YL CONNECTOR
4.5 mm pitch/Disconnectable Crimp style Wire-to-wire connectors
Specifications
• Current rating: 10 A AC/DC (7 A when retainers are mounted)
• Voltage rating: 300 V AC/DC
• Temperature range: -25℃ to +90℃
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 7 mΩ max.
After environmental tests/ 10 mΩ max.
• Insulation resistance: 1,000 MΩ min.
• Withstanding voltage: 1,500 VAC/minute
• Applicable wire: AWG #26 to #16
0.13 to 1.25 mm2
• Applicable panel thickness: 0.7 to 2.0 mm
YL CONNECTOR
Panel lock
Inner lock
Retainer
Housing lance
YLコネクタ表1
Note: The current rating varies depending on the number of circuits and the
wire size used in each connector. The table below lists the current
rating as a function of the number of circuits and the wire size.
Current unit: A
No. of circuits
The retainer features added protection
against non-insertion or disconnection.
Housing lance
Secondary retainers
Inner-housing lock
Panel lock construction
#16
#18
#20
#22
#24
#26
1
10
7
5
4
3
2
2
10
7
5
4
3
2
3
9
6
4
4
3
2
4
9
6
4
4
3
2
6
8
5
3
3
2
2
8
7
4
3
3
2
2
9
6
4
3
3
2
2
12
6
3
2
2
2
2
15
5
3
2
2
2
1
16
5
3
2
2
2
1
21
5
3
2
2
2
1
Note: Secondary retainers cannot be used with AWG #16 wires.
* In using the products,refer to "Handling Precautions for Terminals
and Connectors" described on our website (Technical documents
of Product information page).
* RoHS2 compliance
* Dimensional unit: mm
* Contact JST for details.
Standards
Recognized E60389
Certified LR20812
R9351052
Wire size (AWG)
YLコネクタ表3
Panel Layout and Assembly layout
A
YLコネクタ表4
B
(35.1)
(38.7) (including retainer)
20.5
3.2
10.8
16.6
21.8
A
C
9.5
15.3
D
Single row
2・3
2-row 4・6・8・12・16
3-row 9・12・15・21
Dimensions (mm)
A
B
E
Type No. of circuits
9.8
Panel
thickness
No. of Receptacle (mm)
circuits housing
Model No. Dimensions
(mm)
2
YLR-02V
3
YLR-03V
4
YLR-04V
6
YLR-06V
8
YLR-08V
9
YLR-09V
YLR-12V
12
YLR-12VA
15
YLR-15V
16
YLR-16V
21
YLR-21V
0.7 to 2.0
0.7 to 0.8
0.9 to 1.3
1.4 to 2.0
A
B
C
10.7
16.8
7.1
D±0.1 E±0.1 D±0.1 E±0.1 D±0.1 E±0.1
4.4
1.35
5.0
1.05
5.6
0.75
15.3
21.3
7.1
4.4
1.35
5.0
1.05
5.6
0.75
10.7
16.8
12.9
7.1
2.9
7.7
2.6
8.3
2.3
15.3
21.3
12.9
7.1
2.9
7.7
2.6
8.3
2.3
19.8
25.8
12.9
7.1
2.9
7.7
2.6
8.3
2.3
15.3
21.3
18.2
7.1
5.55
7.7
5.25
8.3
4.95
19.8
25.8
18.2
7.1
5.55
7.7
5.25
8.3
4.95
28.9
34.8
12.9
7.1
2.9
7.7
2.6
8.3
2.3
24.4
30.3
18.2
7.1
5.55
7.7
5.25
8.3
4.95
37.9
43.8
12.9
7.1
2.9
7.7
2.6
8.3
2.3
33.5
39.3
18.2
7.1
5.55
7.7
5.25
8.3
4.95
Note: 1. Punch holes in the panel according to the figures and table shown
above. Burrs must be removed.
2. The strength of the panel must be considered when punching two
or more holes.
3. The connector must be inserted from the same side as the hole is
punched.
B
1
YL CONNECTOR
YLコネクタ表2
Contact
Applicable wire
Model No.
Pin contact
2
Pin contact
AWG #
Insulation O.D.
(mm)
26~20
1.3~2.5
0.5 ~1.25
20~16
2.0~3.4
*0.3+0.3~
0.5+0.5
*22+22~
20+20
mm2
Socket contact
SYM-01T-P0.5A SYF-01T-P0.5A 0.13~0.5
4.4
SYM-41T-P0.5A SYF-41T-P0.5A
2
0.5
1.1
19.5
Q’ty/
reel
4,000
*1.5+1.5~
2.0+2.0
SYM-01T-P0.5A
5,000
Material and Finish
Phosphor bronze, tin-plated (reflow treatment)
RoHS2 compliance
Note: 1 . Contact JST for special products.
2. Retainers cannot be used with electric wire whose insulation O.D.
exceeds 2.7 mm and AWG #16.
3. *Marked products are not approved by TÜV .
