204P-H-G3 PA-860-354P-H-G3 Non-provided PA-868-503P-B-R2 PA-868-104P-B-R2 PA-868-204P-B-R2 PA-868-354P-B-R2 Provided PA-868-503P-H-R2 PA-868-104P-H-R2 PA-868-204P-H-R2 PA-868-354P-H-R2 Non-provided PA-868-503P-B-G3 PA-868-104P-B-G3 PA-868-204P-B-G3 PA-868-354P-B-G3 Provided PA-868-503P-H-G3 PA-868-104P-H-G3 PA-868-204P-H-G3 PA-868-354P-H-G3 ※ Verify the above model numbers when placing orders. ■ STANDARD SPECIFICATIONS ● Unless otherwise specified, the specs are defined at an ambient temperature of 25 ± 5 °C and excitation voltage of 12 V DC. Item Model number 503P 104P 204P 354P 503P 104P 204P 354P Gauge ※ 1 Pressure reference General specifications PA-860                PA-868 Rated pressure range MPa 5 10 20 35 5 10 20 35 Maximum pressure MPa 10 20 40 52.5 10 20 40 52.5 Operating temp. range °C − 10 ~ 75 Compensated temp. range °C 0 ~ 50 Operating humidity Storage temp. %RH °C Pressure medium ※ 2 Insulation resistance MΩ minimum 100 (500 V DC) 350 V AC, 60 s(Leakage current 0.5 mA maximum) R 1/4、G 3/8 Pressure port Protection grade − 20 ~ 90(Atmospheric pressure, humidity 65 %RH maximum) Hydraulic oil Dielectric strength Net weight 35 ~ 85(No condensation) g Approx. 170 Without drip-proof cover : IP54, With drip-proof cover : IP65 ※ 1:The transducer measures gauge pressure using an absolute pressure sensing element. ※ 2:Hydraulic oil is used as a measurement medium at the time of delivery inspection. PA-860/PA-868 PRESSURE TRANSDUCERS WITH AMP. ■ STANDARD SPECIFICATIONS ● Unless otherwise specified, the specs are defined at an ambient temperature of 25 ± 5 °C and excitation voltage of 12 V DC. Power Item Model number Supply voltage PA-860 PA-868 503P 104P 204P 354P 503P 104P 204P 354P 12 ~ 24 ± 10 % V DC maximum Consumption current 10 mA ———— 1~5V 4 ~ 20 mA Zero voltage/current 1 ± 0.05 V 4 ± 0.1 mA Span voltage/current 4 ± 0.05 V 16 ± 0.1 mA DC Output voltage/current Analog output %F.S. ± 0.5 ZERO %F.S./°C ± 0.05 SPAN %F.S./°C ± 0.05 Linearity/Hysteresis Thermal error 500 Ω maximum ※3 (At power voltage 24 V) 10 kΩ minimum Load resistance ms maximum Response 20 ※3:Maximum load resistance RL(Max.) = (Vopr-10.8)/0.026 Vopr = power supply voltage to be used. ■ ENVIRONMENTAL CHARACTERISTICS Test item Test conditions (At 25 ± 5 °C) Shock 10 ~ 500 Hz, 1.5 mm maximum/98.1 m/s2, 3 directions for 2 hours each 490 m/s2 3 directions for 3 times each Pressure cycling 0 〜 Rated pressure 106 cycles Moisture resistance 40 °C, 90 ~ 95 %RH, 240 hrs. Vibration Permissible change Zero voltage/current, Span voltage/current: ± 3 %F.S. maximum each ■ INTERNAL ELECTRICAL SCHEMATICS ● PA-860 ● PA-868 Pressure Sensor Main circuit Power ⊕ • Output Power ⊕ • Pressure Sensor Main circuit Common Output Shield Shield PA-860/PA-868 PRESSURE TRANSDUCERS WITH AMP. ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance : ± 0.5 (Unit: mm) ● Configurations of joint G3 (G 3/8) type 0 (41) 30 –0.3 16 φ16.8±0.1 25 Label 7 (φ30) 1 0.1 PRESSURE TRANSDUCER G 3/8 (PF 3/8) (Iron, Ni-plated) φ1.6 3-core shielded cable (φ5.0) L = 2000±20 AWG22 ULNo.20276 Pressure port ● Configurations of joint R2 (R 1/4) type 0 (41) 30 –0.3 26 Label 7 (φ30) 15 PRESSURE TRANSDUCER G 3/8 (PF 3/8) (Iron, Ni-plated) φ1.6 Pressure port 3-core shielded cable (φ5.0) L = 2000±20 AWG22 ULNo.20276 ● Drip-proof cover type Drip-proof cover Please make sure that the drip-proof cover is properly placed over the main body and the cable. PA-860 Wire color Red Black White Gray PA-868 Connection Power ⊕ Common Output Fitting Wire color Red Black White Gray Connection Power ⊕ N.C. Output Fitting
PA-860-354P-H-R2 价格&库存
很抱歉,暂时无法提供与“PA-860-354P-H-R2”相匹配的价格&库存,您可以联系我们找货
