DotStar Micro LEDs (APA102–2020)Smart SMD RGB LED - 100 pack
PRODUCT ID: 3587
Description
These incredibly small surface‐mount LEDs are an easy way to add a lot of very tiny (but bright!)
colorful dots to your project. They're mini versions of our digital DotStart strips and matrices with full
chainable 2‐wire control. They are just mind‐bogglingly small. They are a mere 2mm x 2mm (way
smaller than APA102‐5050‐RGB), which makes them pretty darn bitty, so they might be a little
cumbersome to hand solder. SMT techniques with solder paste and hot air will work best here.
There are three LEDs inside, red, green, and blue. The RGB LEDs are controlled by a tiny chip that takes
a 24‐bit color level via the clock and data in and then does all the PWM control for you. So you just 'set'
the color data once. Like DotStars (and the similar NeoPixels) you can chain them together, the output
of one leading into the input of another for near‐infinitely long strips.
Comes in a strip of 100 pieces. Also available in a 10 pack!
Please note this is a surface‐mount part! It is possible to solder thin wires to the pads, but it's designed
for use on a SMD PCB. If you are not comfortable with hand soldering SMD parts, check out our other
RGB LEDs such as the thru‐hole ones or in pixels/strips.
Technical Details
o
o
o
o
o
o
o
Red color: 620‐625 nm
Green color: 520‐525 nm
Blue color: 465‐470 nm
Red brightness @ ~20mA: 600‐800 mcd
Blue brightness @ ~20mA: 800‐1000 mcd
Green brightness @ ~20mA: 1500‐2000mcd
Datasheet http://www.led‐color.com/upload/201604/APA102‐2020%20SMD%20LED.pdf
Product Dimensions: 2.0mm x 2.0mm x 0.9mm / 0.1" x 0.1" x 0.0"
https://www.adafruit.com/product/3587 9‐8‐17
很抱歉,暂时无法提供与“3587”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+262.338951+32.89781
- 国内价格
- 1+553.15440
- 200+220.71960
- 500+213.34320
- 1000+209.69280
