V11
EC6AW-110 SERIES
10 WATT 4:1 INPUT
DC-DC CONVERTERS
FEATURES
* 8.25-10W Isolated Output
* Efficiency to 88.5%
* Low No Load Power Consumption
* 4:1 Input Range
* Regulated Outputs
* Input Under-Voltage Protection
* Remote On/Off
* Continuous Short Circuit Protection
* Over Current Protection
* All Ceramic Capacitor Design
* UL60950-1 2nd (Basic Insulation) Approval
* Meets EN50155 with External Circuits
* Shock & Vibration Meets EN50155 (EN61373)
* Fire & Smoke Meets EN45545-2
* 3050m Operating Altitude
OUTPUT CURRENT
INPUT CURRENT
% EFF.
CAPACITOR
LOAD MAX.
89 mA
85
2500µF
105 mA
87
2000µF
104 mA
88
835µF
103 mA
88.5
666µF
6 mA
107 mA
85
1000µF
±416mA
6 mA
105 mA
87
416µF
±333mA
6 mA
104 mA
87.5
333µF
MODEL
INPUT
OUTPUT
NUMBER
VOLTAGE
VOLTAGE
MIN.
MAX.
NO LOAD
FULL LOAD
3.3 VDC
0 mA
2500 mA
6 mA
EC6AW-110S05 43-160 VDC
5 VDC
0 mA
2000 mA
6 mA
EC6AW-110S12 43-160 VDC
12 VDC
0 mA
835 mA
6 mA
EC6AW-110S15 43-160 VDC
15 VDC
0 mA
666 mA
6 mA
EC6AW-110D05 43-160 VDC
±5 VDC
0 mA
±1000mA
EC6AW-110D12 43-160 VDC
±12 VDC
0 mA
EC6AW-110D15 43-160 VDC
±15 VDC
0 mA
EC6AW-110S33 43-160 VDC
NOTE:
1. Nominal Input Voltage 110 VDC
1
V11
SPECIFICATIONS
All Specifications Typical At Nominal Line, Full Load, and 25℃ Unless Otherwise Noted
INPUT SPECIFICATIONS:
GENERAL SPECIFICATIONS:
Input Voltage Range....……………........…........ 110V ................... 43-160V
Input Surge Voltage (100ms max.) ………………………….... 200Vdc max.
Under Voltage Lockout ……….........….. Power up …..…...………. 40V
Power down …..….....…. 38V
Positive Logic Remote On/Off (note 3&4)
Input Filter ……………………………………………………….……... PI Type
Efficiency ............................................………..………............ See Table
Isolation Voltage .................................……..………......... 3000VDC min.
9
Isolation Resistance …....................…….…....…….……… 10 Ohms min
Isolation Capacitance …………………..……………………… 1000pF typ.
Switching Frequency ............................................................. 240KHz typ
Operating Ambient Temperature Range ...…..…...…….... -40℃ to +85℃
OUTPUT SPECIFICATIONS:
De-rating, Above 60℃ …… Vo=±5V ….…. Linearly to Zero Power at +100℃
Voltage Accuracy ….....................................…..………........... ±1.0% max.
Voltage Balance (Dual Output) ……………………….………... ±2.0% max.
Transient Response: 75% - 100% Step Load Change
Error Band …..… ±5% Vout nominal, Recovery Time ………….. < 250us
Ripple & Noise, 20MHz BW (Measured with 1uF MLCC)
Vo=3.3V, 5V, ±5V .………………….…...... 75mV pk-pk max.
Vo=12V, 15V, ±12V, ±15V ……….………. 100mV pk-pk max.
Temperature Coefficient ....................….................…..... ±0.02%/°C max.
Short Circuit Protection .........………………......................... Continuous
Line Regulation (note1) ……............................................…. ±0.2% max.
Load Regulation (note2) ……............ Single ........................ ±0.5% max.
Dual ..…….………... ±1.0% max.
De-rating, Above 67℃ (note 7) .. Others .… Linearly to Zero Power at +100℃
Case Temperature (note5) ……..…………………………….. 100℃ max.
Cooling ………………………………………………… Natural Convection
Storage Temperature Range ...……..........……....…....... -55℃ to +125℃
Humidity ................................................. 95% RH max. Non-Condensing
Cross Regulation (Dual output) Load cross variation 25%/100% …... ±5.0% max.
MTBF ……. MIL-HDBK-217F, GB, 25℃, Full Load ….…. 1200Khrs typ.
nd
Safety ………………….…………… Meets UL60950-1 2 (Basic insulation)
EMC (note6) ……… Meets EN50155(EN50121-3-2) with external filter
Shock/Vibration ……………….……………… Meets EN50155(EN61373)
Fire & Smoke …………….……………………………….. Meet EN45545-2
Dimensions ………..…….… 1.25×0.80x0.50 inches(31.8x20.3×12.7mm)
Case Material ……………..….…………… Non-Conductive Black Plastic
Weight ………………………………………………………………….. 16g
Over Voltage Protection …………………..………… Zener or TVS Clamp
NOTE:
Current Limit .................…….…………........... 110%-170% Nominal Output
Start up time ……………………....…………......................……… 10ms typ.
1. Measured from high line to low line.
2. Measured from full load to min. load.
3. Logic Compatibility … CMOS or open collector TTL referenced to –Vin.
Module on ……….….…… >3.5VDC to 160VDC or open circuit
Module off ………………………………….……. 0 to 3.5VDC to 160VDC or open circuit
5. Maximum case temperature under any operating condition should not
be exceeded 100℃ .
6. For information about EN50155 and RIA12, refer to application note.
7. Others model refer to application note.
CASE A Dimensions:
Typical Derating curv e f or Natural Convection
NOTE:Pin Size is 0.02±0.002 Inch (0.5±0.05 mm)DIA
All Dimensions In Inches (mm)
Tolerances
Inches: X.XX= ±0.02 , X.XXX= ±0.010
Millimeters: X.X= ±0.5 , X.XX=±0.25
120%
PIN CONNECTION
SEE NOTE
2
3
1.25
[31.8]
BOTTOM
0.200
[5.08]
0.10
[2.5]
1
23
22
VIEW
16
9
14
11
0.600
[15.24]
0.80
[20.3]
Pin
Single Output
Dual Output
1
Remote On/Off
Remote On/Off
2,3
-V Input
-V Input
4,5
NP
NP
9
NP
Common
10
NP
NP
11
NC
12
NP
13
NP
14
0.15
[3.8]
0.50
[12.7]
15
16
-V Output
NP
NP
+V Output
+V Output
NP
NP
-V Output
Common
20,21,24
NP
NP
22,23
+V Input
+V Input
* NC-NO CONNECTION WITH PIN
* NP-NO PIN
2
LOAD(%)
100%
-40
60
80%
-2.50%/℃
60%
40%
EC6AW-110D05
20%
0%
-40
-20
60
80
o
Ambient Temperature( C)
100
很抱歉,暂时无法提供与“EC6AW-110S12”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+359.99640
- 200+143.64000
- 500+138.84480
- 1000+136.46880
