Gravity BNO055+BMP280 intelligent 10DOF AHRS
SKU:SEN0253
INTRODUCTION
BNO055 is a new sensor IC for implementing an intelligent 9-axis Absolute Orientation Sensor.
It is a system in package, integrating a triaxial 14-bit accelerometer, a triaxial 16-bit gyroscope, a
triaxial geomagnetic sensor and a 32-bit microcontroller. At just 5.2 x 3.8 x 1.1 mm³, it is
significantly smaller than comparable discrete or system-on-board solutions and also is the
sensor-hub product of the smallest size that supports Windows 8.1 at present. BNO055 is able to
provide not only single data of the three kinds of sensors
(accelerometer/gyroscope/geomagnetic), but also integrated data, such as quaternions, Euler
angles or vectors. Besides, the built-in MCU frees the users from the complexities of algorithm
processing, which provides application support in many aspects for smart phone, wearable
device and so on.
BMP280 is an absolute barometric pressure sensor especially designed for mobile applications,
which can realize the measurement of barometric pressure and temperature(the data can be
converted into altitude through the specific formula). The sensor module is housed in an
extremely compact package. It is based on Bosch’s proven Piezo resistive pressure
sensortechnology featuring high accuracy and linearity as well as long term stability and high
EMC robustness. Numerous device operation options offer highest flexibility to optimize the
device regarding power consumption, resolution and filter performance.
Now, this sensor module integrates BNO055 and BMP280 on one board to combine the two
sensor into a 10DOF sensor module. The standard Gravity-I2C interface eases the integration
process for customers, freeing them from the complexities of multivendor solutions so they can
spend more time on product innovation, including novel applications such as wearable hardware.
It is also the perfect choice for augmented reality, more immersive gaming, personal health and
fitness, indoor navigation and any other application requiring context awareness.
FEATURES
BNO055:
Outputs fused sensor data: quaternions, euler angles, rotation vector, linear acceleration, gravity,
heading.
3 sensors in one device: 16‐bit gyroscope, 14‐bit accelerometer, geomagnetic sensor
Intelligent Power Management: normal, low power and suspend mode available
BMP280:
Barometric pressure & Temperature sensor
SPECIFICATION
Operating Voltage: 3.3V~5V DC
Operating Current: 5mA
Gravity-I2C Interface
BNO055 Accelerometer:
Acceleration ranges ±2g/±4g/±8g/±16
Low‐pass filter bandwidths 1kHz~
很抱歉,暂时无法提供与“SEN0253”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+227.090901+29.52110