2.8
Socket contact
2
4.4
SYM-01T-P0.5A
1.1
SYF-01T-P0.5A
SYM-41T-P0.5A
1.8
Applicator
Crimping
machine Crimp applicator
Contact
14.2
Crimp applicator with dies
Dies
MK/SYF/M-01-05 APLMK SYF/M01-05
AP-K2N
MKS-L
MK/SYF/M-41-05 APLMK SYF/M41-05
SYF-41T-P0.5A
Note: Contact JST for fully automatic crimping applicator.
Contact position location numbers
Contact position numbers are stamped
Retainer
Receptacle housing
Retainer
Plug housing
3
3
2
1
1
2
2
1
4
8
3
7
L JST
12
11
10
L JST
8
9
3
7
6
2
5
21
17
16
15
18
10
9
8
11
12
13
14
1
7
8
16
7
15
6
14
5
13
4
12
3
11
2
10
9
6
6
12
5
11
4
10
7
1
1
15
14
13
L JST
12
4
1
5
2
6
3
6
2
5
L JST
1
4
4
2
L JST
3
10
9
8
11
1
7
9
6
5
2
4
10
3
3
2
11
1
4
16
15
14
13
12
11
10
9
1
12
8
7
6
5
4
3
2
1
5
8
5
L JST
13
7
6
5
4
3
2
1
15
14
13
12
11
4
2
15
6
14
13
12
11
10
9
8
10
9
8
7
6
3
9
14
1
21
18
17
16
15
5
4
3
2
1
2
3
16
7
6
5
4
3
2
1
12
11
10
9
8
7
1
4
17
10
15
2
11
10
9
8
7
6
L JST
5
18
11
8
7
15
14
13
12
11
L JST
16
3
12
1
4
3
2
1
6
5
4
3
2
1
L JST
6
19
12
4
8
5
9
2
8
7
6
5
8
7
6
5
4
3
2
1
3 6 9
2 5 8
1 4 7
3
9
13
5
13
2
L JST
6
9
3
10
14
7
15
4
11
10
8
L JST
12
12
11
10
9
16
15
14
13
12
11
10
9
3 6
2 5
1 4
2
8
7
21
14
2
3
1
9
7
8
2
L JST
8
7
3
2 4
1 3
1
9
6
4
9 6 3
8 5 2
7 4 1
4
3
2
1
5
10
8
7
6
5
6 3
5 2
4 1
6
5
4
3
2
1
4
5
L JST
11
1
1
1
6
2
5
4
12
3
L JST
4
2
7
6
5
3
8
7
2
6
4
9
8
3
5
L JST
L JST
6
12
11
10
9
8
7
L JST
1
1
2
1
L JST
L JST
3
1
1
L JST
1
4 2
3 1
2
4
2
L JST
1
3
2
1
3
2
2
1
L JST
L JST
1
Plug housing
L JST
Receptacle housing
4
3
2
1
8
7
6
5
4
3
2
1
8
7
6
5
12
11
10
9
7
6
5
4
3
2
1
14
13
12
11
10
9
8
21
18
17
16
15
P266
YL CONNECTOR
c
Housing
Material: Housing...PA 66, UL94V-0, white
Retainer...Glass-filled PA 66, UL94V-0, ivory
26.6
8.5
3.35
500
6.0
YLP-02V
Q’ty/
bag
1,000
2.9
YLS-02V
Q’ty/
bag
L JST
26.6
YLR-02VF
8.3
3.1
10.3
1
6.7
500
500
8.5
3.5
20.9
2
1,000
2.9
6.0
L JST
10.3
20.9
2
3.0 10.3 3.0
Q’ty/
bag
7A
(10 A)
500
Q’ty/
bag
3.8
L JST
3.0
YLR-02V
300 V
YLS-01V
1
6.7
2
Q’ty/
bag
2
7A
(10 A)
YLP-01V
Retainer
L JST
300 V
Q’ty/
bag
L JST
1
5.8
YLR-01VF
Plug housing (for socket contact)
5.8
Receptacle housing (for pin contact)
1
No. of Voltage Current
circuits rating
rating
1
6.7
3.1
26.6
YLR-03V
3.0
Q’ty/
bag
YLP-03V
Q’ty/
bag
26.6
12.8
2
L JST
3.1
14.8
6.7
6A
YLR-03VF
500
20.9
3
8.5
3.5
6.0
500
1,000
2.9
2
L JST
14.8
1
(9 A)
3
3.0
1
300 V
Q’ty/
bag
2
L JST
14.8
3
3
YLS-03V
(commonly used for
3-circuit housing and
6-circuit housing)
1
6.7
3.1
26.6
RoHS2 compliance
Note: 1. Current rating in parentheses is for use with AWG #16 wire. (Retainers are not mountable.)
