MR-PINS2-10
MR-PINS2-10
    FLIR(菲力尔)
    MR-PINS2-10
MR-PINS2-10 数据手册
2 inch pins for MR06, MR07, MR08, includes 10 pair of pins P/N: MR-PINS2-10 Copyright © 2015, FLIR Systems, Inc. All rights reserved worldwide. Names and marks appearing herein are either registered trademarks or trademarks of FLIR Systems and/or its subsidiaries. All other trademarks, trade names or company names referenced herein are used for identification only and are the property of their respective owners. Document identity Publ. No.: MR-PINS2-10 Release: Commit: 30138 Language: en-US Modified: 2015-10-31 Formatted: 2015-11-02 Website http://www.flir.com General description Part number MR-PINS2-10 Part name 2 inch pins for MR06, MR07, MR08, includes 10 pair of pins Customer support http://support.flir.com Disclaimer Specifications subject to change without further notice. Camera models and accessories subject to regional market considerations. License procedures may apply. Products described herein may be subject to US Export Regulations. Please refer to exportquestions@flir.com with any questions. FLIR’s new insulated pins are smaller in diameter—requiring minimal force to drive the pins into a surface-resulting in less impact to the material. The sandblasted, hardened-steel pins with a singlepiece design prevent bending and create an improved bonding surface for the abrasion-resistant insulation. The insulation extends all the way to the connection to the probe, so even if you drive the pins all the way into the wall cavity, the drywall will not affect the measurement. • • • • • Fits FLIR’s hammer, wall cavity and combo probes. Unibody construction rather than two piece. Smaller-diameter pins. Sandblasted hardened steel. Insulated with abrasion-resistant coating. Replacement pin set for FLIR MR06, MR07, and MR08. Meter data Suitable accessory MR06, MR07, MR08 Included insulated pin pairs and length 10 pairs of 2 in. (50 mm) Warranty 1 Year (with Registration) Meter physical data Weight 0.12 kg (0.25 lb.) Dimensions (H × W × L) 8 mm × 8 mm × 76 mm (0.32 in. × 0.32 in. × 3 in.) Material Stainless steel Color Black insulation Shipping information 1 (3) Packaging type Plastic bag Packaging contents 10 pairs of 2 in. insulated pins Packaging weight 0.127 kg (0.3 lb.) Packaging dimensions (H × W × L) 1 cm × 9 cm × 8 cm (0.4 in. × 3.6 in. × 3.2 in.) Inner carton weight 6 kg (11 lb.) Inner carton dimensions (H × W × L) 13 cm × 19 cm × 38 cm (5.2 in. × 7.5 in. × 15 in.) Inner carton quantity (bag) 50 Master carton weight 12 kg (26.5 lb.) Master carton dimensions (H × W × L) 15 cm × 40 cm × 40 cm (6 in. × 15.8 in. × 15.8 in.) Master carton quantity 100 EAN-13 0793950372128 www.flir.com 2 inch pins for MR06, MR07, MR08, includes 10 pair of pins P/N: MR-PINS2-10 Shipping information © 2015, FLIR Systems, Inc. UPC-12 793950372128 Country of origin China Tariff code 9025900000 #MR-PINS2-10; r. /30138; en-US Technical support 2 (3) Website http://support.flir.com E-mail TMsupport@flir.com Phone 855-499-3662 Repairs repair@flir.com www.flir.com © 2015, FLIR Systems, Inc. All rights reserved worldwide. No part of this drawing may be reproduced, stored in a retrieval system, or transmitted in any form, or by any means, electronic, mechanical, photocopying, recording, or otherwise, without written permission from FLIR Systems, Inc. Specifications subject to change without further notice. Dimensional data is based on nominal values. Products may be subject to regional market considerations. License procedures may apply. Product may be subject to US Export Regulations. Please refer to exportquestions@flir.com with any questions. Diversion contrary to US law is prohibited Modified Date Modified By Wednesday, September 30, 2015 T&M Engineering Description MR-PINS2 Units Scale Millimeters Not to Scale
MR-PINS2-10 价格&库存
很抱歉,暂时无法提供与“MR-PINS2-10”相匹配的价格&库存,您可以联系我们找货
