REX12-TA1-107-DC24V-6A 数据手册
REX12 Electronic Circuit Protector
Description
The compact and flexible all-in-one solution REX consists of several
perfectly matched components. It comprises the EM12-T supply module
for the plus and minus potential via a single or double channel REX12-T
electronic circuit protector which can be mounted side by side in any
number and the PM12-T potential extension module for plus and minus
multiplication. Connection of the only 12.5 mm wide modules is exclusively
with push-in terminals which allow no-tool time-saving wiring.
The circuit protectors are placed on the symmetrical rail one after another
in combination with EM12-T and PM12-T and are electrically connected
by means of built-in connector arm - no further accessories are required.
The circuit protector REX12-T offers selective overcurrent protection
by responding to short circuit or overload faster than the switch mode
power supply. Capacitive loads of up to 20,000µF can be switched on
without problems. The circuit protector is available in all standard fixed
and adjustable current ratings from 1 A to 10 A. Besides the UL508listed
approval and NEC Class2, the REX12-T also meets the requirements of
cable protection to EN60204-1.
US patent number: US 9,899,807 B2
Features
l
l
l
l
l
l
l
l
l
l
Benefits
l
Saves cost – no further accessories required
Saves 50 % time through innovative and flexible mounting and
connection technology
l Saves space – with a width of only 12.5 mm per channel
l Provides flexibility through ease of mounting, disassembly and
modular design
l Reduces storage costs because only one product is required
for all current ratings
Combination of supply modules, overcurrent protection and
power distribution
Selective load protection by means of electronic trip curve
No accessories required for connecting the components
Width per channel only 12.5 mm (1-channel) or 6.25 mm
(2-channel)
Fixed and adjustable current ratings 1 A - 10 A
Integral fail-safe element, adjusted to max. current rating
Switching capacitive loads up to 20,000 µF
Manual ON/OFF/reset momentary switch
Clear status indication by means of LED and signal contact Si
Connection via push-in terminals including orange press
release buttons
l
4
Preferred types – for more details on all configurations please see page 4
Preferred types are E-T-A products most frequently used by E-T-A
customers. We manufacture E-T-A preferred types in particularly high
volumes. Our preferred types are supplied at shorter lead times than
non-standard versions.
Preferred types
Preferred types
Short description
REX12-TA1
1-channel
REX12-TA1-107-DC24VREX12-TA2
2-channel
Preferred ratings (A)
2
4
6
10
x
x
x
x
2
4
6
10
REX12-TA2-107-DC24VREX12D-TE2
REX12D-TE2-100-DC24V-
Approvals
2-channel,
adjustable
2/2
4/4
6/6
2/2
4/4
6/6
x
x
x
1 A…10 A
x
Data sheet
The current data sheet is available on our website: www.e-t-a.de/d359
NEC Class2
Compliances
2010
www.e-t-a.de
1
Technical data (Tamb = +23 °C, UB = DC 24 V)
REX12-Txx-xxx circuit protectors
REX12-TA1-107-DC24V-xA 1-channel
REX12-TB1-107-DC24V-xA
1-channel
REX12-TA2-107-DC24V-xA/xA 2-channel
REX12D-TE2-100-DC24V-xA-xA 2-channel
The REX12-TAx is operated in the standard mode with EM12-T. The
REX12D-TE2 can be operated both with EM12D-T or EM12-T. The
operating mode EM12D-T (COM mode) or EM12-T (standard) is
recognised automatically. The following data exclusively refer to the
standard mode:
Operating voltage UB
DC 24 V (18...30 V)
Closed-circuit current I0