2. Contact JST for Glow Wire compliant connectors.
3
YL CONNECTOR
P267
Housing
circuits rating
rating
1
500
8.5
20.9
3.5
500
11.8
1,000
2.9
2
L JST
10.3
8.3
10.3
4
L JST
2
26.6
3
3.1
YLR-04VF
4
00
Q’ty/
bag
1
12.5
6A
(9 A)
YLS-02V
2
300 V
Q’ty/
bag
3
4
YLP-04V
Retainer
L JST
y/
g
Q’ty/
bag
4
3.0 10.3 3.0
YLR-04V
Retaine...Glass-filled PA 66, UL94V-0, ivory
3
1
y/
g
12.5
3.1
26.6
YLR-06V
YLP-06V
Q’ty/
bag
6
3
5
YLS-03V
(commonly used for
6-circuit housing)
Q’ty/
bag
2
4
00
L JST
14.8
3.0
Q’ty/
bag
3
5
2
L JST
14.8
500
8.5
20.9
3.5
12.8
500
6
g
14.8
YLR-06VF
L JST
2
5
(8 A)
4
300 V
26.6
1
6
3.1
3
6
3.0
1
12.5
5A
1,000
2.9
11.8
4
1
L JST
12.5
00
3.1
26.6
YLR-08V
YLP-08V
Q’ty/
bag
YLS-08V
Q’ty/
bag
8
4
7
3
6
2
L JST
19.3
3.0
Q’ty/
bag
5
26.6
19.3
YLR-08VF
500
1
5
250
8.5
4
7
3
6
2
3.5
11.8
1,000
2.9
L JST
8
20.9
19.0
L JST
2
6
3.1
3
7
12.5
4A
(7 A)
19.3
300 V
4
8
3.0
1
8
5
1
12.5
3.1
26.6
YLR-09V
YLP-09V
Q’ty/
bag
3.5
Q’ty/
bag
1
3.0
9
8
14.8
6
7
L JST
3
500
8.5
17.7
3.1
26.6
20.9
RoHS2 compliance
4
5
4
4
7
250
1
2
14.8
3
5
8
4A
(6 A)
L JST
300 V
6
9
9
2
3.0
Q’ty/
bag
17.0
YL CONNECTOR
P268
Housing
YLR-12VA
YLP-12VA
1
26.3
L JST
1
7
20.9
26.6
12.5
3.0
1,000
7
2
8
200
8.5
11.8
2.9
3A
YLR-12V
Q’ty/
bag
Q’ty/
bag
4
8
12
3
3
7
11
6
2
2
6
Q’ty/
bag
Q’ty/
bag
10
1
17.0
YLP-15V
3.1
23.8
15
14
13
L JST
10
9
8
200
1
1
12
6
11
11
2
7
7
3
12
6
4
8
13
5
5
9
2
10
L JST
14
200
4
3.5
3
3.0
1
20.9
Q’ty/
bag
3.0
9
5
5
200
8.5
26.6
15
23.8
19.3
4
7
9
3A
(5 A)
L JST
8
10
L JST
200
17.7
Q’ty/
bag
3.5
11
19.3
YLP-12V
3.1
3.0
(6 A)
12
300 V
28.3
3
6
12
4
9
200
YLR-15V
15
Q’ty/
bag
5
11
5
10
300 V
YLS-12V
3.5
4
10
6
11
12
Retainer
Q’ty/
bag
3
9
3.0
12
L JST
28.3
Q’ty/
bag
3.1
2
8
circuits rating rating
8.5
17.0
YLP-16V
Q’ty/
bag
YLS-16V
Q’ty/
bag
11
3
10
2
L JST
37.3
37.0
100
200
1,000
1
1
9
9
4
7
15
12
6
14
5
5
13
6
8
16
3.5
4
12
3.0
7
37.3
8
13
L JST
14
3A
(5 A)
15
300 V
Q’ty/
bag
3.1
16
16
20.9
3
11
YLR-16V
26.6
2
10
3.0
17.7
3.0
8.5
12.5
26.6
20.9
11.8
2.9
RoHS2 compliance
5
YL CONNECTOR
P269
Housing
YLR-21V
Q’ty/ YLP-21V
bag
1
3.0
26.6
20.9
RoHS2 compliance
6
21
18
L JST
17
16
15
17.0
32.8
7
14
6
13
5
12
8
4
2
15
11
9
3
3
16
10
4
17
10
9
5
18
11
2
6
12
100
8.5
17.7
Q’ty/
bag
3.5
1
3.0
7
13
32.8
14
L JST
19
3A
(5 A)
300 V
Retainer
Q’ty/
bag
3.1
21
21
8
200
很抱歉,暂时无法提供与“YLP-08V”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+3.02210
- 50+2.95962
- 100+2.90130
- 500+2.83153
- 国内价格 香港价格
- 1+1.690591+0.21809
- 10+1.3489710+0.17402
- 50+0.9810750+0.12656
- 100+0.91099100+0.11752
- 500+0.85844500+0.11074
- 1000+0.832161000+0.10735
- 2000+0.814642000+0.10509
