Additional Resources:
Product Page
3D Model
PCB Footprint
date
12/12/2019
page
1 of 4
MODEL: CMI-9605-0580T │ DESCRIPTION: MAGNETIC BUZZER INDICATOR
FEATURES
through hole
80 dB
magnetic
internally driven
SPECIFICATIONS
parameter
conditions/description
min
rated voltage
max
5
operating voltage
current consumption
typ
3
at rated voltage
rated frequency
2,400
sound pressure level
at 10 cm, rated voltage
dimensions
Ø9.6 x 5
2,700
units
Vdc
7
Vdc
30
mA
3,000
Hz
80
dB
mm
weight
1.0
material
PBT
terminal
pins (brass with tin plating)
g
operating temperature
-30
70
°C
storage temperature
-40
85
°C
max
units
250
°C
RoHS
Notes:
yes
1. All specifications measured at 25±3°C, humidity at 60~70%, under 86~106 kPa pressure, unless otherwise noted.
SOLDERABILITY
parameter
wave soldering
see recommended wave soldering profile
min
5±1 s
0.5~1.5°/s
>6°/s
Temperature (°C)
250
200
150
100
50
60
90
120 150 180 210 240 270
Time (sec)
cuidevices.com
typ
Product Page
3D Model
PCB Footprint
CUI Devices │ MODEL: CMI-9605-0580T │ DESCRIPTION: MAGNETIC BUZZER INDICATOR
date 12/12/2019 │ page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
(32;
很抱歉,暂时无法提供与“CMI-9605-0580T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 15+6.6252615+0.80250
- 40+6.5942940+0.79875
- 150+6.59415150+0.79874
- 400+6.59400400+0.79872
- 1500+6.593861500+0.79870
- 国内价格
- 1+10.64657
- 10+8.84136
- 25+8.18015
- 50+7.69879
- 100+7.23591
- 250+6.71198
- 500+6.22512
- 1000+5.81944
- 5000+5.70284