REX12-Tx1 1-channel in ON condition: Typically 5 mA
REX12-TA2 2-channel in ON condition: Typically 8 mA
REX12D-TE2 1 A-4 A 2-channel in ON condition:Typically 9 mA
REX12D-TE2 1 A-10 A 2-channel in ON condition: Typically 12 mA
Reverse polarity
protection Yes
Power failure
buffering time
up to 10 ms
Rated current IN ratings:
REX12-Tx1
1 A, 2 A, 3 A, 4 A, 6 A, 8 A, 10 A
REX12-TA2
1 A/1 A, 2 A/2 A, 3 A/3 A, 4 A/4 A, 6 A/6 A
REX12D-TE2
1 A-4 A, 1 A – 10 A condition upon delivery
max. current rating
Visual status indication
green: Load circuit connected
by means of LED
green/orange
blinking: load current warning limit
reached 90 %
orange: overload or short circuit until
disconnection
4
- after disconnection due to
- after undervoltage release of
operating voltage in ON
condition with autoreset
OFF: Device switched off by means of
ON/OFF momentary switch or
no operating voltage
Load circuit
Load output power MOSFET switching output
(plus switching)
Load current warning limit (IWLimit) typically 0.9 x IN
hysteresis typically 5
Overload current
disconnection (IÜL)
typically IOL: IN x 1.05 tOL: 3s
typically IOL: IN x 1.35 tOL: 0,5s
with trip times (tÜL)
typically IOL: IN x 2.00 tOL: 0.1s
typically IOL: IN x 2.50 tOL: 0.012 s
short circuit
typically at short circuit (ISC) tSC: 0.002 s2)
trip time (tSC)
see time/current characteristic
Influence of ambient
see temperature factor table
temperature on
overload disconnection
and load current warning limit
Voltage drop in load circuit at IN and at IN 70 % for REX12-Txx
between LINE+ and LOAD+
IN: 1 A (CL2) typically 180 mV
IN: 70 %
typically 125 mV
IN: 2 A (CL2) typically 110 mV
IN: 70 %
typically 80 mV
IN: 3 A
typically 120 mV
IN: 70 %
typically 85 mV
IN: 3 A-CL2
typically 130 mV
IN: 70 %
typically 90 mV
IN: 4 A
typically 115 mV
IN: 70 %
typically 80 mV
IN: 4 A-CL2
typically 180 mV
IN: 70 %
typically 120 mV
IN: 6 A
typically 170 mV
IN: 70 %
typically 110 mV
IN: 8 A
typically 160 mV
IN: 70 %
typically 105 mV
IN: 10 A
typically 180 mV
IN: 70 %
typically 120 mV
2
red:
REX12D-TE2-100-DC24V-1A-4A-CL2
IN: 1 A-CL2 typically 50 mV
IN:
IN:
IN: 2 A-CL2 typically 90 mV
IN: 3 A-CL2 typically 135 mV
IN:
IN: 4 A-CL2 typically 180 mV
IN:
70
70
70
70
typically
typically
typically
typically
42 mV
70 mV
95 mV
120 mV
REX12D-TE2-100-DC24V-1A-10A
IN: 1 A
typically 30 mV
IN: 2 A
typically 39 mV
IN: 3 A
typically 48 mV
IN: 4 A
typically 57 mV
IN: 5 A
typically 66 mV
IN: 6 A
typically 74 mV
IN: 7 A
typically 83 mV
IN: 8 A
typically 92 mV
IN: 9 A
typically 101 mV
IN: 10 A
typically 110 mV
70
70
70
70
70
70
70
70
70
70
typically
typically
typically
typically
typically
typically
typically
typically
typically
typically
28
34
40
46
52
59
65
71
77
83
IN:
IN:
IN:
IN:
IN:
IN:
IN:
IN:
IN:
IN:
mV
mV
mV
mV
mV
mV
mV
mV
mV
mV
2) depending on power source
Fail-safe element
IN: 1 A (CL2)
fail-safe IN: 1 A
integral
IN: 2 A (CL2)
fail-safe IN: 2 A
blade fuse
IN: 3 A
fail-safe IN: 3.15 A
adjusted to
IN: 3A-CL2
fail-safe IN: 4 A
related current rating IN IN: 4 A
fail-safe IN: 4 A
IN: 4 A-CL2
fail-safe IN: 4 A
IN: 6 A
fail-safe IN: 6.3 A
fail-safe IN: 8 A
IN: 8 A
IN: 10 A
fail-safe IN: 10 A
IN: 1 A/1 A (CL2) fail-safe IN: 1 A/1 A
IN: 2 A/2 A (CL2) fail-safe IN: 2 A/2 A
IN: 3 A/3 A
fail-safe IN: 3.15A/3.15A
IN: 3 A/3 A-CL2 fail-safe IN: 4 A/4 A
IN: 4 A/4 A
IN: 4 A/4 A-CL2 fail-safe IN: 4 A/4 A
IN: 6 A/6 A
fail-safe IN: 6.3 A/6.3 A
IN: 1 A-4 A-CL2 fail-safe IN: 4 A
IN: 1 A-10 A
failsafe IN: 16 A
operating voltage
OFF at typically UB < 16.0 V
monitoring re.
