MBRB2045CT
MBRB2045CT
    SMCDIODESOLUTIONS(桑德斯)
    D²PAK
    MBRB2045CT
MBRB2045CT 数据手册
MBR2035/2045CT MBRB2035/2045CT MBR2035/2045CT-1 Technical Data Data Sheet N0186, Rev. A MBR2035/2045CT MBRB2035/2045CT MBR2035/2045CT-1 SCHOTTKY RECTIFIER Features              Applications 150 C TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request     Switching power supply Converters Free-Wheeling diodes Reverse battery protection MBR20...CT MBRB20...CT MBR20...CT-1 TO-220AB D2PAK TO-262 Maximum Ratings: Characteristics Symbol Condition Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage VRRM VRWM VR - Average Rectified Forward Current IF (AV) 50% duty cycle @Tc=95°C, rectangular wave form Peak One Cycle Non-Repetitive Surge Current(Per Leg) IFSM 8.3ms, Half Sine pulse, TC = 25 C Max. 35 MBR2035CT 45 MBR2045CT Units V 10(Per Leg) 20(Per Device) A 200 A  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  MBR2035/2045CT MBRB2035/2045CT MBR2035/2045CT-1 Technical Data Data Sheet N0186, Rev. A Electrical Characteristics: Characteristics Symbol Forward Voltage Drop (Per Leg)* Reverse Current (Per Leg)* Typ. Max. Units VF1 @ 10A, Pulse, TJ = 25 C 0.57 0.70 V VF2 @ 10A, Pulse, TJ = 125 C @VR = rated VR TJ = 25 C @VR = rated VR TJ = 125 C @VR = 5V, TC = 25 C fSIG = 1MHz Measured lead to lead 5 mm from package body - 0.55 0.60 V 0.03 1.0 mA 9 15 mA 220 600 pF 8.0 - nH - 10,000 V/s IR1 IR2 Junction Capacitance(Per Leg) CT Typical Series Inductance (Per Leg) Voltage Rate of Change LS dv/dt Condition * Pulse width < 300 µs, duty cycle < 2% Thermal-Mechanical Specifications: Characteristics Junction Temperature Storage Temperature Typical Thermal Resistance Junction to Case Case Style Symbol Condition Specification Units TJ Tstg - -55 to +150 -55 to +150 C C 2.0 C/W RJC DC operation TO-220AB D2PAK TO-262 Tube Specification Tube Specification(TO-220AB/TO-262) Device Package Weight Shipping MBR20...CT TO-220AB 1.8g 50pcs / tube MBRB20...CT D²PAK 1.85g 800pcs / reel MBR20...CT-1 TO-262 1.85g 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  MBR2035/2045CT MBRB2035/2045CT MBR2035/2045CT-1 Technical Data Data Sheet N0186, Rev. A Ratings and Characteristics Curves TJ=125℃ TJ=25℃ TJ=25℃ Instantaneous Forward Current-IF(A) Fig.1-Typical Junction Capacitance Fig.2-Typical Reverse Characteristics 100 TJ=125℃ 10 1 TJ=25℃ 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 Forward Voltage Drop-VF(V) Fig.3-Typical Instantaneous Forward Voltage Characteristics Marking Diagram Where XXXXX is YYWWL MBR B 20 35/45 CT -1 SSG YY WW L = Device Type = Package type = Forward Current (10A) = Reverse Voltage (35/45V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  MBR2035/2045CT MBRB2035/2045CT MBR2035/2045CT-1 Technical Data Data Sheet N0186, Rev. A Carrier Tape Specification D2PAK Millimeters Min. Max. Symbol A 10.70 10.90 B 16.03 16.23 C 5.11 5.31 d 1.45 1.65 E 1.65 1.85 F 11.40 11.60 P0 3.90 4.10 P 15.90 16.10 P1 1.90 2.10 W 23.90 24.30 Mechanical Dimensions TO-220AB Dimensions in millimeters Symbol A A1 A2 b b1 c D D1 E e e1 H1 L L1 ΦP Q Min 3.56 0.51 2.03 0.38 1.14 0.31 14.22 8.38 9.65 5.84 12.70 - Typical 2.54 5.08 3.56 Max 4.83 1.40 2.92 1.02 1.78 0.61 16.51 9.42 10.67 6.86 14.73 6.35 - 2.54 - 3.43  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  MBR2035/2045CT MBRB2035/2045CT MBR2035/2045CT-1 Technical Data Data Sheet N0186, Rev. A Mechanical Dimensions D2PAK Symbol Dimensions in millimeters Min. 4.06 0 0.51 1.14 0.31 1.14 8.38 6.86 6.22 9.65 A A1 b b1 c c1 D D1 E1 E2 e H L L1 L2 L3 Θ Max. 4.83 0.26 0.99 1.78 0.74 1.65 8.65 14.60 1.78 - 2.54BSC 0.255BSC 0 10.67 15.88 2.80 1.68 1.78 8° Mechanical Dimensions TO-262 Symbol A A1 A2 b b1 c c1 D D1 E E1 E2 e H L L1 L2 L3 e e1 e2 e3 Millimeters Min. 4.55 0 2.59 0.71 0.36 1.17 8.55 6.40 10.01 7.6 9.98 14.6 2.00 1.17 0  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  Typical 4.70 0.10 2.69 0.81 1.27 0.38 1.27 Max. 4.85 0.25 2.89 0.96 0.61 1.37 8.70 8.85 10.16 10.31 10.08 2.54 15.1 2.30 1.27 10.18 0.25BSC 5° 4° 4° 15.6 2.70 1.40 2.20 8° MBR2035/2045CT MBRB2035/2045CT MBR2035/2045CT-1 Technical Data Data Sheet N0186, Rev. A DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC Diode Solutions. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
MBRB2045CT 价格&库存
很抱歉,暂时无法提供与“MBRB2045CT”相匹配的价格&库存,您可以联系我们找货
