ECLB40W-110S12
ECLB40W-110S12
    CINCON
    ECLB40W-110S12
ECLB40W-110S12 数据手册
V14 ECLB40W-110 SERIES 40 WATT 4:1 INPUT DC-DC CONVERTERS ︳ FEATURES * 40W Isolated Output * Efficiency to 91% * 2.05’’ X1.2” X0.4’’ Six-Sided Shield Metal Case * 4:1 Input Range * Regulated Outputs * Fixed Switching Frequency * Input Under Voltage Protection * Over Current Protection * Remote On/Off * Low No Load Power Consumption * Continuous Short Circuit Protection * No Tantalum Capacitor Inside * UL60950-1 2nd (Basic Insulation) Approval * Meets EN50155 with External Circuits * Fire & Smoke Meets EN45545-2 * 3000m Operating Altitude * Full Load Operation Up to 69℃ with Heat-Sink M-C655 Natural Convection OUTPUT CURRENT INPUT CURRENT % CAPACITOR NO LOAD FULL LOAD EFF. LOAD MAX. MODEL INPUT OUTPUT NUMBER VOLTAGE VOLTAGE MIN. MAX. ECLB40W-110S33 43-160 VDC 3.3 VDC 0 mA 10000 mA 6 mA 340 mA 88% 10000µF ECLB40W-110S05 43-160 VDC 5 VDC 0 mA 8000 mA 6 mA 409 mA 88.5% ECLB40W-110S12 43-160 VDC 12 VDC 0 mA 3333 mA 6 mA 404 mA 90% 8000µF 3300µF ECLB40W-110S15 43-160 VDC 15 VDC 0 mA 2666 mA 6 mA 399 mA 91% 2700µF ECLB40W-110D12 43-160 VDC ±12 VDC 0 mA ±1667 mA 6 mA 408 mA 88% 1650µF ECLB40W-110D15 43-160 VDC ±15 VDC 0 mA ±1333 mA 6 mA 408 mA 88.5% 1350µF ECLB40W-110D24 43-160 VDC ±24 VDC 0 mA ±833 mA 6 mA 408 mA 89% 850µF NOTE: 1. Nominal Input Voltage 110 VDC 1 V14 SPECIFICATIONS All Specifications Typical At Nominal Line, Full Load, and 25℃ Unless Otherwise Noted INPUT SPECIFICATIONS: GENERAL SPECIFICATIONS: Input Voltage Range ....……………........…........ 110V ............... 43-160V Input Surge Voltage (100ms max.) ………………………..……... 200Vdc max. Under Voltage Lockout ……….........….. Power up …..…...………. 40V Power down …..….....…. 38V Positive Logic Remote On/Off (note4&5) Input Filter ………………………………………………..….……... Pi Type Efficiency ............................................………..………............ See Table Isolation Voltage .............. Input/Output ..….....……..….. 3000VDC min. Input/Case, Output/Case …. 1600VDC min. 9 Isolation Resistance …..................…….………….……… 10 Ohms min. Isolation Capacitance …………………..……………………… 1500pF typ. Case grounding ……..……... Output/case ………………….1000pF typ. OUTPUT SPECIFICATIONS: Switching Frequency ............................................................ 250KHz typ. Voltage Accuracy …......................................………………........... ±1.5% max. Voltage Balance (Dual Output) …………….…………………….... ±1.0% max. Transient Response: 25% Step Load Change Error Band …………. ±5% Vout Nominal Recovery Time ………..… 3.5VDC to 75VDC or open circuit Module off ……..……………………….…………. 0 to 3.5VDC to 75VDC or open circuit 5. Maximum case temperature under any operating condition should not Thermal Shutdown, Case Temp. .………….....................……. 110℃ typ. Humidity ................................................. 95% RH max. Non-Condensing MTBF ……….. MIL-HDBK-217F, GB, 25℃ , Full Load …… 905Khrs typ. Safety ……………….……………meet UL60950-1 2nd (Basic insulation) EMC(note6) ………… meet EN50155(EN50121-3-2) with external filter Shock/Vibration ……………….……………… meet EN50155(EN61373) Dimensions ............................ 2.05x1.20x0.40inches (52x30.5x10.2mm) Case Material ………………….… Aluminum with Non-Conductive Base Weight …………………………………………………..……………….. 36g be Exceeded 105℃. 6. For information about EN50155 and RIA12, refer to application note. SIZE LB Dimensions: ECLB40W-110S15 Typical Derating Curve 120% NOTE: Pin Size is 0.04±0.004 Inch (1.0±0.1 mm)DIA All Dimensions in Inches[mm] Tolerance Inches:x.xx=±0.02 ,x.xxx=±0.010 Millimeters:x.x=±0.5 , x.xx=±0.25 LOAD(%) 100% 2.05 [52.0] 1.800 [45.72] Mounting lnserts M2.5*0.45 Through 2pl. 0.400 [10.16] 0.400 [10.16] PIN 1 2 3 4 5 6 PIN CONNECTION Single Output Dual Output +V Input +V Input -V Input -V Input +V Output +V Output -V Output Trim -V Output Common Remote On/Off 60 69 80% 60% Natural Convection(20LFM) 40% 20% With Heatsink M-C655 105 0% -40 -20 0 20 40 60 80 Ambient Temperature( oC) 100 External Output Trimming 0.04 6pl. [1.0] +Vout 0.40 [10.2] 0.400 [10.16] 0.350 [8.89] 0.22 min [5.6] 1.43 [36.4] 0.39 [10.0] 0.81 [20.7] 0.200 [5.08] 1.20 [30.5] 0.052 [1.33] BOTTOM VIEW -40 +Vout TRIM DOWN TRIM TRIM TRIM UP -Vout 2 -Vout 10K Ohms TRIMPOT 120
ECLB40W-110S12 价格&库存
很抱歉,暂时无法提供与“ECLB40W-110S12”相匹配的价格&库存,您可以联系我们找货