ON at typically UB > 19.0 V
undervoltage
hysteresis typically 2 V
with automatic OFF and ON switching
ON delay
- with power ON
channel 1: typically 100 ms (REX12-TAx)
channel 2: typically 200 ms (REX12-TAx)
channel 1: typically 1,500 ms (REX12D-TE2)
channel 2: typically 1,600 ms (REX12D-TE2)
- when switching on with channel 1: typically 5 ms
ON /OFF switch or
channel 2: typically 100 ms
channel 2: typically 5 ms
disconnection of
- manually on the device with the
- after an overload / short circuit
disconnection with storage
(no automatic reset)
- temporarily at undervoltage
- at no operating voltage
Switch-on of load circuit
- momentary switch ON/OFF
device can only be switched on when
operating voltage is applied
- applying
The device starts up with the condition
operating voltage
last stored.
www.e-t-a.de
2010
Enquire
Enquiry of currently adjusted
adjusted current rating
current rating, independent of the
with REX12D-TE2 operating mode (COM or standard),
possible for each channel directly on the
REX12D-TE2
Enquiry mode is started by pushing the
button between >= 2 seconds and < 5
seconds After releasing the button, the
LED is RED for 333 ms to indicate start of
enquiry. Afterwards, the LED flashes ORANGE in a puls/break ratio of 1/2 with a
frequency of 1 Hz to indicate the adjusted
current value. When the adjusted current
rating is reached, signalling re-starts after
the RED LED re-lights for 333 ms. The
enquiry mode is left after the adjusted
current rating was signalled 5 times or
by pressing the button. Visual indication
will now show again the current operating
condition.
The enquiry mode is possible in all operating conditions (ON, OFF, UNDERVOLTAGE
and TRIPPED).
Adjustment of
The adjustment mode directly on the
current rating with
REX12D-TE2 can only be activated in the
REX12D-TE2 standard mode
The adjustment mode is started per
channel by pushing the button for >=
5 seconds. After releasing the button,
the LED is RED for 333 ms to indicate
start of adjustment. The LED is blinking
GREEN with a pulse/break ratio of 1/4 at
a frequency of 0.6 Hz for visual indication.
GREEN After reaching the max. adjustment value, signalling re-starts. Overrun of
the max. adjustment value after 1 Ampere
is indicated by the RED LED (333 ms). The
current rating to be adjusted is adopted
by pushing the button during the blinking
period of 1 A up to the max. adjustment
value. If for instance the button is pushed
after the 7th illumination of the GREEN
LED, 7A is adopted as current rating and
visual indication again shows the current
operating condition. If the button is not
pressed, the adjustment mode is left
after 5 times signalling the current rating
range without a new current rating being
adopted and the visual indication returns
to current status indication.
The adjustment mode is possible in all
operating conditions (ON, OFF, UNDERVOLTAGE and TRIPPED).
Go to video Mounting and operation:
Reset function
a blocked load output (blocked by
overload / short circuit) can externally
be reset by the ON/OFF momentary switch
Leakage current in
typically
REX12-TA1-107-DC24V-6A 价格&库存
很抱歉,暂时无法提供与“REX12-TA1-107-DC24V-6A”相匹配的价格&库存,您可以联系我们找货
