RC1180-MBUS3-IEB
RC1180-MBUS3-IEB
    RADIOCRAFTS
    RC1180-MBUS3-IEB
RC1180-MBUS3-IEB 数据手册
Radiocrafts Embedded Wireless Solutions RCxxxx-IEB Radiocrafts IOT-Module Expansion Board for FX30 and mangOH Gateway Product Description The RCxxxx-IEB is a series of expansion boards for the Sierra Wireless FX30 Programmable IoT Gateway (hereafter named FX30) and the open source HW mangOH. A complete IoT solution is easily created by using the Radiocrafts IOT expansion board and the gateway in combination with sensor nodes based on Radiocrafts RF modules in a local wireless network. The boards contain an RF module giving wireless connectivity, and the interface circuitry to the host processor in the gateway. The card has an SMA connector for connecting the external antenna. The insertion board series include several different products supporting different frequencies and radio protocols. The embedded protocol inside the RF module handles all RF communication and only data payload and easy-to-use commands are sent over the UART or SPI serial bus to/from the gateway processor. Supported Protocols and Network Standards  Wireless M-Bus  IEEE 802.15.4g  RC232/TinyMesh  ZigBee Applications 3G/4G LTE gateway solutions for:  Internet of Things applications  Wireless Sensor Networks  AMR / Smart Metering  Home automation, building automation and industrial automation  Fleet and inventory management 2018 Radiocrafts AS RCxxxx-IEB Data Sheet (rev. 1.02) Page 1 of 12 Radiocrafts Embedded Wireless Solutions RCxxxx-IEB Features  On-board radio module with embedded protocol  Easy-to-use UART/SPI interface connects to powerful Sierra Wireless-internal WP module  RF interface with SMA connector connects to any standard antenna  Same PCB supports modules from a large portfolio of RF modules  Miniature LED indicators (connects to RF module-processor)  CE certified module for EU frequencies  FCC pre-qualified for dedicated RF modules 2018 Radiocrafts AS RCxxxx-IEB Data Sheet (rev. 1.02) Page 2 of 12 Radiocrafts Embedded Wireless Solutions RCxxxx-IEB Functional block diagram Sierra Wireless FX30 Gateway/mangOH Sierra Wireless Internal CPU UART/SPI Ethernet/ Serial Radiocrafts IoT Expansion Board Level shifter circuitry Radiocrafts RF Module SMA EEPROM (optional) USB Figure 1: Functional block diagram for FX30 gateway and IoT expansion board Gateway programming1 The FX30 and mangOH integrates the Legato® Open Source Linux Platform that simplifies application-level development with a secure application framework, maintained Linux distribution, and feature-rich development environment. Legato® enables efficient C-level programming, making FX30 the core component for distributed IoT systems. Legato features an application sandbox that provides a secure environment to run and control multiple applications. With security and connectivity built in, Legato’s robust APIs enable users to connect to any cloud or network, and allow developers to focus on building the value-add IoT applications. Legato offers an Eclipse-based integrated development environment (IDE), providing an extensible and familiar toolset with built-in API awareness. With multi-language support, Legato allows developers to code in their preferred language, and provides a robust suite of diagnostic tools, to enable- local and remote debugging, troubleshooting, monitoring and profiling. Figure 2. FX30 gateway from Sierra Wireless 1 Information from Sierra Wireless FX30 Datasheet 2018 Radiocrafts AS RCxxxx-IEB Data Sheet (rev. 1.02) Page 3 of 12 Radiocrafts Embedded Wireless Solutions RCxxxx-IEB Figure 3. mangOH Red gateway Antenna connection A quarter wave antenna can be directly connected to the SMA antenna connector. If the modem is placed in environments where RF performance is reduced, an external antenna can be connected via an extension coaxial cable to the SMA connector. It is strongly