XK-VF3000-L33-AVS
XK-VF3000-L33-AVS
    XMOS
    XK-VF3000-L33-AVS
XK-VF3000-L33-AVS 数据手册
VocalFusion™ 4-Mic Kit for Amazon AVS FAR-FIELD VOICE CAPTURE FRONT END FOR AMAZON AVS ENABLED PRODUCTS KEY FEATURES  XVF3000 processor o Programmable multicore voice processor for far-field voice capture applications o Integrated Voice DSP processing includes:  4-microphone adaptive beamformer  Full-duplex Acoustic Echo Cancellation (AEC) with barge-in support  Dereverberation, noise suppression, Automatic Gain Control (AGC) o 4-mic digital microphone interface o Inter-IC Sound (I2S) audio interfaces o Inter-Integrated Circuit (I2C) serial control interface o High speed USB2.0 compliant device  Multi-channel USB Audio Class 1.0 o Integrated 2048KB flash o 128-pin TQFP package 0.4mm pitch  XVF3000 processor baseboard o XVF3000 voice processor o Low jitter audio clock source o DAC with headphone amplifier o USB bus powered  Linear microphone array card o 4x PDM MEMS microphones o 33.33mm inter-mic spacing The VocalFusion 4-Mic Kit for Amazon AVS enables developers of smart home products to evaluate and prototype far-field voice interfaces using the Amazon Alexa Voice Service. Built around XMOS’ XVF3000 voice processor, the VocalFusion 4-Mic Kit for Amazon AVS provides embedded far-field voice capture and processing. With direct interfacing to a linear array of four digital microphones, the VocalFusion 4-Mic Kit for Amazon AVS (together with a Raspberry Pi) is an ideal platform for developers who want to integrate Alexa into smart panels, kitchen equipment, and other commercial and industrial electronics. Enabling voice control of devices located several meters from the user requires addressing the challenges of distance, isolation, noise and directivity, whilst also enhancing the clarity of the captured voice. The XVF3000 achieves this using an adaptive beamformer in combination with full-duplex echo cancellation and noise suppression to locate the desired speech source and effectively isolate voice commands from any audio the device is playing while suppressing background noise and room echoes. Getting started with the VocalFusion 4-Mic Kit for Amazon AVS couldn’t be easier, find out how at www.xmos.com/vocalfusion-avs. VocalFusion 4-Mic Kit for Amazon AVS PRODUCT BRIEF FUNCTIONAL BLOCK DIAGRAM Linear Microphone Array DAC Audio Output Far-end Processing (optional) Equalizer Dynamic Range Control Automatic Gain Control I2S Audio I/O I2S Voice Processing Acoustic Echo Cancellation Adaptive Beamforming Noise Suppression De-reverberation Automatic Gain Control I2S Sensory Wake Word Engine BRCM43438 Alexa AVS Client LAN9514 802.11n BCM2837 Quad ARM Cortex-A53 I2C PDM Mic. Interface PDM → PCM Filtering Delay Lines SSRC Control I2C | LED | GPIO XVF3000 Ethernet USB Raspberry Pi 3 XK-VF3000-L33-AVS VOCAL FUSION 4-MIC KIT FOR AMAZON AVS Features  XVF3000 processor base board  Linear microphone array o 4x Infineon IM69D130 MEMS microphones o 100mm long, 33.33mm inter-mic spacing  Raspberry Pi header I²S audio and I²C control connectivity  Micro-USB connector for power (and optional USB2.0 device connectivity)  Low jitter, audio quality clock  DAC with integrated headphone amplifier  4 configurable user input buttons  13 user controlled LEDs ORDERING INFORMATION For a list of XMOS distributors, please visit www.xmos.com/support/distributors. Part number Description XK-VF3000-L33-AVS VocalFusion 4-Mic Kit for Amazon AVS Contents: XVF3000 base board, 100mm linear microphone array, mounting kit, xTAG debugger, USB cable x2, ribbon cable Note: Other components required for evaluation are: a Raspberry Pi 3 (RPi 3) and USB power supply (minimum 2A), microSD card (minimum 16GB), USB keyboard and mouse, monitor, internet connection and a powered loudspeaker. FURTHER INFORMATION To learn more about XMOS and the VocalFusion 4-Mic Kit for Amazon AVS, please visit www.xmos.com/vocalfusion-avs. © 2018 XMOS LTD Third party trademarks are hereby acknowledged. Contents are subject to change. XM-011874-PB | 2018-12-06
XK-VF3000-L33-AVS 价格&库存
很抱歉,暂时无法提供与“XK-VF3000-L33-AVS”相匹配的价格&库存,您可以联系我们找货
XK-VF3000-L33-AVS
  • 1+7113.361651+922.02711
