GPS-15210
GPS-15210
    SPARKFUNELECTRONICS
    GPS-15210
GPS-15210 数据手册
    SparkFun GPS Breakout - Chip Antenna, SAM-M8Q (Qwiic) GPS-15210 The SparkFun SAM-M8Q GPS Breakout is a high quality, GPS board with equally impressive configuration options. The SAM-M8Q is a 72-channel GNSS receiver, meaning it can receive signals from the GPS, GLONASS, Galileo, and BeiDou constellations. This increases precision and decreases lock time and thanks to the onboard rechargable battery, you'll have backup power enabling the GPS to get a hot lock within seconds! Additionally, this u-blox receiver supports I2C (ublox calls this Display Data Channel) which made it perfect for the Qwiic compatibility so we don't have to use up our precious UART ports. Utilizing our handy Qwiic system, no soldering is required to connect it to the rest of your system. However, we still have broken out 0.1"-spaced pins in case you prefer to use a breadboard. U-blox based GPS products are configurable using the popular, but dense, windows program called u-center. Plenty of different functions can be configured on the SAM-M8Q: baud rates, update rates, geofencing, spoofing detection, external interrupts, SBAS/D-GPS, etc. All of this can be done within the SparkFun Arduino Library! The SparkFun SAM-M8Q GPS Breakout is also equipped with an on-board rechargeable battery that provides power to the RTC on the SAM-M8Q. This reduces the time-to-first fix from a cold start (~30s) to a hot start (~1s). The battery will maintain RTC and GNSS orbit data without being connected to power for plenty of time. The SparkFun Qwiic Connect System is an ecosystem of I2C sensors, actuators, shields and cables that make prototyping faster and less prone to error. All Qwiic-enabled boards use a common 1mm pitch, 4-pin JST connector. This reduces the amount of required PCB space, and polarized connections mean you can’t hook it up wrong. FEATURES              72-Channel GNSS Receiver 2.5m Horizontal Accuracy 18Hz Max Update Rate Time-To-First-Fix: o Cold: 26s o Hot: 1s Max Altitude: 50,000m Max G: ≤4 Max Velocity: 500m/s Velocity Accuracy: 0.05m/s Heading Accuracy: 0.3 degrees Time Pulse Accuracy: 30ns 3.3V VCC and I/O o Current Consumption: ~29mA Tracking GPS+GLONASS Software Configurable o Geofencing o Odometer o Spoofing Detection o External Interrupt o Pin Control o Low Power Mode o Many others! Supports NMEA, UBX, and RTCM protocols over UART or I2C interfaces                                                      https://www.sparkfun.com/products/15210//4‐17‐19
GPS-15210
- 物料型号:SAM-M8Q - 器件简介:72频道GNSS接收器,支持多种卫星信号,具有内置充电电池,可快速锁定位置。 - 引脚分配:文档中未明确列出,但提到了0.1英寸间距的引脚,兼容面包板。 - 参数特性:水平精度2.5米,最大更新频率18Hz,冷启动时间26秒,热启动时间1秒,最大高度50000米,最大速度500米/秒,速度精度0.05米/秒,航向精度0.3度,时间脉冲精度30纳秒。 - 功能详解:支持地理围栏、里程表、欺骗检测、外部中断、SBAS/D-GPS等,可通过SparkFun Arduino库配置。 - 应用信息:适用于需要高精度定位和快速定位的应用场景。 - 封装信息:3.3V VCC和I/O,追踪GPS+GLONASS时电流消耗约29mA,支持NMEA、UBX和RTCM协议。
GPS-15210 价格&库存
很抱歉,暂时无法提供与“GPS-15210”相匹配的价格&库存,您可以联系我们找货