recommended that the Sierra Wireless 3G/4G antenna and the antenna on the expansion card are not pointing in the same direction, in order to reduce possible interference and range reductions. Thus, use angled 3G/4G antenna if straight antenna is used with the expansion card, and vice versa. Product variants For detailed information on each variant of the insertion boards, please see the User Manual and Data Sheet for the respective Radiocrafts modules used on the different variants. Datasheets can be downloaded from the Radiocrafts site www.radiocrafts.com IOT expansion board The expansion board is designed to be the link between the local radio network (ISM band radio), and the cell phone network modem. The IoT Expansion Card form factor represents an open hardware standard for sensors, network adapters, and other IoT technologies that can be "plugged" into host applications to provide new features and interfaces. As a family, IoT Expansion Cards share a standardized footprint and pinout, with several interfaces to support various IoT technologies The IOT module has a standardized PCB edge connector that fit in the QSFP+ IoT Connector at the host. The pinout is standardized but described here for each module. 2018 Radiocrafts AS RCxxxx-IEB Data Sheet (rev. 1.02) Page 4 of 12 Radiocrafts Embedded Wireless Solutions RCxxxx-IEB RCxxxx-IEB Circuit Diagram The board will have different components mounted depending on the type of Radiocrafts module used. Table 1 shows which signal from FX30 is used at each expansion board. Figure 2-5 shows the schematic for each type of expansion boards. 26 27 2829 30 31 32 3337 38 GPIO3 NC VCC_3V3 VCC_1V8 TXD RXD CTS RTS SPI_CLK SPI_MISO SPI_MOSI SPI_SS NC GND I2C I2C NC GPIO2 RC2400HP-ZNM VCC_5V NC GND NC RC1701HP-MBUS4 1 2-3 4 510 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 Description and internal MCU connection RC1880CEF Pin name RC1180-MBUS3 Pin no ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ GND n_Card_detect n_Reset NC ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ ۷ GND ۷ 2018 Radiocrafts AS 5V supply Not Connected (USB) System ground Not Connected (SDIO) 1.8V supply Connects to the module TXD (RXD on host) Connects to the module’s RXD-pin Connects to the module’s CTS-pin Connects to the module’s RTS-pin Both RC1880CEF and RC2400HP-ZNM default use UART as communication port at baud rate 115200. But the expansion board include the driver for SPI as an option. Config (enable module configuration mode) System ground Not Connected (GPIO1) Connect to BSL_ENABLE (RC1880) and CONFIG pin for all other MRDY signal for SPI Enabled modules Not Connected (GPIO4) 3.3V Supply System ground Not Connected (I2S/PPS) ۷ ۷ ۷ System ground Table 1. Pin mapping RCxxxx-IEB Data Sheet (rev. 1.02) Page 5 of 12 Radiocrafts Embedded Wireless Solutions RCxxxx-IEB Figure 4. RC1880CEF-IEB schematic 2018 Radiocrafts AS RCxxxx-IEB Data Sheet (rev. 1.02) Page 6 of 12 Radiocrafts Embedded Wireless Solutions RCxxxx-IEB Figure 5 RC2400HP-ZNM-IEB schematic 2018 Radiocrafts AS RCxxxx-IEB Data Sheet (rev. 1.02) Page 7 of 12 Radiocrafts Embedded Wireless Solutions RCxxxx-IEB Figure 4: RC1701HP-MBUS4-IEB schematic 2018 Radiocrafts AS RCxxxx-IEB Data Sheet (rev. 1.02) Page 8 of 12 Radiocrafts Embedded Wireless Solutions RCxxxx-IEB Figure 5: RC1180-MBUS3-IEB schematics 2018 Radiocrafts AS RCxxxx-IEB Data Sheet (rev. 1.02) Page 9 of 12 Radiocrafts Embedded Wireless Solutions RCxxxx-IEB RCxxxx-IEB PCB and Assembly layout The PCB is a 4-layer board where Layer 2 is used as ground plane. The laminate used is compliant to IPC4101D/126 giving excellent reliability in challenging environment. The PCB is 1.0 mm thick. PCB is edge bevelled/chamfered were is connect to host for easy and repeated mating with connector at host. Figure 6: RCxxxx-IEB PCB component placement, top side Mechanical Drawing 22.3 mm 45 mm Figure 7: Mechanical drawing Mechanical Dimensions The board size is 35.7 x 57.0 x 4.1 mm (total height for PCB and module). 2018 Radiocrafts AS RCxxxx-IEB Data Sheet (rev. 1.02) Page 10 of 12 Radiocrafts Embedded Wireless Solutions Article Numbers Ordering Number RC1180-MBUS3-IEB RC2400HP-ZNM-IEB RC1701HP-MBUS4IEB RC1880CEF-IEB RC1180-RC232-IEB RC1190-RC232-IEB RC1180-TM-IEB RC1170-TM-IEB RC1701HP-RC232IEB Module Description Embedded Wireless M-Bus protocol (EN13757-4:2005, 868 MHz radio) ZNM module for 2.45 GHz mesh Embedded Wireless M-Bus protocol (EN13757-4:2005, 169 MHz radio) for gas, water, heat and electricity meter readings IEEE 802.15.4g connectivity Module is delivered as HW platforms, but as part of our internal tests the module is loaded with COP freeware.2 868 and 915 MHz high speed modules, RC232 protocol Tinymesh gateway RCxxxx-IEB Availability Standard parts Non standard parts. Contact Radiocrafts sales for lead time and MOQ 169 MHz module with RC232 firmware Other variants are available upon request. Please contact sales@radiocrafts.com 2 The COP FW is a firmware image which implements the MAC IEEE 802.15.4-2006 standard in a dedicated system on a chip (SoC), providing a simple serial interface to an external host processor for control and processing of the Co-Processor operations. http://dev.ti.com/tirex/content/simplelink_cc13x0_sdk_1_40_00_10/docs/ti154stack/ti-15.4stack-cop-interface-guide.pdf. The image is also available for download on www.radiocrafts.com. 2018 Radiocrafts AS RCxxxx-IEB Data Sheet (rev. 1.02) Page 11 of 12 Radiocrafts Embedded Wireless Solutions Document Revision History Document Revision 1.00 1.01 1.02 RCxxxx-IEB Changes First release Part number update on RC1880 variant Name change from –FX30 to IEB in order to also focus on mangOH Disclaimer Radiocrafts AS believes the information contained herein is correct and accurate at the time of this printing. However, Radiocrafts AS reserves the right to make changes to this product without notice. Radiocrafts AS does not assume any responsibility for the use of the described product; neither does it convey any license under its patent rights, or the rights of others. The latest updates are available at the Radiocrafts website or by contacting Radiocrafts directly. As far as possible, major changes of product specifications and functionality, will be stated in product specific Errata Notes published at the Radiocrafts website. Customers are encouraged to check regularly for the most recent updates on products and support tools. Trademarks RC232™ is a trademark of Radiocrafts AS. The RC232™ Embedded RF Protocol is used in a range of products from Radiocrafts. The protocol handles host communication, data buffering, error check, addressing and broadcasting. It supports point-to-point, point-to-multipoint and peer-to-peer network topologies. All other trademarks, registered trademarks and product names are the sole property of their respective owners. Life Support Policy This Radiocrafts product is not designed for use in life support appliances, devices, or other systems where malfunction can reasonably be expected to result in significant personal injury to the user, or as a critical component in any life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. Radiocrafts AS customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Radiocrafts AS for any damages resulting from any improper use or sale. © 2018, Radiocrafts AS. All rights reserved. Contact Information Web site: www.radiocrafts.com Address: Radiocrafts AS Sandakerveien 64 NO-0484 OSLO NORWAY Tel: +47 4000 5195 Fax: +47 22 71 29 15 E-mails: sales@radiocrafts.com 2018 Radiocrafts AS RCxxxx-IEB Data Sheet (rev. 1.02) Page 12 of 12
RC1180-MBUS3-IEB 价格&库存
很抱歉,暂时无法提供与“RC1180-MBUS3-IEB”相匹配的价格&库存,您可以联系我们找货
RC1180-MBUS3-IEB
  • 1+910.013851+117.62895
  • 10+907.9519910+117.36243
库存:1
